- e85 knock
- ROM version 96940013
- Going back to stock ecu
- Weird EvoScan issue with reviewing logs
- Is this false knock?
- need definition file .. help
- So I'm trying to disable my rear 02 sensor (Since thats where my wideband is)
- EGR hose off running really rich!
- Logging With An AEM UEGO
- Tactrix Fail
- How do I get into disassembly?
- Need stock EVo IX map....i have a new ECU and I'm not sure where it came from..
- help with my timing please.
- Switch to BCS from MBC to get higher boost @ track
- need evo x rom
- strange fuel cut, need help.
- retardation, strangulation...
- EGR valve forced open at high boost?
- Please help me evaluate and improve my tune.
- wastegate solenoid activation Rpm table question
- Can I use a mac?
- ecuflash question: wastegate solenoid activation, boost desired engine load and other
- evoscan No response from ecu(ecuflash work)
- target interpolated not populated after 240 load
- MUT Commands Known?
- when using map tracer problem
- Remove P0172 code from ECU ROM
- What would happen if I did this.....?
- evo 9 jdm rs stock ROM, xml needed
- Logworks 3 - how to make it log 2 bite load
- Downloaded evoscan on wrong pc
- can someone sent me a good definition for 93660005
- innovative lm-2 - insane values
- EGTs for Road Racing
- How Important is a 3 Bar MAP?
- EvoScan + Logging AEM UEGO = Arghh!!!
- Scrambled map from an 03
- Looking for Global/latency values:Precision 1200's?
- AEM UEGO logging help
- TephraMod V.6 boost control problem
- Map Switching In Evo X While Using Aquamist? Tephra?
- Is Excel the ONLY way to read EvoScan logs?
- EvoScan 2.5 and LC-1 skipping?
- Electrical Q: quick ground question
- Who's tuned fp4r's?? Midrang knock?
- 2 different ECU's, same immobilized code, WTF?
- Anyway to disable CEL P0107??
- need help setting my car
- Lancer DE 2008-2009
- ecu flashing?.. new to it.. who did it results ?? who did your reflash??
- Ecu internal Counter and MFI relais (fan)
- Thanks to those of you putting in the work on the stock ECU.
- Logging aem wideband
- ecuflash could not recognise rom image
- 05 ecu in an 04 evo
- map switch help
- FP Green, FPR4 cams, Meth, And TBE Tune
- followed by injecting
- No 2 step?????????
- evo 5 2 bute mod
- using apexi avcr map sensor to log boost
- Installing sensor IN the Cat?
- New ECUflash version not working with 2.0 cable?
- 2.3 hks 272 stock everything else.
- Pegging 380 load with Evo IX
- EvoScan 2.5 Download link
- EvoScan v2.6 B16 Logging Problems with Zeitronix ZT2
- WBo2 lag time.
- ECU based boost / help
- care to comment on this map
- 3 bar JDM Map Sensor harness EDM Evo IX
- looking for stock evo rpm and airflow log
- EcuFlash 1.42 Released
- Speed Density - Evo IX - Possible? Questions?
- Everyone loves ECUFlash
- DISASSEMBLERS please read. New Platform
- anyones ecu failed afer reflash????
- knock after a NLTS
- ECUFLASH Knock
- Logging and Patching 2001 Evo VII
- merging 0-40 load
- AFR to rich at idle with Innovate LC1
- Guidance from EcuFlash gods
- JDM 8 MR upgrade
- NO table info after rom read?
- Ralliart Torque Limting
- LC-1 Wideband Logging in EvoScan
- EvoScan Version Question
- Sensor questions
- Reasons why my fuel table would max out at 7.4?
- Boost Control tables
- what does MUT table affect
- EvoScan install Help plz!
- help with jdm evo 8 gsr map 93660005
- Way to adjust for tire size?
- Ecuflash error on a X
- Battery voltage WOT
- GM 3-port: VTA or not?
- 2 byte mod for 98640014????
- Periphery Bit for P0420 Code
- Acer Aspire ONE 11.6 netbook FTW!
- Problem with LC-1
- Random question: Does hex copy correctly?
- Ign Fuel Maps??
- sudden enrichment and stalling
- Comp. shuts down, when hooking up WB?.?.?
- scanning with open port 2.0
- What A/F ratio should i aim for?
- Need help finding new items to log
- Scaling 260 -> 300 with different roms
- Error message with Ecuflash
- Boost settings for Perrin 3 Port Solenoid
- Cold start enrichment for 94170015
- Best AFR for power and safety.
- Disassembly: 2-byte variables
- LC-1 Problems
- changes in fuel map does not have effect . why ?
- is this 2 byte mod correct
- slight hiccup peak boost 4th/5th gear
- More boost than 18 Psi/redline is nonsense
- how to start
- 35R tuning with 4" inlet pipe - question/advise
- Odd Issue....knocks ONLY @3k or lower
- changed values for Y axis
- launch control?
