- ? About EcuFlash and OBD 2 Generic Scan Tool
- Evoscan help please...
- EVO IX ECU Reflash
- How often does your tune stray?
- Going to JDM land
- Questions PM'ed to me..
- NEED Serial to USB driver please...
- 3 logs... got any suggestions ?
- For those trying who need info on GM 3bar
- Tactrix Cables on ebay
- open/closed loop.
- Interesting findings from a weird setup...
- Added IDC?
- Anyone can help me out with e Evo 8 Map???
- My downpipe is likely causing false knock
- Immobilizer Question
- Need a file please... Stock IX map...
- Odd Immobilizer problem w/ dealer
- does anyone have the cable in stock?
- How to change Idle RPM?
- FQ 360 IX mivec/ ignition maps
- 500whp Tuned MIVEC on stock turbo
- JDM MAP sensor vs real load value
- Cali's 76 vs Shell 91 octane.
- when tuning what needs to be changed
- Macs and ECUFlash/Evoscan
- Help needed installing Ecuflash
- Method For Tuning Part Throttle
- Why!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I have knock that I can't explain
- ecuflash maf translating?
- tune for better gas mileage?
- HELP! EVO wont start after flash
- Some advice with knock and adjustment [pics]
- Setting up Wideband.
- Post and Evo Scan?
- Unknown ROM image please help
- My First Evoscans..... What do you guys think?
- flash question
- New GUY
- Obd-ii Scan Tool Software That Works!
- Help, car will not start
- Westgate and Boost control
- AFR map advice
- ecuflash cables, maps?
- Attempt for the final answer.
- ECUflash v. ECU+ compatability?
- MAF Calibration
- Need evoscan.txt for latest evoscan + dll
- calculated load taper?
- Ebc?
- MAF Sensor Filtering
- Next version of Evoscan?
- 03 evo ecu -> 03 eclipse
- question about injector scale
- MAF Scaling
- Unable to connect
- AEM UEGO Serial Cable Instructions
- adjusting "boost cut"...
- Quick Off Topic Opinion.
- smog?????
- Boost/Taper fluctuation in different Gears.
- Ecu flash question?
- EcuFlash & Tools... 64 bit Support?
- Have ECUflash and cable, now need logger software, any ideas???
- Strange RPM values
- Cured my knocking issues. Wasn't the tune.
- Battery Voltage?
- Fuel Trims don't change in evoscan
- What timing are you running for peak torque and max RPM
- Hotter day = more power
- Silly idea to log boost in EvoScan??
- Can't install EVOSCAN Help!
- Inconsistent Air/Fuel Ratio
- High Load Calcs
- Evoscan Download help?
- throttle tip-in adjustment
- Opinion on low and high maps.
- Mitsulogger v1 Officially Released
- low octane maps leaner?
- MitsuLogger v1 to be Released this weekend
- question on afr on maps
- Quick easy question, please help!
- Aftermarket DP with built in bunge?
- 2-step launch.
- What happend to the small description?
- Evoscan Log Viewer?
- recommended boost pressure question
- tuning...
- Innovate LM-1
- Fq340?
- flash or custom tune on dyno?
- Recommendation for wideband please
- Opening JDM Maps????
- Are base e_flashes interchangeable.
- Stock Evo IX map
- Wideband serial connection
- AFRs, Low RPM, High Load ??
- Need Some input! back 2 Basic Bolt ons
- Has anyone had success getting the load to read correctly for .97 Evoscan?
- odd timing
- Mail-in tune, No MIVEC Changes?
- Dataloglab definitions for use with evoscan .097
- Gauges for Evoscan v0.97
- Load with GT-3076
- Injector size?????
- Boost Taper with MBC Evo 9 MR
- How to retune the block of 8* timing?
- 100 octane + Ecuflash
- Gas stations based on Experience?
- EcuFlash+OSX [screenshot]
- Tuning for Intake?
- Is there any Closed Loop Adjustment in Ecuflash?
- Questions on new and old software
- Need Help changing Immobilizer
- ECUFlash Cable ?
- AFRMAP numbers
- Those with Dyno experience >>> Timing light ???
- Best Wideband??
- anybody has a flash on a stock evo?
- Help with EvoScan, EcuFlash.
- unstable afrs?
- unstable afrs?
- Load Cal off???
- Deleting error codes
- CEL codes with Evoscan?
- Evoscan / Computer help
- Air Volume Reading?
- On road Dyno graphing? with .97?
- Idle target AFR map?
