- At what mileage should you tune?
- A few knock counts on spool up...
- Lopey idle with MIVEC
- help pls.. dad's been stealing my car for joy-rides
- Dynoflash not working?
- what do you Experts thnk about this , how many of you have done it
- 94170008 ROM 2 byte load mod for dummies (like me :)
- aem o2
- Anyone running 280 cams without P0300 code?
- Modified BCS pill and general tuning (Review me!)
- IX top end boost with O2, WGA tightened
- VIII (8-10) counts of knock after 6000 rpms
- Load + RPM scaling...
- Timing map with 280 cams...
- Service Engine Soon Light
- logging wgdc, jdm boost and 2 byte load in logworks
- trying to get evoscan to work help
- Pseudocode to VB code to display max knock over the ignition map
- is 10.2 a safe afr?
- Installation and Tuning for Perrin EBCS...
- Cant remove Boost Cut..HELP
- EcuFlash and stock maf tuned to 571awhp
- Will someone look at these logs for me please?
- Quick answer please... Ecuflash version
- Ecu Timing Tables
- Logging with a Palm?
- ROM ID Flashing
- Mitsubishi logger live mapping screenshot
- Ecu Locked. Cant read..
- where tuners fear to tread...
- Help! EvoScan .99 2 byte load problem
- E-85 Ignition Timing
- Disable P0300
- my a/f & timing
- Fuel Trims Questions - bad day at the track!
- boost....
- very basic question on injector & latancy
- white evo owners
- Evoscan v99 issue
- i need some good advice someone that knows
- Cams installed...No lopey idle? Could it be in the tune?
- recomended specs for mitsulogger laptop?
- Need help with visual basic textmatrix displaying editable map - needs to be editable
- Possible to log CAM timing?
- ECU flash error: no known code
- LogWorks 3 Beta 1
- Tial e-wastegate and stock BCS hookup
- what AFR's should I aim for
- tatrix cable - Malaysia?
- Thoughts on my knock?
- Evoscan 99 and DLL with AEM WBAF
- anti lock FLASHING!!!
- Interesting find
- sobering thought for tuning
- What conditions do everyone use to log?
- Intercooler spray disassembly/explanation
- Evo anti-lag ECU disassembly
- my ecu flash/unlocker experience
- Boost and load?
- Which cams for IX FP green?
- KnockSum vs. external Knock Monitoring Device
- Knock Gauge and Alarm
- Understanding Barometric Pressure (units)???
- Can someone please review these data logs?
- Ignition advance going up and down!
- JESTR tune
- Weird A/F Problems
- Is there a way to make CLOSED LOOP richer without touching OPEN LOOP?
- open loop load 1,2,throttle low high
- Raising Boost Levels
- look at this log...?
- Ivey Tuned
- My humble request of tuning experts
- vendors offering flashes via email
- Jestr raised prices?
- logging boost???
- MAF output signal
- Want to remove/disable your rear O2 sensor without a CEL? Here's how..
- Need 91890014 Definition File
- Hey Guys. I'm new to the ECUFlash world.
- Logs posted, comments plsss....
- EcuFlash error message?
- warm start (rich) ?
- Rear O2 removal (Fix?)
- Lean Spool Disable, Before/After
- Which is the firts map to alter 1,2,3, etc?
- Mail Flash: Ok Or Not?
- making the idle lopey on a ix
- Injector Scaling ?
- Latency for 2.4
- Correlation of knock sum to voltage, and one other question.
- What program do you use to view logs??
- Formula on load calculation???
- Injector scaling/latency for Precision 880cc
- Knock filter updates?
- A problem with evo 9
- Start an Address list for ROM ID's?
- Question for the tuning gods
- Nitrous and launch control
- Would you send me a stock map?
- 3rd gear tuning has no knock but....?
- what is up with ECU Flash??
- 2 Byte RPM for IX - 88590015?
- More dumb knock...
- Another "Look at my tune!" thread...
- Inmobilizer code
- Flash question
- EGT readings in Evoscan
- LogWorks2 is awesome, question for Logworks users
- Knock Issues up High
- Near Perfect Tune....
- Reading stock rom, confused in how to proceed
- knock during deacceleration
- My ignition maps
- Getting ready to tune for E-85
- Ignition map 1, 2, 3?? Knock??
- Few quesitons on Reflash with EcuFlash, plsss
- 99 ish Octane Flag = Knock ?
- 272 maps??
- Timing and Fuel maps pics with some detail
- Problem connecting to ECU
- EVOScan/mitsulogger + injectors + load...?
- New cost for Jestr M1 tune!!!???!!!
- Questions about Evo IX map
- Help me decide which wideband
- gotta question when making logs and tuning??
- post alky timing maps please
- A/F Question and Log Review.
