View Full Version : Evo Engine / Turbo / Drivetrain
  1. the right turbo for a 2.3L stroker
  2. What more can I do to improve my shifting?
  3. What oil filter do you use?
  4. Do I have a Boost Leak ??
  5. Anyone play w/ BW s300 series turbos?
  6. Solid Lifter Camshafts
  7. Transmission whine?
  8. Clutch Job
  9. Need some answers...
  10. turbo question
  11. what cam's should i get for my 9?
  12. Timing belt loose
  13. how much whp will i get from this setup. do reply plz.
  14. Pics of my new 80mm FP Red and head work
  15. Swapping gears in the transmission question
  16. Tanabe Concept G Pictures (56K fail)
  17. Help with the hotside
  18. Jun BL USA
  19. Stock and leaner tune produced the same HP & TQ curves
  20. Intake question for those running a speed density/MAP/AEM EMS setup
  21. Rod end caps: which side faces the flywheel?
  22. Whos running Kelford 272's on stock turbo?
  23. Hotside V-Band Clamp Torque Spec
  24. fp actuator and profec 2
  25. Modified wastegate actuator
  26. Best Turbo For 06 MR
  27. ACT Street Disc Clutch Abuse....
  28. Maf Sensor Question?
  29. A/C issues..
  30. 35r install. Oil and Coolant Lines.
  31. Turbo Oil Feed/drain lines
  32. A/C Problem
  33. Question about tuning Lancer EVO 03
  34. What bearings?
  35. Car cranks but won't start, Check Engine light blinking...
  36. Having a Problem. Can you Help?
  37. turbo sounds strange
  38. Intake install...
  39. Fp red?
  40. Stock Evo8 Pistons VS Stock Evo9 Pistons (Compairason)
  41. All 3 ACD lights on..
  42. Cruising in 5th gear @ 10.0 AFR
  43. Low oil after 1000miles!!!
  44. evo 1 injectors/fuel rail wont go all the way on
  45. Strange noise when in 1st gear only`
  46. Anyone have a Clutch Masters?
  47. Evo 9 Timing Belt
  48. Battery/Brake lights on..
  49. power steering reservoir cap leaking??
  50. IX and X stock BOVs the same?
  51. Need help, Idle, afr issues
  52. Camshaft Position Sensor trouble?
  53. balance shafts?
  54. Weight of a 5 speed transmission
  55. Engine Overboost code at 11psi??
  56. oo Brass shavings in my oil!
  57. 1st gear is 3rd, 3rd gear is 3rd and then 1st finally comes online after downshift
  58. blown motor, thinking about swapping a jdm motor in the car
  59. Shearer Stock Frame Turbo Tubular Manifold HAWTNESS!!!
  60. 2 very different exhaust systems... but which flows better theoretically?
  61. Cant get into gear
  62. Transmission Fluid Volume Question
  63. Piston Top - Front Marks (Dots) - What do they mean?
  64. o2 sensor replacement for hi rollers
  65. Garrett or Bullseye T04e 50 Trim?
  66. CompClutch
  67. Just bought a QTP downpipe and electric cutout for my 100% STOCK car....Any thoughts?
  68. Question about discoloration on Pressure Plate
  69. Thinking about making a straight pipe TBE
  70. evo 8 evo 9 o2 sensor
  71. TurboXS FMIC??
  72. OEM spark plugs vs others???
  73. Stud Extenders
  74. Car Not Starting after putting HKS exhaust on !! Help !
  75. Samco intake setup for a stock Evo 8
  76. Couple Questions...
  77. Amsoil VS Redline evo8 trans fluid need your input
  78. removing silencer from greddy ti-c
  79. No power to fuel pump!?
  80. guys i really need help
  81. wiseco pistons?
  82. EVO IX MAS Bolts Stuck! HELP!!!
  83. help id this licp??
  84. Wierd clunk
  85. clutch
  86. Need help in installing turbo smart boost controller on evo 4
  87. Non ACD Transfer boxes
  88. Need part number asap!
  89. idle/stalling issues
  90. Sudden jerkiness when let off throttle
  91. Question from a newer owner
  92. blown motor please read, (its not a story)
  93. pressure in rear diff?
  94. evo9 starter on evo8
  95. Has anyone dyno'ed the new Greddy or Titek v2 turbo outlet aka O2 housing
  96. Oil light flickers on and off at idle?
  97. Exhaust manifold......
  98. Evo rear diferentia convertion for mirage
  99. Water temp overheat
  100. fidanza test pilot elect?
  101. Best intake pipe for stock ecu ?
  102. BIG PROBLEMS!!!!!!! I need help
  103. Upgrade 35R or GSC or Kelford cams
  104. VSS bolt size?
  105. this isn't a 9 BOV is it?
  106. how resolve this type of surge?
  107. How to keep the crankshaft pulley in place.
  108. Cam Timing... An excerpt from a friend
  109. acceleration grind???
  110. GSC s1 or s2 cams for fpgreen
  111. Normal Idle
  112. help
  113. problems with my new shep trans install
  114. Look what i did to my front diff
  115. Parts for Evo V-VI??
  116. Overboost Problem
  117. Noob Question about Starter Location..
  118. Did anyone tried Pulstar Spark Plugs?????
  119. Hallman MBC Pro RX ceramic ball
  120. HELP Experiencing Shift Failure
  121. T-bolt clamps
  122. looking for GM maf delete
  123. EVO 7 parts on an EVO 8
  124. where would I find this jdm part
  125. what sensor is this....???
