View Full Version : Lancer Tranny/Drivetrain Tech
  1. CVT Tranny
  2. Cvt oil!
  3. Trans swap?
  4. Short Shifter and base bushings?
  5. I need a new clutch!
  6. Advice and Opinions are welcomed. Please read...
  7. Upgrades for CVT w/ sport mode?
  8. new ACT clutch!! :D
  9. Trouble getting into reverse and 2nd gear grinds?
  10. Trouble getting into first
  11. tranny fluid
  12. Spec clutches?
  13. CVT ECU hack?
  14. Jerky ride in 2nd/3rd between 15 and 40
  15. Manual transmission - downshifting / Heal and toe rev matching
  16. Using cvt tranny to slow down
  17. RRM needs to make a tranny swap!
  18. About the CVT transmission..
  19. Quaife ATB Differentials available from July 2009
  20. which is better for torque transfer?
  21. belt or chain driven?
  22. RRM Grip Springs
  23. tranny change from automatic to manual
  24. Grinding while downshifting to 2nd gear
  25. * Did Mitsubishi Get the CVT Right?
  26. CVT Trans fluid
  27. Road//race make a lsd already!
  28. Tranny popping out of 1st
  29. cvt?
  30. trans messing up
  31. Stuck on 1st gear
  32. CVT E-Brake Drifting
  33. 3 CVT Tranny's
  34. help in runing 1/4 mille
  35. Will this shift knob fit '08 ES?
  36. CVT Performance?
  37. Auto stick
  38. Park lock on CVT
  39. ~ The CVT Further Explained
  40. CVT Transmission Flush!
  41. Clutches 08 - 09 Lancer On Sale
  42. CVT MODE; When to shift gears?
  43. silly question about CVT OIL!!!
  44. CVT capability
  45. TWM Performance big sale on 2008+ Lancer Short Shifter!
  46. CVT Final Drive "Gear"
  47. Custom Dual
  48. Lsd
  49. Why does the cvt in manual mode doesnt reach redline?
  50. 2 Step/No Lift 2 Shift
  51. Greddy Ti-C Exhaust
  52. ROAD/RACE- CVT Trans Coolers.
  53. CVT- Sport Question
  54. CVT reinforcement?
  55. Outlander CVT = Lancer CVT
  56. Coasting in neutral, brakes failing
  57. Where's the LSDs?!
  58. Traction Control?
  59. Twm Checkered Flag Grand Prix Sale!!!
  60. TWM 2008 Lancer Short Shifter Review
  61. shifting times
  62. Mitsu article - CVT Drivetrain Vibration Analysis and ACS Design (2005)
  63. 08 lancer clutch question
  64. TWM 2008 Lancer Short Shifter Pre-Order!
  65. Fidanza light aluminum flywheel or other
  66. How much to replace clutch in 2008 Lancer 5spd?
  67. BG Synchroshift
  68. CVT, Sport mode or D mode Faster?
  69. Can someone explain this to me?
  70. FWD vs AWD
  71. [CVT] Can you throw the stick from D to sport while in motion?
  72. CVT sputtering
  73. CVT power
  74. 2nd gear grind?
  75. fidanza flywheels
  76. CVT performance programs
  77. CVT fluid change - info?
  78. Performance Clutch?
  79. tranny problem
  80. WORKS '08 Lancer Short Throw Shifter
  81. 2 Drivers - One CVT
  82. Lurching Forward when slowing down
  83. Taking foot off gas when "shifting" with CVT
  84. Need help using the Sport/Triptronic mode on the CVT
  85. CVT (D) vs Sport mode
  86. Best cvt launch?
  87. CVT (Sport) or MT which is faster?
  88. What do you guys think about...?
  89. MT shift knob?
  90. To shift, or not to shift...
  91. CVT Launching RPM
  92. Coasting/Engine Braking with the CVT
  93. Lancer Manual transmission driving techniques
  94. MT Vs. CVT
  95. stalling a cvt?
  96. CVT shift knob?
  97. Short Shifter???
  98. CVT Belt/Pulley VS Chain
  99. CVT & SST, Whats the difference?
  100. Lsd
  101. Paddle Shifter Install
  102. To my suprise...CVT downshift from Auto
  103. Paddle Shifter?
  104. GTS: Liking the CVT
