- RRM piggy back ecu
- Tuning capabilites
- lancer es fuel management question!!!
- INF Values???!!!
- rrm piggyback question
- Need Help With Base Tune
- rrm piggyback ecu
- EcuFlash: Rev Limit problem
- Should I Turbo????
- Definition Problems with ECUFlash
- Tuning My first try at EFI
- Timing Map Explanation?
- Good Base Map For Me?
- help with iac valve...
- OBD-II patches?
- emanage blue tuning
- trouble with 1.3 tactrix cable
- Lancer MAF Swap Step-by-Step Guide
- Need help with ecu flash.
- new to the game
- thermostat location
- ECU Reset
- Whats your Oil Brand
- ecu/flash help
- RRM Piggyback ECU.
- Finding MBT without dyno?
- Safc Neo Vs Ecu flash
- question RRM piggy back V.1
- E-Manage on 4G94 (ECU Diagram)
- Evo 8 ECU Swap Works!!!
- coil pack
- Looking to get a bit more power
- Incressing the Load in ECUFlash?
- piggyback map
- turbos
- Greddy Informeter TOUCH
- ROAD///RACE Light Aluminum Crank Pulley
- Aem ems
- Innovative Wideband o2 in replacement of STOCK
- Help Need my 5th injector Piggy tuned
- 03 lancer oz new to tuning
- 4G93 IM swap
- Looky what I found, 4g93/4g94 fuel rails
- RRM PiggyBack problem for 05 lancer auto!!!
- 60k mile tune-up
- Evoscan Issues
- weapon r air intake install
- Need a modded Lancer Rom for EcuFlash, Stage 1 or 2 turbo
- Megasquirt w/MS2extra
- piggy back problem
- O2 sensor heater circuit malfunction
- Scantech
- A/F Install
- AEM Fuel Ignition tuning problem...
- OBX Coil packs
- turbo help! noob
- Headers?
- MAF Circuit low ..but
- Help!
- RRM piggy OR Apex'i Neo???
- Lean under boost!!
- need a good bham or atlanta tuner.
- 02 sensor
- Temporary ECU Flash plz!!
- Returnless Fuel Options
- limit rpm
- Piggy Back install problems Please help
- Breaking in a Piggyback
- EcuFlash...wrx 440s shut off at idle???
- Ecu
- So I think my Starter is done!
- Someone please help me with Ecuflash
- piggyback ecu... dynos?
- can't log knocksum...
- Local, Southern cali tuners??
- Tuning RRM Piggyback V.2 Automatic
- Advice for upgrades
- tuning shops
- OK ecu flash switch from piggy, help
- RRM piggy response? Input..?
- EcuFlash tunning help
- Quick help with ecuflash(stupid)
- Need tuning help.
- piggy back tuning?
- emanange blue or tactrix + ecuflash?
- Evo Scan - not reading my car
- datalogging
- Longer wires on Secondary 02 Sensor - Options?
- Tuning RRM Piggy V.2
- some quick questions
- hard time tuning...
- Base Map
- how I can eliminate the MAF sensor?
- Cancell Power Steering Pump 0z Lancer
- rrm piggyback tuning
- Free tune ... anyone interested?
- about to buy a piggy.
- Anyone do a lean tune?
- Knock and Flutter
- Best Spark Plug Gap?
- greddy e-manage ultimate
- need help finding injectors
- Unusal problem.. Plz Help
- Nitrous? On stock internals?
- Engine mod route, opinions?
- RRM Piggyback Install
- ECU flash?
- Performance coils?
- EcuFlash Definition File Master List
- ECU Definition file for 2002 lancer oz
- dual ecus for AT boosted Lancer
- apexi neo installed
- wideband
- CEL on
- what size resistors to use
- Stroker kit 4g18
- Got my piggy back tuned
- 05 engine in 02-03 lancer
- Colors of O2 sensor Wires
- emanage (blue) + which wideband?
- lancer 2003 es awd?
- ECU flash help!!!
- EvoScan Log
- piggybck question.
- recalibrating an fmu for injectors
- Help in finding a part!!!!
- Lost top end.
