- Restrictor pill..
- Did anyone know of this ecuflash feature
- Should I'd be flashing soon?
- EGT too high, reading 2,200 F
- AEM UEGO need help.. Is mine too old?
- Mail in Flash...Dyno Flash or Buschur Racing?
- Mitsulogger v1.6 Beta 3 ***RELEASED***
- 845cc injectors + ECUFlash
- the fuel map, a question
- Dumb question on ECU reset
- Help Connecting...I'm a little flustered
- OBD-II Scantech Running on my Bench ECU Harness
- log boost with JDM MAP sensor (updated instructions)
- boost enhancement start/stop
- Partial Throttle Knock ?
- noob question for Jestr tuning
- log WGDC in EvoScan
- Help setting stationary rev limiter
- Ecuflash 1.3
- dataloglab question
- Timing advancing, while knock counts rise
- Boost Question on 9s
- 2005 Evo8 ECU's have vin# embedded in them
- tuning experiment
- Cant get Antilag to work
- what boost with stock fuel system
- EVO8 Bench harness works.. Mostly..
- uego 1000 USERS
- Data log lab Help??
- E85, Idling problems
- -12.8 Fuel Trim Low
- Please comment on this dyno graph..
- Mitsulogger v1.6 Beta 3, INNOVATE SUPPORT to be released
- What are you guys logging while tunning
- Is this the right cable (tactrix cable)?
- A flash I made. Review?
- Please comment on my graph!
- 03 - 05 MAP. TBE, Intake. Need this map please!
- evoscan knock sum question!
- question about evoscan knock sum!
- Sorting out the details of realtime mapping
- Need help.. Review my logs plz.
- Need help - Innovate LM1 with ECUFlash Issues
- Evoscan log with AFR(uego)
- Need a bone stock 03 ROM
- ECU wont hit the higher load cells
- Boost vs. Timing -- Optimal Power?
- Leaving the Openport cable plugged in - does it draw power?
- Jestr Mail in Flash....
- have 03 post-P0300 rom?
- Our ECUs can have eight sets of maps...
- po300 "fix" ?
- Need ECUFlash 1.28 or 1.29a
- Q's about purchasing a wideband
- ECUFlashed, heavily modified, and still passes inspection.
- Looking for a comletely stock map.....
- ECUFlash Troubles
- Running fuel map in RAM - tested and working
- Advice on these, more power on the table?
- Lost Password/Serial Number for ecuflash
- Timing at idle- log
- Wtb Oem Evo 9 Ecu
- Need advise on my flash
- Thanks Jestr! + 40 HP
- issues with ecuflash not working
- phantom knock?
- How would I tune my evo8 acc. to 3037 turbo kit?
- Wideband Logging LM1
- why does exhaust modifications require ecu remap?
- Very Beginer Intro please
- fired up the 2.3 with ecuflash
- Tuning books or courses ?
- 05 EVO8 MR map->03 EVO8
- Jestr M1 flash gained me 20whp/50ft-lbs
- Need help testing new mobile logger.
- look at my strange map. need some help
- Strangest .98 evoscan issue
- A/F R... and Knock,,, what should i buy
- Does this look like I have a boost leak?
- Stock ECU records!
- Can someone pls look at my log??
- cant get ecuflash towork anymore.....
- New EcuFlash 1.30 released
- libmut help
- How to use Dataloglab
- injector pulse width calculator (link)
- IDC & Fuel questions
- Ecuflash 335awhp/296torque Street Dyno
- Discuss: Real time mapping DSM Link style?
- Begginer map, K&N cone, and CatBack
- first dataloglab power / logs and a few questions
- Value for injector scaling using 660cc injectors??
- Successful test of reading any memory location
- Vista Compatibility ?
- Ralliart Evo 7 rom on stock evo 7 ecu?
- Different AFRs for different pulls/ Lean spool/Logworks
- Can someone post a stock MAF Scale from ECUFlash?
- Innovative 02 Replacement?
- Data Log Lab question
- 2.3 with 35R other bits, ecuflash, almost ready
- EvoScan and AYC/ABS readings.
- First tune observations
- hitting really high load on stock turbo?
- Cold Start AFR's
- Just got ecuflash
- Mistulogger Vs. Evoscan
- Boost Limit Numbers
- Idle "ranging" till warm
- Dumb question about EcuFlash
- Approximate boost number
- LC-1 install guide?
- Unknown knock source
- My 1st attempt at logs...
- Best way to spend $52...
- Evoscan v.98
- Weird Idle - What to adjust?
- Fuel trims - constant values
- has anyone been able to get their AFR curve this flat with ecuflash? :P
- Another...review my first logs
- Car will not start after new flash
- Wideband with Evoscan
- Best Way to connect AEM UEGO to Evoscan?
- Evo VII stock AFR ...Lean!
