- Oil Change Evo 9 Mr
- AEM has just brought out a WAI system
- aquamist system Q
- Aquamist 22mm hole cutter ON LOAN thread...
- Aquamist HFS-1 system: Official Q&A...
- Adding a flow meter
- question about aquamist hfs-1 install
- help!!! METH AND WATER MIX!! aquamist
- Aquamist Install Question
- Running higher boost with meth
- The beauty of the "Nick" Tank/Pump/Tank setup
- Super Size It! - Aquamist HFS-5 Milo style
- Aquamist HSF-5 Phase I Complete:
- How Much Meth Pressure Should I Have????
- Where to place AEM AIT Sensor??
- Loud Snow Performance Pump
- alky vs meth
- hanging twin 6 quart flambeau tanks
- Snow Performance Stage 2 and 100% Meth
- Picture or measurement request for DDS3 gauge
- HFS-5 multiport questions
- special tools for aquamist HFS system install
- Snow install help
- Formic Acid -- Is this an issue for injecting water?
- 72 quart injection system...
- Can three seven quart meth tanks be used with a snow meth kit on one pump?
- Mac failsafe valve ports (1/2/3) and aquamist HFS-5
- aquamist shsv
- Pre Turbo Injection
- Nitromethane Thread
- Perrin PWI Best place to put nozzles???
- My Aquamist HFS-5 Install Guide
- 5' Wiring Harness Now In Every Kit
- HFS-5 Installed and Tuned!
- Need some snow performance pics...
- DIY failsafe idea w/ schematic
- HFS-5, one or two nozzles?
- Tuning H2O Injection Basics
- Adding external spray light for SMC controller??
- NEED SMC m-15 jet and junction block with gauge to mount on UICP
- Snow Performance Compare: Check Valves vs Solenoids
- moving forward with ethanol injection
- HFS-1/5 : MAC solenoid valve & flambeau tanks
- Max MAF values running alchy?
- Adding Ice to Meth Tank.
- Aquamist...Special Thanks!!!
- Aquamist
- Reverse Flow Check Valve
- aquamist race pump - increase flow
- N-tercooler
- what alky kit are you using w/stock turbo
- How much fuel are you guys taking out?
- HFS-1 & Pressure switch ?
- alky?
- what's the best jet to spray meth????
- Sti meth tank
- Another install
- jet location
- Any HSF-5 kits installed completely in the engine bay?
- Shelf life of methanol
- Quick pics of HFS-5 Install
- Setup on Nitrous?
- Post Your Set -ups
- feeding time
- Bolt on IX 50shot dyno/track vid's
- OEM IC sprayer tank on IX?
- 100% Methanol 3 Weeks
- Nitrous Questioning
- methanol mixtures
- Replacing my SMC pump with another brand
- Anyone using the Aquamist HSF-5?
- Mac Solenoid Group Buy
- Help decipher mystical world of injection
- yellow wire to ? on maf sensor plz help
- High load timing with alchy
- Gb Hfs-1
- Perrin Meth Injection kit Primer Pump
- Where can you buy methanol???
- water jet size thread
- Spraying water before tune
- Meth Pressure gauge ??
- Fuel Injector Wiring?? (for FIA2)
- Smc not spraying, supposed to get tuned tomorrow.
- Aquamist and denatured alcohol
- Snow Performance: "GOOP" Now Included In Every Kit!
- smc settings
- Race Gas and meth
- do any one on evom make a meth kit
- Venting a meth tank?
- best alcohol injection kit.
- Priming/Testing Pump for Alky Injection Setup
- Snow Performance
- which pin on the AEM EMS?
- New DV / BOV Needed??
- Meth tank placement?
- Nozzle options???
- Zeitronix ZAVT problem
- Rookie Questions
- General meth questions.
- Aquamist tuning configuration
- Need to Buy Meth Tank(s)
- Windshield Washer Fluid
- Recommended Nozzle Size for SMC Kit on 9
- snow performance alky kit problem
- SMC Kit Malfunctioning?
- snow performance install
- HFS-Install, Beautiful !!!
- Looking for a Meth Tank
- NEW Snow Performance Mounting Adaptor and Bungs
- Front SMC kit, can it pump water?
- SMC Kit: Where to purchase?
- Storing methanol.
- I did a search, but I still need some help.
- Selecting Nozzle Size (Aquamist)
- Getting Meth
- Isopropanol vs Methanol???
- Shurflo pumps of major WAI kit manufacturer
- Going to test new SMC kit with just water?
- Aquamist myths and views... HFS-5
- ultimate auqamist system
- 360° questions, i'm new to wi.....
- Faisafe's with the SMC kit?
- NEW Snow Performance Safeinjection Q&A...
- Evo 9 running meth at 30 psi with a gt35r and ignition amplifer, question.
