- Installed 880's and now my FuelTrim_High is off.
- Air Fuel Calculator
- Data Log Lab
- Open port 2
- max boost on stock internals
- cold start enrichment table
- Mitsulogger question.
- Evo Scan V2.2 Help Plz!
- 2byte to 1byte load mod
- ecuflash v1.34 help
- rom help
- Why are there multiple desired idle tables
- lean afr ....effects?
- my car got slower
- very confused about email tune?
- Low load numbers
- Inconsistent pulls
- About to File for Divorce from the Factory ECU . . .
- Cant Read Rom???
- Boosting problems
- plugs for e85
- need everyones help..
- evoscan 2.1 wdb not on list
- Low RPM Studder (Injector Latency Help needed)
- Geek Squad needed!!
- Answer please: 2-step w/o being in gear
- Evoscan 0.99 Random "USB device not responding"
- JDM Map Sensor and Gauge
- Thottle hang issues . . .
- 96940011 & Evo7base xml
- Direct PSI based boost control on ROM ID 96420008
- Emissions Help
- Using Boost Control patches with V5 Patch
- If "Accel Enrichment" isnt accel enrichment, how do you fix this?
- afr dump
- V5, NLTS and the load threshold bug
- ecuflash guru'sand anyone else (fuel trims)
- software fix for the Rear O2 CEL for the Evo IX 88590015 ROM with v5 tephra rom?
- need a solution
- Two unique problems with Evoscan
- Tuned 2 Evos today
- EcuFlash and Vista
- Newbie immobiliser help required
- Looking for more maps, 80700010 Def
- PID boost control code
- Is there a baud rate mod for IX?
- MAP averaging
- Adjusting the MIVEC Min/Max
- FIC1050's
- 27.5 psi on 91 octane maps
- LC-1 vs. Stock O2 readings..
- logged some data, need some input
- ECUFlash Min Temp for Full Boost Control Setup
- evoscan aem uego
- 88580014 anyone? Tephra?
- evoscan serial #
- Rom ID
- External Wastegate - Stock BCS setup
- Narrowband Output Graph
- 2byte airflow
- Can I use multiple patches ?
- Evoscan Help
- Evoscan reprogramming LC1
- New Tactrix Openport 2.0
- Map Tracing spreadsheet - looking for feedback
- my tune gone bad
- Reading CEL's with Tactrix
- 2byte load log issue
- Evoscan and UEGO problem
- Running LC-1 WB power?
- Logging Boost
- Please review my log
- ECU Flash Tuners
- Idling AFR's 10.0-.8; No Boost Leaks
- Issue logging AFRs with ZT2 and Evoscan
- Measuring injector latency...
- exhaust leak cause artifical AFR's?
- Does Sean Ivey use ECUflash?
- 2-step help!
- ecuflash gurus needed
- DLL power graph showing up blank?
- My load is too hi !!
- Smoothing out boost?
- Help to JORO-FOTO: Need us back! (crashed laptop)
- MAF Translator with Ecuflash
- Crazy AFR and no knock
- ECU Flash
- Flashing to 15 ROM
- 255 counts of knock.
- no breather?
- Different idling issues. Any Suggestions?
- Logging other Mitsus
- Adding resolution?
- ECUFlash timing/knock
- Moved/drove accross the country (observations, issues, looking for suggestions)
- Front 02 sensor dead, i think
- Detailed mapping of Periphery bits underway
- Immobilizer code
- Known Causes of Phantom Knock?
- New tune, now it bogs bad off the 2 step?
- EvoScan Issues
- Timing Map Help:
- ECUFlash Write Failed on Evo IX
- Burping at 5 grand
- There is one more Periphery!
- Evoscan 2.1 and zeitronix WB
- Deatschwerks Injectors?
- FIC 950's - any issues/praises?
- Evoscan Log Results
- A Great Tuner with Great prices
- EvoScan 2.2 and weird logging numbers
- Help Needed: 2byte setup for Evo 7
- Has anyone used the new Zeitronix-DashDAQ?
- How to get rid of GM 3 Port mid throttle overboost?
- BOV flutter problem
- FIC 1050 latency values?
- disable immobolizer
- Please help translate the log...
- For Your Consideration... Some Maps and Logs - 94 Oct.
- Do fuel trims really affect open loop fueling?
- Is it safe to log at 22 PSI on a stock ROM
- boost cut with 98640014 def
- Ecuflash guru's...help needed
- Please tell me what you think about this Log....
- Perrin EBCS with EcuFlash
- Knocks at red line fuel cut?
