View Full Version : EcuFlash
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21
  1. how-to: Log AFR from the LC-1 w/o a serial cable
  2. post ECUFlash MUT table definitions here
  3. Tuning the Green - Initial impressions vs. Stock Turbo
  4. LC1 power supply and electronics question
  5. worried about my tune
  6. Instructions for removing a pin from an Evo 9 ECU plug
  7. does this make sense?
  8. LogWorks 2 Map Tracing not Working.
  9. knock at 6000-7000 rpm, 92 oct, need tuning advice...
  10. LogWorks 2 OBDII or MUT?
  11. Questions about GM 3 Port Tuning
  12. 3 port solenoid - what is the best way to control???
  13. Shameless EvoScan Gauge Layout
  14. LC-1 installed, logging AFR without serial cable
  15. 36 Counts of Knock
  16. Load Error & WGDC Correction Address
  17. EvoScan2.1 Problem - Link Succesful... NO DATA
  18. ECUflash 1.34 problem with vista???
  19. About to get back into speed density testing
  20. Fuel problem on a 2G
  21. Ekcutek ROM compatibility with ECUFlash????
  22. Need help re scaling maf
  23. MAp tracer will not work.
  24. Any benefits in advancing idle mivec?
  25. ecuflash problem(stat rec limit)
  26. Mitsubishi OEM Boost Pill
  27. 88840013 ROM and EcuFlash definitions
  28. Logworks and fuel trim logging
  29. Possibly a new mobile logger?
  30. Lower Thermostat Temp?
  31. Looking for input on my logs
  32. Evoscan cable flashing ACD and ABS lights....
  33. Semi-offtopic: brush up your assembly skills with Corewar
  34. Reflash help
  35. Disassembly question
  36. I can't scale my pte 880's.. help
  37. Best way control boost with the stock BCS system,
  38. Retune needed ?
  39. ECU Question
  40. Easier way to calibrate GM Maf?
  41. Need some tooning help to rid knock.
  42. evoscan when I start logging RPM goes to +/-2500
  43. Who can tell me what "accel enrichment" specifically does?
  44. Qucik help
  45. multiple ecu's
  46. Which one; OpenPort 1.3U vs. OpenPort 1.3M for an EVO
  47. Timing vs. AFR in relation to making power
  48. Scantek to work in older cars?
  49. How do you tune a car from scratch?
  50. P0505 with "super" MIVEC
  51. 272 cosworth cams, how to tune mivec table??
  52. Can't install Evoscan 2.1
  53. map tracer
  54. P0300 code and EcuFlash
  55. ECU disassembling?
  56. Defi BF vs JDM Map accuracy
  57. Stock ECU and COP
  58. Looking for 06 Evo 9Mr stock ROM
  59. Tephra, can you make a mod to fix the VIII's p0300 issue?
  60. Evoscan gauge Templates V11
  61. Looking for help on setting up my fuel
  62. Any ideas why my stationary rev limit is not working?
  63. Shipping EVO to Germany
  64. Question?
  65. problems with Evoscan
  66. Let's see your customized EvoScan Data.xml
  67. Strange issue with trying to read '06 Evo 9 MR ecu
  68. What is the best program for data logging?
  69. Evoscan 2.2 --How is loadcalc related to fuel table load
  70. how to disable second 02 sensor?
  71. EGR VALVE: when is it open and what makes it shut?
  72. evo scan and ecuflash questions need help
  73. 9653006v5.1 NLTS and other rom questions
  74. ECUFLASH(Pakistan)
  75. just adding an open filter what to do...
  76. need help: new xml files for upcoming ECUFlash release
  77. Knock Problems
  78. problems getting stock rom
  79. Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
  80. i don't know what i did
  81. Quick question regarding stock turbo setups and peak loads hit
  82. faint fuel smell in cabin during pulls
  83. Is there a basic/cheap IAT Sensor?
  84. System Too Lean(Bank 1)??????????????????
  85. What can I do with OpenECU software?
  86. Issues, need to tap into the collective..
  87. How to use Evoscan and plx widebands
  88. 9653006v5 WORKS for 05 USDM (9694011)
  89. EcuFlash and EvoScan problem.
  90. Data missing in EVOScan logs ???
  91. Current ROM Mods?
  92. Is it time for new injectors or what?
  93. 96940011 rear O2 sim patch
  94. need rom defs please help
  95. Evoscan wide band reads 5.000 at idle Gauge reads normal
  96. Question on Tephra Mods
  97. Wrecked tactrix cable?
  98. Rom Mods for ECU controlled BOOST
  99. Map rescaling..
  100. more boost control tables found
  101. 1.34 Problem
  102. Changed injector scaling after disconnected battery
  103. Ecuflash with mac
  104. Max WGDC Correction vs TPS table
  105. RPM Error in EvoScan Log
  106. Any ECU flashers want to help a brother out
  107. Which Tactrix cable
  108. changing roms
  109. 2byte - im lost
  110. Switching IGN 12v source for LC-1 (not acc)
  111. IDA output to gas input
  112. 93660005 ROM Swap?
