- intake messing up MAS readings?!?
- 2nd Gear lockout
- fp green to paper weight ...
- Getting ready to install evo 9 turbo into evo 8.
- Fuel gauge not working
- 4" intake pipe/stock maf
- Buschur Racing 2.1L stroker kit now availible on the BR website
- evo ix ignition with msd dis2
- New evo owner, help please, big problem
- Do you occassionally have light grind in 5th at high speeds?
- random misfire, EGR flow insufficient
- Idle all messed up...help needed
- Taping valve cover for large breathers
- Anyone heard of Pro Blend products...?
- Grind going into 5th at high speed
- boost questions....
- Lenght of Accessories Belt
- What are the differences between the EXEDY Twins?
- Bleeder Nipple on TC / Transmission ??
- place to get banjo bolt other than dealership?
- tell me what clutch to get.
- Which order should I install these parts?
- Tune or MBC?
- brian crowers 280/ 288
- Going for a tune...Do I need headstuds?
- Power steering fluid for the EVO???
- HKS Twin PLate Clutch
- Which cams..HKS 280's, Comp 280's, or FP 4R cams???
- my evo is tuned for a stock turbo to 340 i have a red installed on my evo is it safe?
- Which Engine Oil is the Best
- What is this?
- getting rid of maf ?
- Aftermarket manifold on stock turbo
- should I build my engine? and to what
- Cam gear bolt snapped...thoughts?
- what is this?
- Greddy Boost controller issues..
- ? on block
- Type of oil to use with HKS cams?
- lol i knew this would happen!!!
- problems!! need help car will only go 20 mph
- Ok the FP RED is out, Whats next?
- 1600cc & stock ecu & e85
- no boost?
- Anyone have before and after dyno results of MAP downpipe?
- Bad Bish Update - Turbo Comparisons
- 05-06 evo factory 2 step
- What Cams are U RED guys Using 4 Street/Autocross?
- mishimoto line m intercooler ?
- Anyone Running Magnus 2.3L Stroker?
- Low oil while cruising??
- EVO 9 turbo
- Mystery Camshafts...Help Identify
- Problem after Clutch Install...
- Anyone have experience or info on Precision's new line of HP turbos?
- Boost help!!!!
- need help quick
- Question about setting timing.
- Need size of upper cam cover bolts for clear cover..
- doing something crazy and need some technical info
- Question about CC clutch kit! HELP!!
- no boost slow boost
- ix bov
- Spark PLug Gap ?!?
- transmission part number help please
- Just finshed my GSC S1 install
- 600hp short block options?
- fp red or atp ver.2 gt35r
- no boost with boost leak tester...
- arp rod bolt
- Question on ARP headstud install
- 1g or 2g dsm oil filter housing? Fit on evo
- Engine Loosing power and hesitating under load
- aftermarket FMIC that fits on stock IC pipes
- CBRD BBK or Red for 2.3 stroker?
- hks mega suction
- EVO MR ACD mated to a EVO 8 5 Speed?
- Carbing Undertray and EPM o2 dump
- Sort of ACD issue?
- fp white anyone?
- 02 housing help
- Fp Red, 30R or 35R?
- Help, I drop 1 new injectors to engine (outside)
- Help Exhaust Leak
- While driving on the highway...
- Whats an IX engine harness worth? ( I have one)
- 4g64 and cam shafts
- What Is This?
- Harness for Map sensor ;(
- Resonators/mufflers/quieter exhaust? Where and how?
- Vendor for 9 Turbo compressor O-ring
- Spark Plugs - Are all those fancy plugs that claim increased power/mpg worth it?
- downshift noise????
- need help
- Perrin, Aem short ram or Buschur intake
- Triple Disk Rebuilt..Carbon to cerametallic
- used 8 head price
- More torque at wheels without any engine mods.
- Rebuilding my Transfer Case
- Any suggestions for my FP RED set-up?
- Is this the correct way to install FP Inline filter
- Motor Mounts
- Suggestions on LICIP and UCIP?
- Balance shaft removal question
- Question about my build
- What is normal oil Pressure ???
- Has Anyone Ever Seen Anything Like This?
- Evo 8 Mivec Conversion - specifics
- Wahlbro Question
- need part# for oem oil cooler
- anyone running fp5s?
- Apexi Power Intake
- Transfer Case Advice...
- P0132 cel
- o2 housing bolts!?
- 2.3 just in, question about some smoke.
- I'm stumped!!
- Drivetrain clunking, video inside
- TDC with no timing cover...?
