View Full Version : Evo Engine / Turbo / Drivetrain
  1. Oil cooler Position info
  2. Any of you with block heaters have problems blowing seals?
  3. Porting the Exhaust manifold?
  4. Vibrant maf adapter and amsoil fiter?
  5. Boost Issue
  6. Transmission Life ?'s
  7. 10.5 hotside + EPM O2 dump problems
  8. Extremely Loud Walbro 255 Fuel Pump...
  9. What did I do i have no boost!!!
  10. some pics of an HTA35r compressor housing with an HTA30r compressor wheel
  11. banged up evo...
  12. What Should I Put Here?
  13. Cbrd bbk
  14. clutch restrictor pill removal
  15. Best Short throw Shifter??
  16. am i screwed
  17. Is this true..
  18. boost question
  19. service engine light after car wash.
  20. Help me delete this...
  21. Evo 9.8cm or 10.5cm turbine?
  22. Drop in rods and pistons
  23. Injen Downpipe
  24. 6500rpm 2 step?
  25. Before my 1st tune.....
  26. what is this actually for?
  27. Where to get o2 sensor
  28. Injector sizing help
  29. sensor question
  30. Cam Gear adjustments?
  31. Size of damper bolts?
  32. clutch job need help!!
  33. FP RED on a V RS
  34. Blown/Torn Injector Rubber O-Ring?
  35. ETS IC any good?
  36. engine replacement
  37. installing ETS intercooler
  38. Help Decide on Turbo
  39. Helicoiling?
  40. external wastegate help
  41. hks stamp on evo9 mivec cams missing?
  42. Major tranny problem
  43. Very Strange Idle
  44. greddy M spec
  45. Fp red cost
  46. AC DELCO O2 Sensor Part Number?
  47. greddy type s bov prob
  48. 10-second, Full-Interior Evos That AutoX / Road Race?
  49. ACD Help
  50. Stalling problem- help!
  51. ACT HDG6 Users, needed your opinion
  52. We swapped out .63 37R for .82a/r 6262 on AMS manifold...pics inside!
  53. where i can get just one apex ev1 coilover?????
  54. 10.5 hotside on 8 turbo vs 9 turbo
  55. Question on stock air box modding
  56. OMG catch can thread!
  57. Best 1000cc Injectors
  58. AEM Tru Boost Tuning ..... advice?
  59. Is $700.00 for timing belt, water pump, and seals a good price
  60. Stroker Advice
  61. Best way to clean up a rusty block?
  62. Question for all u.
  63. Knocking sound....please help!!
  64. Evo 9 first gear really worth it?
  65. question/favor please
  66. DV Flutter Solved! not BOV, not what you want to hear
  67. Help arp rod bolts torgue value
  68. Just installed a new Clutch .. now it makes a noise any advise
  69. Air in clutch line?
  70. Boost leak??!
  71. $1,200 to fix a 5th gear at mistsubishi dealer ?
  72. Exhaust Wrap on a o2 Dump
  73. What is the best intake filter to use with fp red to help get the most power out of t
  74. ETS, English Racing 2009 Drag Evo Revamp
  75. Head gasket
  76. scratches
  77. ewg setup???
  78. noise after clutch and flywheel install
  79. What does this connect to?
  80. Some things I did over winter...
  81. ECU Help (HKS V-PRO)
  82. Catch Can
  83. fp green taper
  84. Turbo PROBLEMS, HELP!
  85. no spark on cylinder 1 and 4
  86. temp gauge video
  87. Good Place to Buy Die Grinder Bits
  88. p0300 break up in 5th on highway
  89. What type of Octane you feed your Evo
  90. after how many miles?
  91. Question about intercooler spray on 04 Evo GSR
  92. overheating...
  93. Turbo Upgrade
  94. smoke coming from exhaust
  95. Jun 272/S2's
  96. Knock Problem
  97. White rabbit need help
  98. best clutch
  99. Driving untuned?
  100. driveline slop...
  101. JE Pistons
  102. EVO 4 turbo manifold
  103. How often do you miss shifts?
  104. Holy Engine
  105. Running richer and richer...
  106. fp red or 35r
  107. boost leak?
  108. bleeding the acd
  109. Anyone interested??
  110. evo8 newb problems
  111. LSD front diff. pre load value?
  112. Oil leak on my Rebuild Engine
  113. 5 qts Mobil 1 Incl. Ext Perf Synth and Mobil 1 Filter $29.99 Until March 25th
  114. Which UICP would fit Perrin Intake? Nisei, Buschur?
  115. PTE injectors.
  116. help needed: cylinder #2 injector not supplying fuel
  117. White Rabbit need help....
  118. 2.0 Build
  119. Please help! Td05hr-16g6c-10.5t
  120. Not sure if head is built or not.
  121. Fluids ?
  122. What CEL Code
  123. New APS BOV Stuck Open?
  124. What would you do? Turbo Upgrade ~
  125. Tranny/Transfer case problems?
  126. evo 9 motor in an evo 8???
