- Internal ID: undefined
- Anyone having this problem with v0.9?
- Evoscan 0.9 airflow volume reading
- Confirmed: AEM UEGO logs in evoscan 0.90 just fine.
- New to ECUFlash - logs inside
- Injector pulse width
- Evoscan 0.90 problem
- Evoscan 0.9 map reading
- ECU Scan and Zeitronix
- OpenSource Flashing
- Stock Boost Control solenoid question.
- Unsafe timing map?
- 8MR JDM ROM and xmls link
- EvoScan V.90 Is Ready
- OBD Scan/Reset software for OpenPort cable?
- BCS operation?
- Looking for Base VIII/IX Flash's
- question.....
- Australian Delivered Evo IX Map - 88580013
- Calculating Load
- Problem flashing 06 IX RS. Error CRC
- ECU Can handle at least 3000hz
- Evo IX GSR serial routines 1 to 14 disassembly
- Knock sum=36, octane number=0, forged pistons, false knock story
- Ecuflash updates?
- having trouble with ecuflash please advise
- Full working EDM 9 Definition file?
- questions on fuel trims
- problems everywhere lol
- evoscan features
- For those who can get a decent load calculation
- Direction for stock map.
- modifying a locked ROM?
- I am new to ECU flash
- Stock 04 rom w/ P0300 fix
- TPS values
- a few updated EvoScan definitions
- Why cant I see Immobilizer under MISC.
- Evoscan 8000 RPM Logging limit?
- rev limit and off throttle knock
- Tractrix Cable for EcuFlash?
- EvoScan Accel Enrichment?
- big turbo ecu flash help
- Custom 2 map tuning? for evo 9!
- Evoscan Log Analyzer 2.0 with Load!
- ECU flash
- SuperH emulator
- I need some help pls
- rescale flash
- Map request basic bolt ons
- 7000 RPM IPW step on US Evo IX
- 20G maps
- ECU Flash users?
- AFR & intake questions
- pulls timing with no knock at all
- Octane number update information - 1-3=increment/4-5=no change/6=decrement
- new to ecu flash
- Evo IX ROM available?
- having idle & cold start problems
- how much knock is ok?
- 35r and EvoFlash. Lets see what happens...
- Determing Evo IX ECU Ign. DTC mode
- what is this?
- Boost Control using Max Wastegate Duty #
- All available Eflash vendors & info
- Vehicle Speed (kph) Confirmed on US EVO8
- Which log is the "right" log?
- Who should I get an Email Tune for my IX
- EvoScan? How Long???
- Dynoed My 05 Evo 8
- data logging
- ROM year info
- When will the ECU *REALLY* pull timing?
- EvoScan help! Timing + Knock count
- EcuFlash Trace?
- MIVEC voltage?
- Long term fuel trims not changing
- New injectors
- ECUFlash with Apple MacBook
- evoscan .net framework??
- Question, ECU load determining accuracy
- idle ac solution?
- Does reflash clear ecu memory?
- Logging boost with EvoScan
- Low Boost Question
- 16g/20g Alky users post your timing!
- Any tips on tuning Mivec?
- how are you guys logging A/F?
- Help with starting EcuFlash software!
- This is why TurboTrix is the best =)
- Bad ECU reflash?
- Noticed This With Evoscan
- FS: Tactrix Cable
- Need help with Evoscan
- instead of standalone
- 2004 ECU Rom question?
- timing first? or AFR's? pointers for Alky?
- Morality of sharing tunes
- Wideband tuning question
- Should you mess with the low-octane timing maps?
- MBC Or Not to MBC
- Any base flash suggestions?
- Target AFR log graph
- load flopping.... need some input
- Locked ECU Unlocker tool..
- EVO 9 maps 13,14, and 15
- Fast shifting knock is something to consider.
- problem
- 680cc injectors
- A great tune with EcuFlash (by EIP Racing)
- JDM ECU and EcuFlash
- Help with injector scaling
- Help reading map
- Random knocks with stock tune
- ecuflash PROBLEM!!
- A systematic way to lean out the fuel table
- First Reaction to a datalog
- definition for MN132750
- Ecutek and EcuFlash
- EcuFlash Knowledge Base
- Perrin EBCS anyone?
- reading/clearing CEL codes with ECUflash cable?