- LM-1 Logging Issue
- Help: Evoscan v2.2
- Evoscan 2.5 & Lm-1 issues
- So I took my MBC off today he he!!
- datalogged my car - opinions
- Tractrix cable question (not the average ?)
- Com1 Access Denied.
- Vista and patching problem, help me!!
- suspension data logging with evoscan ?
- Stumble at 7000 RPM with log...
- Virtual Dyno Room-Dyno Simulator
- Another idle issue
- ECU Pin 43 - Clutch Position Switch
- Trying to use 2 byte load
- NLTS Knock!
- Intake Air Temp vs Timing Table
- Opinions on tune...
- evo 7, 2001 JDM ecu no definations defined
- Switching to Low Maps w/o Knock ??
- Help Please with Boost Control 30R and Tial
- Evoscan - disconnecting on logging runs?
- Evo5/6 Load and PW Cap?
- Alt Map switching, installed and thanks
- Looking for Evo club, Seattle
- Evoscan: Diagonostic Trouble Code: o2 level 19.9%
- How low for timing to be dangerous?
- Evo Scan issue
- What happens at peak load?
- Can't log fuel trims
- creeping injector scaling
- Airvol question
- sputtering car, log inside.
- need a fully patched
- 885800014
- Log boost with Defi Boost sensor
- Unknown ECU strategy for boost control
- P0603 Error
- Knocking Issues at Low Rpm/Low Load
- Injector Scaling Formula
- Car Will not connect to ecuflash.. Evo 9..
- Does "baseline WGDC" = "Max Wastegate duty"
- Precision880cc latency values?
- Help for a ECUflash noob
- Stock BCS hose routing
- What's the general consensus on a blow-thru setup?
- evo ecu on evo 3
- 2006 Eclipse, manual trans, V6
- Idle tuning - question/advice
- ACD/ABS dash lit flashing
- Idle Stepper Look Up Table Findings....
- valet patch
- TPS adjustments or tables?
- accelerator enrichment = too much
- Cannot read from ECU (searched)
- Ok driving to 9k feet on sea level tune?
- 88580014 Stuff Required
- Viliv S5 UMPC review
- Innovative LM2 EVOSCAN support?
- Hitting higher loads now and wondering what do I need to do to accomodate ?
- injector and ignition logging
- Engine Trouble Code Cycle Time?
- Evo9 FP Red Timing Maps/Fuel tables
- Searching for tephra mods on 99270000
- Mitsulogger v2.0 Beta 1a Released
- Running full time open loop = no maf needed?
- egr/cat monitoring disabled in rom
- removing rear o2 sensor
- EvoScan 2.5 issue...
- OmniPower 4 bar settings
- How to compare ROM Metadata from 2 different ROMs
- How do I remove the load an IPW caps?
- tuning in WA?
- how to run a ics button on a 05
- FIC bluemax 1250 - any input on pump gas?
- Fuel Cut Ignition Timing Retard
- Wish I had an Evo but issues with Evoscan
- Evoscan Logging Problem
- Searched but found no exact answer.
- Patch Request: Improved 2-step control/resolution
- Ecu boost control inop
- Evoscan disconnecting during logging.
- Logworks 2-byte load problems
- airflow 2-byte mod for 96260009
- evoscan error msg
- Am I supposed to be hitting 300 load cells???
- VP12 PErformance chip
- Upgraded to 1.41 and lost info...
- ECUFlash and Wide band logging
- tactrix sd card logging any closer
- Car does not start with tephra rom 9626009
- Tuning for maf pipe?
- Ecuflash can write but not read
- terrible startup.
- Two installs of same ECUFlash, two different 88590015.XMLs :(
- get rid of rich dip at WOT
- Problem with Ecuflash
- very simple question: better fuel economy??
- psi based boost on a BBK?
- Timing Question:)
- Running 2 different versions of ecuflash...
- PLX R-500 wideband
- how to switch to 90550001?
- Periphery bits - advice required
- 89280002 rom ID
- Running e85 at 12.5 AFR WOT
- which parameters to log for tuning timing?
- What does "inheriting evo9base_20081101" mean in Task Info field?
- Imobilizer Delete anyone?
- Info on some things
- EvoScan RPM skipping
- Activating 2-Step
- ISCV control system disassembly
- VIII patch to reset fuel trims?
- Injector latency base?
- Ecuflash + Mitsulogger
- 0011 to 0006 Conversion Problem
- Tuning with LS enabled
- Training Videos: How to tune an Evo with EcuFlash
- 4th gear log to sink your teeth into
- Oh dear...
- Are these 1byte load spikes normal?
- EvoScan v2.5 USB error / issue
- CA Smog Check
- Narrowband voltage in Evoscan
- Common Roms
