- Can't datalog..with either mitsulogger or evoscan
- Another Fuel Trim Question.
- Wastegate Activation / Deactivation value question
- please help car not starting!
- ECU boost control mods
- Need XML for Evo 7 MR560648 (E6T34871)
- 2 logs on the fire
- Impact of LICP on Tune
- Calling Malibu Jack!
- '03 EVO 8 tune, thoughts?
- logging many load variables
- noob needs help
- Engine just rebuilt... when do i flash?
- PATCH: CEL Flash on Loaded Knock
- Injector voltage latency problem
- Fuel trims on stock intake/injectors
- Evoscan and larger injectors
- Hks 264 272
- Fuel trim adjustments
- EcuFlash Glossary
- Evoscan MPH sample rate?
- Noises while flashing...
- Odd Load Spike?
- Help scaling injectors
- AFRs in Germany
- cold start acceleration enrich table?
- Stationary rev limit Problems??
- VVT map
- JDM IX_MR: Removing speed limiter
- help with ecu swap
- Code scanning on ODB2?
- need tuning for evo 9
- Something interesting venting BOV to atmosphere.
- I need a little help.....
- L@@King for best tuner in CO
- Need EVO IX stock map ASAP!!
- Tuning Guide for the GM 3-Port - My Experience..
- Different a/f in each gears at same load??
- Mitsulogger and LC-1 ?
- misfire at 7200 rpm?
- First log of a friend's tuned evo IX please help..complete newbie
- Dyno'd my first custom tune
- Immobilizer code change
- Car Down On Power Big Time
- Limits and Evo IX
- AFR Tuning - HELP
- Question for stock-ecu tunners
- hardware install failed
- How can i tuning my ECU ?
- Changing Immo in the ECU. Programming keys with new Immo. Possible?
- Tune for Cams
- can't read ECU, need help
- Mitsulogger formula to Logworks formula
- Evoscan wideband probs
- 431whp Stock turbo E98
- Logs attached for new mods -- anyone w/DLL?
- Help! Clutch in idle problem
- Need Map Opinions, Weird Timing/Load Issues
- Need your help.... please read
- Some help with a tune and possible wideband issue
- conservative meth tune?
- Timing : Fuel?
- Strange problem
- Trying to get a disaster running. Any help appreciated.
- Another Log Review...
- Cutout downpipe benchmarks
- Safe AFR
- ECUflash
- Did a few logs tonight...
- Any Interest in More Custom Pills?
- I cant richen up my car
- 2 byte load for 96940011???? Am I missing something?
- automatic tracking of peak boost
- evoscan > 250 load
- Need Some Help ...
- Tuning a stroker motor
- how to change my idle with ecuflash
- Help with Ecu boost and custom pill
- immobilizer code is 0001
- My Evo IX Maps
- Installing Wideband Suggestions
- adding extra cells to get to 300 load
- P0300 cell fix?
- Help With Evoscan And Ecu Flash
- EVOScan not working anymore..
- Check out my Evo IX tune...
- Need ECU Defintions for 03 EVO
- tuning for unleaded vs. leaded race fuel?
- Universal rom
- Help with Funky AFR
- Mivec and boost
- how to let torque hold longer?
- Ecuflash
- Tactrix and LC-1 Newbie ?'s
- need help
- a few observaions,
- fouled plug and logs
- Tune for Walbro
- injector question
- Simple help with AFRs
- installing 880's tommarrow and....
- RPM selection and DLL
- Where now???
- Ecuflash
- MacLogger 2.0
- Turbo Boost Error Correction basics?
- Stationary Rev Limit
- Using Mivec to induce Lopey Idle
- ECU flash help
- 2 Byte Load Spike in Logworks
- Good books/resources on tuning?
- Any comments on my tune?
- Log of slipping clutch
- how does my graph look?
- EvoScan v1.0 to be released next week with Map Tracer support
- wierd boost observations
- Cause of high idle
- Winter de-tune
- Tested: Ebay Filter
- Adjust Baseline WGDC RPM points and boost control?
- 20glt iam impressed!!!
- 2.1 bar boost on Evogreen - What timing???
- Stock 05 Evo Map
- How much fuel are you guys taking out?
- What IAT sensors?
- Change the init in a ROM?
- Boost with 100 Octane
- Insalled LC-1..Free Air Question!
- Help, my tune
- Evoscan difficulties... need a genius
- Wideband O2 Shootout!
