View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21
  1. DOes the avcr put you into closed loop fueling?
  2. Unusual load reading during datalogging
  3. Subaru EcuFlash Resources?
  4. Altered Idle stepper and ISCV tables
  5. ECUFlash Tune Milage and Mods
  6. Getting an error with EcuFlash
  7. Help with Knocking at 7000RPM
  8. Evoscan gauge Templates
  9. How to MOD your ROM with NLTS or others!
  10. evoscan questions please
  11. ECUFlash: Adding more Load/RPM Cells?
  12. Problems..
  13. Do Fuel Adjustments Impact Timing?
  14. who needs a tune in hawaii
  15. Will either of these 2 Serial to USB Adapters work?? Please enlighten!
  16. everyone replacing restrictor pill at WGA?
  17. Datalab??
  18. spool up timing/fuel question.
  19. strange problem with launch, thinking it is ecu related..
  20. Help: 2byte Airflow (96240008 RomID)
  21. Exact Formula.
  22. evoscan problem
  23. Evoscan .99 issue( need some help)
  24. Evoscan 4th gear pull from last night... thoughts?
  25. help! map sensor clip - possibly OT
  26. 2 Byte Load for 96420008 ?
  27. A quick question about Accel Enrichment
  28. Stationary Rev Limit not working?????
  29. FIC 750cc Injector Scaling/Latency?
  30. how to tune for VTA BOV with ecuflash
  31. Please check my gt35r on 91oct log
  32. Vehicle Speed Sensor Readings
  33. V1.33 problem
  34. Problem with fuel maps INF
  35. look at my rom?
  36. Datalogging guesstimate HP
  37. Compare Ecuflash tunes here
  38. How exactly does elevation change the tune?
  39. Looney Tune Fix
  40. Question about NLTS shifting.
  41. *** EvoScan Feedback Required ***
  42. Evoscan questions
  43. help asap
  44. Care to analyze my logs...
  45. My Tune - All My Settings & Logs
  46. Would someone care to check my logs?
  47. high logged load?
  48. LC-1 and ECUFlash
  49. majorrrrrr headache
  50. Need Help! definition file for JDM EVO 8 MR.
  51. help with ecuflash/tactrix cable
  52. EcuFlash 1.33
  53. Cell AFR verus actual AFR?
  54. noob to tunning/engine management
  55. Best Place to buy ecuflash/evoscan cable?
  56. Please help analyze my gt35r 91oct log
  57. DLL defination file
  58. how do I know
  59. Evoscan error, please help!
  60. Help with Evo7 STFT/CEL as well as VDP com port
  61. EvoScan: Can not find log maps in folder..
  62. Log Reqest: JDM MAP and Stock Airbox
  63. mitsulogger and data log lab
  64. DLL Results Vs Dyno Jet
  65. Lift off knock (cure?)
  66. swap question
  67. Accerlation Inrichment
  68. OK who did it, Someone selling flashes on EBAY
  69. Antilag Evo 8's
  70. Ball park date for gas?
  71. Question to the California guys.
  72. Newbie Play Nice
  73. Is Evoscan 1.0 out??
  74. Lean spool AFR opinions
  75. Standard Rom Versions
  76. Scaling/latency for 750's
  77. JDM EVO 9 logs... need input
  78. Older ecuflash versions
  79. PATCH: NLTS + Valet + KnockCEL
  80. Looking for logs to correlate load to massair/rev
  81. FlashEvo with Tactrix Cable ???
  82. Not Pulling Codes
  83. Mind looking at a couple logs?
  84. 2-byte RPM HOW-TO
  85. How to upgrade evoscan??
  86. Incorporating a Meth Failsafe into the Stock ECU
  87. Enhanced resolution
  88. EcuFlash 1.32
  89. Newbie question
  90. is it safe?
  91. What else should I add to this write-up?
  92. Help ! !
  93. 3rd gear log
  94. looking for a -008 US Evo8 rom.
  95. windows mobile
  96. A few Questions about Ralliart ECU and Flash ...
  97. Timing pulled in different ACD modes
  98. Reading/logging 2-byte load.
  99. How to setup evoscan or data log lab to show correct hp or torque?? please help!!!
  100. Launch Control
  101. I'm a n00b...
  102. 680cc injectors
  103. IDEAL BOOST CONTROLL patch discussion.
  104. good AFR, good timing, and no knock BUT higher EGT's??
  105. Very low load numbers?
  106. The list of current ROM modifications
  107. Got evoscan working on 2nd gen DSM
  108. usb to serial using 2 usbs does it work ok?
  109. adding cams mild modding sorting out idle jdm 8mr
  110. evoscan intializing
  111. A few Ecu Flash questions
  112. Smoggy Log - 2byte load
  113. Boost Error Gone Wild
  114. Wierd GM Boost Solenoid issue
  115. Question to the CEL flash mod people.
  116. Cant Flash or Read ECU.
  117. rescale rpm axis?
