View Full Version : EcuFlash
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. EvoScan v2.5 USB error / issue
  2. CA Smog Check
  3. Narrowband voltage in Evoscan
  4. Common Roms
  5. front 02/closed loop disabling.
  6. Standalone User - Help me understand the stock ECU
  7. ACD Pump: all 3 acd lights on - fyi
  8. HELP: Evo 8 Rear o2 heater circuit patch
  9. 03 jdm evo 8 (car running rich after tbe)
  10. EvoScan Map Tracer - Alt-Maps (and standard maps)
  11. Evoscan error... New 1.3 cable + Logging wideband
  12. Mivec and timing numbers to promote spool
  13. Stationary Rev Limit
  14. Weird 96940011 to 96530006 issue
  15. Found - New items to log
  16. Weird issue at idle and cruising! Not the common one you always see. Please read!
  17. need help with evoscan!!!
  18. Trying to determine software for gauges...
  19. How Do I Fully Uninstall Tactrix/Open Port FTDI Drivers?
  20. keep throwing p0171 with bosch 950cc
  21. VERY ODD - JDM EVO 8 MR MAPs (how can this be?)
  22. Best ECUflash version
  23. Fuel light/cell adjustment
  24. Mitsulogger 1.6 not working
  25. Weird Knock Issue
  26. Load went nuts!
  27. unknown rom image - jdm evo 9 mr rs
  28. Ruining in open loop for idle??
  29. Mid Trim adjusting at idle?
  30. Need help switching 94170008 to 94170015
  31. need help ALS
  32. Rich Idle and Cruise AFR's since injectors
  33. need to figure out AC signal.
  34. Knock on shifts.. Help
  35. Need help re-flash my evo vii gt-a
  36. 2 byte mod XML problem
  37. FS: 2 JDM map sensors
  38. E85 Tuner
  39. Too rich AFR's causes knock?
  40. USB to Serial Adapters That Work
  41. No start after flash (experts please)
  42. couldn't add timing with 264/272's over MR cams??graphs
  43. Lift off knock
  44. Knock between 2800 and 3000
  45. Can 12 V ICS pinouts support any power?
  46. Setting Up Larger Injectors
  47. Mitsu 3-bar MAP sensor calibration
  48. ROM's and some questions.
  49. Can't Download latest version of EVOSCAN
  50. Etacs rom
  51. Can not read/write to ecu...not locked
  52. ecu locked
  53. openport 2.0, ecuflash 1.41, and evolution 9, not working!
  54. MAc book
  55. Found - LT Fuel Trim Control !!!
  56. Lots of timing advance for low end - Comments ?
  57. New to this, Help wanted.
  58. Boost control with Ecu
  59. Noob question re Alt Map Swtiching
  60. disable idle test
  61. idle test
  62. idle test
  63. switch to 88590015
  64. EvoScan stops logging AFR?
  65. knocks
  66. Load dipping issues
  67. Netbook - opinions
  68. PO125 issue
  69. EVOScan - Injector Duty % issue
  70. P1400 After installing the JDM Map
  71. Timing pulled until fully warmed up
  72. MIVEC with cams/stroker/large frame turbo
  73. Omg nlts.........
  74. Making the car run better in the Heat with the AC
  75. Noob needs help!
  76. Interesting MAF based datalog
  77. evo 7 launch control
  78. which tables need to edit ?
  79. Trying to change only rev limiter
  80. evoscan cable question
  81. NLTS patch is awesome!
  82. so ... Lets play wont my car start???
  83. Found - Short Term Fuel Trim maps
  84. Hard Starting with New Injectors
  85. Help - Bogging when cold
  86. Inconsistent IPW's sometimes causing smoke on spool? 90550001
  87. Question: Load Scaling NA to Boost
  88. ECU works but now I cannot flash or read
  89. EvoScan Error
  90. Maf Scaling Offset Address for 9417008
  91. Evo 9 boost
  92. Changing mininum speed on launch control?
  93. EcuFlash BUG on E6 GSR ECU !!!
  94. where to find boost definition for ralliart
  95. PTE 1000cc Driveability
  96. evoscan error question
  97. A/C fan threshold
  98. Timing/Fuel map for Reverse Gear ?
  99. Need spare 0-5v logging input???
  100. LC-1 Signal oszillating
  101. Evo X maf?
  102. anti-lock brake light blinking with evoscan cable
  103. Any ideas on what could be causing this?!?
  104. P0170 Fuel Trim Bank 1 Fault Code
  105. Evo7, Tephra RA rom / current map.
  106. HELP!!!!! 3 port GM boost solenoid
  107. AFR's with CAT
  108. Fuel Sender/Pump connector??
  109. Gm maf/maft ?s
  110. AFRMAP not matching real values
  111. Injector Scaling and 14.7 AFR
  112. Evoscan disconnects during full throttle
  113. help with 2 byte load for 98640014
  114. 94170008 to 94170015 potential problem found
  115. hwo to add a new table?
  116. Need disassembler's help — top clutch switch
  117. latency increments??
  118. Tuning Fuel 2009
  119. Evo 9 Wagon GT-A rom?
  120. Closed loop control
  121. Found: Purge solenoid duty @ MUT_4A
  122. Do all 8&9 ECU's have an ICS light output?
  123. Bought license 9 days ago, still nothing from Evoscan?
  124. Electrical Connectors and Pins?
  125. Evo 8 MR ECU Pinout
  126. unable to connect to vehicle interface.???