- Two logs, tuners help me out if you will...
- Question about evo scan
- Race Gas And Timing
- CBRD project 2.3 454whp/378wtq
- USB help
- Did not save my immobilizer code and stock rom, now car won't start, HELP!!
- ECU Flash remap protocole
- 2-Byte Load Issue
- Gurus hows my log look to you
- Calling evo4mad, calling evo4mad !!
- My timing map suck?
- another knock issue
- My map.... Is it bad?
- Adding injector scaling for IX t-13/14
- Cant connect with Tactrix cable...
- How are you "smoothing" the non WOT parts of your maps?
- texas tuning
- Cold start?
- EVOSCAN Difficulties
- Mitsulogger/ZT-2 boost logging issue
- Breakdown of open loop operation, anyone?
- Tune necessary for Buscher Air Filter Kit?
- mivec "30whp" gain on evoscan
- 96940011 05 EVOVIII ROM: Known Patches
- High knock count
- MP3 player adapted to ECU uses? 2GB, USB, display, control buttons, 75 MIPS device
- Tuning/Flashing 2003 Mitsubishi Lancer OZ Rally 5sp - Help!
- Help! Can't read from ECU
- check my logs
- Need help ASAP!!!!!!
- FTDI time-out?
- Need help, only boosting 15psi
- need help with ECUFLASH
- Problems with EVOSCAN V 2.cannot log (3rd gen eclipse)
- Ecuflash
- Anyone else with these Evoscan problems?
- Spare ECU Question
- “no response to any known code”
- Logging boost in evoscan/mitsulogger
- Evoscan .99 DataLogLab Definition?
- EVO8 2-Byte Load How-to 94170014 ROM!
- RAM address for load?
- VVT Datalog? How?
- 2.4L & 3065 finished - need help with base map
- Did my first log yesterday
- more knock in higher gear
- WOT log
- Can someone look at my logs???
- help saving my current rom
- what afr gaguges work with mitsulogger?
- Effects of pulled timing on power (pic)
- Was searching aktivematrix for some ecurom info and now I'm excited
- Anyone tuned EVOGREEN on stock ECU?
- Tuning 91oct
- Tuning 1000cc injectors on ECU Flash
- 12.04@114.8 evo 9
- Logging WGDC / No Worky
- Car stumbling/dying
- Brand New
- My First Logs with New Evoscan and LC-1
- Annoying closed loop problem
- tunning for Cams
- EVOScan Help, trying to log on an Eclipse
- Is there a way to eliminate the rich spot I get at peak TQ/boost/load?
- Wideband LC-1 - Power and Ground? Where and How?
- Negative Calculated Load Values?
- Question about EvoScan log files
- Quick Q about timing vs afr
- EcuFlash Read from ECU Button
- 110 octane
- Evo Scan and Windows Vista....
- Idle Stepper Look-Up Table Alittle messed up...
- Please view my log...
- ECU Timing Question
- Success dialing boost?
- Impressed with Ecuflash
- Evo7 ECU transplant to a 6?
- Question for those with 2byteload,airflow,and baudrate mods
- MitsuLogger question
- MUT Table 94170014 help, I think I found it
- E85 flex fuel switch on the fly
- Pill Placement for ECU Boost Control
- EcuFlash noob questions...
- 2 step/launch control is very slow on my car??? help!
- A Virgin Logger's first log (impressions+questions)
- Logging a 6 TME.
- Dump question about turbo!!
- Simple question
- First person to answer this gets a . . .
- E85 Cold start/Coldest air temp loged on wot pull
- Strange Knock
- error msg opening Ecuflash
- upgrading a few things from last reflash
- Decel enrichment??
- OEM Style Gauges for EvoScan .99
- Long term fuel trim
- various loggers
- Evo IX 2-byte Load & Lean Spool for Dummies
- Throttle Hang?
- I need ECUFlash v1.29
- How to disable the boost limit
- I need an opinion
- tuned our 2.3 evo project car with ecuflash...
- ECUFlash Error: rkrv: preamble 1 error
- Pasting Data from Excel to Ecuflash
- HO Igntion Map / Low RPM range question
- Evoscan v.99 Problem
- Mitsulogger 1.6 beta 4 - SNEAK PEEK
- Real time picture
- Evo scan 0.99 problem
- New fuel pump. What to change
- EvoScan v0.99 - Zoomable Graphs / RealTime Alarms / Power & Torque Graphing.
- EvoScan 0.99 out
- DLL numbers vs. real dyno numbers
- Trouble with EvoScan gauges
- EvoScan Log Analysis Needed
- ECUflash wont load my rom.
- Possible Blackbox?
- Wanted: developers for 7/8 realtime mapping
- Almost ready.. 2.3 35R..
- ecuflash error
- BCS Pill Removal Safety
