- AEM to stock ecu = No start
- Cold engine noise
- Bov........
- Clutch/Transmission problems
- New clutch blues
- question about strokers
- 2.3L Rebuild. Someone Point Me In The Right Direction
- carbon build-up
- Cams are VERY noticeable after 2.3L install
- motor blows again :(
- Thick white smoke from exhaust, not coolant. Need expert opinion please!
- E85 and 91 octane??
- SparkTech Sequential COP on Procco/CFT EVO breaks 1000whp!
- Change in idle AFR after tubular O2 install?
- Change if idle AFR after tubular O2 instal?
- Worth Porting Stock Intake Manifold?
- Cam damage / scoring
- Anyone know what exhaust this is... (pics)
- Single Scroll GT3076R vs HTA35R or FPRED... for stock motor, need input
- Buschur Catch Can Condenstation in Oil..Anyone Else have this?
- RMR filter kit not fitting
- Whats goin on somebody help - idle problems
- Trans Help
- Help with p0069 cel
- High Idle ~ 2,500 rpm?
- Going with exedy quick question.
- Cam install ?!?!?!
- 550Plus WHP what clutch
- Help with Whine!!
- Car Jerking at WOT
- injen ic piping causing problems??
- msd dis-2 2 channel ignition on evo ix?
- Exedy Twin SD convert to HD
- Powertrain Technology Twin Disc Clutch Kit or QuarterMaster Twin Disc
- Picture Request: Stock intercooler pipe bracket?
- For sale - MBC, Stock Cams, Boost Gauge, Downpipe
- Very weird problem....any help appreciated!!
- Break in for a new turbocharger?
- Evo Bolt-On 75mm Billet Throttle Body ( A MUST SEE PRODUCT )
- help!!!
- boost problem. help please
- Put in Mini Battery- Gettin Lower Boost
- Oil in catch cans (DC2) ??
- help plz
- max hp with denso 720cc injectors???
- Buschur HTA 37R kit question
- 40+psi boost gauges
- 05 RS starting problems
- Turbo woes... your thoughts please!
- eBay ARC intake copy?
- Tranny
- How to measure turbine housing size
- Shifting when it's cold
- stock downpipe + 3" cat-back - how far have you gone?
- Greddy Turbo Timer not working properly
- Spark plugs
- help with Dynatek ignition
- Need Help !!!
- Most Horsepower on Daily Driven Stock Block?
- How many have modified their walbro (bypass mod), is it still running?
- FP Red with only meth and TBE
- Question that's got everyone stumped
- Our engines are air pumps!
- New Clutch for XI!
- Quick question...twin disc clutch engagement
- ACD 3 solid lights after transfercasse replacement
- Cutout exhaust, safe?
- Upgrade Intercooler??
- Anybody running Kelford 280's?(non-Mivec) Please share your results here!
- LICP Question
- Quick question... ACT clutch slipping
- HELP with high HP clutch decision.
- Clutch Shutter / Chatter
- What oil to use?
- Car wont start
- trans in and out 3 times this last week
- stock IX, 16psi max? -help please
- 2 Issues I'd like to resolve before...
- Lil Help?
- is there a single MAP sensor I can use for everything?
- Exhaust size
- Engine rebuild suggestions?
- Big Strokers: Low Rod Ratio Real World Durability
- HELP: used hks cams
- What do you guys think ?
- FP Red failure
- transfer case
- Fujitsubo RM01A
- Exedy twin plate question
- Evo race bearings PLEASE HELP
- MBC back to stock...help a moron out
- People happy with the Buscher ported stock manifold?
- Lifespan of a tubular manifold
- 4g63 turbo block in Evo 8
- 6262/HTA86 or 6765/HTA88??
- Ebay Catch Can
- Question for u guys
- What is this solenoid?
- Is This Normal??
- Megan o2 housing different than the old ebay o2 housing?
- "Heavy Shockproof" review...
- BlowOff Valve: Have Recirc or Move MAF sensor
- Help: Super Rich Idle
- AMS lower clutch line
- 02 housing
- Spark plugs affecting tune
- Getting ready to install Walbro 255
- Installing Manley I-Beam Rods ... HELP!
- ACD help
- Please Advise---Wont Reach Boost
- Who is running modified walbro - releif valve closed?
- Gas mileage and cams
- Built 2.0 or 2.3, and which Turbo??
- RPM Skipping HELP
- Samco vs. Perrin intake pipe
- EVO 9 GSC S1 cam owners or anyone...
- Need a Part Number
- blow off valve
- Having issues!!!!!!!!!!!!!!!!!
- Turbonetics MBC?
