- *** Engine Runup Kit Question ***
- alky q's
- SMC Controller Wiring Help Please
- 20G SMC Alky guys
- Coolingmist Stage II kit
- Failsafes & Closed Loop Control w/ XEDE & Aquamist
- I have come across a good paper on WI/Al injection -
- Which tank did you get alky for?
- torn between these alky kits. help
- With these mods would it be safe to run Water/Alky inj?
- Confused on the water/alky?
- Meth/alky in cincinnati
- alky and cat life
- Integrating the BOV as an additional failsafe
- SMC boost start/stop
- SMC Dip Switch Settings for M10 Nozzle
- before and after timing for W/A inj
- What PSI of boost are you guys running with MEth/Alch?
- a/f was stable at 10.8 now 12...WFT
- alky/meth kit buyers guide.......
- With alchi improve octane?
- Alky injection using Methanol
- 87, 89, or 92/93
- Need Answer Fast
- 12VDC solenoid valve, EPDM, 200psi
- SMC & Aquamist DDS integrated...finally done!
- Alky Injection
- 100% vs. 50/50
- FAQ's for Alcohol Injection
- Safety Measures with SMC version 2
- NHRA tech?
- Question about tuning w/Alky
- where to order smc kit from?
- Water Injection????
- toulene or xylene?
- What Alky Injection is everyone using?? Which one should I get?
- how does it all work
- Alcohol Injection or Cams???
- Alky Injection-Yes or No?
- Snow perfomance CHECK IT OUT!!!
- I already have a base flash. Do I need another tune for Alky?
- Snow Performance questions and answers...
- SMC Kit Question
- ARP Head Studs a Requirement?
- Fire Extinguisher
- alchohol injection ona 06 mr9
- anyone using 15gph nozzle
- AIT and Alky Placement question
- TTP-Engineering
- smc kit trouble shoot please!
- Boost on Alky
- SMC pump, kicking on at 18psi?
- How to prevent BLOW if alky fails!
- What sealant is meth resistant?
- Aquamist WI strictly as a SAFETY measure?
- Mounting 2.5 gallong tank?
- long term effects
- Is the smc pump suposed to sound like its pulsing?
- Need help with getting the right kit
- 100% methanol for boost, gasoline for everything else
- Trunk Mount Water/Alcohol Tank
- Aquamist system not spraying.. (Yet)
- maximum flow thru DDS3 sensor
- Is Alky worth it on Stock Turbo?
- Breaking up really bad with meth
- What's the resultant effects of nozzle location?
- where to get low fluid sensor
- problems tuning with meth. help!!!
- Anyone know this!!!!
- Alky install
- Nozzles to buy!
- Methanol Safe Pump
- SMC Kit not working all the time
- Has anyone tried powermist Hot Shot methanol?
- aquamist bracket
- which alky kit ?
- Anyone know were to get spare parts for the Coolingmist (Shurflo) pump?
- water tanks
- 05 Alky
- racing methanol vs. methanol
- My DIY alky kit experience
- Which alky kit
- thanks SMC
- Check Valves with Alky Injection.
- Can I run H2O inj without a tune for 2 months keeping boost at 22 psi?
- what fitting to use off the i/c spray tank?
- Progressive controller settings
- There are failsafes, failsafes and failsafes...
- Spark plug:no water inj vs. water inj
- Water injection and EGT
- just did a "dry" run...
- Shurflo pump pressure switch
- SMC Failsafe?
- Snow's failsafe device - safeinjection
- Seasonal greetings.......
- Accumulators not work w/ progressive setup?
- Distribution of water/r-oh mist and knocking
- Nitrous jet VS Mxx Mcmaster jet for DIY methanol kits
- Changing the setting of my controller after car is tuned
- Tuning with AFR or Lambda?
- Which Shurflo pump to use?
- Stock I/C piping w/ Alky injection
- Spark gap for R-OH/H20 injection
- Progressive injection Vs. on/off injection
- Using washer fluid
- SMC kit questions
- Adding race fuel to an alcohol modded car
- Rare animals - new breed of tuners ...
- H2O/Meth injection results
- Museum pieces
- DIY water-alcohol injection system
- SMC stock pump overloaded?
- Hago injection nozzle info
- My Aquamist 2D/DDS3 installation pics
- My Aquamist 2D Installation
- Switching from denatured alcohol to Methanol after the tunning
- Who's who and what and where...
- Coolingmist progressive controller
- which plugs for 100% methanol?
- Two interesting questions about SMC
- Are you running too rich?
- Where to buy METH or ALKY
- Thank you, EVOM
- Pics of my SMC Alky install, need help/advice...look inside!!
- Alcohol injection getting bad rap
- Denatured alcohol = Methanol ???
- Stupid Water/Alky injection Question
- Methanol, Denatured Alchohol, Water Injection - Street Legal/Cat Friendly?
- Buschur/Dynoflash/SMC alky kit problem?
- Aquamist (Water injection) questions and answers here...
