- JDM 3-Bar Map Sensor Group Buy #2
- Crazy Map issue
- Help: EvoScan .99 not logging certain parameters and fuel trim question
- how to log from the odb with logworks
- Dataloglab results from a newbie
- 10.0 and 18.9 idle drops, Im rdy to blow this thing up!! Need some help
- Please help me understand Boost Error
- Random thought on rear O2 readings
- HowTo: Identify Diagnostic Cables by PinOuts.
- tactix cable / jumper question
- Ralliart rom & Engine fan
- +25 hp & 17 ft-lb from Cosi cams with ECUflash
- ECUFlash 1.35 Trys to read ecu and freezes
- ECUFLASH 135 error loading FTD2XX.DLL
- how powerful of a laptop needed?
- How is 2-byte Load found?
- Evoscan v2.4 fixes
- re-flash question
- 99860002 JDM7 To 99270000 EDM8RA Dilemma
- deleting rear o2 and NO CEL light.. little right up/how to
- explain my log
- now simulating front O2 signal using WB signal
- AFR Problem
- I need your opinions on my log....
- Cannot connect to vehicle interface!?!?
- Knock free on 3rd but knocking on 4th
- Wideband O2 Questions
- thinking about ditching my LC1
- Why to log the Battery Voltage on EvoScan?
- roms and tephra patch
- ecuflash x&y wrong values
- How can I increase EVO IX Lauch Control Limit?
- Quick question on GM 3 port boost solenoid
- Rom routines - Tephra Mfred etc etc
- tatrix cable not working and im getting pissed
- How many of you run MAFTPro/ECUflash
- ecuflash dies again
- 9gsr, flashing any rom
- what to log??
- 03 Evo 8 Tune Help- Fuel-Ignition Map
- rom 94170015 and V5 patch.........
- i need ecuflash 1.29......... someone link me
- EGR removal and CEL
- Is WGDC Correction acting correctly in this log?
- how long to get a evoscan ticket query back?
- question about latency
- 16g Choke Flow?
- have problem with knock retard
- stock cold start rpm is too high
- IX running rich, changes to fuel table not working
- Strange ECUFlash crashes
- Innovate LC-1 Install & Location
- Unknown Rom Definition?
- AFR #'s for completely stock IX?
- knock sum 22 , what did i do wrong
- rear o2 sensor patch / help
- Evoscan 2.4 my coolant and air temp logs backwards - need fix
- Turning off knock sensor under certain conditions?
- ALL DIY'ers: READ THIS
- Need opinions about my "hot lap" logs
- Asus Eee issues
- 10 knocks at 2843rpm (stationary)!?????
- LogWorks 3 released
- how-to: Log AFR from the LC-1 w a serial cable
- Mitsu loger
- Patch needed: run less than -10 degrees
- swapper ecu?
- ADC Inputs - Which ones can we use and how can we use them
- tactix cable ?
- Can't log data with EvoScan on IX MR
- 400hp EVO's need help
- EvoScan Logging a single load cell
- log boost on uk jdm E8 (with no map sensor)
- New Motor Build, Looking for Tuning Advice..
- ECUFlash 1.35, EVOSCAN 2.X, and EVOSCAN Flashing Cable (universal) - Cannot connect
- How do I download the new Evoscan?
- Ecutek has a lock on my ecu?
- what do you think?
- Which gauges to trust; dyno or self gauge?
- Higher boost = lower timing?
- Need help with EVO 9 RS EDM ROM
- Evoscan
- not feeling the love for open loop cruise
- disable rear o2
- Open loop cruise creates missfire when leaned beyond 15.2
- vista 64-bit and evoscan and ecuflash
- Tuning issues; car won't lean out?
- will a tune with no mods make a gain?
- Innovate LM1 "Cuts-out" while logging Evoscan 2.3
- Please help!!! Evo IX stucked in Canada.
- wideband wont log afrs in evo scan
- Basemap for Cossie M2's
- evoscan not connecting???
- OpenPort 2.0
- Patch for Failsafes on stock ECU
- stock map thread
- Innovate Wideband working, but not logging correctly
- Data Junkies - One Lap @ Redline
- Safe Boost for Stock Turbo
- Odd injectors ...
- PTE 1000cc scaling?
- Ecuflash 1.35 cant reflash
- Log Plots of EVO 8; Do they look OK?
- EeePC true test...
- evoscan user manual/guide
- Question from the new ECU flash/Mitsulogger user
- GURU's please look...36 knock counts!!
- Knock Sum
- idle afr
- How do I make sure all drivers are deleted?
- new cam now car won't start
- Idle and cruise AFR
- Having a bad p0300 issue lately...need help
- hks blowoff on ecu
- evoscan/ecuflash noob with question
- MAF scaling with a wideband - am I doing it correctly?