- Using Mitsulogger to log Zeitronix
- My Map/log
- Evoscan connect help.
- Tuning for higher compression
- Cold start rountine fuel enrichment Qs?
- JDM/EDM/USDM Ralliart ROMS: is there a difference??
- Howto: EvoScan v2.3 reduced diagnostic light flashing
- Help and input required please!!
- ECUFlash accel enrichment table not really accel enrichment?
- HOW TO Scale MAF Sensor?
- so i decided to pull my VC.....cams affect tune?
- what should my timing advance be?
- JDM MUT Table Pic Needed
- Pros and Cons of having the stock MAF in blowthrough mode
- How-To: Log Estimated Boost in EvoScan
- Help Me Understand
- Tuning for Torco Accelorator?
- Stock Evo with flash, post your power results :)
- My first patch for E85
- MR560648 defenition??? help
- what you guys think of my tune
- serial number for evoscan
- Adding the 280-300 load range on an Evo VIII
- Retune for season change? Suggestion please!
- Help with loadcalc on evoscan
- Jdm Map Sensor Won't Read
- Stock Turbo 369bhp
- Patch how-to: manifold air temperature logging
- low load knock
- Evo Ix Ecu Pins Are Here!
- AEM uego is outputting wrong voltages
- Changing fuel map scaling
- Do you need to tune for Injector Duty Cycle?
- Mustang dyno load = street load?
- Rescaling Your ECU for E85 - It's Easy
- Knock, Timing Help
- Evo Scan Wide Ban Question
- EVO9 ECU pins...
- Evoscan IDC reading 0
- Ok why the F wont evo scan work right??
- Ecuflash help!!
- weird throtle issue
- help with injector scaling
- evoscan download......
- Logworks
- What AFR's you guys shoot for
- Accell Enrichment News
- adding fuel: % vs. ratio
- switch from 88590013 to 88590015
- how does ecuflash deal with the multiplier
- saving logs
- openport 2.0
- Cant view maps
- weird problems
- Switch aircon (a/c) off when at WOT?
- Continued testing biggie boost on 91 octane
- Trying to log evoscan with zeitronic external wideband
- Why do you need a Resistor with the GM 3 Port?
- Evoscan logging Evo 6
- MBC/OE BCS Hybrid
- Adding RPM points
- Need help with MAF scaling
- new tune and sputtering
- Phantom Knock?
- problem with evoscan
- Missfiring problem & P0304, log attached
- 94170008 no injector scaling help
- Mitsulogger - cranking engine
- Raised 2-step now it misses when using
- Differeces between GM 3Port and OEM Sol for Pump Gas?
- reading/access on a locked ecu, now identifying the rom
- installing older versions of ecuflash and crashing
- figured out how to associate ODB-II error codes with error checking subroutines
- Tactrix cable question
- Interesting pix we might learn from
- tuning in high altitude
- help with ecuflash and evoscan
- hesitation during pulls
- e70
- Broke my wastegate solenoid boost line
- Can I Run Stock 05 Rom on 03?
- Knock sensor question
- tuning idle
- Different Fuel - Way different AFR's
- Total noob to tuning....few questions
- lol @ this timing map...
- MITSULOGGER ERROR hex file
- I have problem logging
- zetronix Wideband not working lambda sensor hot tho?
- Boost solonoid harness able to be used for input?
- Boost limit table
- What is the purpose of using 2 byte?
- Trouble with MAF
- Evo VII GT-A EcuFlash
- Can't get Mitsulogger to work
- EvoScan support?
- change closed loop a/f
- Tuning with an External WG dump
- Where to download EvoScan ver 2.1
- Just got EcuFlash and EvoScan, what to do?
- Can't flash my ECU...
- show your designed load curve
- Intake temp?
- LC-1: No real time data link? HELP
- download evoscan .97
- Good lesson learned!
- boost change
- stalling issue w/new build
- EvoScan logging with AEM UEGO???
- Problems with EVOSvcan 2.2 and crazy reads
- Screenshot from working DMA live map/log + Tephra V5
- installing new turbo tonight and need tuning baseline hlep
- Which BRAND of injectors are the easiest to work with/scale?
- IX FQ340 missing top clutch switch wiring
- Ralliart Map
- Idle tables for 94170008-15?
- Tuning 272's cams
- Need quick help on disabling patch for P0443
- openloop idle
- small laptop ecuflash?
- trying to flash
- Quick Question
- 1-2 shift hesitation?
- exhaust pop when engine braking. What's the cause?
