View Full Version : Evo Engine / Turbo / Drivetrain
  1. What would you change?
  2. what do you think??
  3. Need advise on my new clutch choice. Help!
  4. ACD pump relocation
  5. Tranny kicks shifter back in 1st
  6. Looking for specs on the older GSC 280's
  7. Greddy or HKS
  8. 2006 MR Cold Air Intake (CAI)
  9. Starting Issues (Fueling problem - Walboro?)
  10. Help Please...
  11. need help! evo6 max psi
  12. Over Rev on shifts, who's got the answer?
  13. HKS Hi-Power Possiable Issues.
  14. My Battery Relocation
  15. Gay boosting prob...need advice.
  16. Tranny Oil Options?
  17. Has anyone made 400whp on an Evo9 turbo on pump?
  18. HELP! Tranny from Block:how?
  19. Anyone have Thermostat part # ?
  20. evo 9 ecu compatibility? hAlp!
  21. Stipped center exhaust manifold bolt...how bad is it?
  22. 2.0 rebuild question
  23. Buying new Thermostat...OEM or Mishimoto ?
  24. evo pulling mass timing?
  25. Anyone ever used OS Giken's Super Lock LSD Gear Oil 80W-250?
  26. The Physics of Multi-Plate Clutches
  27. HKS twin plate warps easily?
  28. Static ignition timing retarding by its self
  29. boost leak or faulty boost controller?
  30. Cost of coolant flush?
  31. Titanium Exhaust vs Stainless Steel
  32. FP red porting
  33. Bent crank angle sensing blade?
  34. Stock Alternator vs. Autozone Alt??
  35. Broken transmission and cracked exhaust manifold, what to do?
  36. New FpRed vs old FpRed
  37. Oil pressure question....mounting
  38. need help did boost leak test and leaking from throttle body
  39. Turbo XS bov rfl evo IX
  40. Leak Down Test- Simple Explanation
  41. Crankcase catch can vs. Open breather
  42. does the vibrant maf adapter come with hardware?
  43. E3 Spark Plugs
  44. Evo 9 starter on evo 8??????
  45. Need quick suggestions before tomorrow on transmission warranty
  46. ams balance shaft delete install??
  47. Which alternator... F or D??
  48. crank pulley removal???
  49. Unbelivable blown clutch PICS INSIDE
  50. Stock Axles Max Power
  51. Limits on the stock valve train
  52. just bought redline oil...question
  53. Ottomatic's FP Red Install / e-85 build - Progress Pics
  54. JDM Evo 7/8/9 Transfercase compatibility
  55. What are the nessessay parts needed to convert evo8 gsr to evo 9 mr
  56. cams
  57. Random electrical problem, help
  58. Tranny Oil and TC ,Help Asap!
  59. Piston To Valve Clearance
  60. Where can you purchase the Driven Innovations Intake Manifold and Throttle Body?
  61. tranny lockout
  62. cam ?
  63. Are some cams knockier than others?
  64. What is the metal thing behind the crank pulley called?
  65. Wheres the fuel pump relay?
  66. Need help with LICP for FP Green setup on 03 Evo..
  67. Titek version 2 o2 housing
  68. Hallman Pro Series Boost Controller boosting capacities
  69. Hallman Pro Series Boost Controller boosting capacities
  70. Found 2 bolts broken... Now what?
  71. Help! Please run out to your evo to help me! Pic Needed
  72. p0138 problem
  73. Turbo Transfer
  74. blown clutch
  75. how to check tranny fork?
  76. Annoying whining noise....
  77. oil light
  78. Greddy full I/C pipes with stock I/C evo 9
  79. CCI stage 4 clutch kit with stock EVO 8
  80. Greddy Ti-C Turboback
  81. RPMs drop 500 during WOT in 4th and 5th, why?
  82. clutchmaster stage 2 clutchs and flywheels
  83. Help: A/C Questions
  84. compressor surge?!?
  85. Ball joint removal
  86. throw out bearing question
  87. Sard FPR and Guage
  88. Need an Explanation :S !!!!!!!
  89. Evo 8.5 starts, then dies after 5 seconds
  90. Stock block/pump power?
  91. slight slight flutter from tial bov
  92. no spark check list.. help!!
  93. Can anyone confirm piston clearance for me?
  94. Evolution 8 MR AYC Prob
  95. 1st gear/Reverse vibration?
  96. AGP Intercooler
  97. boost leak test oil cap leaking?
  98. suddenly car wont go into gear!?
  99. Where can I find a decent rear differential for a decent price.
  100. light smoke
  101. How long for lifters to pump back up after bleeding
  102. Injen intake is lifting my greedy pipes and wont let my hood close.....
  103. 5000rpm misfire.
  104. Finally started my built
  105. Ihi vf37 ?!?!?!
  106. 04 Lancer WRC engine bay
  107. dynotune gauges?
  108. Fuel injector problem
  109. Cams and Emissions
  110. Evo IX piston to wall clearance. HELP!
  111. Opinions on DD on cams?
  112. Lookin' to build a leak tester...
  113. Spark Plug ?'s
  114. CAT Hitting my driveshaft. why?
  115. Drag guys......What power diff running without AC and PS?
  116. Upgrade clutch, or wait till stock dies?
  117. need brains 4 boostgauge hookup ...
  118. clutch completly blown, SUCKS
  119. WOT Heard POP no Electric for 1/2 second, then all fine WTF?
  120. What IC pipings will fit?
  121. HELP! Detonation in only one cylinder!
  122. when to change timming belt?balance shaft?
