View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Is there a Tephra Mod on my Evo8 96940011???
  2. Correct formula for 2ByteLoad
  3. Installing evoscan 2.5 issue
  4. trying to log HP and TQ?
  5. EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
  6. Openport 2.0 hardware failure
  7. EvoScan 1.4E cable
  8. Unknown ROM
  9. Difference between 2004 jdm ralliart and 2005 evo 8?
  10. 3 port boost control solenoid
  11. dataloglab question (help?)
  12. Injector latency help please - PTE880's
  13. flashing problem
  14. .Zip Files
  15. 264s to an already tuned Evo 8.
  16. logged Evo 9 idle Airflow values
  17. The stock ECU has gear dependent boost control!
  18. P0105 MAP Circuit Malfunction
  19. Ecuflash 1.40 freezes Evo 9
  20. Someone advise on this map
  21. Couple issues w/ "Direct Boost Control"
  22. I F**ed UP - Question about immobilizer ECU and reflashing
  23. Question on Logging.
  24. P0304 Misfire Detected - Cylinder 4.
  25. EVO 7 Stock rom
  26. Need help! Disable o2 Sensor?
  27. need help tuning this is my first tuning
  28. 94170008 xml
  29. Lean Spool with ECUflash 1.40
  30. rear o2 sim patch for my 03 evo!?!
  31. EvoScan 2.5 not showing values under Map Tracer feature. Any ideas?
  32. Need some help, for my first tune
  33. changing COM port in evoscan
  34. Please help with NLTS
  35. Fastest Map Switch?
  36. load% taper. Boost leak?
  37. ecuflash problems
  38. ecuflash v1.38
  39. Periphery Bits CEL Fix - on ECUTek - how to??
  40. GM boost solenoid and boost pill question
  41. ECUflash problem
  42. Dynos and "Knock"
  43. "Drive" and "Nuetral" ECU definition
  44. Disabling Various ECU Functions
  45. Cable wiring??
  46. Boost Limit ECUFLASH
  47. ecuflash 1.38
  48. Knock Sum discussion
  49. Mut_05 = Mut_06 - 20
  50. BCS testing data
  51. problem with evo 9
  52. Veh Interface
  53. FIC 750's scaling and latency issues and THE MEGA FIC 750 thread (hopefully)
  54. FP Red intake pipe, hard pipe vs stock, power and scaling
  55. EcuFlash Problem
  56. EvoScan and EcuFlash - Questions And Answers
  57. evoscan/dataloglab problems
  58. evo x xml
  59. Help me do this real quick
  60. Setting base idle using SAS mode....
  61. I just Screwed up....HELP!
  62. no ECUFlash updates
  63. Flashing Problems
  64. JDM 3-Bar Map Sensor Group Buy #3
  65. 2 step
  66. Idle drop
  67. More injector woes
  68. Interpolation between high and low ign+fuel map
  69. Air flow meter???
  70. Getting my car t pass inspection
  71. fuel trims
  72. looking for stock 96420007 ROM
  73. Boost control correction is pulling WGDC w/out being enabled!?!?
  74. Is this a boost leak?
  75. evoscan load
  76. evoscan
  77. disable P0300 test
  78. Looking for help with P0300
  79. 96940011 And P0300 Codes..
  80. keys
  81. will ecuflash work if i own a mac??
  82. Possible to disable P0300 Random Misfire code?
  83. Stock fuel line technical specs
  84. 9MR stock MIVEC map
  85. need help with 1.3 cable and ecuflash
  86. need unmodified 94170008 and 94170014 ROMs
  87. One more knock source discovered
  88. my LC1 is pissing me off!
  89. rear o2
  90. Check my logs (KNOCK)
  91. How long after a P0300 till the CEL lights up?
  92. Stft/ltft
  93. ecu flash 1.40
  94. Knock sensor detection via MUT
  95. Special Request: I need to disable Fuel Pressure Solonoid circuit in the ECU
  96. Bought New Car - Need Tuning Advise
  97. X axis for 88590015 for OBD Diagnostic trouble codes table
  98. Need some help...
  99. Cosworth Mivec with FP Red, help.
  100. Ever seen Evoscan make your car misbehave?
  101. Speed Density Implementation Discussion
  102. RC 1000cc car doesn't start well
  103. Readiness code
  104. Help me diagnose this knock?
  105. How do I log Fuel Level in Evoscan?
  106. 94170015 MAP to MAF Patch:
  107. Problem with load
  108. Strange bost issue
  109. injector size scaling
  110. Phantom knock?
  111. higher boost/lower timing - how far is too far?
  112. Help Understanding Logs Values
  113. What would happen if you saw more load then on your amp scale?
  114. Rom Id Problem--HELP
  115. Quick ALTMAP question
  116. ecuflash evoscan issue
  117. HELP cant write/read ecu
  118. Ignition Retard Limit
  119. BCS activation RPM causing problems?
  120. fed up with knock control
  121. IAC Maps & limits
  122. borrow a GM BCS to characterize?
  123. No lift shift : Please help
  124. rich afr's during spool
  125. Help please with Hex-editor use
  126. Periphery code for immobilizer activation
  127. how-to: airflow rate in gm/s or lb/min and mpg
  128. knock sensor filters
  129. tune for stock evo with aftermarket cams
  130. o2 sensor and flashing
  131. disabling lean spool
  132. Correct latency values
  133. I cant connect!!!!!!
  134. help with ecuflash
  135. What do you think about this my method ?
  136. Tuned by TTP Engineering, Orlando
  137. highest MAF Hz logged with stock MAF?
