- new parts....problems
- Got 2 probs and a ***** aint 1....need some help with my evo...lol
- ATP T3 Adapter ... Anyone Using It ?
- Car died at the track?
- Rich off the accelerator
- DG Motor's Drag Evo 8....
- Gsc s1
- What should I be running?
- Timing diagram for Kelford 268
- Throw out bearing question
- T-Case Warranty Help
- No start on Evo 9!
- Just got 223 miles from 9.9 gallons
- Thinking of Zinc Plating Engine Parts. Anyone do this before?
- Evo pistons: A, B, C sizes?
- steel braided radiator hose question
- rope method for changing valve springs
- need help .......wt to do
- Megan Racing O2 housing
- 2 BOV's?
- Best Downpipe and Cat Combination (Evo IX)
- whats causing my overboost
- GReddy Easy Cams?
- Who is running the hta86
- Help fuel pressure regulator vac line!!!
- My Engine Build w/pics (Drop-In Setup)!!
- High HP evo's what do you do with your PCV valve?
- Forge EVO15 Bov??
- GT35R oil restrictor...
- YABLT - Yet Another Boost Leak Tester
- Input/Output Shaft removal question
- Noob Turbo Questions
- FP Red is Here!
- do i need a new alternator?
- 1-piece Driveshaft
- after 5 months of trobule shooting (MELLON THANK YOU)
- Transmission swap?
- Is an EVO 7 block the EXACT same as an EVO 8 block?
- Correct compression on a 2.3?
- Thoughts on 2.0l long rod
- Any good evo mechanics out in la
- O2 housing, DP, Cat, test pipe, cat-back QUESTION
- Used clutch?
- Is an upgraded clutch required?
- bov opening all the time
- My ghetto rebuild - any thoughts?
- Car "shutters" during light throttle cruise
- Hallman MBC Problem...
- Will painting IC affect..?
- 4th and 5th gear problems?
- Is BG syncro Trans fuild good?
- P0172 code and erratic cruise. Still can not find what is causing it!
- Oil warning light
- idle goes crazy when fan kicks on/off
- more clutch questions
- new altenator????
- Help oil feed line trouble
- Is this a green or a 9 turbo?
- HKS SSQV VTA with 272 cams
- To stroke or not to stroke
- Cam gear settings for a faster car? Not just more hp.
- Thinking about a turbo upgrade, BBK?
- 4.6L BBK Throttle body Leak Fix??
- Who has upgraded FROM a RED and what did you go with+why
- where can I find 65mm throttle plates?
- Need help finding something
- Need some help with gaskets!
- Full Blown Double - Modified Return fitting, stock FPR?
- .40 bore?
- How does LSA effect the powerband?
- Buschur Licp Pic? From turbo outlet
- cracked sensor
- Clutch Questions, ACT HDG6
- Mishimoto intake worth trying
- 1450CC on single pump?
- does anyone run BC288s?
- Engine Overheating
- Quartermaster: Really That Hard To Drive Daily?
- Having bad problems with my evo 8 power delivery!! please help!!!
- Tube and Fin Intercoolers better for Evo's?
- idle a/f/r with 272's
- Helppp..Nasty noise and feeling in clutch pedal
- CCI clutch problem
- turbo timer
- Electronic problem??
- po300 Quick answer needed
- Quick Help needed. Surge or Flutter? MBC installed.
- Relocation of the Battery
- Rev limiter - stocks springs on HKS 272s
- Gauge cluster and windows no work???
- Denso 1000 cc injectors dont plug in?
- trouble getting into reverse
- How offten to change trans fluid?
- Best tool(s) for Valvesprings install?
- Safe to use FP5R??
- MIVEC on Exhaust?
- uego sensor on megan t/p
- broken spark plug, head damage?
- looking to replace my clutch and flywheel
- Exhaust and Housing problem
- K&N Filter for Eclipse fits on EVO IX ?
- P0365 code with Evoscan
- CEL fix and STILL FAILED!
- How to fix TOB clip from coming off Exedy Twin?
- Head Gasket
- No ignition signal...I cant crank the car
- New Clutch and knocking in suspension?
- Are these low loads for Stock cams for an Evo 8
- Grinding after trans fluid change
- The red is here!!!
- Trans. Rebuild
- Evo VIII - 3" Test Pipes
- Transmission pictures and diagrams
- RON 98 Fuel?
- epm dump pipe
- Smoke at idle
- quick question about the evo 9 turbo someone sent me.
- 5th Gear Grind
- when should I install?
- Help (Low Idle Warm Start)......
- ***please help asap evo sounds like dying turkey when boostin!!!*** need to drive car
- help to decide
- Changed BOV back to stock MR = no boost -- need help
- people running a 2.3, Amsoil series 2000 racing oil 20W50 discontinued!
