View Full Version : Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 [2] 3
  1. Potenza RE960AS Pole Position
  2. 18x8.5 +46 with 225/45/18's, will it work!?
  3. OEM X rear sway bar on regular lancers
  4. 09 GTS 16in. wheel fitment
  5. 18x7.5 or 18x8 fitment???
  6. Which lowering springs for 09 GTS?
  7. Strut Top Mount - Part number/replacement?
  8. Slotted Rotors
  9. Black Rims blue lip
  10. 2008 retro projectors installed
  11. Best All-Seasons! I need opinions!
  12. What rim is this?
  13. 18x8.5 +48 fitment
  14. got these springs?
  15. 2008 Lancer GTS OEM brake fluid
  16. Gunmetal or Black?
  17. LOOK what arrived today :D
  18. spray or powdercoat my rims?
  19. Rear Brakes
  20. Different Look For a Lancer
  21. Black On Black GTS Wheels?
  22. Opinion on Wheels
  23. Rota Grid 18x8.5 for the 2008+ Lancer *Concave*
  24. RRM springs ROCK!!!!
  25. 215/45/18 stretch...
  26. OEM SP Sport 5000
  27. 18x8+35
  28. Issue with stock tires, please help
  29. MMR-GT1 (Black) 18x8.5 5x114.3?
  30. Suggestions?
  31. 08 RRM camber bolts
  32. Wheels for 2009 Mitsubishi Lancer GTS [Octane Blue]
  33. RRM Grip Spring ?'s
  34. GSR Mags on Lancer GT 2009
  35. 09 lancer rims
  36. My Wicked White Gts 09
  37. Winter tires and steel rims
  38. Suspension Technical Article - Issue #1 - JRZ USA
  39. Need to shave rotors when replacing brake pads?
  40. Megan Racing Coilovers
  41. 18x9.5 test fit on my car...is it possible?!
  42. B&G Suspension is looking for a test car
  43. Gram lights Time Attack or Silver??
  44. Best size rims for 2008 GTS
  45. Graphite Gray GTS with painted rims?
  46. tein basics!!!!?????
  47. rrm spring install ?
  48. Axis Widetrack fitment?
  49. Endlinks Kaput
  50. Can I use 225/40/18's?
  51. What do you think rims would look like?
  52. Anybody got a pic of these rims on a 08/09 Lancer?
  53. PCD Question
  54. I need help on set of rims/tire!!! on GTS 09
  55. 5-Zigen's installed
  56. Will this setup work??
  57. Eibach Springs?
  58. between the two wheels....
  59. Gold or White rims?
  60. Will this work?
  61. Works Ride springs
  62. 09 Wicked White Lancer - New wheels
  63. Do i need new rotors?!!
  64. Blown struts??
  65. Pulling to the left.
  66. This Brand of wheels any good?
  67. RIMS: which would look better on 08 lancer
  68. High Quality rims
  69. Rotors... FYI they get really stuck!
  70. Killing tires
  71. Best 235/45/18 Tire for 2009 Lancer GTS?
  72. How do the brakes compare to past models?
  73. Just dropped off at my house today
  74. Would these work
  75. Camber Bolts
  76. what do you think?
  77. Identify this car's suspension...
  78. Camber Bolts Question
  79. Will this fit?
  80. Aftermarket wheels worth it???
  81. calibrating tire sensors???
  82. Lightest 18" Rims on GTS ?
  83. Interested in painting calipers?
  84. Stock airbox with RRM Strut bar?
  85. Suspension Upgrade
  86. 2008 Lancer alignment specs
  87. gts with stock black rims?
  88. 2009 GTS 5 Speed Steering & Suspension Upgrades?
  89. Eibach Pro & Sportline Kit
  90. Nail/Screw In Tire, Is It Covered?
  91. AM wheel problems??
  92. Works springs alignment
  93. Which wheel set would you consider for the evo x conversion kit.
  94. 4200 miles and i need new tires?!?!
  95. Are stock rear shocks adjustable?
  96. Stock GTS tire thread, pull to the left ?
  97. Help - Tire Rotation
  98. What about these Pirelli tires?
  99. ROAD/RACE- Worked with TEIN last week
  100. Knocking after Installing H&Rs
  101. Hub bolt broken
  102. RRM Springs Pictures Tommorow!
  103. Megan Coilovers $850 Shipped!
  104. 2008 coil overs from Megan Racing
  105. Road///Race - 08 Megan Coilovers
  106. 08 Lancer LSD
  107. Works spring/swaybar installed - review coming
  108. Should I consider lowering my Lancer?
  109. Big rubber for 08 ES - fitment question
  110. Removing center cap on stock GTS wheels
  111. DBA Rotors???
  112. V2 G.R.I.P. springs RRM
  113. Will These Fit?
  114. Wheel Spacers
  115. 2008+ Mitsubishi Lancer Progress Lowering Springs
  116. Caution GTS owners
  117. Powder Coat My Rims?
  118. Stock EVO X wheels
  119. G.R.I.P springs?
  120. Will you guys do alignment on tire change?
  121. 30mph pass thru the speedbump Nooo
  122. RRM Upper Strut Bar question...
  123. Already lowered but wanting to drop an extra inch
  124. Improved Handeling
  125. Brake pads...mmmmmm
  126. Tenzo Type-M
  127. Drop/Tire Question
  128. Changing Rims/Tires
  129. RRM Slotted Disc Brakes/Pads/Braided steel bake lines
  130. Tenzo DC-6 Version 1
  131. H&R Lowering springs
  132. 18" x 8" Too Wide??
