View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Logworks or Evoscan maptrace
  2. MAP switching issue on Evo 9
  3. EvoScan 2.5 + LM1 = no reading (but EvoScan .99 is fine)?
  4. how-to: control closed loop AFR with your wideband O2 system
  5. aquamist hfs1 + tephra mod 5.10 problem.
  6. How to tell if your tuner ripped you off
  7. need the XML 88580015
  8. Tactrix Cable
  9. 2 byte clarification
  10. Stock tune + 15% displacement. Will it run?
  11. Is it possible to log with Openport 2.0
  12. Tuned car and now it won't start.
  13. Boost control tables
  14. Idle issues
  15. MalibuJack HELP!
  16. FIC 1150 injector latency times but what does it mean?
  17. Question about 2-Byte Load and MAF Scaling
  18. Very Odd P300 Issues ... any insight?
  19. Evoscan & Evo 6
  20. Immobilizer issues?
  21. Evo 6.5 Help
  22. Ecu boost control (solenoids "?")
  23. injector scaling help
  24. OBD-II tables (ecuflash 1.38)
  25. Logging other Innovate sensors trough Evoscan?
  26. MAF Scaling and size findings.
  27. how to control boost through the ecu
  28. Race gas map??
  29. Evo Scan 2.5 Issue suddenly
  30. Software question?
  31. Low load timing not matching your maps?
  32. Extension Cable for OP2.0?
  33. Wierd problem after clutch line install!?
  34. Anyone understand ICS maps?
  35. Ignition map help.
  36. Stalling issues..Mind looking at my maps?
  37. Rom ralliart and cams brian crower 272/272
  38. not sure whats going wrong....mitsulogger won't log correctly
  39. need help fast
  40. ECUFlash 1.38 cable fix.
  41. bad log results!!
  42. No communication with ECU through ECUflash, EVOscan
  43. knock sum count
  44. Greddy Solenoid & ECU control?
  45. Definition creation help for 01 Mirage
  46. My car was un-tuned
  47. Equipment needed for tuner?
  48. Dell Mini... anyone use it?
  49. ACD and ABS flashing
  50. Fuel trim scaling
  51. Major fuel economy issue
  52. Which Map do you guys need to help?
  53. ECUFlash 1.37 cable fix
  54. $$ Anyone with latest Evo7 JDM Definition file please
  55. It's alive! (Speed density, stock ECU)
  56. TephraMod O2 Simulator
  57. No Injector Duty Cycle data
  58. EcuFlash Version 1.37 released
  59. 88590015 Evo Live Map - source
  60. Status of fuel trims after reflash - VIII vs IX
  61. MUT Requests to monitor processor IO ports with SH based ECUs
  62. 90550001 v5.10 Weird problems..ideas appreciated
  63. v1.35 graph viewing issue
  64. 88590015 Evo Live Map - ROM and software
  65. HELP needed, please read
  66. PTE 1200cc scaling/latency
  67. Talk about knock...
  68. help with lean idle
  69. Huge knock count during cruise
  70. Pump gas record?
  71. How To Log
  72. EGR CEL Removal Code Question
  73. Evo 8 Reflash went wrong.. HELP
  74. Dataloglab evoscan 2.5 definitions?
  75. Air Temp Comp/Tables for E85
  76. LTFT Mid Issue scaled maf
  77. can't get the throttle to stop diping
  78. Confused about my Fuel Trims
  79. The "Ive upgraded my injectors and I still have niggling issues" Thread
  80. new feature in ECUFlash 1.35: periphery bits
  81. Knock Filter 1 is Purge Control?
  82. Anyone got the link for the EvoScan/Lowworks How to?
  83. Put in cams now runs lean
  84. rough idle on hot startup
  85. Logging LC-1 with EVOScan? - help
  86. Changing values w/ certain modifications.
  87. Evoscan to datalog before tuning?
  88. am i running out of injectors??
  89. help with 1000cc injectors
  90. EvoScan Registration
  91. EVOScan reading a/f in V?
  92. How do you change the color schemes in ECU Flash?
  93. Quick qusetion about evoscan 2.4
  94. EGR Solenoid as a 3 port option?
  95. lean out = massive knock
  96. Evoscan Request Numbers
  97. Boost Desired Engine Load?
  98. What is the point of this timming block? Pic
  99. Evoscan serial number problem???
  100. Self Tuned
  101. Too lean?
  102. Car shuts off/ Bucks at 60% throttle 2100 RPMS 6 psi boost
  103. Stepper table question
  104. ECUFLASH cable
  105. Anyone interested in Disassembling an Evo 5 / 6 Rom ?
  106. My AFR. Please comments, Advise and Solutions
  107. Strange Looking ROM tables, any help??
  108. question about lean spool
  109. First Logs with WB (weird knock up top)
  110. Detectability
  111. I need someone to host my logs
  112. Yesterday run my Evo8
  113. Need help Controlling Boost with GM Boost Selenoid
  114. Fuel Trim Issue Post Cam install
  115. installing LC1
  116. can i bring my fans on earlier?
  117. Will Evoscan support Openport 2.0 Cable?
  118. Bigger injectors?
  119. EVO 7 GT-A ECUFLASH Problem
  120. Tactrix cable doesn't work
  121. Flash evo Youtube video
  122. Map confusion
  123. New Maps for Evo 7 and 9
  124. Another idle problem with A/C on.
  125. anyone in phoenix area????