  126. changed the intake and got idle issues
  127. AMS turbo kit problem with hta 86...
  128. are these hks cams?? PICS
  129. EGR Solenoid Removal + Replacement
  130. Oil leak need help!
  131. roller tip rocker's
  132. need wire diagram: evo 9 gauge cluster harness
  133. Anyone running 20G???
  134. stroker
  135. Quick boost question
  136. Wastegate Actuator Arm Came off
  137. sputter / backfire (e85 evo)
  138. Need some help with something
  139. Clutch Problems please help...if possible
  140. reduce hot air
  141. Boost problem. 10 PSI only.
  142. DIY: 35r kit, wisdom from those who've done it
  143. where is ignition power transistor?
  144. metal shavings in oil...
  145. Igniton help!!
  146. Help! Hesitation on throttle
  147. Rattling exhaust problem
  148. 2003 EVO car completey turned off after sharp turn
  149. HELP! no 6th gear!?!?
  150. acceleration problem
  151. Rewire Walbro?
  152. Alternator problems??
  153. HELP!! Can't get into 5th gear
  154. Help with diagnosing an engine sound..PLZ
  155. Need Help ASAP!!!
  156. How different are the Cossworth M2 and Kelford 272 for Evo 8
  157. Tcase install?
  158. Meth Kit or Bigger Turbo?
  159. water pump- oem??
  160. Revolver cam help...?
  161. blown transfer case or not?
  162. Stuck TOB
  163. T04Z Turbo
  164. What PSI Is Safe On 110 Leaded Untuned? Evo IX
  165. Third gear stutter
  166. "Hiccups" around 5,500-6,000 when flooring it
  167. What size intercooler to get?
  168. Cylinder bore type and pistons needed
  169. sheptrans or buswacker???
  170. help plz
  171. Confusing Problem?
  172. oiled filter
  173. P0340 Code. Only...!! no start.
  174. Quick SLAVE CYLINDER question
  175. Greddy V-Spec intercooler
  176. O2 Housing vs. Dump
  177. Oil Line to turbo
  178. Bottom end rebuild questions
  179. Dyno numbers WTF?
  180. Can someone give me pics of stock turbo lines
  181. Tomei vs. BBK Full vs. FP Red Flow -- Flow Data
  182. transmission fluid..PLEASE READ
  183. Anyone using competition stg 4 clutch
  184. So... my engine mount broke, but not how you would expect...
  185. Changing Clutch: What Oils to Use??
  186. New Turbo suggestions
  187. Help with rattle. Not Throw out bearing
  188. Buschur racing 2.3L break in
  189. ACD Fluid rising and falling
  190. Quad Turbo Evo
  191. TC whining and lessons learned
  192. How To Prevent Cracking Aftermarket Exhaust Manifold From Cracking
  193. Spark plug crushed... how bad am I screwed
  194. quick radiator question
  195. bov HELP!!!
  196. Turbo ???
  197. TOB keeps coming off pressure plate
  198. Most def couldn't be happier
  199. Got my Shearer stock turbo header today (pics)
  200. compression
  201. Inline fuel pump...
  202. Clutch Vibration???
  203. aps twin vent bov
  204. School me on the FP Turbo differences
  205. Urgent
  206. aftermarket o2 housing or stock?
  207. Boost Coltroller HELP!
  208. need some info on turbo manifolds!!
  209. Differences between evo 8 and 9 J-pipes
  210. Anyone have info on a borla turbo manifold?
  211. Help!!!!!!!!!!!!!!!!!!!!!!
  212. Question about BR intake filter
  213. random idle problem
  214. 6spd build.
  215. how about this kit?
  216. titek vs invidia 02 housing
  217. Help Engine high rpm knocking
  218. clutch fork!?HELP
  219. Transfer case parts
  220. TiAL BOV Question...
  221. Water pump leak / defective?
  222. Wideband O2 Sensor/Gauge installed in Test Pipe ??
  223. cam question
  224. Stock or Aftermarket?
  225. Need a new clutch
  226. how much whp?
  227. Oil on top of spark plugs?? Help!?
  228. Burning oil, or not burning oil...???
  229. Help starting issues pic inside..
  230. Tial wastegate help!
  231. Ethanol fuel conversion
  232. Evo 9 Intercoolers and Piping
  233. little bit of cam help
  234. ATTN people with 5th gear grind...
  235. Diagram for the Timing belt assembly?
  236. Modding?
  237. Clutch going and flywheel warped effects
  238. Car Stalls When Started
  239. Turbo cant boost....RPM cant go beyond 4000rpm
  240. Anyone do a fuel injection flush or induction service on their Evo?
  241. Does any company make Titanium 3" Test Pipes?
  242. Stock 16G fit on 2005 WRX
  243. 16g turbo
  244. Help with new clutch please
  245. Slave Cylinder(spring inside) Problem HELP
  246. Not boosting past 21psi after O2 Dump installed
  247. Car wont boost...help!
  248. hks 280's
  249. Trans Question Help Please
  250. stock turbo repair?
