View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21
  1. Target AFR
  2. Stock map
  3. wastegate solenoid on/off?
  4. Can't get Load to hold flat
  5. Evo live map - hugely experimental alpha logger/realtime mapping skeleton
  6. Anti-Lag option.
  7. Mut table for rom 96420008
  8. How to determine what load cells are being used????
  9. Evoscan 2.0 formula Syntax
  10. Fuel Trims are way off--need some help
  11. Fuel flow switch?
  12. Getting AFR's closer to Tables
  13. Live mapping PC side app - progress yes and no!
  14. exhaust manifold
  15. Most Common 2003 Evo Rom?
  16. Has it happend yet?
  17. questions about simple log parameters
  18. AEM UEGO Wideband AF issue..
  19. JDM EVO IX help
  20. Power Falls out
  21. Fuel Injector Question
  22. Evo 2byte Airflow changes
  23. Can idle timing affect idle AFR?
  24. Gt30r
  25. GM boost solenoid LOUD!!
  26. Post your fuel map please (Evo 8)
  27. Evo IX+110 Oct=Bat out of Hell
  28. Problem with A/F changing...
  29. no injector scaling
  30. 1 step colder spark plug, any changes to Timing?
  31. **Lean Idle with 50-trim, Cossies, and PTE 880s***
  32. Need some help with my car/tune guys...
  33. Bez's perephery calculator
  34. EVOscan 2.0 maptracer issues
  35. Selling GM Solenoid & JDM MAP Sensor
  36. What are the signs for airflow meter going bad?
  37. Mitsulogger question
  38. cant read or write to a ecu
  39. Help With Running ECU Flash
  40. Can u remove the CEL for EGR
  41. engine load question
  42. ECUflash with Evo 6???
  43. MIVEC disassembly notes
  44. What BCLO do you run?
  45. logging wideband question
  46. boost change on altitude your experience
  47. Idc% Evoscan 2.0?
  48. Question about tuning timing. .
  49. Can't seem to download ecuflash ver.1.34 and am missing taxtrix driver for evoscan
  50. how to tune for cams?
  51. EvoScan 2.0: Map Tracer not working for me?
  52. Airflow 2-byte??
  53. Lost my evoscan serial number...help!
  54. 2 byte load the same for 94170015 as 94170008?
  55. Time pulled without apparent reason...
  56. OT: pressure differentials over long vacuum line
  57. buschur mass air pipe w/filter version 2
  58. Ecu Flash buggin
  59. let's see your maf scalings
  60. P0300
  61. Cant DL my ROM using ECU Flash please help
  62. review a log
  63. How do you interpret Maptracer in Evoscan 2.0?
  64. Take a look at this screenshot, 94170015 rom ID
  65. Can I burn newer rom ID's onto an older model ecu?
  66. 2 byte load dumm question
  67. question about my tune
  68. ECU knock algorithm effective at 2500-3500 rpm??
  69. more timeouts in EvoScan 2.0?
  70. Trigger logging session using TPS?
  71. converting target AFR's for different scalings
  72. Went for a drive
  73. Evoscan2.0 is out
  74. how to log afrs, need explanation
  75. Any need for AFC?
  76. engine code raeder download link
  77. cant log AFR with evoscan
  78. Let's see your fully tuned timing maps
  79. newb question..
  80. ECUFLASH shows error and unknown code?? Any ideas??? CANNOT FLASH MY ECU PLEASE HELP
  81. fuel pump dual voltage- load value?
  82. Min temp for full boost control
  83. Link for Evoscan Plz
  84. Problem With Scaling Injectors
  85. Inconsistent Knock...
  86. tuning closed loop knock
  87. converting to a toyota maf?
  88. What is wrong with these maps??????
  89. Rom ID issues, '03 Evo 8
  90. EcuFlash + Pocket PC???
  91. Weird dip in curves and low output on dyno!
  92. Possible to tune for aftermarket recirc valve?
  93. Does evoscan have real time logging?
  94. problems with evoscan and ecuflash
  95. O2 sensor
  96. EVO IX fueling troubles...
  97. Modified maps for download
  98. different maps
  99. Hitting boost cut suddenly, what to set BDEL to?
  100. Bosot Estimate
  101. Bucking low rpm
  102. evoscan settings??
  103. Thoughts on the wideband
  104. strange knok on high gears low rpms
  105. Any chance of improving boost control?
  106. do i need reflash?
  107. How much boost on pump gas do you run?
  108. Not logging LFT or HFT in Mitsulogger
  109. Disable IACV
  110. car back to stock and still few knocks?
  111. An Idea on logging backpressure need some info and input.
  112. 2byte load's
  113. Anyone running Mitsulogger on Vista? I need some help...
  114. AFR Too High? Newbie still learning
  115. Anyone care to take a look at my ROM ?
  116. ECUTEK - Out For Evos?
  117. What does your tractrix cable look like?
  118. Zeitronix AFR in DataLogLab
  119. ecu boost controll help needed...log included
  120. EvoScan Questions - Please help.
  121. ecu flash 1.29a
  122. Very Interesting Tuning Case
  123. LogWorks is working, but evoScan is acting up...please help...
  124. Pulling off ISC bad idea or ways around it ?
  125. evoscan log ?
