- help new to ecu flash boost problems
- Slow Spooling Stock IX turbo (4000 rpm)
- Help me.......ROM 92460000
- Aquamist 2D -> HFS-1 or HFS-5 ?
- How to install/use a wideband O2 sensor?
- Damn Map tracer! Need advice
- More Questions for tune my evo!
- help me with mitsulogger:
- need help with a/f at idel
- going into load based bost control, but need help
- JDM 99860002 EVO7, definition problems
- Verify some info regarding 2 byte load (Evo8)...
- 93 ocT "10% ethanol" = 13.5 AFR-WOT
- Disable clutch down to start car functionality
- Idle Surging.
- direct boost control in action
- Laptop question - Asus Eee
- XmlHandlerHelper problems
- Evoscan Logs
- pocket logger?
- how much timing increase
- Can Not Connect
- NLTS....and knock
- EGR patch request
- Evoscan formula for GM 3 bar MAP
- EvoScan 2.0 - logging HP and Torque...
- flash preppin'
- not sure if the horsepower is good..?
- ECUFLASH v1.29
- What do guys thinkof my log (GT30R)
- JDM MAP sensor vs Zeitronix Boost
- ECUFLASH Dictionary
- Hard time having ECUFlash to connect!
- quick NLTS question...
- Big cams = Injectors staying on during deceleration??
- good shop for a tune
- Which shop should I go to flash ECU (Socal)
- problem with notepad
- Spudder Problem Someone Help!
- Acronyms/Abbreviations
- Is there a way to change maps W/O laptop
- Evoscan help!
- blew away data.xml file, can you send me one?
- partial/moving throttle knock
- Load target changed?
- MAF Scaling + MAF Smoothing=AFR Adjustment
- Brian Crower 280s and Mivec Map
- LTFT mid Fuel trims don't change
- Race Fuel Tune.Info needed?
- need a driver
- ECU code & Boost & WTF
- Locking the Ecu!
- injector latency changes between 91 & E85
- Something new happened today after changing spark plugs...
- Ecuflash/Evoscan on MacBook with BootCamp/Parallels?
- need Mitsulogger
- unable to read/write in cold wheater
- 94170014 vs. 94170015
- Finding load cells
- Boost Enhancement Table Addresses?
- JDM IX Immobilzer issues (have original immobilizer code)
- Who do i talk to to get Evoscan 2.0?
- from your experience what is the best Ecu Flash
- HELP!! - Fuel Trims and O2 feedback
- Most 2004 Evo Rom?
- economy tuning
- EvoScan2.0 writing weird log files...
- Anyone using an Asus Eee PC w/EcuFlash?
- LTFT Low, Mid and MAF Scaling
- Knock on deacceleration??wierd
- Can somebody assist me for inputting this log into the DLL?
- Evoscan maptracer help, again
- Car Idling really rough, please advise!
- hp record?
- MUT Request Boost Error Correction?
- Having EvoScan 2.0 Maptracer Problems? Read Here.
- Need Help! Need definition for 07 JDM
- Updates for evoscan lap timing?
- Logging 2-byte Load
- Car acting odd after disconnecting battery...
- help in using 2-byte load with maptracer.
- Mut 86 Wgdc
- Evo IX Unresponsive to Fuel Map Changes.
- best boost control method?
- Tuning for high boost on 93oct
- IveyTune? Turbo Trix? RIPP Mods? Tuning Suggestions
- Formula To Log Gear In EvoScan?
- evoscan problem
- Speed density/MAP patch-who needs patch...
- ecuflash definition files
- This Month's Modified Magazine
- In order of importance....what's best to log w/ wideband?
- LC-1 and Evoscan 2.0 problems
- which xml file to use? HELP!!!
- What and How do we tune for maximum torque?
- zeitronix and serial to usb not working?
- Ecuflash For Evo X???
- does anybody have a map for the new evo X base, tuned, stock whatever.
- Hints for the patch writers
- evo scan
- stumped with knock...please give input
- immobilizerkey readout
- Blow Through Mass Air Meter
- Wideband loaner...
- Scrambled Map? Easy fix.
- ECUFlash Training?
- fix for "unable to connect" error in ECUFlash 1.30+
- Bought a car with a scrambled map
- 94170008 def error and fix
- EcuFlash installation problem
- Normal Range For Fuel Trims +/-
- Can we use evoscan and/or mitsulogger to adjust basic Idle?
- Need Ecuflash 1.29a!!!
- .xml file help
- tuning percision 780s
- Samco intake hose driveabilty?
- ECU does add timing...discuss
- Tactrix cable and PDA/Pocket PC - working logger
- Idle Trouble
- Scaling Injectors SUCKS!!