  126. Looking for a stock map
  127. Low RPM Issue
  128. downloaded the AYC/ACD ROM
  129. Map sensors and difficulty tuning
  130. My first shot @ it!
  131. Tephra!
  132. Autosmoothing tool for Fuel and Ignition Maps
  133. Original ROMID
  134. afr & timing
  135. Dyno tuning; tail pipe or LC-1 best?
  136. Knock on Deceleration?
  137. Looking for help, running off the map
  138. Help Reading Rom
  139. 4K RPM idle
  140. Engine Load %
  141. evoscan, can't open logs w/excel
  142. 1000ccs on stock ECU
  143. Anybody pass emisions without a cat?
  144. IX won't connect to PC?? experienced tuner can't figure this one out...
  145. 36 counts of knock...scary!
  146. High/Low Octane Fuel Map confusion
  147. AFR advice please
  148. having problems with knock
  149. USDM EVOX map offsets
  150. Can Anyone In Jersey Give me a temporary Street Tune?
  151. You and your load......
  152. Zeitronics and Evoscan ?s
  153. ECU Pin 38
  154. flashing back to stock..
  155. Definition of Load?
  156. 3rd gear Pull very quick "hiccup" / pop???
  157. Need Addresses for Lean Spool Start/Stop for 94170015/14
  158. Solution for ECUFlash 1.35 freezing with 100% cpu when reading/writing rom.
  159. which logger works with mac?
  160. Problem reading ECU with EcuFlash
  161. Separate ignitor/coil setup than works on Stock ECU :)
  162. Need help with my logs...(how to start with new mods)
  163. is it possible
  164. disable o2, Version 1.35.1650?????
  165. Smoothing your tune with graphing
  166. Please take a look at these logs
  167. Shift Light in cluster?
  168. Possible BOV issue?
  169. LoadMut 2-Byte doesn't fit with the Ignition (ROM)
  170. My Fuel And Timing Maps Please Take A Look
  171. Fuel trims...again.
  172. Bulletproof tuning for track use
  173. TephraMOD V5.10
  174. Do I have a boost leak? log graphs attached...
  175. NLTS boo boo.
  176. This rom any good?
  177. innovate lm2 and datalogging
  178. Minimum Temperature for Boost Control?
  179. car stalls with a/c on
  180. Carbon fouled plugs after a short trip...
  181. WB instead of front o2 -> tephra, mrfred et al.
  182. EGR Solenoid Loggable?
  183. Dynojet versus Dataloglab graphs
  184. Stock Evo 9 IDC's
  185. need help with 3bar Map
  186. Can't log WGDCCorr
  187. Fuel trim ?
  188. Bad Gas???
  189. log request: stock evo 8 low load
  190. Evoscan 2.5 and fuel trims.
  191. ICS relay pinout for Evo8?
  192. A/F at idle is WAY lean
  193. Anyone Forged and Logging with EvoScan?
  194. EVO Scan Wideband AFR Log fixer!
  195. evo scan 2.4 question
  196. flashing check engine light but not constant...
  197. HHO and Dyno Tune
  198. Br350 evo 9 will not read rom
  199. Need some help with GM Boost Control
  200. Openport 2.0 Cable, Aktivematrix is beta testing!
  201. evoscan dyno question
  202. throttle hang induced knock fix
  203. Innovate might be dead
  204. Is fuel pump require for ECU Flash?
  205. Front O2 Sensor Heater Cel Removal.. With Math!
  206. EGR Advancement for 96530006
  207. Boost map question
  208. Is my 2byte load logging correctly?
  209. ecuflash wont read my computer!?
  210. How long is to long????
  211. Question about knocking.
  212. Can anyone confirm that EVO X MAP sensor is same as JDM MAP?
  213. Tephra map switching and E85 Q?
  214. Coolant temp impact on AFR, ECU AFRMAP and subsequently - on Knock?
  215. RPM increase after no throttle
  216. Load differences per gear
  217. What knock do stock Evo's make?
  218. How to spot ignition misses due to spark gap
  219. options for 96420008 roms
  220. Advice for UK FQ-300 please, am struggling
  221. First Log (2 byte) take a look
  222. Car wont start after moding the MUT tables Flashing CEL
  223. Stock ECU Tuning Wiki is up and running
  224. First tune, impressions?
  225. patch for 88590015: control front and rear O2 with wideband
  226. MUT tabe mods...what cell? (Pics)
  227. Knock Help
  228. LC-1 + Leaned NBO input = Spiking AFR
  229. ecuflash ic sprayer definition descriptions
  230. Made a Boo Boo :-(
  231. lean in first but more then enough fuel in second??
  232. post your e85 fuel maps!
  233. EVOscan - Load Values on MAP Tracer
  234. Evoscan 2.5
  235. My First tune..take a look please
  236. ecuflash 1.29 and 1.30 problem connecting
  237. ecu reflash question
  238. 88590015 xml definition
  239. Quick Noob Question on Tephra.
  240. Same setup, transfering tune...
  241. EvoScan Actuator SAS Mode
  242. Tephra CEL flash knock mod Question
  243. AFR's went lean from last drive
  244. DashDAQ possibilities?
  245. Mac having problems with Evoscan and ECUfalsh
  246. how to turn off knock control?
  247. EcuFlash, EvoScan, ECU Patches - Organization Needed
  248. Maf scaling/fuel trim questions
  249. 94170008 to 94170015 = no more cruise p0300
  250. Will the Innovate LM-2 replace the Tactrix Cable?