  126. Short term fuel trim
  127. Need Help with ROM but no way to post
  128. RPM/load Values
  129. Look at my logs....Whats wrong?
  130. Gt35
  131. Obdi / Obdii
  132. A Good Flash!?
  133. What program do i need to run Open ECU's programs ?
  134. Can't Flash ECu When its Cold Out??
  135. 'octane level'
  136. Where to get replacement o2 sensor for LC-1?
  137. Not Detecting Car When Running ECU FLash
  138. Anti Lag
  139. New Ecuflash user has a few questions.
  140. EvoScan Question
  141. Weird Dip in Load
  142. My evo ix overboosting??
  143. Car won't idle Evo9 Cosworth Cams
  144. Tactrix cable not working with MacBook
  145. JDM Map sensor off?
  146. engine braking effect
  147. mod roms to run 6 injectors?
  148. How much memory is needed to tune effectively?
  149. MWGDC and TBEC Tables?
  150. Rear o2
  151. Rom immobilizer
  152. Overboost
  153. Need Help!!!!!!!!
  154. EcuFlash V1.34 released
  155. Is my NLTS working right?
  156. Help me with DLL please...
  157. Evo ix loads of knocks
  158. Which of these is the correct scaling for the PTE 780cc Injectors?
  159. evo X ecu
  160. 2.2 with gt35r would appreciate some help
  161. corrupted dynoflash
  162. Cams to big for Stock ECU?
  163. EcuFlash Versions
  164. Ecuflash ROM definition!!! help
  165. Proper EVO IX Car Definition in Data Log Lab??
  166. Does disconnecting battery effect boost immediately after?
  167. Evoscan dyno curve accurate?
  168. ECU Flash not working...
  169. mitsulogger??
  170. Reputable tuner, what should I expect?
  171. How old is MIVEC?
  172. maxed stock inj?
  173. GM BCS + NLTS = boost spike!?!
  174. AEM Uego won't log!
  175. interface close??
  176. Noob....need ecu flash cable..datalog?
  177. GM 3.5 BAR MAP Sensor -vs- JDM Map sensor
  178. Idle Stepper Maps?
  179. Speed Density with stock ecu
  180. MAF Screen / Honeycomb - How do you prevent it from getting sucked in?
  181. Another check my logs but with a twist
  182. Controlling boost with restrictor pill removed
  183. a couple of logs, 1-2 counts of knock, advice please
  184. help! trying to get ecufash to work
  185. ecuflash problem
  186. Evoscan, UTEC compatible
  187. Trying to fix my "PRO" tuned maps (please review my logs and help)
  188. 7500 RPM, WOT, 14.xx afr, 35 degrees 0 knock!
  189. lean idle? perfect cruise/wot
  190. Pimp my log
  191. New cams, tweak what?
  192. ECUFLASH cant download my rom - IX
  193. Meth and knock!
  194. These Open-Loop values correct for fuel efficiency?
  195. Check out this Mivec Map???
  196. Is this AFR okay? Still learning so pls be kind.
  197. ecuflash on evo 8 and 7 *help*
  198. What is wrong with this 04? Datalog Included..
  199. ECUHACK for ABS?
  200. i need a map
  201. Speed density on stock ECU dyno results
  202. Engine cold map /// Emissions /// ???
  203. Zeitronics Calibration
  204. Race Fuel tune experience
  205. Links to Valuable ECU topics
  206. 98950010 datalogging higher load than the fuel map
  207. Lopey Idle via MIVEC
  208. Autometer Wide band and ECUflash compatability
  209. soft boost-cut
  210. Rear O2 as loggable input?
  211. Problem with injector voltage.
  212. Easy way to add additional column of ECU LOAD for evo8
  213. what load should I expect?
  214. my IX mr not started
  215. IDA Pro tutorial request
  216. ecuflash gauge display
  217. Quick Question
  218. MIVEC tuning for Cosworth Cams
  219. How To Tune an Evo
  220. Noob to EcuFlash, many questions...
  221. Looking to find usb and obd 2 cable and ECU flash software
  222. Ecuflash 1.29 plz
  223. Ecuflash 1.29 plz
  224. Ecuflash Help
  225. fuel trims
  226. Walbro 255?
  227. 1st time logging with evoscan?
  228. Datalogging with AEM Uego
  229. Unstable RPM after NLTS Mod
  230. Some quarter mile logs for your viewing pleasure
  231. Pocket PC and Tactrix cable
  232. School me in Opensource
  233. e7 rom definition file needed for 98640016
  234. 88590015 wastegate solenoid xml
  235. Mod request: Knock count buzzer
  236. GM solenoid getting frustrated!! Need help
  237. Knock on NLTS
  238. So I pulled a MAP of a 04 ECU, and.....
  239. The final ok number for knock.
  240. My gt35r on 91oct evoscan log. Some questions, please help.
  241. High Knock from 5K to Redline
  242. open loop load?
  243. So confused on 2byte setup... need help quick
  244. Stock IX Voltage Latency Settings w/Stock Injectors w/Injector Size Scaling set to 48
  245. AFR 13.3 w/o knock?!?
  246. Alpha Testing: log.reader... web-based dynamic graphing
  247. Patch Idea: Can you help Tephra?
  248. Stat. rev limit with high boost
  249. Evoscan error again...
  250. Can anyone help plz..