  138. Weird rpm/boost limit table on 94170015
  139. Ignition Timing E85 vs 91 octane
  140. Car wants to stall coming to a stop
  141. "Logged Timing" deviating from Timing Map, every log, every time it does, it KNOCKS!!
  142. Volumetric efficiency
  143. Tunning With A Restrictor
  144. tactrix cable problem
  145. Load Limit? - Anyone Ever See >380?
  146. Playback error evoscan v2.5
  147. noob question about immobilizer
  148. Please help!!! 2 Evos wont work with my ecuflash
  149. 94170015 issues other than boost issues! please help!
  150. New FIC 1250cc on 93 and E85 - Latencies
  151. What's the most stable version of ECUFlash to use?
  152. Ecuflash v1.39 thread
  153. LM-1 logging
  154. Evo IV ECU to Evo VII ECU
  155. What do u think
  156. Coolant Fan Temp
  157. 23mins of Open Loop driving
  158. “Max WGDC cold engine / CEL" table for ROM ID 96420008
  159. high idle
  160. EcuFlash DSM help needed, non evo related
  161. EGR exclusion
  162. rear O2 sensor function?
  163. OBD-II Codes Table Explanation Please
  164. 04 evo with o2 sensor problem after tune
  165. EvoScan v2.7 MapTracer Bilinear Interpolation
  166. Noob confused about ecu tuning
  167. idle fluctuation
  168. Logs, timing and fuel map
  169. switch ROM ID's...
  170. cable for ecuflash
  171. Tuning Cam Idle
  172. what maximum side injetor can i use on stock ecu
  173. tuners in North Carolina?
  174. Where can I find ECU reflash shop in Seattle?
  175. Tephra mod showing strange knock CEL
  176. Boost limit Address for 94170015
  177. Ecuflash 1.29?
  178. logging and scanning software help
  179. Evoscan cable or Tactrix 2.0 cable?
  180. Help please with adjustment boost
  181. Urgent: USDM EVO8 Doesn't Start anymore, help needed please
  182. 1000cc injector e85 question
  183. Gets rich right after shift when at WOT
  184. NLTS tuning....lean during shifts
  185. injector scaling problem
  186. I need a baseline tune...help
  187. Evo scan.... Connection issues
  188. Load Calulated Not Reading
  189. send me an older version of ecuflash
  190. EvoScan UserGroup Meetings
  191. openport 2.0 scan tool software?
  192. ECU Boost Control Duty Cycle info
  193. ? Mivec Temp Trim Table ?
  194. Is this normal decrease in load?
  195. HELP!! Can't connect to EVOScan
  196. MAF or MAP sensor ???
  197. Ralliart no pasa de 15 psi........ help
  198. injector scaling
  199. EvoScan 2.5 fixs
  200. WTF Evoscan 2.5 (weird logging issue)
  201. bad MAF?
  202. lean afr's at idle
  203. another logging AFR w/ ZT-2 w/ serial/usb adapter.
  204. V1.38 problem
  205. Ignition Retard Vs. Air Temp
  206. MIVEC and high boost
  207. Timing w/cams
  208. Air Density Compensation Table
  209. Help me with my first tune! (Maps and log inside)
  210. Load scaling on a IX
  211. Long Term Fuel Trim Request ID and scaling
  212. Tephra v5.10 94170015 Boost control BUG!
  213. Problems with stationary rev limiter
  214. Just filled up with e85 and...my car is not happy :(
  215. table cuestion!
  216. Evoscan help
  217. Should i be able to read with ecuflash without the reflash connector?
  218. Sudden drop of load during pull...
  219. can a tune go bad?
  220. GM BCS users: Are you using a 10 ohm resistor in series with BCS?
  221. new to TehpraMOD
  222. Evoscan,computer crashed-nedd to download again
  223. Map switching on evo IX
  224. Load/Boost 3rd gear run vs 1-4 gear
  225. Some Help please
  226. super locked ECU???
  227. evoscan 2.5 Log and reading ACD
  228. Changed ECU, OBDII testing
  229. please help with ecuflash problem!
  230. Need a little help fine tuning
  231. Boost control using EcuFlash and stock pills
  232. what else can I do
  233. question about map switching
  234. 500WHP on Stock MAF&ECU
  235. EVO Drive Cycle for OBD-II emissions
  236. My first log, What do you think?
  237. Ingersoll Rand Boost Solenoid, confirmed works and cheap
  238. modified xml file but no changes appears in EcuFlash?
  239. JDM MAP sensor calibration
  240. Fighting the P0300 monster
  241. how to install tephra mop
  242. 2 step question
  243. tactrix cable No software
  244. new intercooler
  245. Logworks or Evoscan maptrace
  246. MAP switching issue on Evo 9
  247. EvoScan 2.5 + LM1 = no reading (but EvoScan .99 is fine)?
  248. how-to: control closed loop AFR with your wideband O2 system
  249. aquamist hfs1 + tephra mod 5.10 problem.
  250. How to tell if your tuner ripped you off