- Can oil pressure be logged thru EVOSCAN
- ECUflash Experience
- I'm maxxed out. WTF
- Un-associating deffinition files
- Don't think it's the tuning - trying to find the culprit
- Heading to dealer, got questions...
- EVO 9 Open Loop Throttle Low and High?
- 1000cc injector Calibration
- Why the hell won't my computer install my cable?
- Request IDs
- Anyone have EcuUnlocker 1.1
- final say.
- false Knock
- New Logs - These Seem Better Except One
- Knocksums and Timing
- Any ECUflash tuners Have 91 octane experience?
- Controlling Radiator Fan with ECUFlash
- Highest safe level of PSI on 91.
- HOW TO - Control boost using ECUFLash and the stock boost solenoid
- My flash and and locked ECU!!
- can not open maps evo IX
- May have solved my knock problems...
- out of stock injector...
- MitsuLogger V1 Beta 3 to be released tonight!
- Weird load calc. with log analyzer
- short term fuel trims reading high
- EvoScan v0.97 supports for Innovate LC-1 / TurboXS / PLX
- What do you think about this log?
- Throttle hang and the Idle Stepper Table
- Designing a logo for EcuFlash?
- Serial Output on WB -> USB Cable -> Laptop?
- Proper Way To Lean Or Richen Afr?
- Still confused on Taper down.
- ECU Locked
- CAN'T Download Flash
- ECUflash 1.29
- MitsuLogger v1 Beta 2 Released..
- Still playing with boost, need some advice!
- How do I log AFRMAP?
- Knock sum with 100 octane and 1.6 bar??
- getting started
- whats wrong with this pic
- How much load??
- cars feels like boost cut but its removed
- Question about boost level and knock with a flash
- What's the best formula for figuring out LOAD?
- Anyone with JUN 272s with ecuflash......
- Change MIVEC to JDM after tune?
- need help!!!
- 2005 ecu in 2003 Evo?
- First log attatched
- MUT at high baudrates WORKS! 62500 tested.
- Load Analyzer Question
- High/Low maps the same
- Funny Numbers in the X and Y axis
- Custom street tune?
- How does "Fuel Trim" work in the ECU?
- A few questions
- 2 quick questions.
- dyno and tune the Car tell me what you think
- tools for disassembly of a ROM?
- 2nd o2 Sensor?
- Quick way to calculate actual AFR
- AMS 2.3 + RnR GT30R results w/ dyno
- SmoggyLog: 91 octane, 95 degrees out, 21.3psi boost
- Logging AFR with evoscan?
- Logging Load
- I want more PSI??
- ECUEdit Now Supports EVO Logging!!!!
- Strange Fuel Problem
- Please Help!
- Car dying in neutral - Fuel trims way off - HELP!
- is this timming ok??
- Datalog Lab Dyno
- Lean at idle...getting very frustrated!
- ECuFlash wont work on my car after Mitsu gives me new immobilizer...
- What Wideband lamda for Evoscan and future logging programs?
- Unexplained Knock
- Evo 9 hex on Evo 8?
- eflash question?
- stock ix hex
- EvoScan Charts - Opinions Please
- Stable Boost is Very Important!
- How to ECUFLASH Questionsl.
- No direct reading of load from ECU?
- creative way to keep a lap top in the car.
- 04 & 05 ROM differences
- Stroker Timing
- sending rom
- libmut
- Need help analyzing EvoScan logs
- Cable for sale
- coolant and air temp revisited
- Locked out of my ECU
- ECU Hi/Lo Octane maps selection
- Changing mivec map...few Qs?
- how to make more rich or more lean
- 18:1 AFR at Idle!?
- Looking for advice/comments on my log
- tratrix cable and other stuff i have no idea of
- EvoScan w/LC-1 Problems/Warning!
- best AFR safety/performance,
- evo scan question.
- Mitsubishi Logger proof of concept code WORKS!
- Take a look at my logs :) please
- How much boost with 100 octane
- 2 Step and knock sum??
- what should i set my ecu to
- Heading back to the Dyno
- O2 Sensor tests
- Newbie Wideband Questions
- Suddenly ignition cut, Log inside
- Decipher my datalog (Evoscan)
- Bad o2 sensor?
- 93%-98% duty cycle on Evo IX with just a mail-in flash?
- Internal ID: undefined
- Anyone having this problem with v0.9?
- Evoscan 0.9 airflow volume reading
- Confirmed: AEM UEGO logs in evoscan 0.90 just fine.
- New to ECUFlash - logs inside
