View Full Version : Evo Engine / Turbo / Drivetrain
  1. NGK BPR6es
  2. turned my perrin hfc into a test pipe
  3. Low vacuum at idle, with idle drop
  4. Buschur uicp and Turbo xs fmic
  5. Something leaking, but only when launched?
  6. Cost for clutch installation
  7. Every time i **** quickly i hear a thump
  8. Slowboy Racing FMIC
  9. Where's the woosh sound? (Greddy RS BOV)
  10. How much power with these mods?
  11. HKS 272 intake cam problem... P0505
  12. NGK spark plug evo 9...
  13. air filters; filtration
  14. Need HELP! Problem Evo
  15. Full Blown Dual Pump Hanger
  16. Constantly Adjusting Boost?
  17. Boost leak issue
  18. Return pipe
  19. looking for oppinions on a couple clutches
  20. (Help) Loud vibration when launching
  21. Purpose of a Oil Catch Can
  22. i think my clutch master cylinder went bad!
  23. Forge recirc valve to APS twin vent with problems now
  24. Any one with a Fullrace intercooler?
  25. Greddy type RS bov
  26. LICP sludge
  27. What oil do i need to use for the transfer case and rear differential?
  28. Help: Spark plug in 2nd Cylinder from driver side black...?
  29. I have a newb question..
  30. Oil Cooler + Turbo
  31. New problem...can't figure it out
  32. Slim fan size?
  33. 37R guy please step in tuning question...
  34. bad wastegate maybe or something else?? (this car is driving me nuts)
  35. crankshaft discussion
  36. Just Ordered my Tomei ARMS kit today
  37. NGK BPR7ES gap on stock evo 8
  38. ACT 6 puck sprung guys ???'s for ya
  39. how do ya take out gearbox????
  40. HELP oil light blinks n idle
  41. Clutch job turns into lil build up :)
  42. Cost of Tcase/Tranny
  43. Does your EPM dump tube leak?
  44. Evo 8 turbo problems please help
  45. balance shaft seized up!! help
  46. MAF sensor orientation?
  47. Blew seals on newish FP Red?
  48. intake cam install help please....
  49. Greddy counter weight shift knob
  50. question about tc and rear diff fluid
  51. Any one have issues with water damage to their BOV?
  52. Oil for BUILT Engine! *Yes, I searched*
  53. fuel pump and fuel filter loction
  54. Buschur or Shep Rebuild?
  55. Manifold Coating
  56. Anyone with a VIII tranny not installed..need help
  57. quick question
  58. To destroke or not to destroke
  59. 4th gear problem
  60. Amsoil severe gear 75w110
  61. Cylinder head testing - Part 1 - 823 whp base line on HTA88
  62. methanol... do or don't
  63. looking for the "how-to" timing belt swap
  64. Evo 9 mivec gear differences??
  65. ? On Apexi exhaust.
  66. evo hesitation
  67. building block ?
  68. Help me plzzz
  69. Need help asap, injector question.
  70. Boost not holding
  71. I think my 3rd gear syncro is done!
  72. converting my 9 to an 8 (remove mivec)
  73. How much HP can the stock clutch hold before starting to slip?
  74. boost leak?
  75. theory question???
  76. Stainless steel clutch lines???
  77. stupid brake/clutch fluid question
  78. Oil catch can question
  79. help! headgasket blown.
  80. Competition Clutch Flywheel/Clutch Install on Evo IX RS
  81. How much does the Evo muffler/tip weigh
  82. wont boost all the way :(
  83. Loud beep noise
  84. Labor/ Hourly Rate for Install of Cams, S&R, Timing Belt kit, Head Gasket....
  85. Oil temp. sensor on the 5 speed tranny
  86. Kelford Cams Selection
  87. ACD problem
  88. ACD problem
  89. 5 speed tranny lockout
  90. Samco and amsoil 4560?
  91. switching to e85?
  92. Low Boost bad ignition coil boot?
  93. Bad clicking sound, axles maybe or something else?
  94. Weird Noise on first decelerate??? (not throwout bearing)
  95. optima battery
  96. engine whine
  97. RPS Clutch
  98. best fuel pump
  99. mY nEW bOOST leak Tester. (pics)
  100. fidanza 4.3 clutch kit
  101. bubbles in oil on dipstick?
  102. cant track down this t-case leak!
  103. I/C piping
  104. Advise on turbo 850 or 950r
  105. Exedy Twin rebuild
  106. Engine Built - Now Strange sound!!!
  107. Engine vibration after head gasket install
  108. Stock Fuel Lines
  109. Cam Gear Setting (hks 280)
  110. aftermarket clutch/tranny??
  111. HKS 280 lift?
  112. Bar to PSI conversion.
  113. Low boost after shifts... help
  114. Grinding from motor mount
  115. Problem please help!!
  116. Best Turbo with 2.2L and E85
  117. Having a problem with lower IC pipe for Buschur Race FMIC
  118. will stock radiator fan fit with Full race single scroll mani and Gt35R?
  119. New Clutch & Flywheel Noises
  120. decel smoke / E85
  121. Evo Intake Manifold from Finland
  122. tial waste gate??????
  123. 35 R with full rase mani on stock motor with stock head studs?
  124. 6 spd tranny fluid quantity?
  125. exedy twin ?