  127. P0135 CEL Fix for 90550001/98640014?
  128. Innovate LM-2 analog out into Evoscan
  129. Evo 9 ECU pin removal tool
  130. How does this E85 Timing Map look?
  131. Largest Injectors being run on stock ECU?
  132. Found: code that transfers injector times to the hardware
  133. 94170008 stock rom from 2005?
  134. stationary rev limiter
  135. Individual cylinder knock test - initial results
  136. Stock Flash for 88590015 ?
  137. EVO 6 logging 2 byte load?
  138. Newb to latencies and trims
  139. Ecuflash incomplete definition
  140. Wrong RPM reading after 011 to 006 switch for the 05
  141. Hitting a max value for EvoScan AirFlow
  142. Added free flow CBE, how should I tune ?
  143. A/C Logging and RPM control found !!!
  144. ROM tables hosed with Ecuflash 1.41
  145. Factory ECU Dual Pump Control
  146. Knock Sensor Sensitivity VIII VS IX
  147. Cobb ap
  148. How does the ECU interpret Beyond Tables?
  149. Cyl # index found
  150. Rich AFR's after shifting to next gear.
  151. 96530006 can't logg trims
  152. Misfire or Load Limiter?
  153. 2-byte Injector Pulse Width
  154. Issues and problems
  155. JDM MAP sensor and altitude
  156. Mut Monitor V2.0 Released 12/04/2009
  157. Coil on Plug - std ecu
  158. Imobolizer code?
  159. Logging data for Horse Power
  160. completely given up on trying to tune and log
  161. how to unblock a ecutek flash
  162. 91 oct at 5000 ft. what do you think?
  163. EvoScan v2.6 Beta11 now supports EvoX and OpenPort2.0 datalogging
  164. Post your ETS intake maf scaling
  165. P0125 Trouble Code
  166. help me understand my logs ...
  167. Speed density users, accel enrichment tip
  168. PTE 880cc Scaling help
  169. GTA downshift ignition retard / multimap ?
  170. Why is there no scaling in maf tables?
  171. tactrix 1.3 vs 2.0
  172. I need old ecuflash version
  173. Parse errors in EcuFlash
  174. Back to stock?
  175. Problem- Evoscan not logging
  176. wrong x and y axis values
  177. help with idle
  178. Afr calculator
  179. Disable ODBII totally?
  180. Flashing error
  181. Changeable boost problem
  182. How does the HighOctane/LowOctane stuff work?
  183. Tune or flash
  184. Evoscan Issues - Thread Failed During Processing
  185. injector question? newb
  186. need a dedicated tester for TephraMods
  187. Need flashing logs from various romids + ecuflash version
  188. Starting over with ECUflash and Evoscan
  189. need a tune
  190. Found Thermo Fan Switch Conditions
  191. Removing stock BCS
  192. smog.. obd2.. help.. :)
  193. limitless 1.3U cable= flashing anti-lock light when connected
  194. Tuning Help - New Injectors
  195. mac version of evoscan
  196. Unknown file type ROM id
  197. Help with AC idle and cams
  198. logworks3 time delay..
  199. What would your perfect logged AFR map look like
  200. 1.29 vs. 1.41 trouble shooting
  201. How do you set your launch boost?
  202. accel enrichment table is not defined correctly
  203. Need help rescaling load in evoscan
  204. Tactrix cable fault? Detailed troubleshooting!
  205. ECU Pin for clutch switch
  206. Question about my maps and my datalog after cam install
  207. glitch with 2-byte airflow logging in Logworks
  208. ECU vs AYC
  209. rom evoVIII 2.3
  210. My turbo wont boost above 20psi at the track???
  211. How much knock pulls timing??
  212. Mounting GM solenoid
  213. How does one log load accurately?
  214. p01238 o2 sim patch fix for ROM 94170015
  215. Live mapping and/or speed density instructions
  216. how do you activate the Tephra mods?
  217. Suggestion need on my 4th gear pull
  218. Still throwing codes P0037 and P0138, while using tephra mod 88590015.
  219. Live Graph Download
  220. An Interesting idea for cruise AFR :(
  221. "Correct" Idle MAF Hz
  222. EcuFlash and Windows 7?
  223. Evo 7 question & tuning
  224. 96530006 Live Map download
  225. Hows my Fuel and Timing look ?
  226. How the DMA code works
  227. problem lots of knock while cruising.
  228. MAF No Screen / Who's doing it?
  229. acamus' automatic disassembly script is ace
  230. Injector Scaling Issue
  231. Modified ROM 94170008
  232. ECU Flash Problem on Vista
  233. Breakup After hardshifts, Possible Knock , please help.
  234. 9626009 xml
  235. 1 byte vs. 2 byte
  236. Any ACD/AYC evoscan logging experience?
  237. loginig software for my needs
  238. Lean Spool ?? Help Pls.
  239. HELP!! evo ix audm DEFINITION
  240. how do I log STFT&LTFT
  241. MAF Hz and Load at idle.....spikes
  242. Issue with BARO and P0107, with Potentiometer
  243. Question regarding "the switch"
  244. Towards a universal ECU
  245. FP Red is FUN
  246. tranny temp monitoring on EDM Evo IXs
  247. wb o2 help
  248. What is the key to getting WB AFR to match the map AFR?
  249. P0300 Code
  250. Show case your Evoscan GPS Display
