View Full Version : EcuFlash
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. 88580014 AUDM - EDM Dual or single BCS?!?!?!
  2. Factory immobliser
  3. Home made knock detector
  4. Need two additional solenoids switched by ecu
  5. Laggy moving off - Need comment
  6. tactrix 1.3 cable
  7. quick sanity check
  8. Gear-depending boost problem ?
  9. Question about ECUFLASH communication
  10. Evoscan Airflow Hz pegged??
  11. Logging aiflow with evoscan
  12. ECU tune and manual ICS button
  13. Speed density (again)
  14. GT35r - Bov VTA Vs Bov recirculated
  15. 88590015 - MUT 8A = 0-100% Throttle position
  16. EvoScan download assistance
  17. For Anyone Considering an AEM Boost Control Solenoid . . .
  18. Help.. Battery died while in valet mode, now car wont come out of valet
  19. New Motor, New Turbo, New Problems
  20. Timing idle autopilot?
  21. Evoscan 2.5 maptracer question
  22. Richer/Advance or Lean/Retard ?
  23. LEAN SPOOL question
  24. low load knock and heat
  25. need full house XML 94170015
  26. Cold Start Confusion
  27. Need map.. Please help
  28. Need a map.... changed turbo
  29. need Evo 9 owner to test rear O2 *heater* sim patch
  30. Fuel Trim issue
  31. ECUFlash RVR X3 4G63T issues...
  32. force full time open loop
  33. HELP! on Tempra Patch V5.10 for 9470015
  34. 1000ccs/flashing cel
  35. Ecuflash tune by Mail
  36. 94170008 to 94170015
  37. trting to pull map off friend car!!
  38. How to disable P0710 ?
  39. evoscan reading 150 load at iddle
  40. Evoscan EGT reading
  41. Starting sets for GM 3-port solenoid ?
  42. Can some1 look at my tune?
  43. MDP questions? ?
  44. Path from MAF pulse to Injector pulse
  45. Need help logging AEM wideband in Evoscan 2.5
  46. numerous tuning and wideband problems
  47. Openport 2.0 unusable
  48. (RPM)ReScale Boost Tables/ ReScale Fuel table
  49. Omni 4bar map sensor Plug and Play
  50. BCS for ECU controlled boost
  51. Mut Monitor V1.5 Release working with OP2.0
  52. Idle Stepper look up table
  53. who are the best shops a tunning with ECUFLASH (country wide)
  54. Strange dip in timing ! Why !?!?!
  55. open loop tuning??
  56. Need advise
  57. Car not starting in the cold (video)
  58. Trying to find info on crank/cam sensor signal for ecu swap
  59. Load dropping off
  60. tantrix cable
  61. UK IX FQ-360 Rom
  62. ecu flash jacked up!!
  63. Stock ROM needed...
  64. Map switching harness inop
  65. Disabling EGR and fuel pressure solenoids
  66. Look screwy logs, what could cause this?
  67. Differences between EvoScan and Tactrix cable?
  68. New Injectors, help
  69. Evoscan LoadCalc reading zero
  70. difference between load based boost control and direct boost control
  71. logworks open port 1.3 logging
  72. NLTS not working after clutch adjustment?
  73. Scaling help please
  74. Any success with bleeding AYC with Evoscan and Limitless cable?
  75. Tuning Kelfords
  76. injector problem?
  77. Help a noob with Evo 8 JDM
  78. Can a Titan motorsport WB logg with evoscan?
  79. Two evo9base xmls?????
  80. ECU Swap & Immobiliser Code Issues
  81. looking for 0300 cel fix
  82. Ix rs 97710001?
  83. hey any help
  84. CEL P1400 after VSR intake install??
  85. Open Source OBD-II/MUT project for Mitsubishi Vehicles.
  86. Lots of DTC questions P0141,P0441,P1400,P0183,P0443,P0446
  87. FP Green and Revolvers installed...looking for?
  88. deleting evoscan data items?
  89. Tephra Rom Mod - Ver 6 ??????
  90. Just a got a 35r (63) does someone have a base mapI could have?
  91. Open Loop > Matt55
  92. evoscan to logworks porting
  93. Fuel trims and idle
  94. IC settings in Ecuflash??
  95. Alternative MAF Sensor Implementation
  96. anyone using an lm1
  97. tephra any alternative
  98. Help with Ecu Direct Boost Control
  99. does this tuning method work?
  100. patch how-to: 96530006 MAT logging
  101. boost cut
  102. anyone have a 05 evo 8 tune (turboback, intake)
  103. Evo 8 ECU in my 2g DSM, help please!
  104. EvoScan 2.5 and VISTA..HELP...
  105. Time discrepancy
  106. Question about barometric pressure sensor on an interesting project
  107. Help/Advice Please
  108. Any issues on these graphs? Idle problem. Help
  109. evoscan 2.5 w/ vista woes
  110. 94170015 work for all 03-04 Evos?
  111. Anyone in the Indiana area interested in tuning a VII?
  112. Which cam, kelford 177A or 177C?
  113. OEM replacement primary O2 sensor
  114. EcuFlash ver 1.39 Please
  115. Load with V.5.10 Tephra
  116. Editing ROM
  117. help! please
  118. Is the 97250001 ROM patchable?
  119. Question about EGR Disable
  120. Thermo fan map
  121. XML Rom editing problem - Vista Ecuflash 1.40
  122. MDP Connector?
  123. Can you disable Front 02 sensor?
  124. ECUflash ver 1.34 help
  125. Adventures in load-based boost control with the GM 3-port solenoid.
  126. 5000ft tune... Looks rich...right?