- 2 Step
- 21.5psi peak 326awhp 323awtq with a turboback
- 349whp mustang dyno EcuFlash Map
- 36 counts of knock as soon as gas is touched and randomly...
- Problem with new Evo Scan
- Evoscan knock detection
- I dyno'd again 306awhp 312awtq with test pipe and intake
- Q about rescaling load on maps...
- ECUflash,280's,1000cc, & 35r!
- Flashing the 4G69
- where to get The Tactrix cable & ECUFlash software
- A:F 0.5 leaner when it's colder outside
- RPM not showing with Mitsulogger
- welcome me to shouldn't be
- Mitsulogger v1.6beta1 To be released
- Plx M-300....
- Man i love ecuflash.. some other tidbits..
- evoscan "air temp"
- Vista and OBD2 Scantech issue
- MapTracer for Evoscan and Mitsubishilogger
- Cable Recognized...Still wont connect....HELP!!!!!!
- Boost/evoscan/boost gauge
- You & Your Wideband & Evoscan
- EvoScan v0.98 Now with Power & Torque Graphing - Map Tracing completed also!
- Target AFR and Actual AFR
- removing phantom knock with thermal insulation.
- Hks Dli 2 ?
- fuel map smoothing?
- Bad Gas/Injector/etc?...log inside
- changes to ecu map
- Mivec and Knock..
- Some help with my timing maps
- Evo 8 with ecu-based boost control
- Maximum Timing Advance: IX
- "No known code"?
- Assembly language confusion - please help me understand linkers
- is this boost dip look normal?
- Data Log Lab Question / LoadMax160?
- SES light after flash
- mitsulogger???
- Questions about EcuFlash...
- If you have to ask, maybe you shouldn't be tuning yourself..
- Still waiting on evoscan .98
- windows vista???
- F/S Tactrix Cable
- Unable to read ECU
- Looking for E85 help
- reminder- exhaust leaks boost leaks
- Ignition Timing Question
- EVOSCAN and LC-1(LC1) question
- Map Tracing App (EvoScan) - Preview ONLY
- Strange deceleration / engine braking
- Power graph of FPEvo Green
- Please review my maps
- Steps to Injector Scaling - ?
- Small Tool: Offline Map Walker
- Don't forget to look at your low octane fuel map!
- Getting my Evo 9 ROM
- Tuning STi's???
- Jdm Evo Ix Rom Help
- boost dropping around 6k?
- Evo IX Ignition map differences / Boost Desired Load / Lean Spool questions
- Knock Count Unit of Measurement
- help!! my evoscan wont save my settings
- Evoscan not working
- Evoscan for MAC's???
- reflash
- Log & MAP Question
- who is using aggressive cams on flash..
- How to disable ECU knock control - if you really want to...
- does EVOSCAN do this??
- Discuss: Scheme for real time mapping
- Load scale view changes
- Totally Lost, please help
- help tuning
- How to XML a Bin. file?
- ECU tracing and MWGDC Tables
- Acceleration from Evoscan?
- Map switching up and running on my Evo IX
- next step?
- 1st Log - A few noob questions
- Anyone have 880cc latecy and scaling tables?
- Is venting your crankcase bad for your tune?
- Brief retardation knock 10 counts[pic]
- Theoretical aspect of knock in respect to piston speed.
- Understanding load
- How to adjust for a 255 fuel pump
- ecuflash /ecutek gurus
- Is it safe to increase by 0.2 bar
- Please review logs.
- Safe amount of knock?
- AFRMAP differs from fuel map too much
- I'm dropping into open loop and getting 10AFR at idle [screenshot]
- Need advice jester or custom dyno tune
- MAF frequency / fuel trims / P0300 questions
- i seem to be having a knocking issue no matter how i tune my map
- Selfmade Pocket MUTLogger/Dash first alpha release
- Tutorial: How to scale your MAF [pics]
- Difference Between RALLIART FQXXX AND OEM ECUs
- Stock timing/fuel maps...
- Ecuflash vs Power FC
- What's the difference between these two cables for datalogging?
- step by step to 2 byte
- ECU-Flash & cam set up on the IX
- What would cause a car to knock?
- How do you add a custom scaling
- unlocker program ?
- Windows Vista Compatability?
- questions about setting up ecuflash
- FQ360map for EVO 9 MR?
- Your estimate when tuning.
- Dyno #s
- LM-1 Issue
- Mitsulogger v1.5 Alpha featuring Wideband Support!!
- AFR adjustment
- IsEcuflash a pirated software from Ecutek?
- e-flash
- 03 Rom
- ecu tuning for meth injection failsafe
- New to 91 octane tuning!
- SOme LC-1 Questions for Understanding
- Pros and Cons Evo Scan VS. Mitsulogger
- DSM Link Cable?
- My logs using the Innovate Motorsports LC-1, LMA-3, OBD-II cable, & LogWorks2
- knock questions