- 2006 Evo IX turbo lag!
- GREDDY cam gears out of balance??
- Clutch bleeding issue.
- ams tbe owners
- would like 450awhp
- Is it worth it
- Help me decide if to upgrade to the HTA 86 or not
- Evo cutting out.
- 550whp on pump gas
- 50trim upgraded to a 35r PICS INSIDE.
- hks intake cam upgrade
- DSM 1/2g Cam gears on evo 8??? marks r in different locations
- FIC injector question with large Pics !
- what clutch for 6 speed?
- where to buy motor mount inserts other than AMS
- Slowly using Coolant From Reservoir!?
- 9 turbo on an 8 only hitting 24psi...
- Ouch
- Is this normal?
- Weird sound while tuning...Head Damage?
- ATTENTION all ETS intake and upper IC pipe owners
- Intake problem
- Loss Of Power
- Fuel Injectors
- Vibrating clutch pedal
- Help: Car breaking up badly
- Opinions on Budget Upgrades
- Looking to upgrade from the pt67
- Car sounds like a WRX?
- Tomei 260 Cams
- Ticking Noise coming from engine
- from stock turbo to hta86
- ? about T-ing the vac lines on Syn BOV
- Can't make up my decision on a transmission
- Clutch ? fadanze clutch...
- act clutch slipping
- forge "splitter" bov
- Reverse gear on 6 speed grinding only
- BBK or keep meth or both?
- Corroded stater wire
- 2.3L on stock ecu?
- Help!! Throttle Sticking!!??
- IX MR Transmission fluid
- Spark Plug Recommendations?
- E85 hurting fuel injectors
- Best Twin Disc Clutch?
- Problem with turbo need help !!!
- Exedy twin disc hd or Quartermaster twin disc?
- 57 trim numbers on race gas
- FP Red and 880cc injector install
- Buschur Build/Tune + BBK = One Broad Power Curve!
- WTF ! My tune sucks and my car is slow - what next ?
- T3 o2 housing???
- Upgraded oil line for fp red turbo
- JMfabrications, making turbo dreams come true! Tial V-band manifold
- Getting ready to install GM 3port
- Just bought 06 evo! Problem!!!!
- Car not moving
- Walboro 255lph
- Valve cover is ****** up.
- stock turbo charge pipe.
- Case Hardening Shop?
- 3076 from 1g dsm to evo ix
- Question about Boost Solnoid
- Hallman MBC
- HTA 3076 and stuff on my IX MR
- Oil Feed Fitting? (Want to replace banjo bolt)
- muffler delete
- What spark plug?
- t-case seal!-t-case leaking fluid. SUGGESTIONS?
- LICP install help
- Muffler help
- Stock turbo SS Lines
- buschur racing intake pipe couplers
- Boost Problem
- Problems
- is an 03 evo8 turbo the same as the 05 evo 8 turbo?
- BR Double Pumper install?
- Injectors? Size?
- removing the honeycomb!!
- Please provide opinions on drivetrain noise
- How does this happen?
- T-case
- new evo motor parts...?
- Please help confirm/identify the issue
- Boost Problem
- Motor mounts
- Injector size limitations with EcuFlash?
- Exhaust header studs
- hey some one help me
- Gsc 280's any good?
- Spark Plugs
- Whining noise in rear.
- Stock exhaust on RNR downpipe?
- Can anyone tell me what turbo this is??
- Head studs
- Release bearing?
- strange problem with p0136, p0505 and p0170
- Re-torque Head Studs?
- Test Pipe question
- Walbro 255 low pressure good enough???
- Help with clutch or slave cylinder issue...
- Twinscroll 35R or HTA35R
- 124k EVO IX MR maintenance
- IX MR owners
- need help!!
- Front O2 Sensor replacement Q?
- Has this ever happened to you or anyone you know?
- GT35r low end power
- Throw-Out Bearing wont Release
- Please Help MIVEC Intake Cam install Questions???...
- arp rod bolts!!
- I discovered this bolt was loose and leaking... [HUGE IMAGE]
- Exedy Stage 2 clutch vs ACT XTSS
- How high can you rev HKS Cams
- Cylinder Bad?? **PIC**
- Help! Off centered steering wheel *pics*
- Need new cylinder head. Looking for suggestions
- Alternate thermostat options?
- newbie build help
- 2005 lancer evolution rs
- need evo 4 axles
- Dsm head on evo8 block??
- Aftermarket BOV
- Kelford 272/280 IX cams
- 500WHP on 750cc's and Meth??
- how far to push a Green and 680's on pump?
- Opinions on shifting problems
- intake messing up MAS readings?!?
