View Full Version : EcuFlash
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. EVO X 53040010 XML file needed
  2. Openport 1.3 Unversal
  3. Using lean spool tables to match AFR's
  4. Alternate Map for tephra mod v5.1 9642001
  5. BlueMUT - logging via cellular
  6. New help finding some maps in two ROMS
  7. tuning problem with evoscan
  8. tuning questions
  9. Why big cams throw a P0300 code?
  10. timing during spool up
  11. ecu unlocker compatibility with vista
  12. Has rescaling your load caused the car to bog when the engine is cold?
  13. Rear O2 disabled thanks Mr.Fred
  14. 22.5 PSI vs. 26.5 PSI pump gas results
  15. Any one know what this Unit is?
  16. trims logging, strange values
  17. Help me to identify this connector
  18. Clean in 3rd, Knock on 4th
  19. converting 99860002
  20. Not scaling injectors???
  21. All bow down and give praise to the great disassembling ones!!
  22. Logging EGT via EcuFlash
  23. Definition File needed for EVO 8
  24. MAF Compensation Table
  25. knock tuning.
  26. ID2000 scaling and latency
  27. need help on which periphery bits to enable
  28. installing a GM 3-bar MAP sensor
  29. Major problem with my log *Please Help*
  30. How to set address?
  31. Will I have To Tune Again?
  32. Is this normal while logging Speed
  33. I think I may have found a new 3port boost solenoid...that comes on every EVO
  34. No activity from fuel trims
  35. Rescaling question
  36. 880cc Injectors installed. Scaling and STFT confusing
  37. Logging problem with Evoscan 2.6
  38. help ME open it
  39. How to read an ACD Error code?
  40. how does my timing look to you? no knock
  41. Had a weird issue with Ecuflash yesterday
  42. Help. i need a MAF Scaling
  43. evoscan root element missing
  44. in over my head with how many roms i have help
  45. 80040154 error
  46. How many have switched to SD? (anonymous poll)
  47. PLS help me open rom80230006
  48. WGDC is actually what is controling/building boost?
  49. ECUFLash ROM Deffinition Refference Data Base
  50. Speed Density Air Temp Correction
  51. Simple SD question
  52. Surging on stock turbo?
  53. disabled egr via faa bit 11 and now crappy cold start help
  54. Can bad fuel cause knock at cruise but not at WOT?
  55. how to log actual timing?
  56. Timing logged at idle
  57. Colby, Tephra, EVO4Mad and the rest of the experts, take a look.
  58. Alt Map not working (logged)
  59. 3 bar map sensor
  60. MUT table question
  61. Help: EDM EvoX 53040007 - no definition
  62. 3 Port Boost Solenoid
  63. can anyone tell me the scaling and latency for Denso 660CC injectors
  64. new to evoscan. help me
  65. boot limit
  66. ecuflash not reading help
  67. I need a 2003 stock map,,,
  68. Agressive E85 ignition timing
  69. Openport 2.0 Cable for RVR in NZ
  70. Werid issue adjusting 2step and rev limt 2003 stockmap
  71. Help : Evo7 EDM FQ300
  72. looking evo 8 gsr RA xml
  73. A quick question on Map Switching for Tephra or others
  74. ECUFlash idle tables with A/C on
  75. ECU Unlocker
  76. Uprated Coil Packs ?
  77. Ever seen Knock like this?
  78. Need some quick help.
  79. ECU load commands at ignition startup...help?
  80. Hanging RPMS
  81. Inconsistent Logging Data
  82. JDM 3 Bar sensor pinout - anyone.
  83. Need XML for 5304-0010
  84. need help w/ roms
  85. Evoscan Request ID's
  86. Map stock boost on ecu??and definition file help
  87. NLTS(No Lift To Shift) For Beginners
  88. need help
  89. Speed density !!!!!Need help ASAP
  90. Map Tracing on EvoScan v2.6 ?
  91. stock mas limit finally found?
  92. EvoScan and WHP
  93. Ecuflash 1.41 unable to read EVO VIII
  94. EvoScan logging issues
  95. Help with tephra 5.10
  96. close loop timing vs open loop timing
  97. P0135 fix
  98. Phantom Knock??
  99. NLTS worked 'great' for me...
  100. Coolant Temp CEL periphery bit
  101. 1BYTE load going from 330 to 20? Logging rate Hz?
  102. Evoscan and WRX
  103. Weird Tuning Problem - Please Help
  104. Can't read 03 evo?
  105. Speed Density Help
  106. EvoScan MAP Tracer
  107. 96530006 SD issue?
  108. USB Detection on PC
  109. !Help with Openport 1.3!
  110. Serial wideband input freezing on vista64 with dynex on evoscan2.6
  111. Important ECU Thread Links
  112. New Code Help. (Code Gurus Needed)
  113. Speed density + NLTS patch??
  114. Anyone Have A Base Map For Evo VIII?
  115. P0243 problems.
  116. ECU Control Boost and Tephra Mod
  117. Injectors scaling after a cam install???
  118. For those who have problem logging wideband signal with Serial-USB cable
  119. Just did GM 3-port and Omni 4-bar. Got a few questions.
  120. Problems logging with Evoscan
  121. Looking to convert to Speed Density...help needed
  122. Gear based timing map (drag vs road race tunes)
  123. 2 Inherits?
  124. can i bypass the immobilizer on my '06 MR?
  125. gear based A/F? or am i missing something?
  126. 3 bar map sensor and Evo 8 EDM
  127. Best 2 Step Settings
  128. EcuFlash manual
  129. Big Cams Cruise Tune for the Evo 8
  130. LM-2 logging with EvoScan?
  131. got a quick Ix timing question.
