View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21
  1. Jestr anti-lag
  2. EvoScan DTC/SES Light Checking...Help please.
  3. EvoScan DTC/SES Light Checking...Help please.
  4. how long of wait for flash
  5. Need some Advice here...
  6. ECUFlash error...quick question.
  7. Little help - making it leaner at idle
  8. tune to shoot fire ball.
  9. Sharing ROMs So We Can Learn
  10. So I emailed Jestr Tuning...
  11. Hanging Throttle, and the "cruise control" effect [POLL]
  12. Idle w/1000cc injectors and 280 cams
  13. TPS problems
  14. What flash from who? for New Hampshire
  15. Does anyone have this with the 1.29 ECUFlash?
  16. 1.3M cable problems?
  17. anyone use mitsulogger and zeitronix simultaneously?
  18. Wastegate duty cycle maps 1-4...???
  19. OS X libmut logger
  20. Why won't Aktivematrix verify my account??
  21. Newb Zeitronix Question
  22. Here is my datalog on Evo IX!!!
  23. EcuFlash Dyno Tuned 328 awhp
  24. Question: Driving technique in order to log appropriate data?
  25. MBC needed higher boost on ECU Flash
  26. how do these look? Newbie...
  27. question logging with mitsulogger
  28. why i can't save/open rom?
  29. How to get ECU FLASH??
  30. my tps only goes to 99.6?
  31. how much is acceptable? knock
  32. Antilag table defined
  33. TPS adjustment,?
  34. Wierd Knock...logs inside
  35. What parameters do you log and why?
  36. need help downloading Mitsulogger
  37. Tuners "Scrambling" their maps.
  38. email rom to my self? how?
  39. Evoscan
  40. stock timing @ peak torque
  41. Are loggers all getting EVO RPM Wrong?
  42. JDM evo wants to use ecuflash?
  43. 91 octane to 100 octane tune on a IX
  44. ECU Flash
  45. Lean spool address in 05
  46. Help needed using ecuflash and a tactrix cable?
  47. Tuning for a flat Torque Curve
  48. Idle, low speed cruise, high speed cruise question
  49. EvoScan help
  50. computer requirements for Eflashes
  51. The Best ECU Flash Tuner
  52. Boost pressure differences from 1st thru 6th gears.
  53. 880's with reflash???????
  54. Help....2002 Airtrek Turbo or Evo7 GTA xml Definitions wanted
  55. Ecuflash tuning question
  56. Anti-Lag Question
  57. Evoscan and LC-1 - Weird readings
  58. TTP e-flash
  59. Finally success!!!!
  60. Is my tune safe for a long road trip?
  61. EVOScan Download Question...
  62. Which ignition map to change?
  63. Considering ECUFlash on my IX
  64. stability of boost with stock bcs
  65. Mitsulogger v1.5 - Can it be?
  66. EvoScan and check engine lights
  67. Tuned on 100 octane/evoscan log??
  68. EvoScan Frame by Frame?
  69. P0300 error happened to me
  70. Clutch pedal position sensor
  71. Maf Honeycomb Q Not kidding
  72. AFR Map scaling values when tuning
  73. Base Map???
  74. Vendor e-flash question
  75. smooth or rough?
  76. NO wideband with flash!!!!!
  77. Rescaling load.. When to do?
  78. How much longer until evoscan .98
  79. how many pulls?
  80. Sending logs to a tuner
  81. just want to see something,
  82. Ecu+ & EcuFlash running on linux ....
  83. Tactrix cable problem...
  84. Obd2
  85. Drawing the line with inconsistency?
  86. TTP-Engineering Re-flash = WOW!
  87. 91 VS 100 Octane Tune
  88. Evoscan Datalog
  89. need help with "Unknown ROM Image"...
  90. Logworks and Dataloglab
  91. I only drive in 3rd gear
  92. pls review my datalogs
  93. Bought myself a laptop for logging/tuning...
  94. Logging Questions
  95. Water Temp
  96. How to tune for more torque??
  97. Knock adj.table
  98. Riddle Me This - EvoScan 02 Feeback Trim
  99. 298awhp with a test pipe and intake
  100. Scaling for PTE 780 Injectors
  101. Flashing for mods?
  102. ECUFlash newbie
  103. Disconnected battery??
  104. Help needed - rkrv: preamble 1 error
  105. Evoscan help
  106. Load
  107. Cannot read ECU - Blank Prompt - Help?
  108. Explanation needed for "Min Coolant Temp for Closed Loop"???
  109. First log with Logworks/Ecuflash
  110. Flashing back to stock
  111. Engine stumbles... can this be tuned out?
  112. Getting Data Log Lab to Run Right????
  113. Minor ECUFlash and Logging rant..
  114. Unclipped 2 byte airflow logged
  115. Check out this log
  116. EvoScan Setting File
  117. Newbie, but not an idiot...need a couple clues
  118. question about datalab
  119. EcuFlash & Mac OS X
  120. How to log AFR and RPM using LM-1 and Evoscan?
  121. EvoScan Timing Doesn't Match EcuFlash Map?????
  122. What do u do after you dial in your injectors?
  123. How to: Tune your own MIVEC maps
  124. What racegas to tune for??
  125. NGK AFX Wideband-- Compatible with EvoScan??
  126. evo 9 vs evo 8 load calc.