- how to read hex from 1.1w to 1.34 program?
- How To Log Boost With GM 3bar map sensor?
- More Problems?!?
- new evoscan templates
- Cosworth IX Idle Problems...
- ODB Port Help
- ecu unlocker 1.1 w/1.34?
- Stft/ltft
- EcuFlash: can xml tables be written for use on other vehicles?
- MAF vs MAP & other tuning issues
- EcuFlash help
- Went to the track last night - 12.3 Log inside
- JDM Evo IX GSR Rom Stock
- Ecuflash help
- Lean Spool Trailing Time
- Can I share my Evoscan with my 1g DSM
- Tactrix Universal or not?
- baseline MIVEC degree?
- Lowering Coolant temps
- Peak torque
- Cable for Ecu flash
- EvoScan + PLX M-300
- Pre-boost tuning
- Pro tuner using ECU boost control?
- Free Evo IX Maps from EIP Racing?
- Service engine light help!
- Disabling Speed Cut
- anyone have a "Stage 2" map?
- Running rich between shifts
- Which WB?
- Evoscan Maptracer Issue
- Mellon Tuning
- Evoscan and AEM Uego
- lil help EvoScan v. 99
- Help with fueling issues
- Rpm neutral and drive correct values?
- EDM MAP sensor
- Error in tables ecuflash in idle...
- IC Water Spray Function
- ecuflash stopped working...
- Does anyone usually use the "accel enrichment" table?
- Definition file for EVO 8 JDM 2003
- Accuracy of logged items
- Evoscan: bhp & torque readout
- how to reset ecu if original map is lost???
- Dumping fuel and knock
- 8 map
- Another source of knock discovered
- patches not saving in rommetadata for 96940011
- Conflicting opinions on tuning – Just lay it out please
- Can't get my ecuflash to work after update??
- load rescaling and knock sensor filter maps
- Just got tuned
- really hygh knock on really low load
- Up to Date IX XML for EcuFlash
- Tuning for 0 knock, having an issue with one area
- VIII with a IX turbo map!
- p1104 p1105 codes and running rich
- Individual Cylinder Question
- New log for review
- Anyone here with a 2.3 or 2.4 on ecuflash?
- ECU Flash "An Error Occured"
- How to view logs
- anyone with 96420007/8 ROM running JDM MAP sensor
- data log lab and logworks?
- High Oct Load table - Whats the diff?
- Where to download an older version of ECUFlash
- Looking for recomendation on Wideband
- Are these roms interchangeable?
- tuning for e85 advice needed
- Logging Data
- Dual boost solenoid schematic & ECU pinout for Evo X
- An idea for cars with no ICS switch
- rich idle problem
- Zeitronix WB, NB simulating, + EVOSCAN
- Injector scaling help
- EcuEdit?
- Help: Vista OS OK?
- Idle Quality with RC1000 cc injectors
- Evoscan code reader issue
- ADC assignments for USDM Evo IX 88590015
- Trying to find a fuel/timing fix for aftermarket diverter valve
- tactrix issues with vitsa
- Map for 05
- DMA logging now working - logging 25x faster than MUT
- Question KNock voltage level
- Meth Failsafe and Patches
- from 88590014 to 88590015?
- Two Speed limit boxes? why?
- Airflow/rev question
- can the standard ecu be patched to support wideband lambda?
- DMA logging first test a success
- High Compression High Knock
- injector voltage Stock evo 8??
- need 2-byteRPM formula for mitsulogger
- EcuFlash 1.28
- I look for....88840017
- 2.3L ECUFlash Tune?
- PATCH: KNOCKCEL+NLTS+AltMap (V4)
- reflash without afr log!
- Tuning with MAFT
- ECUFlash mods - Anything else I can do?
- remove maf honeycomb (not a noob lol)
- Which ROMID's have ICS
- USDM Evo 9 ECU pinout here
- WGDC Correction (direct boost control)
- help
- ecu def
- De Tune for Winter
- DMA logging/mapping idea
- Evo Live Map 88590015 Download Ready
- Help Me!!!!!!
- Question about tuning,and fuelpump..
- ecutek to ecuflash....
- IX low on power, excessive load, what's wrong?
- Any One In San Antonio ? Ecu Flash
- need some help with my 2 byte load
- MUT logging - 375 to 750 items per second
- ECU FLASH connection...
- MWDC / BDEL question.
- Help with Maps for Stage1+ VIII
- Having problems downloading EcuFlash
- Trouble. ECUflash wont Flash.
- fuel pump tune
- Evo 9 Running Lean
- Fp Green
- Tuning or logging cable, WTF do i have here?
- GSC cams produce false knock?
- Target AFR