- Jumpy AFR's at low load
- need to save money, writing patch to control closed loop with WB
- evoscan calculate hp/tq
- ecu flash wont read my ecu
- Log Viewers!! Which one is best??
- noob ecu awareness
- Formula for Airflow in lb/hr?
- Log help
- Where to get Data Log Lab?
- Data Junkies + DLL dyno surprise
- always some knock in the first pull when tuning
- Map Switching and Me
- Tactrix Boost Control Solenoid (Plug-n-Play for Mitsu)
- cables
- a/c idle problems
- ecuflash first use
- Running lean @ high load
- Noob needs help
- 96940011 issues
- Need Opinion on Logs
- Newb Need Help
- Here's a wierd one for you...
- You know it's warm out when...
- fuel cut problems
- Jdm Map & Egr
- Evoscan 2.3 released.
- Comparison graph of boost before and after O2 and Manifold install (91 octane)
- Problem between 2500-3000 RPM
- Need some guidance
- New injectors = adjust your IDC alky trigger ;)
- Evoscan wierdness
- Gtech or DLL
- Evoscan not saving Datalogs?
- evoscan v2.2 question
- New input on EGTs
- timing at idle help
- Pin for ecu clutch position sensor
- Beginner tuner here in need of advice
- starting up new 2.3L for the first time
- Best place to mount knock sensor
- Need help tuning!! Cash Paid for services!!
- AEM Wideband.
- TephraMod V5 88590015 - Evo 9 - Help
- Adjusting Cam Lope
- IPW Formula
- LC-1 Access denied Evoscan
- LTFT Maf Scale
- which is the best evoscan
- what is wrong with my ECUFlash?? Someone help...
- Question for tephra, others. RE: map header addition factors
- boost at twostep launch
- o2 sensor fix w/ ecuflash?
- Can Fuel Trims be Perfect?
- AirflowMUT2byte
- Meth Fuel Map---is this look correct?
- Changing the Int ID
- Hot air causing knock?
- TPS 98% + IDC Accuracy
- Fuel trims
- JDM 3 Bar Map Sensor Group Buy
- JDM 3bar MAP Sensor + Evoscan 2.2
- Injectors Scaling
- MAF Scaling Document Inside
- need program for tactics cable
- Cant get any more timing??? Logs & Pics
- Fuel Trims are NOT Changing...Help
- Help scaling MAF
- how much do you set the Low Fuel Maps from the High Fuel Map?
- Map changes during a tune
- Mitsulogger help
- Evoscan Issue (Ecuflash works)
- Limp mode
- Evoscan Log Order
- ROM read & write error.
- calculating MPG and AFR
- Patch Idea-gear dependent boost
- E7 ECU in E4,E5 & E6 Stat limit probs 90550001
- Idle troubles
- evoscan question
- FIC 1050s installed today - observations and a question
- Mut Table question.
- E-85 Questions
- fuel and ingnition map
- Stock Evo 9 rom
- Can I open a map without hooking into car?
- Suggestions to improve efficiency to minimize knock and maximize timing
- Injector Duty Cycle
- Evo 10 - Ecuflash - 3 tables
- Ok thinking of ECU controlled boost
- ???Is an EMS neccasary for this?
- EVO VIII mapping questions
- max hp with stock ecu
- Magnus or any other SMIM with OEM ECU
- Data logging
- EcuFlash v1.35 no read defintions???Help...
- new mod idea - need technical assesment
- Flash Counter
- quick help with TephraMod V5
- Hks Eids
- norcal evo ix swap project help...
- Help with evoscan and LC-1
- What do we know about knock control?
- Patch request discussion: rev-down maf clamp (stalling issue)
- TephraMOD V5.8 - testing help required
- Let's see your lean spool disable Fuel Maps
- innovate, MACs and tuning! Is there a way?
- Evo 9 still knocks on racefuel??
- How accurate are the whp/tq/lbmin/airflow readings in evoscan
- Do “reputable” tuners use lean spool disable
- Phantom Knock on my IX...
- updated xml for 99860002
- Doubt about ignition advance in a tune
- Cel Light Removal
- 96420008 rom
- Buschur intake pipe
- some general noob question on EcuFlash
- evoscan 2.3
- Openport 2.0 - June 15th
- Project87
- Tuning for improved highway mileage
- I need ECU help guys
- EvoScan and ecuflash on linux
- Limits/Stationary Rev Limit/
- ECUFlash+Evoscan+Cable+WhichO2???
- Tune AFR to 12.5
- I need a working copy of Ecuflash v1.35
- Review/Advice Before Tuning (log attached)
- Weird injector noise when I flash my car
- How-To: Rescale your MAF (without pics)
- Higher than 319 boost limit
- going crazy.....
- EVO 8 stalling and idle issues
- ECUFlash XML's
- Load = performance???