  123. Blow off valve stuck closed
  124. Engine cut out at high rpm
  125. HELP Identify this Injector Plz (Pics)
  126. Ceramic Bearings
  127. I got it!! I got it!!
  128. Mini battery love -
  129. Carrillo Rods, Wiseco Pistons Weights etc (New build)
  130. New Competition Twin TOB
  131. where to buy extended vacuum line?
  132. Spark Plugs - To gap or not to gap?
  133. Help, someone rescue me
  134. simple evo ?
  135. o2 dump vs recirculating o2 housing.
  136. FP Red 80mm inlet Flow Advancement Port
  137. False Knocking ISSUE! NEED HELP!
  138. boost controller question
  139. Starter location
  140. Shifter Sux
  141. Need help, won't boost over 5 PSI
  142. Bad tranny, front diff, or Ring/pinion?
  143. ARP L19 head studs 1+1... what to TQ???
  144. having trouble finding the alt plug?
  145. Does this sound like an ignition issue?
  146. Dealer Rec's TB Cleaning & Injector Flush - $200 + Tax
  147. clutch/tranny BLEW today
  148. kelford cam install problem
  149. How many shims for a quarter Master Clutch on average?
  150. Where can i find this part.
  151. 1-2 Shift on hard accel
  152. Can I use stock head gasket with 86mm bore?
  153. Bad First Gear Noise HELP!!!!
  154. Turbo Question
  155. Silly intercooler couplers
  156. kiggly beehives springs/tool
  157. Clutch Blew out Tonight
  158. I can only get 1/2 lb.
  159. Car won't start from time to time
  160. Leak Help!
  161. Help! DRAINING coolant
  162. TOB problems, CLUTCH, PLEASE PLEASE HELP HELP
  163. FP Red or HTAG35R
  164. Loud Ticking from throttle body
  165. Vacuum line placement on tial 46mm gate
  166. Evo 7 Piston Burnt
  167. serp belt install probs
  168. e85 and gas mileage
  169. Tob help help!!!!
  170. Retuned after 60K?
  171. Cat life?
  172. evo9 272/72 cams - valveupgrade ?
  173. What is the best oil filter sandwich adapter for EVO?
  174. Driven Innovations is King?
  175. tried everything! out of ideas! please help
  176. painting intercooler good or bad?
  177. Oil Flow Rate(s) for EVO8 ?
  178. Anyone have this manifold?
  179. Driveline fluid change complete
  180. e85 considering
  181. paracitic draw
  182. Anyone Using A Precision Sc 6176?
  183. Two guys, two mods, and a tune... in the 11's
  184. Will AMS UICP fit Greddy R-Spec FMIC??
  185. oil Pump replaement
  186. gearbox pics/info
  187. hks super sequential blow off valve need help
  188. Ummm...am I missing something? (exhaust install)
  189. Boost Gauge Problem
  190. Need some help from fellow troubleshooters
  191. Serious Idle Issues
  192. Turbo Question
  193. Whistling noise while driving.
  194. rattling when going into 1st gear low rpms
  195. redline package
  196. Bushur Racing Quiet Exhaust?
  197. just got tranny rebuilt from jacks.. help!
  198. okay to run car with ACD fuse removed??
  199. New Timing belt questions
  200. non water cooled turbo question
  201. Best way to store a block w/o it rusting?
  202. drop in pistons help
  203. Whats the best IC pipe to use 2.5How much lbs/min is PT6262? PT6765? HTA37R? HTA3586?
  204. For those running AEM EMS and stock frame turbo...
  205. HELP! I lost my tune
  206. oil catch can or crankcase breather?
  207. Fml
  208. Bolt just spinning help!!
  209. Starter issues.. Please help
  210. Is this normal? (cam question)
  211. Car wont Idle... Stalls out
  212. vented VS. Non-vented Catch cans
  213. life expectancy of evo IX battery?
  214. Mods for SE
  215. MBC hose diameter
  216. Walbro 255lph Fuel Pump
  217. HELPPPPP w/ injectors!!
  218. Help with Code
  219. Clutch Bleed?
  220. Wastegate Creep
  221. head gasket oil leak....
  222. build or not...
  223. mega money turbo gaskets
  224. pulling my motor... help...
  225. HELP rear drivetrain buck during power shift
  226. K1 Lightweight Crank worth the cost???
  227. New Hybrid Turbo
  228. HELP with a starter problem
  229. HELP, things are blowing UP IN MY EVO
  230. Pretty cool veideo....
  231. Backfire problem...
  232. 6 speed transmissions for auto cross
  233. What's a good asking price?
  234. Just wonderingg..
  235. HELP "Transfercase" plug missing..........
  236. EXEDY clutch - whitch to choose?
  237. Looking for your opinion.
  238. Removal of Motor,Tcase, Trans in one shot????
  239. Exhaust Gasket Questions
  240. Lack of crane cam users
  241. MFactory 4.0 Final for us 2.3L stroker guys!!
  242. Is .040 over OK on a 2.3 stroker?
  243. FP RED injector size?
  244. FP red new 80mm compressor cover
  245. Rear Diff Whining??
  246. 4G64/63 power capabilties
  247. Deatschwerks Injector Service
  248. Pros vs Cons of boring your engine!?
  249. help diagnose pls
  250. Last clutch questions before I order...