  113. Issues with DLL graphing Load%
  114. Evoscan
  115. Biggie Boost on 91 oct
  116. Alternate Roms for 96940011 / 2005 USDM Ecu?
  117. PATCH: TephraMod V5
  118. How to disable immobilizer on EDM Evo9?
  119. TBE + semi-tune results on 92 octane
  120. Getting 5+ knock counts ONLY on hard shifts??
  121. Maximum ignition retard for IX
  122. EVOSCAN ISSUE 2.1 When start up
  123. Entire fuel tables path
  124. How to copy ECUFlash map table data from excel to ECUFlash?
  125. timing map for anti lag
  126. SAS Hardware
  127. Drag log for you guys to play with
  128. Map Switching indicator in EvoScan??
  129. Are 780's enough for a Green on 30psi ?
  130. Help
  131. need advice on my tune
  132. Highest whp on stock ECU
  133. Stock Timing/AFR Maps Evo7 and Evo9
  134. Clutch Slipping Dyno
  135. EvoScan 2.1 Fuel Trim Formula
  136. Wideband shootout test
  137. post your timing/afr maps:
  138. Log review request
  139. Can EvoScan log 0-5v output from AEM Uego?
  140. Request ID: Open/Closed Loop?
  141. Trouble Logging 2byte Load
  142. Perephery patch Interesting. Could fix my problems?
  143. 1150cc's Work great on stock ecu W/e85
  144. need a good tuner in the seattle area
  145. Logging at Idle w/ Mitsulogger
  146. H8 Rom Definition
  147. new coolant temp and intake air temp entries for EvoScan
  148. Setup to active immobilizer with my key!
  149. 50 trim help
  150. Mac problems
  151. q45 on stock ecu?
  152. 05 Evo VIII ECU with an 03 Evo VIII wiring harness
  153. need injector scalling format
  154. Problem initializing ECUFLASH with car!!!
  155. Ceramic Cat vs. 100 cell Metal Substrate Cat
  156. Direct ECU boost control/ecuflash problem
  157. Injector Sizing and Latency - Observations and Thoughts
  158. Test Pipe VS 130 cell MS high-flow cat
  159. 88840016 vs 88840017???
  160. Evo X MAF in a VIII/IX?
  161. Comments on log for 94oct
  162. need help reading ecu
  163. idle RPM - neutral
  164. Apexi AVCR MAP sensor for logging?
  165. Keeping all 3 maps the same?
  166. Knock Help PLEASE
  167. problems getting ecuflash to download ROM from evo ix
  168. Question about maf scaling and fuel trims
  169. 2 step ?
  170. Cable connection/ ReFlash
  171. remote start/2step
  172. Knock on fast shift
  173. Speed Sensor Question
  174. Quick engine load cell question
  175. question
  176. On the fly adjustable boost w/ GM3 port?
  177. P0300 override code?
  178. Injector size scaling
  179. Ecu-boost : Stock Solenoid with pill VS GM boost solenoid
  180. Switch from AFC to Flash?
  181. Injector Latency - Warm start problem
  182. Lift-off Stalling
  183. Maximum load value on stock ECU?
  184. Using ECUflash
  185. logged: MBC vs ECU-boost (stock solenoid)
  186. logged: MBC vs GM 3port ECU-Boost
  187. How do you run 24.5psi on 91 oct???
  188. Twin BCS tuning?
  189. 1200cc injectors with stock ecu
  190. mitsulogger cannot innialize...
  191. 94170008 2Byte Load/RPM/Airflow Not Working!
  192. 88590015 Idle Table Conflict
  193. question about timing around idle with cams
  194. 2byte load on LOGWORKS2
  195. EVOSCAN 2.1 Maptracer Problems!
  196. 2byte AirFlow 88840016
  197. ECUFlash Maps in Excel - many decimals?
  198. Boost Cut/ Spike
  199. Well set-up ECU-controlled boost
  200. evoscan incorrect dtc list air intake, engine coollant, presure sensor, knock sensor
  201. New evoscan bad news for me!!!
  202. Which cable is better?
  203. AM ECU Unlocker 1.1
  204. So i plan on doin a self tune...few questions
  205. DMA source code - techie thread - for interest only
  206. Xml help.
  207. Newbie-Need Help on getting Evoscan 2.1 running
  208. Serial number for 2.1
  209. beginner tuner:
  210. 10,000 rpm on flashed stock ecu??
  211. Can't seem to work out knock on spool up
  212. A few questions on this log
  213. Immobilizer code - other reasons
  214. Car is Pissing me off! Help!
  215. Official 2 byte thread!
  216. Opinion on log and fuel.timing maps
  217. evoscan 2.1 problems and fixes
  218. Logging JDM MAP sensor on JDM Evo?
  219. evoscan 2.1 and coolant temp
  220. ecuflash 24 psi tapering 21 psi redline, which spark plugs???
  221. speedometer correction
  222. I need some serious help
  223. Power options for LC-1?
  224. Mitsu 3bar MAP sensor
  225. OpenPort Universal or just Mitsu?
  226. LM1 vs LC1
  227. Boost /fuelcut at 20 psi
  228. Help with CEL
  229. Tested: Number 67 Pill
  230. SAFC, Advantages to using ECUFlash instead
  231. whats so special about 96940011?
  232. help with tune
  233. Mitsulogger requestID file Question
  234. need input on evoscan logs.
  235. Load Required for CEL on Knock -- Tephra Mod Question
  236. Evocan help
  237. help, laptop stolen, need evoscan.
  238. logging 2-byte w/ mitsulogger.
  239. Am I missing something here?
  240. problem with ecuflash 1.34
  241. Idle Problem After JDM MAP Install
  242. Saving Stock ROM with CEL
  243. Start problems after rescaling ign map
  244. Problem writing/comparing/Test writing
  245. Tuning Evo VIII Timing
  246. 2.1 evoscan
  247. Question about logging fuel trims
  248. Confused "boost"
  249. Realtime mapping update - exciting idea from Merchgod on Romraider we could use!
  250. a new way to open more boost???