  118. Minimum TPS value?
  119. Took some logs
  120. What is the most HP tuned on stock MAF?
  121. Scott @ TTP - FLASH RETUNE W/ WIDEBAND READINGS?
  122. Ecuflash version 1.32
  123. how ECU calculates its final value
  124. New to evo. what is all this Ecuflash/mitsulogger/evologger stuff?
  125. Trouble with 2-byte airflow in 96940011 ROM
  126. Evoscan does not record all of my log
  127. Strange knock issues....VERY STRANGE
  128. Help! ECUFlash cannot read my ROM
  129. Switching back to stock injectors, need help!
  130. Guys with JDM MAP and 96940011 ROM
  131. BEZ is breaking out the patches
  132. Anyone care to look at some logs?
  133. Mitsulogger vs Vista
  134. Knock from a twin plate clutch
  135. suggestions on my Log
  136. Vendour recommendations and experiences please
  137. Load Decreasing
  138. e-mail for evoscan 1.0?
  139. New to EcuFlash(and any tuning in general)
  140. Any ecuflash tuners able to tune with Mac??
  141. Patch Request: Pull Boost on Knock
  142. another fuel question
  143. help with evo 8 lean spool disable?
  144. how-to: ECU-based direct boost control
  145. How much hp with good timing?
  146. Tuning for nitrous.
  147. Fq 320/340/360
  148. Currently logging boost with motorola 3bar
  149. Idle Problems with GT35
  150. Mitsulogger 2-byte XML addition?
  151. How does ECUflash use definition/xml-files?
  152. Samco Intake Hose
  153. evoscan
  154. Dialing in idle for cams
  155. How to log boost one edm evo9
  156. Help understanding Map Test Voltage tables
  157. Ecuflash - Actual performance increase?
  158. 2 byte load reading
  159. Dyno Tune knock Gadget and ECU datalog knock
  160. Low Octane flag at idle?
  161. Knock @ Stationary Rev Limit
  162. hitting 24lbs on stock bcs?
  163. Evoscan HP????
  164. 2 byte load mod on 94170015 rom??
  165. ecuflash failed in the midle of a flash
  166. Stalling with AC on issue
  167. evoscan v1.0 ?
  168. How do I post hex file (map)
  169. Tuning lower load cells - help?
  170. Problem starting 1.29 ecuflash
  171. Let's see those IX fuel maps...
  172. coil dwelling on stock ecu? any tuners know anything about this??
  173. Jestrtuning M1 or subscription?
  174. cailbrating evoscan for bigger injectors
  175. Help: Cant download my map of JDM EVo 9
  176. Mitsulogger and 2-byte functions
  177. ecuflash issues...
  178. USDM vesus EDM!!! changes in the ecu map!!!
  179. another evoscan issue
  180. [B]InjPulseWidth Unit on Log[/B]
  181. evo scan framework?
  182. Confused by ROM ID
  183. Does this log seem possible? Straight 93
  184. reflash question
  185. 2byte load & RPM for 96940011
  186. Can Ecuflash works on JDM EVO 8 MR?
  187. Fuel trims
  188. Anyone use an MBC AND the BCS together?
  189. gm solenoid strange boost?
  190. Looney Tune Strikes Again
  191. Understanding xml definitions
  192. ECUFlash Tuned by myself-Results/Dyno graph inside.
  193. Ecuflash 1.31 2d graphing...
  194. Code- Immobilizer
  195. Car wants to die after runs!!
  196. Window XP/Vista Tablet and Logging
  197. Ecuflash Mac Official
  198. Problem with 1.31
  199. ecuflash wont recognize my evo?
  200. Fq340 Rom
  201. need log at 5000 elevation with JDM MAP and 2-byte load
  202. FQ360 Map!!
  203. Copy 88840013 to 88840016 ???
  204. Speed sensitive 3 step (NLTS, launch RPM, Rev limit)
  205. Wierd issue
  206. 2 byte versus Load calc
  207. GM 3 Bar Map Sensor
  208. MAP sensor CEL threshold
  209. Stationary Rev Limit,,,couple ?'s
  210. jdm rs mivec map?
  211. GT35r Suggestions
  212. Nolift to Shift??
  213. ECUFlash Fails to read my Evo map!!! Help Please!!!
  214. anyone datalog on the road course?
  215. USDM OEM EcuFlash file ???
  216. Got my WB hooked up and I got a few Qs (Mitsulogger)
  217. No MAF? No problem!
  218. ECU Reset
  219. ECU Flash on a Mac?
  220. cant diagnose cel light?
  221. unable to connect to vehicle interface.
  222. Wrote wrong map onto my car and now it won't start or respond to Ecuflash
  223. EvoScan Mitsubishi Datalogger - New Features
  224. Tuning with Evoscan
  225. Should i pull some more timing
  226. Tuning for temperature/elevation needed?
  227. Popular EM reliable?
  228. 88590015 MUT Table
  229. i need a logger...
  230. Weird Thing With My Ecu Map!!
  231. Intake=re-scale MAF?
  232. Encrypting for Dealer visits
  233. Stock map with P0300 fix
  234. Feature/Patch request: Temp disable A/C under WOT
  235. Anyone Logging Mivec?
  236. Odd knock sum/jolt episode
  237. I feel the need to lean!!
  238. Cable problems
  239. LoadCalc to PSI
  240. ecuflashsh not conecting
  241. Wavy Boost
  242. Datalogs...b4 and after
  243. Injector Scaling in ECU Flash
  244. Any Resolution To ECUflash 1.30 "unable to connect to vehicle interface" ??????
  245. What do guys think of these logs!!!
  246. IS the load logging with Evoscan accurate????
  247. How to connect AEM wideband to Evoscan?
  248. Looking at my logs with ECU flash
  249. what do you log with evoscan
  250. Accel Enricment Question
