View Full Version : Evo Engine / Turbo / Drivetrain
  1. FP RED injector size?
  2. FP red new 80mm compressor cover
  3. Rear Diff Whining??
  4. 4G64/63 power capabilties
  5. Deatschwerks Injector Service
  6. Pros vs Cons of boring your engine!?
  7. help diagnose pls
  8. Last clutch questions before I order...
  9. Revolver Cams vs. Kelford 272
  10. Boost Leak at Intake Manifold?
  11. Jun 272 or HKS 280
  12. battery and brake light come on today
  13. Hesitation during intial drive?
  14. ACD C161e Code
  15. Loss of Power??
  16. Boost Issue
  17. Engine rebuild recommendations
  18. Engine rebuild recommendations
  19. EVO clutch opinions
  20. Stock Pistons on Aftermarket Rods vs stock rods w/ arp rod bolts
  21. my ball bearing 9 turbo (video)
  22. Help! Wont Start!!
  23. My Tranny Died on me.
  24. "Special" EVO Build
  25. good daily driving clutch?
  26. Just put the Tial on (vid)
  27. Wiring diagram for Bosch 15733 on a 2004 EVO
  28. valve seals keep getting pulled off guide
  29. Boost leak or not?
  30. grinding noise
  31. Don't care 4 the fix, I wanna know why. (cruddy shifting)
  32. Quick Question, LSD
  33. Where's the best place to get?
  34. DSM problem in my evo DIPSTICK !
  35. HKS DLI install guide
  36. Solved my 6spd 1st and Reverse prob
  37. I have one question? for evo 8
  38. Changing shifter base bushings on an MR
  39. Engine Codes GRR..
  40. ARP Flywheel Bolts
  41. Help! Turbo is whining?
  42. Pics - New Head Install
  43. Part Number for axle seal
  44. Modding advice...Need some help.
  45. need help,can't boost past 14 psi
  46. Generous present.....or bad luck??
  47. Question about porting
  48. New O2 sensor, now won't Start HELP!!!
  49. Defi boost gauge gone bad
  50. TOB removal HELP!!!
  51. turbo gasket kit
  52. EVOLUTION VIII oil cap
  53. Where can I get...
  54. epm dump question
  55. ACT clutch
  56. Flywheel/Clutch Inspection Question
  57. SAFE EGTs...Please advice!
  58. Downshift whine
  59. NEED HELP ASAP leaking ACD bleeder
  60. NEED HELP ASAP leaking ACD bleeder
  61. Need help with my turbo gauge
  62. Need Help Car Wont Start
  63. issue with my basically new clutch, maybe someone can help?
  64. APS Bov
  65. CWiLL & TD Autowerkes team 780whp Build
  66. For those of you with a big turbo I need your help
  67. Rattle from Engine, Any Ideas?
  68. 880cc injectors
  69. do i need injectors for a fpgreen?
  70. Pcv system ?
  71. Boost & Spark Plugs go hand in hand?
  72. Help! Evo 7 GSR AYC DRAIN BATTERY
  73. What bolt size to plug up O2 bung?
  74. Clutch Noise
  75. boosting issues?
  76. AWD Motorsports Evo RS.. Precision Billet 67mm.. 818whp / 588tq!!!
  77. External Fuel Pump
  78. non stock plugs for evo 8 (no coppers please...)
  79. wow i feel like a newb
  80. Boost leak test and trange results...
  81. Temp transmission and tcase fluid?
  82. boost problems
  83. 5th gear misfire
  84. QTP hitting tranny on 'takeoff'..helpz
  85. turbosmart bov
  86. CBRD Rad into EVO 6
  87. Slave Cylinder Extension Rod
  88. aem wideband at 14.8 currently
  89. ets pt 61mm prob
  90. High Boost and Engine life?
  91. Two exhaust systems - which one to go with
  92. Synapse BOV & Injen kit
  93. could somone explain something for me?
  94. Whats The Point Of This Cover
  95. ACT guys . . . describe your lockout/shifting problems
  96. Weird idle Q
  97. Fan switch questions
  98. reving
  99. question: is it bad to have no 02 sensers?
  100. Odd clutch pedal movement, Ideas?
  101. Best LICP?
  102. any vertical ICs out there?
  103. EVO 9 Oil drain bolt
  104. Oil gunk on single spark plug.....
  105. Has anyone used this tool for valve springs???
  106. Has anyone used this tool for valve springs???
  107. JIC Spartan Info
  108. Flat spot during WOT?
  109. hta vs...
  110. Radiator Support the same as Lancer?
  111. Question: Evo 8(2005) to a FP Red??
  112. HKS Turbo Timer.. Sometimes it works, other times it just turns off..
  113. 2004 Non-ACD, Front LSD
  114. Big thanks to STM
  115. O2 housing sensor
  116. ETS short route with ETS intake (pics)
  117. flywheel question
  118. NEED HELP fast. Plug tip broke
  119. HTA68: Any plans for the Evo?
  120. Tanabe Concept G exhaust for EVO X, too loud?
  121. GSC S1 or Kelford 264 cams???
  122. Getting the intake manifold off
  123. Getting the intake manifold off
  124. Piston to Wall Clearance - Various Piston Manufacturers Recommendations
  125. A/C COmpressor Troubleshooting
  126. 2.0 Build
  127. Anyone else have an ebay exhaust??
  128. New turbo for Evo IV?
  129. VP Q16 116MON race gas on 98 pump
  130. BOV doesn't sound anymore?
  131. evo 4g64 with 20g turbo
  132. NEED HELP?! whats happening?
  133. DTC 0121 with Tial BOV>>??
  134. ULTIMATE streetcar? Opinions
  135. oil light
  136. What is this knob on the fuel pressure solenoid for?
  137. Clutch Help ASAP
  138. went through a puddle..now im smokin!