- Tuning software
- Engine maintnence?
- ecu problem?
- 05 Es
- No FIC
- Vafc
- cyberdyne DIGITAL GAUGES???
- tuning the piggyback v2
- AEM-EMS anyone?...Please?
- RRM piggyback VS Greddy eManage ultimate VS Apexi safcII neo
- ecuflash load tuning
- Calling for logs ...
- Fuel recommendation for the Lancer
- Alternator
- Accuracy of the Apexi TT's a/f
- Optima battery??
- InaZma Hg Magnetic fuel regulator
- ECU Flash for LAncer OZ 2003
- Performance/racing chips?
- need someone in PA for tuning
- Anyone have a copy of the latest RRM piggy V.2 map?
- missing, bad idle
- Cel - P0171
- Dealership Flashes ECU for recall??????
- Attn: Tuners, i need some help for lancer 2005
- throttle body allen screw
- ECU Flash Help - Experts Needed
- anybody had problems wiring up the RRM piggyback using connectors??
- piggy vs 2
- Piggyback v.2 Maps
- piggyback ecu connection?
- which tuner offers email flash for Lancer OZ 02' ??
- Walbro Fuel Pump??
- IDK whats going on...
- Fuse Problem, Need Help
- Review: RRM Piggy Install (manual trans)
- e-manage ultimate
- RRM PB v2 INSTALL HELP!
- anyone know of any tuners?
- ecu swap on a 2002 lancer es
- Innovate LC-1 Questions
- whp VS temp
- Emanage Blue
- Megasquirt II
- rrm piggyback system display?
- Anyone Help?
- My Piggyback review
- 06 lancer pin out???? help
- ECU Swap...
- ATTN: RRM Piggy Guru's...
- Safc tuning
- just a quick piggy question...................
- RRM Piggy-Just realised something!!
- whats the most accurate a/f gauge besides wideband?
- Needed: Piggyback Map
- which gauge to get 1600 degrees or 2200 degrees EGT gauge?
- PB installation
- rrm piggy
- Guages- Power Question
- RRM Piggyback tuning
- Piggyback CEL (i've already searched w/ no luck)
- AFR with RRM Piggy V2
- RRM Piggyback
- Piggyback Learning
- to those with the PB
- Rrm Piggy
- SAFC tuning
- how is tuning?
- Emanage Ultimate - idle question
- does piggy back tuning and afc tuning cost the same?
- piggyback and CEL
- I need your opinion For ECU
- RRM PB help
- New AEM Fuel and Ignition Controller
- Super ITC
- Changing Out the Spark Plugs, Never done it, ?s
- US Lancer With Haltech Standalone
- gauges for turbo
- injector compatability...
- Might be dumb...
- SAFC wiring on an 04+
- Piggyback.... to be or not to be?
- **weird tune??**
- Ignition Timing
- Piggy back Fuel maps...
- Dumb question right here
- About to dump the piggyback
- Paying for a mistake...
- Turbo tuning?
- E-manage
- The most bang for my buck
- engine swap?
- knock, A/F ratio, WTF?
- R4 map A and B
- whats better
- Anyone messed with timing?
- RRM Piggy for 05 auto es INSTALLED!
- help!!!!!
- Using a Piggy V2. Auto on my 5SPD???
- WRX 440cc with RRM Piggy back
- Piggy V2. questions
- Car Stalling
- finding the right connector...
- ROAD/RACE Piggy Poll- $399?
- Will the piggyback learn new mods?
- greddy e-manage questions.
- RRM piggy output settings
- RRM V.1 piggyback install questions
- Autometer narroband A/F to Wideband A/F
- Piggyback Version 1 (for auto)
- Piggyback V2
- Any modified maps for 5 speed?
- MAF sensor
- Stock injectors?
- ***ECUFlash Now For Base Lancers!***
- RRM piggyback on ebay
- Power Tuner Help
- What is the best fuel management system for US Lancer?
- Upgraded Injectors and Tuning Thread
- Cleveland DYNO
- Piggyback idle - help!!
- Next Level Performance G-Box; Anyone seen or have this mod?