- Introducing the new HFS-1 system by Aquamist
- Warning to all water injection users...
- What are damages to the engine?
- where to installed jet info please
- A few questions before I get started.
- Winter Storage
- Quick question on the SMC Alky injection kit controller.
- new to meth.
- I Have a Failsafe for My Meth Kit. What Else Can I Get to Monitor Everything?
- Snow Performance... users pls share your experience!
- Pls help me finalize my decision
- race gas + meth vs. race gas + H2O
- Aquamist HFS-5 system: Official Q&A...
- Perrin Water Injection Kit ....
- What kind of TUBING for Snow Performance Injection
- rapid cylinder wear w/pics
- coolingmist varicool test
- I want to get a snow performance kit! Please help.
- New to meth/alky
- Evo 9 RS Aquamist 2d (pics)
- Can I use a m15 nozzle to spray across the pipe?
- What spark plugs should on my evo 9 with a snow meth kit running at high boost.
- Considering an alky kit...........
- Think your system is really progressive.......read this
- flow testing your injection system
- PWM valve Vs. PWM pump injection system
- Water Incetion vs Race Fuel
- WI set up
- Ace is the place! Alky by the drum...
- Flow sensor or pump not working?
- Hobbs switches
- Aquamist VS Snow Performance
- cost effective setup for california bay area?
- AMS jet size?
- oil analysis
- Tank/Pump Placement Question
- water injected intercoolerless evo
- coolingmist varicool ( does it work )
- SMC Website/ Contact info
- Snow performance kit
- Does anyone make a mw10 nozzle for smc
- Snow Performance Safe Injection Intergrated into SMC kit!
- Aquamist HFS-5 system design concept explained...
- prob;em with snow performance stage 2 maf alky kit
- Price for Methanol?
- Nitromethane Q&A..
- water flow Vs. methanol flow thru nozzle
- Evo IX's stock turbo with Meth/Akly Injection
- Alky < Meth? ...getting knock with alky...
- Is anyone running the Perrin Meth kit?
- L-Jet connector sources?
- Aquamist new hi-flow system for 2007
- 5th Injector, Methanol, and AEM EMS
- Water injection for autocross
- Anone using Snow's Safe Injection with an SMC kit?
- SMC Methanol Users
- Buschur Racing Alcohol Injection Kit
- Long term effects of meth/alky on engine
- Perrin Puts in their h2o cents
- okay to use teflon tape around fittings? how to seal up around nozzle
- Mounting SMC nozzle.....
- Aquamist needs your advice...
- can boost damage alky pump?
- Coolingmist Low-Level Sensor
- Is it really safe having meth mounted inside
- Another alky injection project
- Jet sizing needed for 50 trim
- Aquamist 2d install Question
- WI system with failsafe for $375 or so...
- Introducing the new DDS3 v8...
- alky system, checkvalve, progressive.....good reading material
- question about meth?
- Alcohol injection without tune....
- Necessary to upgrade OEM IX Spark Plugs with Alky Injection and higher boost?
- Easiest Alch kit?
- Snow Performance questions.... couple easy ones! help me..
- Aquamist forum is alive and online again...
- Is an aftermarket WGA truly necessary when running high boost with Alky Injection?
- Water Injection Research Paper
- Reaction of methyl alcohol with aluminum
- Runing 100% Distilled Water
- Has everyone seen the new coolingmist kit yet?
- BOOST activated system
- would i be able to hit enough boost?
- where to tap for meth jet???????
- Yellow Heet
- Target AFR's for Meth
- Effective Octane
- Home Depot Meth?
- Help!.
- How much to inject?
- Which ALKY kit should i go with??? Need answers quick
- Is a wideband o2 needed to run meth?
- Dual m10's
- In Car Gauge
- Alky Database
- VP fuels meth..M1 or M3??
- Research Paper on Water vs Alky
- Advice or feedback please.
- Install time of Aquamist 1s kit?
- controller problem
- what bov are u guys running w alky?
- Water/alky injection with 91 octane and low boost, worth it?
- Keeping methanol suspended in water/meth mixes
- Who here is using coolingmist pda controller?
- The "Big Boys" are on to us.
- Anyone runing FJO WI system?
- some noob questions about alky injection
- 100% meth or water vs 50/50 mix
- Meth injection reccomendation.
- SMC Front Kit
- IC spray tank, alky pump location?
- Battery In Trunk Plus Meth Tank?
- Evo ix & alky?
- Alchy injection questions
- FJO's new water/meth kit
- what's wrong here?
- Do you need injectors to run alky?
- Water Injection Safe EGTs
- alcohol vs meth
- Does METHANOL kill wideband sensors?
- Aquamist new product promotional video...
- Source for Nozzles??
- Purchasing Methanol In Sacramento Area
- SMC kit question about pressure
- Adding Alky