- quick advice on clutch
- what is better? 2.0l or 2.3l
- 2l History from Russia!
- Weird Problem Help Needed ASAP!
- oil flow diagram
- vacuum diagram
- What shall I do ? Meth or another route ?
- FP red boost creep please help
- boost/vaccuum question
- Broken mivec cam gear...
- o2 housing install- sensor now hitting AC line?
- I need help!! Greddy turbo kit ?
- Engine fluid leak, need HELP!!!!!
- Quick DEFI EGT bung ?
- Buschur Deluxe FMIC question
- Injen Intake Pipe + Nisei UICP?
- HSK timing belt
- Cosworth pistons major problem!!!!
- Clutch Help Needed?
- Sticking RPM's
- Boost leak problem!!
- Blown Engine or Turbo?
- Mitsu CHRA turbo failures...
- hey guy wondering if i had a bigger wheele in my turbo
- Idle drops...need help!!
- light "whistle" from engine bay... Need help!
- Torn between two TBE's. Help decide
- need advice on a problem
- Turbo kit very cheap, what do you think?
- SP compressor cover VS H-Compressor cover? (buschur,Al,mike@awd,seanivey)
- Manifold to turbo and turbo to O2 bolt sizes?
- HUMMING NOISE on '05 rs
- Has anyone bought anything from FTP NYC?
- Got cams but no box!?
- What clutch is good for 375hp?
- damn pressure plate clip
- Stock turbo fit on 06 WRX?
- O2 Sensors
- Greddy Competition TI-C full TBE
- My two step is making no boost... only 10 vac
- heli-coil size for head
- Force Fed newb here... Need help.
- what is the weight of stock FLYWHEEL???
- Hta3582 or hta3586? Is there a big difference
- CHIME IN> Power shifting (NLTS) What Clutch??
- Boost Question
- Diagnose my Exedy Twin please
- What do I need to run a fp red?
- evo ix map sensor
- Advice on engine/turbo setup for a track Evo
- Best Cluch? HELP!
- Exedy Twin Disk to Triple Disk Conversion?
- meth setup
- what all is needed to do a 9 swap
- evo acting funny...
- Squeaking coming from engine?
- AV Gas (100 octane)
- Mitsubishi DiaQueen LSD Gear Oil????
- AP bov...rpms weird
- 5 speed into MR swap thread!
- Rear LSD
- does anyone has a pic of stock bov on evolution????
- 6765 or 6262???? help please
- swap i/m and t/b
- What's better?
- BOV question on high mileage EVO
- Stage 1 vs OEM
- how to clean wash Evo 8 head ?
- I have a fp red on my car and supporting and the boost spikes to 27psi, what should i
- Perrin Intake Tube (Blue) problems
- too much boost with ecuboost control/5th gear flutter help!
- whistle/ grinding sound... help!
- Car heating up, need advice
- hey wondering how to tell if i have a bigger wheel
- What type of engine oil to use
- High Temp Gasket Maker
- Transfer Case Diff Help
- FP Red Wait List
- Spark plugs.
- FP Red on stock 83,000 mile block
- Timing Belts
- bov fluttering?
- Help, turbo Xs D.P, Evo8
- Turbo back catted exhaust
- Slave/Master Cylinders
- Noise after releasing throttle
- GT-Spec header, good choice ???
- 1320awd buildup
- Head torque pattern order???
- trouble with leaking air from bov
- Engine prefix identification
- Stock Exhaust Bolt-Nut Sizes
- Tranny problem please help!!!
- Bushur and fp red turbo?
- Clutch: Decisions, decisions...
- Oil pan gasket
- Car stuttering on WOT.
- Blacken, overheated rod cap?
- Super rich under 2k, -4 vacuum at idle
- Megan Racing O2 Housing Issues?
- would 05 ecu work? with my 03
- ati, stock, or fluidampr?
- major install done by ME!
- Custom Mivec Feed line?? Braided steel line
- Tcase or rear diff
- problem with car driving
- o2 sensor cracked?
- Downpipe fitment
- new motor nee some help
- Dirty MAF Sensor?
- low end flottering? help
- New Evo IX MR, tranny bucking/ clutch noise
- Wastegate overboost and boost creep
- help with excessive coolant usage
- Whats the best 02 housing?
- HKS TWIN POWER ign
- I crashed my car!!!:'(
- Where is stock maf connector?
- Dipstick blown out
- Identify This Diff
- Glove Box Power Source
- FP Red Boost Creep
- Turbo info for beginners...
- need help, coolant question
- Motor Rebuild - What am I missing?