- Clutch Pedal is stuck
- ACD oil
- 400whp on stock injectors?? Has it been done?
- idel problem
- Did your Evo IX fuel pump have this hole ?
- ? for those who have ebay short shifter
- egr code cel after clutch install
- What do you think i can rev to?
- Gear Synchros - Evo III
- Turbo surge on FPGreen or 20Gs
- Guess what I found while changing Spark Plugs... (look inside and help)
- fuel pumps (new)
- HELP please.. car wount start
- Rough Idle
- Thoughts on setup?
- Transfer case output shaft help
- Boost Issue
- Daily Driven Twin Disc
- Stock 2004 EVO 8 Throttle body size?
- Transfer case fluid and..........
- windage tray?
- can anyone help? wheel hub bearing
- Need Help on what to do about dump/dp exhaust leak
- Help!! New Clutch but throttle sticking.
- Stock WGA problem
- turbo problem
- Throttle Position Sensor adjusting help?
- Clutch problem need help ASAP
- Install Replica Tial BOV???
- Fuel and Spark Issues PLEASE HELP!
- stock turbo
- rods and pistons?
- car has been down for almost a year now...
- debating 400+ whp recipe
- Whats wrong with this oxygen sensor?
- Wicked Twin Disk Rattling
- Exedy 05803 Stage 1 Clutch
- Evo Transmissions
- Spark plugs..
- boost selenoid
- Battery in the Trunk
- Any one help me with this?
- porting stock manifold and 8 turbo
- AMSoil MR tranny fluid
- calling all methanol users
- half gallon of meth leaked into the UICP
- Boost Leak or Slipping Clutch
- How much goes in the t-Case
- Clutch pedal too high
- Went to port my header, tuner said it's a waste
- Help with Forge BPV FMEVO15: Spring Question
- Quaife Lsd ........ Wow....
- how do i hook up the stock blow off valve again?
- Fuel Trims no longer log
- 03 with front lsd but no acd ok?
- Anyone running the push style exedy twin?
- unequal length header
- Throttle body idle screw setting?
- Stock Evo 8 Little help
- which tranny fluid to use
- Launch CREADER Universal OBD II OBD2 Trouble Code Reader 14.99 FS
- cam angle sensor's rpm signal wire?
- Fuel Pumps
- FP Red on bearings
- Turbo: help needed
- Car sputtering really bad
- Unknown Boost leak!!
- GM 3 Port
- eno 9 mivec pulley
- Which one will go first?
- Water in oil?
- blown head gasket??
- Cam Gears and Cams Questions!?
- Rounded Lobe
- Symptoms of Blown HG?
- hks ssqv
- injen intake with stock uicp
- P0031 Code symptom of something else?
- REAR Quaife LSD
- ANOTHER!!! camshaft question(theres alot)
- MAP downpipe
- What you think of my cam install plans?
- HTA86r vs HTA37r?
- My day just got REALLY crappy
- Approximate labor for 04 Evo T.C
- bbk vs. fp red vs. tomei arms for stock block pump w/meth
- coolant leak
- HELP: Weird idle issue when refueling...?
- 02 housings suck in cold weather
- mishimoto tranny cooler
- Synapse BOV
- Ebaydealer cop ignition system?
- drop in pistons and rods!
- pleas help with clutch
- A/F and IC pipes?
- Evo 8 idle and radiator fan issues
- Having trouble finding.....
- Car dies without constant gas.
- Turbo Question
- cant make up my mind!!!
- screwed myself over !!!!
- Is this normal?
- Just fished installing o2 dump
- Heater Core Leak..?
- Look what UPS delivered yesterday (39 PICS)
- GD Walbro fuel pump!!!!
- Too much knock!
- Easiest way to remove copper o-ring
- another p0134 question
- Clutch Problem?
- 04 Evo T.C, where to get it
- Aluminum vs stainless steel
- Looking for 450awhp on leaded 110...
- p0171 question
- Precision 1200cc Injector Battery Comp (usec) - Lag timing
- Few cam questions before purchase
- Quiet Possibly Worst Day! what now?
- Does anyone here regret getting a lightweight flywheel for their EVO 8-9?
- AMS Oil Pan?
- pricey inlet manifold
- O2 trouble
- boost actuated cut-out
- Quick question about Walbro 255lph
- Race gas question
- Stock Fuel Pressure in a 04 evo 8?
- Using Stealth FX BOV
- low boost... high boost... spike!?
- Evo 6 TME Parts
- Small Probem (any info would be great)
- Pics of MR 4th gear failure
- My FP-RED vs FP-GRN on 91oct dyno compare
