View Full Version : Water/Alcohol Injection & NOS
Pages : [1] 2 3 4 5
  1. water injection as a base fuel
  2. meth spraying when not supposed to.
  3. Aquamist hfs-5
  4. Aquamist HFS-4 ...
  5. How dangerous is meth really to my car?
  6. 50 hp of NOS question...
  7. Who´s using AEM meth kit? I have a quiestion!
  8. reliable easy to tune ethanol injection is best way to go
  9. What if...
  10. Tank,failsafe
  11. SMC support?
  12. direct port injection... who installs it?
  13. Dead progressive controller and $300
  14. Aquamist HFS-3 on 100% Methonal
  15. Injector location
  16. race fuel and methanol injection
  17. water/meth injection
  18. HFS3 and up users..question on wiring/input
  19. hfs6 issues
  20. How setup my AEm Meth kit??
  21. FS: 2.5 gallon SMC kit
  22. meth cutting out
  23. Is my Aquamist HFS-6 meth kit complete?
  24. Nitrous on the evos
  25. Is it ok for me to run the water-meth line inside the car??
  26. parts needed for aquamist setup
  27. Meth injection and Drag Racing
  28. Evo 9 Aquamist HFS-6 Alt Map
  29. SMC Replacement Line
  30. Bought an Evo X with meth kit, what am I looking at here?
  31. Aquamist HFS-6 BNIB - Flow Sensor Leaking from the Inside
  32. Aquamist dss3 v10 help
  33. What are the disadvantages of Overjetting
  34. Water/Meth jetting size calculation
  35. Please help quick - I'm at the drag strip
  36. Lil help - HSFV5 v.9 Troubleshooting
  37. Automatic Computer Advancement
  38. The Benefits of Water/Methanol Injection for Gas Engines
  39. Post up how much meth you spray
  40. Aquamist jet Question
  41. Good installers/tuners...?
  42. tuning smc controller
  43. AFR issue with AEM kit
  44. Aem Meth Kit Question
  45. wtb a aquamist DDS3 CONTROL BOX
  46. map switching wiring diagram for JDM EVO7
  47. Water-Meth: How long can you stock the mix?
  48. alcohol injection system stage 1 comp meth tank
  49. wifes xmas gift to me... meth
  50. Merry Christmas and Happy holidays
  51. Do I need a 3 port BCS to have proper failsafes??
  52. HFS-5 V10 install on evo 8
  53. About spark plugs bad or what?
  54. How do u choose the right nozzle size?
  55. Aquamist HFS3-v2 / tephra's new "X" patch development is now available...
  56. 50/50 Meth tuning timing figures
  57. Meth switch-on Point
  58. AEM kit. Question about nozzle selection and mounting.
  59. PLug Range for WI
  60. Newbie question methanol without tune...
  61. Aquamist S1 pump replacement
  62. quamist hfs1 install problems
  63. HELP Aquamist HSF-5 leak question
  64. HFS-3 love
  65. Aquamist Hsf-6 install
  66. Spray meth with nitromethane
  67. injector nozzles install
  68. Aquamist HFS-3 on a B5 S4
  69. Low Flow
  70. Universal water/meth controller ?
  71. Propane injection has anyone done it?
  72. New Water/Methanol Injection Failsafe from AEM
  73. Meth it not working
  74. has anyone modded there intake mani for meth injection?
  75. Pros and Cons of E85 & WMI
  76. HFS5 failsafe not reverting to actuator boost
  77. Direct Port W/I Kit??? Aquamist
  78. Methanol Engine Bay Pump Install
  79. Meth injection advise.
  80. EvoX meth tank locations - any good pics?
  81. Tapping plenum for meth?
  82. More questions
  83. New with meth - few questions
  84. Meth questions and help please
  85. New Pump and Check Valve for AEM Water/Methanol Injection Kits
  86. std 560cc injectors with meth
  87. Additional SMC nozzles ???
  88. Need help finding this Aquamist Part (pic inside)
  89. Aquamist Failsafe - Map Switching
  90. HFS-5 double pulse PROBLEM once again!.. VIDEO inside
  91. HFS-5 help
  92. Hfs-6
  93. Howerton Engineering Baffled Tanks - Thumbs Up!
  94. Too Much Nozzle?
  95. SMC Wiring
  96. HELP: AEM failsafe
  97. SEARCHED... AEM Meth Nozzle Location
  98. 100% meth question? Please help :-/
  99. Tuned for 50/50, knocking on track. Safer mixture?
  100. Thank you everyone!
  101. aquamist speciality range
  102. meth pump surge?
  103. meth AFR's - whats good?
  104. twin jets and leaking meth?
  105. HFS tuning, IDC Gain vs IDC Trim
  106. white stuff on jet?
  107. Bubbles in toobs
  108. HFS-5 messing up with 1000cc inj!?
  109. Data collection request-please help aquamist...
  110. Cosworth M3's FTL... H20 Direct Port FTW!!
  111. Micropump = Gods gift to meth injection
  112. Enuff injector?
  113. AEM meth kit
  114. AEM Water/Methanol Injection
  115. Zeitronix + failsafe + ZAVT-1, looking 4 more info
  116. HFS-5 acting weird.. any help?
  117. Nos wet fogger without fuel - can you run as dry?
  118. 50/50 with the AEM methanol injection kit or not?
  119. 50/50 with the AEM methanol injection kit or not?