  139. Clutch Advice Required
  140. OEM Headgsket Thickness
  141. mishimoto evo 4/5/6 radiator install
  142. Need help!!!ACD probleme
  143. gt30r
  144. Anyone ever rebuild their Exedy Twin? Results?
  145. My Cam and Spring Purchase
  146. Time for rebuild????
  147. Trying to build my Tranny need help!!
  148. Does anyone have an ARC oil catch can installed in their car?
  149. Just changed clutch line and bled it, have question
  150. Transfer case
  151. What do you guys think?
  152. speed density
  153. HKS catback w/o resonator + taper
  154. Intercooler outlet size??
  155. Exedy twin wedge collar
  156. Clutch install 56k chillax right where your at...
  157. about how much whp?
  158. compression test results???
  159. Weapon R Engine Torque Damper Question
  160. White smoke when I turn the car on
  161. METRIC NPT and PT DEFI EGT
  162. oil in the intake question
  163. Dyno Speculation?? What will new numbers be?
  164. what could it be?
  165. Street Or Race ACL Bearings ?
  166. **Product Release**AMS Mitsubishi Lancer Evolution VIII-IX Radiator Hose Kit
  167. Power output for Evo 8 with Stock Cams?
  168. Silicone Hoses
  169. Dead clutch pedal!!!!
  170. Main reasons for compression surge???
  171. Clutch Restrictor
  172. Cam question...interesting. No power after 5k rpms?
  173. Bleeding Clutch ...
  174. help needed asap
  175. GReddy EasyCam 264/264 - anyone own these?
  176. CAT problem
  177. straight pipe catback
  178. anyone have this problem with their ARC oil cap?
  179. A/C problem
  180. Need a Part #
  181. worth porting a 10.5 housing?
  182. another rattle question..
  183. Questions on piston to wall clearance
  184. EVO VIII Blow Through MAF
  185. Fuel lines and fuel set up?
  186. Another coolant temp problem
  187. NGK BPR7ES Spark plugs (Discontinued ?????)
  188. How much power i can make with One Cam
  189. where should i run these vacuum lines..
  190. weird idle during rain
  191. Are you running a 3-Speed "Scatter Shield"
  192. Car won't hold idle ?!?!
  193. how much to get to 400
  194. Weight of Evo8 shortblock
  195. Rear o2 Sensor Removal / reprecussions
  196. cant boost past 12psi, need help
  197. evo 8 with evo 9 turbo
  198. Help with Short Shifter.
  199. Opinions on Manley H beam rods?
  200. Opinions on Maley H beam rods?
  201. Different techniques on dropping subframe
  202. POS wedge collar
  203. My car is tripping out
  204. part # request
  205. Detailed alternator photo's please help!
  206. help for building 600 hp daily driven evo 9
  207. evo will not rev passed 3000rpm????
  208. stock axle's?
  209. Boost Problems Please Help!!!
  210. Anybody here running a fp red turbo with meth on a act street disk with out clutch sl
  211. Problemm after clutch install..help
  212. Forge wastegate actuator/ popular or not
  213. Evo 8 turbo problem
  214. how to get rid of boost loss???
  215. Help me find a switched source ? Installing WAI Kit
  216. Oil leak question
  217. need help with my tru-boost
  218. FP Red re - designed
  219. Got the new FPR on!
  220. Head gasket differences?
  221. BR's Project White, "completed". Lots of information.
  222. New Red+Big A** Compressor housing=
  223. What fuel pumps are suitable to run E85 with?
  224. Best cams for stock 9 Turbo??
  225. Head off the car, trying to take out the cams? help
  226. does my diverter valve sound right (w/ video)???
  227. Does the no lift shift puts a lot of stress on the drivetrian?
  228. New Turbo for Stock Location?
  229. Best ic piping for evo 8
  230. weight of EVO 9 head
  231. Need Help with Greddy TT
  232. Problem with Hallman Evolution Pro MBC
  233. Clunking noise coming from front right??
  234. Evos do not like moisture
  235. what does the stock evo8 diverter valve sound like?
  236. Oil feed size?
  237. evo9 rear diff on evo 6 need moustache bar fix
  238. Turbo or Cams first ?
  239. Oil Light Flickering ( I May Have Solved The Problem )
  240. Wow - Looks Like I've Toasted a Rod Bearing
  241. Clutch Intall/ACD
  242. CEL CODE P2229 Barometric Pressure? (Pic Inside)
  243. Hks dli2 igniton install ?
  244. Apexi Avc-r question..
  245. Anymore PT Billet 6765 results?
  246. HELP: K1 or 4G64 Crank?
  247. 15k maintenance for my evo
  248. pic of intake manifold
  249. please help on clutch selection
  250. new parts....problems