  127. What direction does your rear swing?
  128. Need help on decision
  129. White Rabbit turbo making more noise
  130. Cannot put into 6th gear !!Argh!!
  131. Stock Evo 9, larger FMIC... any problems?
  132. ets or buschur intake pipe
  133. which one for trans?
  134. Idle idle idle... 1000 rpm to 500 and then back
  135. What should I convert a mirage into
  136. Encountered a problem. What you think?
  137. stock pistons??
  138. what weight oil do you use?
  139. Fuel Pump Install Kit
  140. Help: all three ACD lights are on
  141. Did I bust my center diff?? Description inside.
  142. Popping sound when turning left
  143. Need help!!!!
  144. Crank Sensor CODE
  145. Leaking front axle seal someone help!
  146. Need Advice for Timing Belt Replacement
  147. Clunching sound
  148. FP RED on 22psi
  149. Best 02 housing?
  150. Need opinion on water temp or oil temp
  151. HTA 86R vs PT6262 turbo
  152. problem with acd/heat/everything
  153. EVO 9 Transfer Case? (Possible Problem)
  154. I need help bad
  155. UICP that fits the ARC intake?
  156. (clunk clunk
  157. Okay, whats my problem?? CLUTCH/BOV
  158. mooohoohahaha
  159. Noob question! Catch Can
  160. 2.3L+TS3076r
  161. removing transfer case HELP!
  162. getting fp red have some questions
  163. New turbo, have some questions
  164. perrin's new filter?
  165. Oil feed line question
  166. Warning - All Those Who Use An Aeromotive FP Regulator
  167. Turbo oil supply line help please
  168. ... crap, i need a new tranny and t-case... best prices around?
  169. O2 Sensor Driveability...
  170. How much to repair a bent valve?
  171. 2 questions....
  172. P0335 & P0340 How do i fix this??
  173. Radiator fan
  174. Odd Noise
  175. Are the evo 9 stock headstuds safe to 30 psi used with an fp red?
  176. Manifold Fitment
  177. Need a new clutch
  178. HTA 42R?? Or something?
  179. Cracked valve cover
  180. Who is using Kelford 272 on stock springs?
  181. GT30R with injection?
  182. rebuild my clutch master cylinder?
  183. Can someone tell me whats wrong with my car?!? ACD Issues
  184. EBC removal
  185. GReddy Competition Ti-C Exhaust
  186. Oil Pump???
  187. Timing Belt goes streaking
  188. t66 turbo
  189. Launching
  190. Tial bov flange question.
  191. Can't decide on my next power upgrade
  192. Anyone ever rebuilt a Mitsu turbo?
  193. Stock Rods w/arp hardware?
  194. Precision Injector Users Using E85 Beware
  195. Smoke coming off vent after O2 and Exh Mani installed
  196. Our 900HP Capable T3 Turbo Kit is Out!!!
  197. BBK from Green
  198. Precision Turbo 67mm Billet Madness!!!! PICS inside..
  199. 4G63 or 4G64
  200. Amsoil
  201. Oil catch can
  202. mishimoto intercooler
  203. HTA86 Twinscroll
  204. belts
  205. NGK gap question
  206. anyone used this turbo before?
  207. Intake mani cleaner
  208. Throttle Hang?
  209. hey guys quick question
  210. FP Green and 2.3L
  211. PPI Intake manifold
  212. top mount vs equal length vs cast manifolds
  213. Can the OEM coolant be mixed with Dexco Red coolant?
  214. What's next for the Evo? Help please?
  215. tranny ques
  216. Is my transmission currently on life support?
  217. T-case Failure?? Please help!!
  218. OK I'm finally fed up..
  219. Shaking/Vibration During Launch
  220. CamShafts
  221. o2 Fowler or Relay??
  222. For those with Megan O2 Housing
  223. Burning Oil Smell After Turning Car Off
  224. Boost Drifting Bad
  225. Need your help
  226. will these injectors work?
  227. PCV Valve
  228. Can boost be upped from the stock solenoid or do I need a boost controller
  229. Any tuners here that can figure this out?
  230. Need help to find out what is causing this noise
  231. best sparkplugs for e85?
  232. having problem similar to boost cut.. but my fuel goes rich?!?!
  233. Experiencing boost creep with Buschur MBC
  234. Dynojet
  235. Fuel level sender ohm question
  236. mivec
  237. The "Bite" has a new toy to play with 6765 AKA 950R!!!
  238. what gasket is this?
  239. Throttle Body Leaking
  240. Anyone else have the Greddy Full Ti Exhaust?
  241. help needed . which cams to choose
  242. Retune after Fuel Pump Install
  243. Skunk2 68mm Throttle Body?
  244. What is this/what do these go to?
  245. trying to find hotside specs on fp red
  246. Whistling noise when driving, with vid/sound clip
  247. Fuel tank issue
  248. Help me get the right Bov/ UICP (dilema)
  249. where can I get a axel seal?
  250. fp red vs Gt30