  127. HELP -- no response
  128. Maf Scaling table
  129. Open/Closed loop mode question along with fuel trim/injector latency issue
  130. First Logs...your opinions?
  131. Where the F do I buy the Tactrix cable?
  132. openecu webpage ???
  133. reading ralliart euro ecu for evo8
  134. EcuFlash download
  135. Knock Issues(?)... what do you think is up?
  136. Stock Evo IX DLL Dyno
  137. Please post ECUFlash/Evoscan/Mitsulogger Questions
  138. Which logger has the dynograph feature.
  139. Please help me understand some before-after dyno figures
  140. injector scaling and injector voltage latency
  141. HOW TO: Change the .xml to open maps
  142. EcuEdit - Impressions
  143. ECUflash and Evoscan problem... not reading car..
  144. Knock in 2nd gear pull
  145. mitsulogger & zeitronix zt-2
  146. Brand of cable for serial to USB?
  147. Datalogs of completely stock 05
  148. Valet Map?
  149. EVOScan parameters
  150. Boost with Ecuflash
  151. EVOscan: TPS not registering...
  152. another source for cable & afr sensor
  153. increasing boost.
  154. Need help with my rom please!!!
  155. injector scaling question
  156. new to ecuflash logs to look at
  157. Feul Trim ?
  158. what do i need?
  159. evo IX ecu part number
  160. WHAT RPM IS YOUR 2 Step LAUNCH SET AT?
  161. EVOscan HELP please
  162. Latency and battery voltage question
  163. looking for email maps
  164. Stock turbo, stock actuator, intermediate gears, top end on pump gas
  165. Minimum boost on an E8 MR ?
  166. Misfire? EvoScan+R-500 log
  167. closed loop at 15.3
  168. EGT - a tuning parameter?
  169. Good results from EcuFlash on TBE Evo IX
  170. cable question
  171. stock Iridiums vs NGK BPR7ES
  172. Does this look bad?
  173. How-to flash your ECU using ECUFLASH
  174. USEvo8 Ecu immobilizer bypass
  175. Tuning for Injen start-up issue
  176. How to set up datalog lab?
  177. ecuflash question obdII
  178. ecu flash and top speed
  179. Boost too high?
  180. Wideband Newb
  181. Interesting case study
  182. Datalog Lab .car file for IX SE?
  183. Problems with Mitsulogger
  184. EvoScan + DatalogLab + EcuFlash
  185. max wastegate duty
  186. Mass Air Transfer functon
  187. need help
  188. E-85 and EcuFlash
  189. Certain Mod Flash
  190. MWDC Tables ?? Please Help...
  191. Accuracy of IDC calculations???
  192. where to get evoscan
  193. How many times have you flashed?
  194. Continuity between high octane timing maps
  195. ECUflash window display problem
  196. Where are your closed loop maps
  197. Boost 24 psi +
  198. High & Low Octane Fuel Map Question...
  199. 10.5-11.5 (difference in power)?
  200. Evoscan Help
  201. problem reading ecu with ecuflash
  202. EVO flash
  203. Tuing the MIVEC ???
  204. Same old question
  205. Has anyone heard from Jestr/John?
  206. 2 Air/fuel questions
  207. i need TPS resistance value???
  208. Decel fuel delivery, stoich @ 0% tps? WTF!
  209. NLTS possible with ECUFlash and stock ECU?
  210. DIfference between Mobil 93 and Shell 93 with 10% Methonal
  211. texas tuning
  212. How long until evoscan .98 comes out?
  213. EVOscan question..newbie?
  214. What program is needed to run ECU unlocker v1.1???
  215. Restrictor Pill pics - IX Jestrtuning flash *pics*
  216. Data Log Lab Definition File For TurboXS Tuner
  217. inyector change
  218. Forgot to write down Evoscan Serial # STUCK!!!
  219. Injector Size Scaling Question
  220. OK guys, playing with ECU FLASH, I need ANY Rom/Tune. 4 Testing only!
  221. Question after dyno pulls
  222. Where to download ECUflash from?
  223. Any ECUFlash tuners in Dubai
  224. base performance map (to begin with)
  225. Out with the old, in with the new - Tuning session with TTP-E
  226. Is this timing map good?
  227. viewpoint on ecuflash and evoscan...
  228. EcuFlash Self-Tune Question
  229. JDM Evo IX MAP sensor group buy
  230. major screw up
  231. Compressor map calculator
  232. need help with ecuflash!!
  233. stock injector rescale
  234. EvoScan FTDI read timeout
  235. EvoScan v0.98 Wideband Support
  236. dyno results ecu flash
  237. Boost Error correction/Desired Engine Load.
  238. Ok I did my first logs
  239. For Euro ECUFLASH users --> ROM & Def for EURO evo 7/8/9
  240. Did my first log
  241. Knock through the gears.
  242. 12:1 afr for daily use?
  243. See if you can figure this one out.
  244. Need Some Help
  245. Code P0171 After EcuFlash
  246. Distinguishing USDM from EUDM and JDM from VIN code?
  247. EVOscan love for PLX?
  248. status of 2 byte load?
  249. ? About EcuFlash and OBD 2 Generic Scan Tool
  250. Evoscan help please...