  127. Reserialized Tactrix cable still won't read/write w/ Ecuflash 1.35 and up
  128. Wierd Evoscan 2.5 Problem
  129. Need help with Evoscan 2.5
  130. Testing 3 Port
  131. Can an ECU be repaired??
  132. 9653006 map
  133. rate this tune for me
  134. Good Base Map for EVO VIII using ECUFlash
  135. Opening an EvoScan Cable
  136. e-85 tune?
  137. Just what are the old Knock Filter Maps
  138. Need older version ecuflash
  139. Issues at full throttle 3rd/4th gear pulls
  140. Can't log AEM WB in Vista (Evoscan)
  141. Stalling , idle problem , take a look at the graphs please
  142. 2byte airflow limit?
  143. Tons of knock...need some advice
  144. Decel Fuel Cut and Cooling Fan Maps for 94170015?
  145. XML for JDM MAP & ECU Boost for 96530006?
  146. Any Reason to Keep These in the ROM?
  147. gt3582r & stock ecu tuning process...?
  148. ECU controlled Window Switch
  149. aem wideband
  150. low octane altmaps - anyone using them
  151. Weird idle issue after swapping back to stock intake
  152. Boost control problem
  153. ignition timing trims
  154. HELP: unable to read/write to ECU with ECUFLASH
  155. throttle/ boost
  156. P0141 and p0136
  157. Definition of Idle Conditions?
  158. new mod feature - thoughts required
  159. Building to much boost with 2 step
  160. wgdc correction based on MAF IAT
  161. Evo IX 272 ignition map anyone?
  162. Timer unit - interrupts for CAS, airflow, injector/coil schedules
  163. Calibration Id
  164. open port 1.3u-b
  165. 99860002 and Load related datalog
  166. WGDC settings help
  167. Evo Scan Load Problem
  168. couple logs from the new all stock 2.3
  169. Evo X xml rom
  170. DLL help
  171. Need help w/ECUFlash 1.40 - Not responding
  172. e85 fpgreen 1 walbro...
  173. ecuedit and OP-2
  174. Additional injector drivers - spare outputs discussion
  175. getting "overboost"CEL and boost limit is maxed at 319??
  176. Knock control - ignition retard
  177. Who's using GM 3port and Direct BC with big turbos/tial wastegates
  178. Knock control - fuel enrichment based on knock sum
  179. Tephra - Map switching 3 maps?
  180. V5.10 and alt map spool up ( 3k-4k rpm) knock
  181. Spooky EvoScan behavior
  182. Knock logs don't work
  183. Unknown table for 88590015
  184. Help with load issues
  185. Installing GM 3 Port Boost Solenoid
  186. Native DTC and MUT_45
  187. Can the Turboxs Knocklight be hooked to service light flash
  188. Weird EvoScan issue I've been having
  189. Is it time for a fuel pump upgrade?
  190. AFR's Evoscan vs Logworks
  191. WGDC w/ a GM 3-Port
  192. Immobilizer Code lost – Where or who can retrieve this for me?
  193. new 2.3l motor in any advice on base tune
  194. EcuFlash 09 Ralliart tables Vs. Evolution 10 tables
  195. where can i get evoscan 2.5?
  196. ECU Corrupted – need HELP rom# 96420008
  197. Evo Scan Question
  198. ecu unlocker
  199. Resetting Trims and effects
  200. Off throttle at cruise but still showing 12.4afr?
  201. The definitive EcuFlash Evo 10 thread
  202. Evoscan not connecting.
  203. Evoscan help, im verrry frustrated
  204. Solenoid: Bleed vs Interrupt
  205. Adding periphery
  206. Air Temp Compensation table
  207. Very Odd Lean Idle Issue, Tried Everything Need Your Help
  208. Audio Logging of Knock
  209. need help base map for 720 inyectors
  210. Evo wiki help for rom collection
  211. Help with changing injector scaling on my current tune
  212. broken ecu???
  213. xml request
  214. OP 2.0 Loggers?
  215. Are stock injectors sufficient?
  216. Difference in tune for altitude
  217. tactrix cable
  218. Having a strange knock issue
  219. ELM327 Bluetooth & Evoscan/ECUflash
  220. Acceleration enrichment for 88840017
  221. help reading rom
  222. Periphery questions:
  223. Tuning with the new Magnus
  224. EvoScan 2.5 vs DLL Dyno??
  225. Modified XMLs
  226. Decrease load at 5500 rpm evo VIII EDM
  227. WGDC Gauge
  228. Stationary Rev Limiter Missing
  229. Changed back to stock intake and different bov, now getting p0234?
  230. Knock control - load vs RPM table found
  231. What is needed for 2 maps?
  232. need help on the base numbers on bdel table
  233. To add immo code to my xml file
  234. E9 IX Def file needed
  235. How To Disable Egr Code
  236. question! Map sensor stock ecu
  237. what rom is this? tried searching..
  238. Changes in Boost after LICP & FMIC Install??
  239. coolant temps and timing
  240. Strange problem with "stop engine"
  241. Two questions
  242. BEC and WGDC Change %
  243. Any howto on fixing the endian issue?
  244. What's your suggested AFR target??
  245. Logging Boost Error Correction/ evoscan v2.1
  246. Timing & Fuel maps: Load auto-rescaling (XLS file)
  247. ECU Flash on a 1.6L Mivec
  248. IAT log you don't want to see
  249. My 60-1 Hifi map
  250. Ecuflash Error