  120. aquamist spray
  121. few questions on the aquamist hfs-6
  122. Priming a meth pump
  123. Water Injection Setups
  124. Aquamist HSF6 & Perrin Performance PWI-2 Progressive Water/Methanol Injection System
  125. Aquamist's new HFS-3 for 2010, replacing the HFS-1
  126. hfs6 flow not linear? screenshot inside
  127. Injection with TPS?
  128. AEM EMS + AEM Meth + HI/LO Boost from single toggle switch
  129. Yet Another Direct Port Thread
  130. What is the real difference between Aquamist and ...
  131. Meth or Alcohol?
  132. Water/Meth Injection
  133. e85 injection instead of alky and a 50/50 mix
  134. need quick fix...two things see pics.. meth injection
  135. Aem meth kit
  136. Is timing with 100% meth knock limited?
  137. question about HFS-1 and meth/fuel ratio
  138. Richard L @ Aquamist, step inside
  139. VP M1 Color
  140. Labonte Meth Inj Solenoid Testing Video
  141. Using Meth with C16
  142. Alky kit help??
  143. Aquamist - Choosing a restrictor size
  144. wi part two
  145. E85 and water injection?
  146. Jet location for evo X?
  147. To Vent or Not To Vent?
  148. help with aquamist HFS-1
  149. water meth ideas
  150. Project X - Water/Meth Install!
  151. Tapping injector Question
  152. Find me a meth kit!
  153. USP tanks
  154. Labonte Meth Kit Help
  155. Change meth/water mix sould retune?
  156. MAC valve is now available form Howerton Engineering
  157. Problem with Aem Meth Kit Pumps
  158. Zeitronix ZAVT, HFS-6; Use both as failsafes?
  159. what mods needed to build the beast
  160. methanol does not spray when its hot outside?
  161. A new generation of water/methanol tank design ... by Howerton Engineering
  162. sneaky snow performance!
  163. Intake temperatures and pre turbo injection
  164. Basic mods + nitrous?
  165. Going to buy a hfs-1..Have questions??
  166. Hose Missing
  167. Sell me your Aquamist HFS-6!
  168. Overlay: old setup on alky vs new setup on pump gas
  169. Dyno Results! BBK on pump vs alky: Aquamist HFS-1 FTW!
  170. Aquamist DDS3 Parts - For Building Your Own Meth Kit
  171. HFS-6 Wiring Question
  172. Perrin boost tube and meth?
  173. New to Meth, Best Kit to Start With?
  174. Plug & Play Mac Valve
  175. Water Kit on completely stock
  176. AIT ~140 Degrees....What's yours? Im thinking about putting Water Injection
  177. No More Meth for Me :-(
  178. Snow Performance stage 1 o stage 2
  179. Is meth good for course racing?
  180. Aquamist HFS6 Must Read
  181. HFS-6 on stock IX turbo..overkill?
  182. Question for stock turbo'd AEM meth users
  183. instead of denaturated alcohol
  184. Need advice on tuning meth
  185. 0-5v flow output from hfs-6
  186. Aquamist HFS-6 installed and running. :)
  187. What EXACTLY is water/meth injection
  188. 2-Step with Meth
  189. Target a/f when running a $hit ton of meth?
  190. Best Meth Injection???
  191. HELP!! Meth Tank Cap
  192. Power FC & Aquamist
  193. Labonte Meth kit issues...***
  194. Aquamist System Install Eye Candy (pics)
  195. Anti lag effects from too much meth?
  196. Looking for a non splash tank
  197. Labonte kit users help please
  198. Alky Jet (sprayer) before Recirc Valve
  199. Smc/ Snow performance??
  200. Aquamist flow low after 3 months of no use.
  201. Coolingmist EVO Boost + MAF SIMPLE 2D MAP KIT
  202. Aquamist with bigger injector
  203. Direct Port 100% H20, Proof of being the ultimate Injection!
  204. aquamist tanks install question
  205. What do you put in your Alky or meth tank?
  206. Meth and Water ??
  207. Using failsafe for normal driving
  208. Aquamist HFS-5 will be replaced by HFS-6 in2009
  209. Water Meth storage
  210. Meth stopped working? AEM Kit PLEASE HELP!!!
  211. Labonte Water-Meth Injection $20/$20 Rebate
  212. AEM Meth Users....
  213. Tank balls Up
  214. pressure guage
  215. Tube length from HSV
  216. aem meth kit
  217. Aquamist - Flow Sensor?
  218. methanol consumption
  219. Meth question
  220. What fuel mods are needed to run meth?
  221. Photo Pre Install
  222. What is the best Pre-Mixed WasherFluid to use for meth injection?
  223. I/C low light for meth level?
  224. Aquamist HFS-5 poblem...
  225. Advice on AEM Meth, Tru Boost, and map switching...
  226. WI seen through "Sight Glass" On Plenum
  227. New source for "Flambeau" tanks
  228. HSF 5 Pump
  229. Meth failsafe ????????????
  230. E85 with 100% meth or 50/50 meth/water?
  231. HSF-5 Being Fitted to my KitCar
  232. Aquamist DDS3v10, tephra and EBC!
  233. New to WAI
  234. My G35 TT Port Injection Pics
  235. Snow Meth Injection Install pics.
  236. Greddy Emanage Ultimate with Aquamist 1S, 2D, 2C
  237. Aquamist DDS3 V.10 Install Pics
  238. nitrous controllers? (dynotune or AEM EMS)
  239. Problem with trunkmount Cooling mist.
  240. Coolingmist nozzle parts
  241. estimated gains with meth on std 8?
  242. Flojet to Shurflo Pump- 200psi too much?
  243. DDS3 & AEM pls help
  244. AEM Water/Meth users - *Free Check Valve*
  245. max boost possible running meth plz help
  246. DDS3v10 & Tephra/Jack_of_Trades cable
  247. pics showing meth corrosive
  248. Big thanks to Dudical26 from Aquamist...
  249. Water injection as intercooler replacement?
  250. Meth Solenoid that is PWM safe.
