View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21]
  1. Knock counts at partial throttle (mostly when lifting)?
  2. noob question....reg lancer
  3. Lift off detonation sorted thanks to Evoscan/Ecuflash/Second Chance log viewer
  4. Evoscan log reader ?
  5. Lots of questions
  6. Links to Evom Vendors offering Maps via Ecuflash
  7. Evoscan
  8. Post your evoscan logs
  9. This is how to pin-point what load cell your car is operating in!
  10. Scaling Map to 300
  11. RPM hang up
  12. Common "Tuner" Tweaks: Intake, Fuel Pump etc.
  13. Feature Request?
  14. Lost immobilizer....car wont start
  15. Accel Enrichment
  16. Evoscan timing values?
  17. AMS Tuning Tips
  18. ATTN EVOSCAN owners a useful tool to view logs
  19. stock rom
  20. engine feels like it hits a wall @ WOT
  21. stock evo ix
  22. Time to reflash?
  23. Change Values to tune higher Boost?
  24. Wastegate duty cycles, target boost
  25. ECUFLASH with 2.3L stroker!!
  26. Flash Limit??
  27. What is the load algorithm?
  28. EVOSCAN Guages
  29. ECUFlash dyno results!
  30. evoscan logger release
  31. Evo 9 ignition maps
  32. ECUflash and Alky/Meth questions???
  33. Timing Maps W/ Alky or Race Gas---Screen Shots
  34. Where to Buy flashing cables?
  35. Ecu reading from 120-140 load table in High Boost!
  36. Injector scaling and latecy for different injectors.
  37. map scaling info in the knock problem spot thread
  38. Mynes Performance Custom Maps?
  39. Stock 9 Tuned on 104
  40. Alky/Pump maps anyone???
  41. Trouble Controlling Boost with Soleniod??
  42. knock problem spot at 3,000 rpm......
  43. Further questions on EcuFlash w/ EcuTek
  44. Starting to tune.. logs and such inside
  45. EcuFlash Part 2...
  46. ECUFlash and TURBO Lancer
  47. Gt35r tuned with EcuFlash result
  48. Flashing tools do not recognize flash method 'evo'
  49. 1.28 now available
  50. Evo 9 and Lancer Auto support added to V1.28
  51. ECUFlash Dyno Day
  52. ECU Flash working with SAFC
  53. ECU Flash Results
  54. ECU explorer for loggin
  55. I get this error when I open my ECU Flash and also can't read rom file.
  56. How much timing are you running on pump gas?
  57. just ordered my cable
  58. Can I still read the ECU w/ Exede connected
  59. Got Tuned With ECUFLASH.. Results/Findings
  60. My ECUFlash track results
  61. uh colby......
  62. 05mr
  63. Re: adjusting fuel map
  64. adjusting the fuel maps??
  65. When i pull my current map...this is what i see...
  66. 2-step function
  67. Flash back to stock....
  68. some IX info to digest
  69. Ignition timing on my JDM Evo IX
  70. Reading ECU with current flash
  71. Windows 2000 NT compatability?
  72. No knock, ECU pulls timing - why?
  73. AFR consistency per gear?
  74. HKS RS intake tuning?
  75. EcuFlash Ignition Table
  76. got new flash uploaded...
  77. Whats the latest on IX Flash capability?
  78. differences in 03 vs 05 timing maps
  79. Wow props to the shipping department.
  80. Fuel cut map
  81. Boost control with ECUFlash - What are you using?
  82. Limit on number of cells that can be copied and pasted?
  83. Anyone with 780cc / 16G/20G map?
  84. EcuFlash - Finally got some time with it today...
  85. post your maps here
  86. EcuFlash ReFlash Limit ?
  87. Just got ecu flash and i want to tune my cams and fuel pump how do i?
  88. Maf Scaling??
  89. Who is running larger than stock turbos on Ecuflash?
  90. Did i do this correctly?
  91. Anyone else have this problem?
  92. I CANNOT get 1.27 to read ANY ecu (screen shots inside)...
  93. Flashed it with the wrong ECU identifier!
  94. Cable for ecuflash
  95. IC Sprayer Settings
  96. Adding additional columns in map definition?
  97. Immobilizer Question
  98. What to use for DataLogging
  99. my first datalog =)
  100. Ecuflash Simple Question
  101. Boost question
  102. warranty question
  103. Question regarding tuning methods...
  104. HKS 264/272 with 680cc injectors --- EcuFlash MAP included
  105. Internal ID #'s
  106. Is Ecuflash for Evo9?
  107. problem connecting
  108. EcuFlash cables are back in stock. First come-first shipped.
  109. I need the stock EVO IX base maps?
  110. Unknown ROM image?
  111. Ecuflash using mapsensor w/o piggyback possible?
  112. Service Engine Soon
  113. ECUFlash Rom table Help??
  114. Rom table help??
  115. Unable to connect to vehicle interface?
  116. First tune with the ECUFlash app..
  117. Any ETA for the IX's?
  118. Apple puter for ECUFlash and min requirments for PC
  119. IC maps?
  120. error loading FTD2XX.DLL
  121. ECUflash before and after dyno results!
  122. Injector Scaling with ECU Flash
  123. Palmone Tungsten E2 OBDII Cables
  124. Knock sensor threshold
  125. EcuFlash stationary rev limit work on 03's
  126. IX or IX MR Dynoflash
  127. EcuTek'ed... what are my options?
  128. XML Defs (Updated for ECUFlash 1.27)
  129. Caution - "Knock Sensor Filters"
  130. Used ECUflash today - WOW!!
  131. New Release Version 1.27
  132. ecuflash cable
  133. Must Read Before Using Software!!!
  134. Do Not Post Vendor Purchased Maps
  135. 2003 first allocation stock rom?
  136. Why cant i get ECUFlash running?
  137. ECUflash tutorial for beginners
  138. TBE, Intake, MBC
  139. Re: Please Read Concerning Posting Vendor Maps Thread
  140. Lean Spool RPM
  141. Grass Roots Tuners
  142. fuel economy
  143. tweaking maps
  144. Engine Coolant Temp...
  145. Users Guide?
  146. Rescaling Load Table
  147. XML Def files
  148. Which Wideband For EcuFlash?
  149. We need some "how to's"
  150. 2 Step Map Definition
  151. Injector scaling
  152. 280's Map
  153. OBD-II software that can use the 1.3m cable?
  154. ECU FLASH Tuning Questions
  155. ECUFLASH Released!!!
  156. Updates for "ECUFlash for EVO, Subaru, 3rd Gen Eclipse" freeware??