- HP/Torq graphing function from EvoScan??
- LogWorks3 Beta 2 out for those of you
- For those searching for a wideband meter
- knock sums present while accelerating during idle why??
- ? for those using Logworks
- Does anyone have MAF scaling for open filter on gt3076r?
- Question about EcuFlash & Evoscan
- ? about Vishnu ECU Flash
- Advantages of GM solenoid over MBC?
- XmlHandlerHelper Error help!!
- tactrix cable ?
- Data Log Lab help
- ecu responding to nothing, locked?
- 2.0bar boost - which Boost solenoids
- Idle speed adjustment not working ...
- First time ecu flash, help with flashing anti lock light
- another log to view evo8
- going to be tuning a 35R car
- Evoscan 99 2byte load problem?
- Bigger turbo builds less boost on 2step
- WGDC wont exceed 78.43. Please help
- evo 7 P0136 and P0141 error codes
- Opinions on Tune ...
- Test Pipe=Rich???
- Invalid Evaluation Expression in EvoScan
- Ideas for Meth fail-safe points.
- Looking for an EVOscan tutorial
- Weird AF/R variances.
- Your opinions on my self-tune are appreciated
- Getting anti-lag working on EDM
- evoscan knocksum = ECUknock
- Evo VII GT-A ROM
- Logging Air Mass Strategies
- Question about Evo 8 & 9 Rom's
- Tested: JDM and GM 3 Bar Map Sensors
- Problems with HP/TQ in Evoscan
- Injector scaling ? AFR - WOT
- Apexi drop-in filter?
- ? about using GM 3bar for boost logging and ecuflash
- Got a wideband... Some help with my AFRs
- EVO Scan fails after reboot???
- Question those using alky
- Mitsulogger with multipe Innovate Devices?
- Fuel-trim mid - Which Fuel Load cell used?
- Mitsulogger use with a wideband???
- flashing newer rom
- Help with error..
- Diag Troub Code - FUEL PUMP RELAY
- lean cold idle, what could be the cause
- PSP for logging?
- Ecuflash safely tunablitiy
- When does the ECU pull timing for knock?
- Need help on Accel Enrichment Table
- Mitsulogger - Low fuel trim
- HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
- Tried to reflash and now cant start!
- Ecuload
- Pocket PC logging now working
- Some help with my tune
- Logworks and EcuFlash
- ECU FLash / Mitsulogger question / Dynoflash
- calc HP/TQ from EvoScan using Excel
- AFR Gauges and Sensors
- St. Louis Area: Who or Where to go for REAL EcuFlash Tutoring/Tuning?
- EvoScan v0.99 Question
- Emissions
- good reason to check tune in 4th gear...
- evo 8 fuel maps
- Boost control pills and ECU tweaks
- questions about tuning with evoscan and ECUflash
- Problem with Greddy E-01 BC
- Questions about the stock maps, fuel and ignition.
- wrong rom definition
- tuned mivec maps?
- CEL Clearer????
- what do I log to be able to generate HP/TQ in DLL?
- evoscan speed wrong
- cant log load calc after 2 byte load mod
- GM MAF without MAFT
- Ecuflash vs Evoscan settings ...
- Adding an intake
- Boost Enhancement (Anti-Lag)
- EvoScan v1.0 - Now with Feature Request tracking.
- Custom made pills
- Need Rom
- car starting and stalling, dumping fuel
- Help!!!!!!!!!!
- Open Loop Load 1 & 2
- What is the max load are u seeing guys?
- What a difference....
- Anyone have a Mivec map for cosworths?
- light load knock sum example/ suggestions
- my 1st log, 3rd gear wot
- ayc/acd bleeding
- 272/272 + Mivec = smooth Idle??
- Wastegate Solenoid Activation RPM
- windows mobile (programs)
- Laptop power issue!!!
- TTp Flash
- O2 Sensor Question
- Tactrix cable drivers?
- JDMMAP vs ZT-2 MAP
- laptop choices
- Alky fuel map help
- Changing Immobilizer
- Evoscan Problem
- what to get ecu flash
- track day log with logworks
- First Log on my Evo IX
- Anyone know how to get 2byte airflow in logworks??
- Lean spool qestions....
- Throttle dead to 20% TPS while moving (OK when stationary)
- Newb Tuning question (yea I searched)
- adding 10% FUEL
- At what mileage should you tune?
- A few knock counts on spool up...
