View Full Version : Evo Engine / Turbo / Drivetrain
  1. Cel p0137
  2. Service Engine Soon with AEM?
  3. Stock Turbo, Max PSI/Boost?
  4. Anyone using the Dejon Intake tube for Evo
  5. Do I need a fuel pump?
  6. camgear question
  7. stutter at wot?
  8. Are the VIII & IX head gaskets the same?
  9. how to read Check Engine Light
  10. Upgrading help
  11. Boost control question.
  12. Profec B spec II High Boost
  13. TOB clicking when clutch ingaged
  14. evo 8 turbo full bolt ons
  15. power steering gone during a curve
  16. Buscher Boost Controler
  17. Converting to Speed Density on stock IX turbo
  18. Simple break down of what comes stock on evo's.
  19. help needed quick
  20. HKS MIVEC 272/272 Cams, but what about 272/280???
  21. what is the iacv do when it accuates???
  22. 20G compressor upgrade
  23. Exedy clutch upgrade or not ????
  24. Help: Dont have Oem Flywheel bolts (What do i use)??
  25. --- FP Green 73HTA ---
  26. AVCR boost memory
  27. megan test pipe/ stock exhaust
  28. New Exedy Twin Pressure Plate design
  29. wut hp on 2.3 stock turbo?
  30. Need help wiring through fire wall.
  31. Lower IC pipe question, NEW one, I think...
  32. 2.0L OR 2.1L help me figure this out.
  33. What will this do WHP wise?
  34. weird clutch problem
  35. Stock BOV fluttering at altitude?
  36. clutch pedal vibration (help!)
  37. Best mod ever!!!
  38. should I install injectors?
  39. Boosting up to 30psi?
  40. help me
  41. weird clicking sound at idle, help!
  42. Did valvesprings and studs today have question
  43. Engine sputter at WOT?
  44. Let's talk about oil a bit 0w-30 or 10w-60? Stock motor.
  45. Output shaft removal, clutch install HELP
  46. BOV noise
  47. 60k maintenance
  48. Cams on stock Turbo
  49. Magnus v5 intake + Boomba 75mm TB = Problems
  50. Amsoil Intake Air Filter Review
  51. Need Help
  52. People with a v band exhaust...
  53. o2 Sensor = Really bad?
  54. Kellford 272s
  55. ACT clutch kits..
  56. Evo going super slow and throwing MAF codes
  57. How often do you chande your oil on E-85
  58. Clutch Masters New 850 series twin disc?
  59. Is it neccessary to o-ring head??
  60. oil filter housing question
  61. Question about AFTER Turbo Install
  62. 22 psi WGA?
  63. 80mm dia resonator ???
  64. innovate wideband random readings
  65. fp red injector size
  66. act hdss
  67. Where to get 02 Dump?
  68. Missing transmission plug?
  69. Stock Water Temperature Gauge Repair/Replace
  70. transfercase leak
  71. Weird clicking noise when i press gas pedal
  72. Help with MIVEC camgear
  73. Any company make this???
  74. where can I find good lifters for not too much money?
  75. ACT Clutch Problems today...
  76. Sleeving an Evo 8-9 block
  77. So, I switched to AMSoil. Rattle rattle...
  78. spark plugs
  79. Boost leak test... WTF?!?
  80. New noise
  81. Whining noise when AC is on?!?!
  82. hallman mbc question
  83. Methanol Affecting Wideband ???
  84. Spec clutch for evo 9
  85. Valve Stem Seals
  86. Boost for stock turbo
  87. Low oil?
  88. can someone please confirm arp torque specs
  89. Looking for shop.....
  90. aftermarket oil sump
  91. Throwout bearing noise? Could clutch adjustment reduce it?
  92. Install Valves or not. What to use?
  93. Prepping Evo IX For Launching
  94. MBC info
  95. HELP GUYS where is located the fuel filter????
  96. FP Green(16G 10.5) or AP TME 20G 10.5
  97. perrin exhaust/ perrin downpipe. test pipe??
  98. What happened?
  99. Megan DP issues out of nowhere
  100. Balance shaft bearing install, Any tricks?
  101. need Downpipe to match with my Blitz 3" cat-back
  102. Fp green 73hta
  103. Turbo Evo 9 80 series
  104. Wheel hop launch, now I'm binding/popping on turns (help diagnose)
  105. HTA Green vs. BBK
  106. AVCR not displaying boost.
  107. how to wideband?
  108. RC 1000cc OR RC 1200cc
  109. SKUNK2 PRO SERIES 68mm TB
  110. Valve Train Install
  111. I have lifter ticking but im not sure what it could be. i think it may be a collapse
  112. Evo8 vs Evo9 bov
  113. JE Pistons Pro Series FSR Forged Pistons 22mm pin 4G63 DSM
  114. boost gauge and vacuum readings dilemma. car runs rough.
  115. Schooling on MAP Sensor, and Boost Controller, please.
  116. What parts exactly do i need to to have a evo head to run high and high rpms safely?
  117. removing oil pan
  118. Lean, Low Idle.
  119. Anyone have problems with low idle stalls?
  120. Replaced TC, found a leak, replaced o ring and seal....still leaking!!!!!!
  121. Want to change the turbo but without changeing the Pistons and conrod
  122. Low Tranny fluid?
  123. Spark plug recommendations?
  124. problem with evo2005
  125. Red turbo, 80mm w/ 35R blade
  126. Does a short shifter really wear synchros faster?
  127. 5 speed to 6 speed mr tranny question, HELP!