  133. Strut Tower Bars...
  134. Need an opinion on a rim Company
  135. Progress Technology Sport Springs
  136. rattling noise
  137. Lowering Springs
  138. Possible rear endlink upgrade?
  139. Coilovers?
  140. 04-06 RalliArt Rims on 2008 Lancer?
  141. Hit a Curb
  142. Price of ES Rims
  143. Vibrating steering caused by suspension?
  144. widest rim set up?
  145. 18x8 Axis Penta
  146. rota wheels
  147. Tein H-Tech Lowering Springs for 2008
  148. Chrome stock GTS rims?
  149. Brake Lines
  150. Braided SS brake hoses - interest?
  151. rear sway bar
  152. Question for ES owners!
  153. Valve Stem Failure = Flat Tire
  154. Control Arm
  155. BBS Rims?
  156. Tanabe Springs
  157. What are your favourite rims?
  158. Buying Advan RS wheels
  159. Lancer DE brakes
  160. What's happening to my lancer when I shift from 1st - 2nd gear?
  161. RRM Rear lip spoiler
  162. 18x7.5 38mm offset.
  163. Will 17x8 +35 with 245/45/17 work?
  164. brembo brakes
  165. Lugnuts - Thread size/pitch?
  166. Biggest wheel's for GTS
  167. EBC brake pads
  168. Smallest rim
  169. Brake Truthiness
  170. APR front splitter
  171. Wheel coming loose
  172. Chassis Truthiness
  173. Works rear swaybar
  174. DE/ES owners - what tires?
  175. X rims
  176. Coilovers installed in my 08
  177. So the Evo Vortex Generator does fit on an 08 Lancer?
  178. TPMS - the ultimate FAQ
  179. Help me decide on rims for my DE! 17x7"
  180. Tire sensors on new wheels
  181. WORKS Adjustable Rear Sway Bar
  182. Rally Innovations
  183. Where to buy stock 18in. GTS rim?
  184. Rally inspired?!?!?!
  185. GTS Recommended Wheel/Tire combo
  186. First time in the snow with my Lancer DE (16" factory tires)
  187. Tire sizes and stock rims
  188. Low offset wheels on the GTS
  189. First winter snow + ice = Not fun
  190. My new Katana's GR4 wheels , pictures
  191. 2008 Lancer LSD
  192. 16" wheels ruin brakes on the GTS???
  193. Springs/Coilovers
  194. ~~~ Fighting Winter with WinterForce Tires! Review
  195. ROAD/RACE-GRIP springs Improved.
  196. Offset question help
  197. Tire questions
  198. Strut bar
  199. Best Lowering Springs for 08 GTS?
  200. New Rims
  201. ROAD/RACE- Big Brake Conversion 2008
  202. Big Brake Kit!!!
  203. RRM Camber kit
  204. Running 14's or 15's for autocross?
  205. Brakes, stopping distance, and weight
  206. EXTREMELY Bumpy Ride? new UNHAPPY GTS owner...
  207. Installed: Tein S-techs
  208. Mazda 3 rims on GTS ?
  209. rims size and tires for 08 lancer gts
  210. Balancing Chassis Rigidity with Suspension Stiffness
  211. help with lowering from people w/RRM springs
  212. Plan on Painting GTS Rims?
  213. Rim Sizes?
  214. WORKs springs installed
  215. Brake Pad Compatibility
  216. Anyone running Tein H Tech Springs?
  217. These should fit?
  218. Custom Suspension Group Buy?
  219. T. P. M. S.
  220. Need new rims...from Canada help
  221. New Rim+Wheels
  222. GTS 18 inch wheels, READ THIS!
  223. Finding Tires
  224. New Wheels - Decisions, Decisions
  225. RRM Upgraded Brakes
  226. something is really weird with my car (tpms)
  227. Eibach Springs for 08 Lancer
  228. ROAD/RACE-08 Lancer FRONT STRUTBAR READY
  229. 17" White Advanti Racing wheels.. any good?
  230. Tire brand?
  231. Winter tires
  232. TPMS warning and Stock Dunlops
  233. - Wheel Purchasing Info. -
  234. Huge 08 Lancer News!
  235. Tire Pressure Sensors
  236. 16" Wheels on GTS question
  237. rrm springs
  238. A question concerning rims...
  239. GTS rims no longer being made
  240. Will the 18" rims fit on the ES?
  241. WORKs Springs Evaluation - 2 Parts
  242. 2008 aftermarket suspension & brake parts list
  243. In Love With My Works Springs
  244. vibration....
  245. TPMS on aftermarket wheels?
  246. Wheel Noise
  247. Evo wheels on an 08 Lancer
  248. OEM Evo IX brembo set, do they fit?
  249. What torque for wheels?
  250. Powder Coating Rims: gunmetal
