View Full Version : EcuFlash
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. where is the Evo 8 ECU pin removal "how-to" and map switching harness?
  2. AT/SST/CVT MUT communication
  3. modifying tehra patch
  4. rc 550 votaje latency compensation ecuflash
  5. live map apps
  6. Fuel trims
  7. '03 Evo Starting Tuning
  8. Mut Sniffer
  9. Anyone have evoscan v2.7b1-4?
  10. Is this just a dream of mine or can i get this in my car
  11. ecu flash and gm maft how would you tune?
  12. ECU Flash Problem
  13. Low Load/Cruise Timing?
  14. Universal USDM rom
  15. ecu periphery2 6FDF
  16. JOT Virtual Dyno Room max rpm Question
  17. Urgent! need help!!
  18. Quick Periphery Bits/lean spool question
  19. wastegate duty deactivation RPM doesn't work?
  20. leanspool tables
  21. who has evo8 ECU pins??
  22. g/rev Scaling
  23. JDM 8 MR read template
  24. Serial port with Evoscan...
  25. lean spool or not to lean spool
  26. Boost problems
  27. Dual ECU
  28. AEM 30-5130 gauge serial hookup...
  29. AEM wideband and EvoScan issues
  30. Going Lean ???
  31. #65 pill and 44mm WG
  32. New thread for Speed Density tuning?...
  33. How do you learn to be a developer?
  34. Maf temp adjustment table
  35. DataLogging with Custom Gauges
  36. phantom knock on shifts how to fix
  37. turn off oil pressure light
  38. Ecuflash for 09'+gtr?
  39. Help: Evo IX running lean, stock MAF/Injectors
  40. Differences in Peripherys v7
  41. logging boost with aem tru boost
  42. Knock is back...WTF?
  43. TephraMod Knock CEL Flash discussion
  44. Upgrading Rom
  45. effect of degrading CAS on data logs?
  46. Auto Tune Program [Dev]
  47. logging boost with jdm evo 7
  48. 2byte load logging issue..help
  49. Getting desperate here....
  50. Ralliart Thermostat = change temp scale?
  51. MAF scaling or injector scaling/latency
  52. question.. lookin for some opinions
  53. timing recomendations log attached
  54. [Disassembly] Periphery Deciphering
  55. Idle Stability Control Table Q's
  56. rpm and load values are random please help here is the rom a xml if anyone can fix it
  57. HELP ! ! ! - EVO 7 - RICH .... :( other problems
  58. Boost Tuning Help
  59. Map interpolation using a flex fuel composition sensor?
  60. What reflash cable do you guys use?
  61. v7 + closed loop wideband or something else incompatible?
  62. anyone care to help me out?
  63. EvoScan: 0% throttle = 13.73???
  64. is 62500 baud a must for 2 byte load
  65. jdm injector scaling and latency
  66. xml needed for JDM Evo 7 RS
  67. help plz
  68. anyone with 90550001 2 byte table
  69. new live map app
  70. CEL( 3 Codes)
  71. SVN repository online! All XML, ROMs, tools, spreadsheets go here!
  72. Ecuflash Expert, please help and guide me. Thanks
  73. Having trouble reading ECU with Ecuflash
  74. Need v1.3 of Ecuflash
  75. Advanced fuel control options
  76. Updated From ECUFlash 1.29 to 1.42, Can't Connect
  77. Speed Density airflow difference
  78. flashing 09 lancer de?
  79. please help!!!
  80. confused with load and RPM scales
  81. 2010 Ralliart ROM help with logging in EVOscan?
  82. turn off knock sensor
  83. PWM routine: what is it all?
  84. Need Help, got error message while reading EVO 6 JDM ECU
  85. Rich Idle questions.
  86. Idle Issues
  87. Intellectual Property
  88. need help guys!!
  89. Can anyone transfer my tuned rom to tephras v7?
  90. throttle hang and enrichment
  91. What can I, David Buschur, do to help?
  92. stock ecu speed density from a vendor
  93. I need definitions for this rom 90160003 please!
  94. Symptoms of bad/faulty knock sensor
  95. Defogger / defroster to start/stop logging.
  96. What could be the problem??
  97. V7, Twin Solenoids and Altmaps (88570008, 96260009, etc)
  98. 88590015 fuel maps
  99. Warm start Idle issue...?
  100. Help with idle and CEL issue
  101. Front o2 sensor probems
  102. EVOscan.... other loggers work better?
  103. [Dev] SH2 disassembler
  104. Evo 5...where do I plug the tactrix cable??
  105. PSI Based Boost issue...
  106. n00b Here: 96940011 Serious RPM Hang
  107. Is my Tactrix Cable busted?
  108. FIC Easytune
  109. Need 2004 stock rom
  110. When cold it sounds like it has an exhaust leak.....
  111. Speed Density tuning an EVO8 w/dyno sheets
  112. 94170015 and 96530006 xml files
  113. Need tactrix cable
  114. launch maps
  115. Injector latency base?
  116. Please Help, Bricked Evo X ECU via EcuFlash
  117. ECU Flash on 2010 Ralliart Sportback.
  118. EVOscan problems
  119. 2step not working,, 2003 evo..