  128. Engine cutting out!
  129. Quick Question
  130. Anyone running this Blitz BOV VTA?
  131. noob question about bov and intake
  132. how much HP increase with cams?
  133. stock turbo, larger intercooler creates more turbo lag?
  134. Willl a JDM altered muffler work on a stock bumper?
  135. Intercooler Questions
  136. timing cover markings help
  137. Car keeps over-heating even after new thermostat, radiator cap, and head gasket
  138. NEED HELP !! clutch not fully engaging..
  139. Did I F up my clutch??
  140. Clutch seized!
  141. SparkTech NONCDI now tested to 700hp!
  142. ???Does the new HTA Green hold boost like the RED???
  143. Best core size for building my own intercooler?
  144. HELP!! Loud knocking from engine..
  145. DIY Transmission Re-Build Tips
  146. $1700, what power mods, why, and where?
  147. What Exhaust upgrades?
  148. MR BOV question
  149. HKS Turbo Kit owners with Cracked Manifolds
  150. sudden bog at high rpm??
  151. color of lightweight shockproof
  152. help weird noise
  153. hot side turbo questions
  154. when does fuel filter need replacement?
  155. *** TAK33r / TAK330r CBRD Turbo Owners ***
  156. Shep conversion help
  157. Power Steering Delete Kit
  158. Cheapest Place to Find Front Wheel Bearing
  159. When you think it's the lash adjusters, but it isn't...
  160. Downpipe hanger Bolt spec's
  161. Cylinder Head Tech
  162. t case/ center diff/ tranny fluid parts needed. sure its been covered. sorryyyy
  163. Looking for a certain type of shift cable bushing
  164. Running @10psi?
  165. A Man, An Evo & 3grand
  166. 780cc enough for red??
  167. clutch upgrade opinoins?
  168. Fuel Cut? Boost leak...
  169. JVT Racing TBE, cheap!?!?
  170. P0420 after running race gas mix...
  171. what should i see for compression? 9 mr
  172. Lesson learned on Boost leak tests
  173. problem boosting past 7psi
  174. LOUD Timing Belt Noise
  175. Evo 6/7 Clutch Issue
  176. Coolant under the car ...
  177. What Donut Gasket for Meagan Racing 02 Housing?
  178. Which one to get?
  179. Should I build my bottom end? Reliable DD?
  180. BOV reccomendations
  181. Potential numbers from decent tune?
  182. Question about Axels
  183. Licp help
  184. Ecu wiring diagram
  185. can i put my ETS UICP in without messing up my tune?
  186. Just installed new clutch/flywheel
  187. Kelford 280/272 Cams on a IX
  188. Need help!!!!!!!!!!!!
  189. FP RED,,,80mm OR 63mm Stock >>??
  190. Piston Choice for Track day / Street 450 hp
  191. What mods to get daily driver 06 mr !!!
  192. Hypertune Intake Manifold + 77mm TB
  193. Started to hear a noise..
  194. ACD lights on / weird warranty issues
  195. adjusting tps on throttle
  196. waste gate set at 15psi?
  197. ATS/Carbonetic clutch
  198. So much for my AMS LICP
  199. HKS cams.. way to identify? 272, 280 etc?
  200. evo 8 evo 9 throttle swap
  201. ACD lights on
  202. Cooling system issues
  203. DV turned backwards..
  204. Is this normal? (pulley picture)
  205. Bloe off valve question. Please help
  206. 2.3 stroker on 85mm bore?
  207. walbro Fuel pump whine Help?
  208. Kevin@MellonTuning's Stock Evo IX Build with pics and DLL dyno numbers
  209. Transfer Case Upgrade
  210. Idle Stays At 1200RPM
  211. Very Helpful BOV Sound Video
  212. Twin scroll vs t3
  213. 02 Dump; EMP Vs QTP
  214. Crower Valve Springs & Ti retainers ??'s
  215. short clutch release rod
  216. Clutch pedal stuck!!!
  217. Turbo Kits.... Which one do you think
  218. Evo engine twin turbo
  219. Lets talk oil quality and why?
  220. 03 evo 8 transmission Problem Help!!
  221. Boost leak locations..?
  222. Transmission inspection cover sealant?
  223. Clutch Pedal Adjustment problem
  224. infamous 5th gear grind
  225. Relocated Battery Now 3 acd lights when running, on= can change setting
  226. ANYONE KNOW HOW I CAN CONTACT Driven Innovations
  227. kevlar belts
  228. What are the specs on a evo 8 IC HELP!!!
  229. What is this part!?!
  230. Another reason I love my wife
  231. transmission leak!
  232. Center Diff Question?
  233. What is the OEM cooling fluid?? What do you use??
  234. Cat Question
  235. HELP transfer case problems!!!!
  236. ac problems!
  237. BBK Full, FP Red... Another Thread!!
  238. Boost trails off after EPM Dump Install
  239. Planning for the future
  240. I need help car wont start
  241. Can 4G63T parts work on the 4G93T ???
  242. Grinding sound in neutral...
  243. which clutch with my red and aquamist setup?
  244. wiped out maf and now car doesnt run right until wot????
  245. evo 9 boost drops to eraly - Help
  246. exhaust mani & 02 housing
  247. squeak coming from pulley
  248. Oil return line leak?
  249. HELP! AEM intake problem??
  250. Stock intercooler sprayer? VIII/IX owners chime in plz.