- Car stumbling, Logs/Maps inside..
- evo 9 boost control orific removed
- Quick Question.....
- flash for 10.5 housing on a evo with an 9.8?
- Inmobilezer code problem
- Need Some help!!
- how does this log look?
- TPS to openloop
- Evoscan website haxored!!
- Having trouble reflashing Dynoflash map
- Topic of the week?
- Mivec Tuning?
- tuning idle for large cams
- Just received cable, High knock and timing pull on stock map?
- ecuflash in texas??
- 03-04 rom read?
- Connection help
- Logged the 2 step today
- Posting Maps
- A weather related tuning question
- Boost Control
- Who's using Greddy/Denso 720's?
- displaying dual map question
- How to detect pulling of timing?
- I did some logging......inputs?
- ecu flash dyno tune results
- Stock 04 Map
- Rescaling Axis
- Cables in stock?
- Ecuflash tuning basics......
- engine immobilizer quick question?
- Is there no way i can use ECU Flash
- New information Load and throttle tables
- EGR temps
- ecu flash + bov now car flutters?
- ELM OBD2 and ECUFlash
- Correlating Evoscan Fuel Trim to OBD-II LTFT
- Remove WGA sol without fault?
- Knock, pulled timing and the low octane maps
- PRESENTING evoscan
- What happened to the Locked ECU?
- Coolant Temp and EvoScan
- Vehicle speed at &H2F confirmed
- Chaning the ROMS
- Evoscan with Innovate
- open ecu ?
- Safer tune produces more power.
- MAF readings at different RPM's
- Data Log Lab
- Help Viewing EVOScan logs in Excel
- e-flash questions
- Launch control help!!!!!!!!!!!1
- Evoscan ?
- Evoscan question?
- Question?
- Load found on Evo
- Where do I buy EcuFlash?
- Owners manual?
- Request IDs from 00 to 3F
- Good MAF info..
- Octane number found on Evo
- 21 psi
- where can I download a free log viewer
- Datalogging options?
- Confused, need help quick!!
- quick question
- EcuFlash ?
- Evoscan freezing
- Step increase in injector time at 7000 rpm
- Barometer readings under high boost/revs - measure of inlet restrictions
- EvoScan, Evo's, And Knock
- cant log into openECU
- MAF Hz
- Evoscan log script
- Making map-driven flash for the evo8 ecu.
- "hanging RPM's" and ISCV maps
- Flat Midrange
- Airflow HZ to Load Value?
- MIVEC dyno tuned!
- Map Switching
- evoscan ???
- Locked ECU's... Not anymore..
- My evo ix knock sum ok?
- 1,28 download problem
- fuel maps - I'm confused
- help real uick
- Quick Question
- what are your EvoScan idle tps readings
- Air temp in Evoscan
- Fuel trim nosediving during hwy cruise?? :confused:
- switching look up table
- Knock question
- EvoScan O2 voltage
- '05 ROM in an '03
- ECUFlash Power Record?
- f/s Tactrix Cable
- Which sensor reads air temp (noob question)
- Where is the correct .NET 2.0 download?
- 0 Knock with a/f @ 10.7-9
- Stroker Advice?
- Tactrix Cable
- ROM definition for ECU
- Last chance to get EvoScan
- P0300?
- How to Safely adjust timing
- How-to: Rescale Load Axis (percent) Values in Evo VIII ECU
- 2 step launch control @ 6,000 rmp
- Adding elements to scaling tables
- innovate lm-1 interface
- Boost control - what I have thought about so far - ideas
- ECUFlash and Outlander?
- Open Loop Load & Open Loop Throttle
- does ECUFlash work on Windows Mobile 5.0???
- MIVEC tuning
- Vehicle speed sensor DTC
- alky injection + 2 low/high maps
- Windows XP works fine Windows 2000 i got problems
- EVO IX Injector Scaling
- Another method of displaying Evoscan 0.8 logs
- Some good datalogging information
- Immobilizer not correct
- Can the idle be programmed into the tune?
- My idle keeps going higher...why?
- Evo IX Connector?
- Crazy ignition timing - Evo VIII vs IX
- Evoscan v0.8 feedback
- checked my afr's with the innovative......confused
- First datalogs, please comment