  126. Megan Black CatBack Exhaust, Sound Clip
  127. Need help figuring out what part goes here.....
  128. Full-race t4 1.06ar twin scroll HTAgt3582r tuned on stock motor results
  129. 2.3L Stroker Owners Unite! - Dyno Sheet & Mod Lists
  130. Stock Oil Return Line Bolts ( Turbo Side )
  131. o2 housing to Down pipe Gasket?? 3 inch 2 bolt
  132. Is this walbro pump ok to use?
  133. walbro or denso?
  134. Steering wheel shaking under moderate braking?
  135. evo main bearings
  136. Evo Warm up Time?
  137. Forged Performance RE-Build
  138. Perrin MBC?
  139. Wanted: ACD Service Manual
  140. o2 issue
  141. Question about lowering compression
  142. 1000cc Injectors question??
  143. Trying to find some info tre 6spd upgrade?
  144. whats wrong with mt trans?
  145. GM 3 port BCS fluctuation
  146. 5 Speed ACD Trans.
  147. Universal K&N cone part number
  148. Fp Green turbine housing size?
  149. Anyone get the shep stage 3 transfer case rebuild?
  150. EVO X BOV for EVO 8
  151. Need help finding out why my car stays in open loop???
  152. MostWanted's --- NEW --- BuildUp - Part ..3..
  153. my vacuum has been dipping really low?
  154. my external wastegate on stock turbo!!
  155. Boost Leak Test Results
  156. Drive w/o Transfer Case (temporary)
  157. Anyone using the ams ss lower clutch line? Feel a difference? Worth the 26 bucks?
  158. Stock Injector Mod?
  159. Buddy Club 272 Cams Info Needed!
  160. looking to switch turbo
  161. Greddy Type-m Intercooler?
  162. do SS clutch lines and removing the clutch restrictor make a difference?
  163. HKS 727's without cam gears?
  164. Which turbo kit would you choose?
  165. 2.3L Stroker from where???
  166. Buschur Race FMIC with ETS piping?
  167. ayc diff blown, need info on evo 8 n 9 diffs
  168. 5 bolt downpipe gasket?
  169. IntercoolerR BreakdownN
  170. Anyone tried the new Tial Recirc. Bov/
  171. Tips for starting new motor??
  172. ACD HELP please
  173. Trans noise...bet ya cant guess what it is!!
  174. My Build project (Sort of build) Fp Red etc. Input Appreciated.
  175. stroker sounds like a diesel care to diagnose
  176. 28 pounds no meth!
  177. Turbine hotside ports bigger than gasket
  178. Whats the ideal spark plug gap for EVO 8, 50 Trim 30 PSI, and HKS DLI2?
  179. Starter relay wire?? Which one is it?
  180. AEM Twin Power settings on 300m coils and stock ECU
  181. exedy clutch
  182. belt size
  183. shifting gears
  184. Car problem after IC & intake install
  185. Getting ready to install my o2 dump
  186. Exhaust Rant/ Need help finding a shop in Salt Lake City
  187. is this the awful transfer case whine?!!!
  188. Buschar strokers use oil?
  189. V Band Bling
  190. How much of a gain will I see???
  191. stupid freeze plug
  192. Another boost thread
  193. AMS base shifter bushings
  194. need some help!
  195. Mods for my Evo IV
  196. Top Mount Manifold Question?
  197. oem diverter valve: silver top and gold top differences?
  198. PiPlease help.!!
  199. water + tubular manifold = bad??
  200. Car dies after walbro install
  201. Routing for GM 3 port and ewg
  202. How to fixp0420 code Need help !!!
  203. my intake cam snapped?!!?
  204. Is there an N/A new style 4G63?
  205. Help! Brand New Engine Out of Oil!
  206. best combination?
  207. GT35r tuning ?
  208. best turbo for 2.3L
  209. Replacing Headgasket
  210. acl race bearings main
  211. Best hose clamps for stock UICP?
  212. Donation fund for Razorlab to test Twin versus Single Scroll
  213. Thinking of Stroking my Evo 6.5 Need some advice
  214. T-case Opinion
  215. Trans.
  216. torque specs using arp
  217. Transmission diagrams (inside view)
  218. Okada coils
  219. T3 Full-Race manifold doesn't fit my HTA37R ! ! !
  220. Manifold Question
  221. Shelf life of diaqueen?
  222. any experience with V bands??
  223. ? For all running AFTERMARKET turbo
  224. Wiseco HD piston to wall clearance
  225. Crank Pulley FELL OFF WTF!!!
  226. Retarded Rich AFRS with new mods
  227. drivetrain clunking in reverse?
  228. Leaking oil
  229. Universal rear 02 sensors...where to get them?
  230. Boost and Idle problems?
  231. Intake manifold, reinstall help etc
  232. Not building full boost..
  233. Evo 8 to Evo 9 Turbo
  234. help need ideas
  235. Eagle's Conrod For Evo 6 TME
  236. Whats wrong with my AEM Wideband?
  237. Snatch
  238. Mitsubishi dealer never heard of Diaqueen?
  239. SRS Light
  240. new mods, no boost??
  241. Oil cooler Position info
  242. Any of you with block heaters have problems blowing seals?
  243. Porting the Exhaust manifold?
  244. Vibrant maf adapter and amsoil fiter?
  245. Boost Issue
  246. Transmission Life ?'s
  247. 10.5 hotside + EPM O2 dump problems
  248. Extremely Loud Walbro 255 Fuel Pump...
  249. What did I do i have no boost!!!
  250. some pics of an HTA35r compressor housing with an HTA30r compressor wheel