  120. Coil Dwell on stock ECU...again
  121. new EvoScan to Logworks file converter
  122. TephraMod V7
  123. Not scaling injectors..and fail emissions
  124. Rom 94170015 questions
  125. Fixed boost leaks -> Now Very Rich
  126. Poor Cold Idle (Yes I searched)
  127. Hard to shift at 8k rpm for my JDM Evo 9
  128. 90550001 xml
  129. Are my logs and power OK for my mods?
  130. Decel Fuel Tables and how they Work
  131. Fuel Trims
  132. PTE 1200 Fuel Trims
  133. Rich after throttle released
  134. How to Log AEM UEGO in Evo Scan
  135. Problem with evo 9 (huge fuel consumption and P0170)
  136. My car will not idle
  137. Interpolation vs Resolution
  138. EVOSCAN and Map trace ???
  139. Knock Filtering?
  140. Tephra v7 9653 thottle hang
  141. GM BCS issue.
  142. Correcting a few 96530006 definitions
  143. What other tables use the same values as MAF Scaling?
  144. Problems with - Full Time Open Loop
  145. Tuning JDM Evo 7
  146. Tephra BIGMAP table size?
  147. Ecuflash doesnt find definitions
  148. 7 ECU -> 6.5 Car (EGR + EVAP CEL's)
  149. Car got over 1 point leaner at WOT
  150. Load based boost help please
  151. wgdc wont move?
  152. Success w/ 94170015 fixed a couple issues; driveability + knock
  153. Evoscan and Innovate LC1
  154. op2.0 problems
  155. Help making graphs
  156. Getting started ???
  157. Is it advance or base timing?
  158. error retrieving rom from jdm evo 9 rs
  159. 97250001 Load calculation problem..
  160. AFRs rich after EGR enable/disble patch...
  161. Speed Density Issue
  162. tactrix cable
  163. wierd ecu issues....
  164. high timing during cruise that i cant change.
  165. LS disable for 94170015 ROM
  166. JDM 3 Bar vs OMNI 4 Bar
  167. ecu flash for mac?
  168. no honeycomb
  169. 2 step help
  170. Speed Density Problem
  171. anyone got CORRECT xml for 98640014 and tephra mod for that?
  172. Adding load columns and RPM rows to maps
  173. how can I get into the evo V ecu...
  174. First time Logging with Question!
  175. Anyone unplug their factory BCS and disable the P0248 CEL?
  176. ecuflash cant read Ecu evo 8 2003
  177. need help!!
  178. Software fix for P0136
  179. ECU ROM mod - double the "Fuel Cut Load Limit" range to 638
  180. openport 2.0 SD flash card logging?
  181. evoscan maptracer
  182. ECU boost users - Do you want a higher boost cut load?
  183. My tuning/logging netbook for sale
  184. do i have to delete xml file to change patch
  185. mut table question
  186. warm up afr
  187. What causes backfiring?
  188. Help - 2001 JDM EVO7
  189. Stat rev limiter - evo 6/7
  190. Password on evo stock ecu
  191. Asynch SD Tables
  192. Placement of MAT for SD with Water Injection
  193. Another idle question
  194. Knock
  195. Alt MAP= Main Map
  196. [Dev/Disassembly] The beginners' guide to Evo ECU table lookups
  197. Open Port 2.0 Purchase feedback
  198. ECUFlash / Vista64 fails to read previously flashed ECU
  199. EcuTek to EcuFlash???????
  200. fully defined 94170015
  201. What maps are affected when scaling is changed
  202. missing tables in ecuflash?
  203. Fuel trims LTFT Low, Mid not adjusting now?
  204. MAF Hz and Load spikes at idle QUESTION ? ?
  205. MAF Scaling and wierd numbers
  206. ECU Based Cruise Control...Plausable?
  207. Anti-Lag Two-step
  208. Tuning for different altitudes & air densitys
  209. Cool link for injector latency
  210. Alternative Map in the Traphra mod v5.10
  211. HELP! I need a 2003 Stock Map!
  212. Does your check engine light flash after tephra mod
  213. EVO X 53040010 XML file needed
  214. Openport 1.3 Unversal
  215. Using lean spool tables to match AFR's
  216. Alternate Map for tephra mod v5.1 9642001
  217. BlueMUT - logging via cellular
  218. New help finding some maps in two ROMS
  219. tuning problem with evoscan
  220. tuning questions
  221. Why big cams throw a P0300 code?
  222. timing during spool up
  223. ecu unlocker compatibility with vista
  224. Has rescaling your load caused the car to bog when the engine is cold?
  225. Rear O2 disabled thanks Mr.Fred
  226. 22.5 PSI vs. 26.5 PSI pump gas results
  227. Any one know what this Unit is?
  228. trims logging, strange values
  229. Help me to identify this connector
  230. Clean in 3rd, Knock on 4th
  231. converting 99860002
  232. Not scaling injectors???
  233. All bow down and give praise to the great disassembling ones!!
  234. Logging EGT via EcuFlash
  235. Definition File needed for EVO 8
  236. MAF Compensation Table
  237. knock tuning.
  238. ID2000 scaling and latency
  239. need help on which periphery bits to enable
  240. installing a GM 3-bar MAP sensor
  241. Major problem with my log *Please Help*
  242. How to set address?
  243. Will I have To Tune Again?
  244. Is this normal while logging Speed
  245. I think I may have found a new 3port boost solenoid...that comes on every EVO
  246. No activity from fuel trims
  247. Rescaling question
  248. 880cc Injectors installed. Scaling and STFT confusing
  249. Logging problem with Evoscan 2.6
  250. help ME open it