  132. Some 969400011 Periphery Mapping Information Help?
  133. Prescision 880cc and scaled to 713 is this not correct?
  134. 94170015 ROM with 2 Byte load
  135. To those running SD on stock ECU: need logs
  136. ECU not reading over 100load?
  137. need help with 96420008 to 94170015
  138. How does the ecu determine which gear you're in?
  139. RC750cc Scaling & Latency
  140. kelford 272 cams - Vacumn Idle
  141. Evo 5/6 ROM disassembly?
  142. Quick Fueling Question
  143. Windows XP or Windows 7 for EvoScan and EcuFlash
  144. issue with throttle after acceleration
  145. help with evoscan can't find logs..... kinda
  146. ecu adds timing????
  147. MAF Hz to lb/min formula?
  148. Can/how do I disable the MPD sensor??
  149. Logging and tuning on a flat road
  150. 96530006 and EGR/EVAP
  151. Need Ecuflash 1.31
  152. Curing overboost with ECUFlash
  153. Kelford 272's, TBE, Perrin filter. LOW OUTPUT on E85
  154. 3.5 bar sensors...AEM & SSI...one the same?
  155. Noob Tuning
  156. any power to be had going from 10.5 to 11.5 afr?
  157. comment on choice of MAP sensor for logging boost, SD, etc
  158. evo reflash info
  159. HELP:Can't view all my parameters for my rom (newbie).
  160. evoscan with aem wideband probs
  161. car suddenly running like crrrrap
  162. ROM 88840017 - JDM MAP and TE 2J1 WB
  163. Need Help, rough iddle with Cosworth M2 Mivec
  164. p0171 & p0300 after tune w/bigger injectors
  165. I need a 94170015 .bin .rom stock factory tune file
  166. disabling rear o2 sensor: which method did YOU use.
  167. Lost my evoscan program
  168. phantom knock i guess?
  169. help i am new
  170. EvoScan on a 1g DSM?????
  171. quick question
  172. Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
  173. What indicate Blue text in EcuFlash
  174. Is any one running a 2.3L Strokerw/big turbo On Stock Ecu/Stock MAF? Please Chime in!
  175. load cap address
  176. HELP Definition File (Xml) needed for Evo 9 MR JDM (80092002)
  177. Question on evo live map, load/timing not corresponding
  178. issues using my apple computer
  179. anyone with a modded/working 88590013 map?
  180. 88570008
  181. Quick Load based boost question
  182. High idle and I'm totally stumped
  183. loads very high
  184. fuel trims dont move....
  185. BOV / DV questions
  186. Comments on Tephra's Gear-based boost control w/ mrfred's direct boost mod
  187. AEM Analog Wideband Gague 30-5130 and evoscan
  188. Evo Scan connection issue..
  189. need help w/ immobilizer
  190. Fuel Pressure Question
  191. Can i log at 10hz exactly
  192. throwing DTC P0513 and car wont start
  193. Issue converting from 94170015 to 96530706
  194. Issues with TephraMods
  195. Knocking problem
  196. AEM stopped reading in evoscan
  197. Locked computer
  198. Coolant Sensors & associated gauges: dash vs ecu
  199. Cannot edit xml files
  200. USB to Serial Compatibility with Vista x64 Bit??
  201. ECU flash help
  202. EVOSCAN XML help plueeease...
  203. reflashing evo 7 ecu on evo 5
  204. Ecu controlled boost with aftermarket hp wastegate
  205. Configure AEM 5 BAR Map Sensor
  206. any geeks heavily modified the way gps logger does stuff?
  207. Question about Bosch 1000cc Injectors
  208. which thread has the evoscan LC1 scalings in?
  209. ecuflash 1.42 installed & tatrix cable 1.3 not working
  210. How good of a laptop will I need to start tuning?
  211. Evo8 ECU in a 1G DSM in the works!
  212. 97470001 to 96530706-v7t6 Problem ...
  213. 1.3 VS 2.0 tatrix cable's
  214. Convert evoscan files to logworks
  215. need advice about my map
  216. AEM to FLASH
  217. Immobilizer help!
  218. Can't get EcuFlash to read stock ROM
  219. How does my High Octane Map Look?
  220. Other/Additional Definition Files...???
  221. Problem converting to 96530006v5.10
  222. Customizing logged items in Evo Live Map
  223. error message when trying to upload maps
  224. Can't edit XML File
  225. Interpreting 2 Byte Load
  226. Looking for a Tuner!
  227. sh7052f developer needed for project
  228. how to connect to the ABS ECU?
  229. wanted: evo 6 LHD electrical wiring/circuit diagrams
  230. MAF Adder
  231. 96530706 + DMA +LiveMap + SD - working
  232. Can A GM 3 Bar MAP Sensor be Used to Log Boost?
  233. A tuner question!!
  234. ? Fuel Trims ?
  235. Data windows resizing?
  236. Best alternative for the 96420008 rom?
  237. Help with Duty Cycle Please!!!
  238. Running rich no matter what i do
  239. Can't save patch?
  240. tell your opinion...
  241. Why does my rom say 2004 when my EVO is an 05?
  242. Which Rom
  243. Need How To on INstalling MAP
  244. Patch: Force OBD Inspection Pass (acamus, mrfred)
  245. what is the perfect AFR and ignition timing ?
  246. Need Help For Those with JDM IX GT
  247. Name that Map
  248. Problems Connecting with Evoscan.
  249. Which Serial to USB converter works with Uego and Evoscan
  250. Interesting read: Ford developing laser ingnition
