View Full Version : Water/Alcohol Injection & NOS
Pages : 1 [2] 3 4
  1. E85 or E98 as a replacement for Denatured Alcohol?
  2. Question regarding HFS-1 install
  3. tank & pump ?
  4. Dry shot & fuel pressure?
  5. Ultimate meth kit
  6. Cooling failsafe w/ Profec-B=wastegate pressure
  7. Running meth at the right time
  8. Tuning for WI??
  9. Water Injection basics
  10. how long?
  11. Water, meth or a mix?
  12. Aquamist second Nozzle question.
  13. Labonte Meth Kit
  14. Tax credit for alcoholics...
  15. Meth, timing, and psi
  16. best EBC for meth injection?
  17. Information Needed
  18. Our failsafe/controller
  19. Water-Meth Q&A (Labonte)
  20. Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
  21. To leave on or not to leave on, that is the question...
  22. Aquamist's new concept system preview...
  23. Nos And Meth Qeustion
  24. Where to buy SMC kit?
  25. SNOW PERFORMANCE: New 2.5 Gallon Reservoirs
  26. coolingmist: more info on this please
  27. HFS 5 in San Antonio, TX?
  28. KevinD Preassembled AquamistHSF-5 Review
  29. Launch Control & Meth???
  30. AEM meth kit help
  31. New! EVO Boost + MAF Simple 2D Kit
  32. Methanol in fuel tank
  33. Upgraded the tank for my Aquamist kit
  34. MAC valve with coolingmist meth kit?
  35. Aquamist HFS-1 alky kit install
  36. Rear washer spraying when meth is on
  37. Anyone have TTP meth install directions?
  38. what meth? and what the diff of M1 and M3
  39. Pump Placement?
  40. Coolingmist custom install explained and reviewed
  41. Snow kit + MAFT questions
  42. meth line
  43. SMC tank for Aquamist kit????
  44. 3 Quart Reservoirs Now Standard In All Kits (SNOW PERFORMANCE)
  45. Question re external venting of methanol tank
  46. Aquamist 2D -> HFS-1 or HFS-5 ?
  47. Labonte MotorSports Newsletters
  48. Where to place meth/water nozzle
  49. Meth/Water review
  50. Aquamist HFS users: At what IDC % are you starting injection?
  51. No tune on meth
  52. Spark plugs
  53. In need of some tubing.
  54. For you methannol users = TANK engine in mustang
  55. SMC kit opinion wanted
  56. Aquamist 2d Bracket
  57. coated pistons
  58. My Evo VIII RS Aquamist HSF-1 Install :)
  59. Call to Perfect Pwr SMT6 whizzes…
  60. DDS3 help...
  61. Alcoholics Anonymous????
  62. Green w/out Meth Green w/ Meth
  63. Anyone got another source for flambeau tanks...
  64. anyone has trouble logging on recently?
  65. Aquamist HSF-5 Nozzle Question
  66. H2O/Meth. Inject. control with an AIC…???
  67. Why you should use a restrictor pill with an Aquamist HFS-5
  68. meth burning up 02 sensors????
  69. DDS3 adjustment
  70. Another Aquamist install in Tucson!!!PICS
  71. Our S-HSV 3rd Party controller kits (ECU/EMS)
  72. New Lifetime warranty on coolingmist kits!
  73. do you vent or recirculate BOV?
  74. Aquamist pump question
  75. Aquamist DDS users: red gauge or blue gauge pics? And mounting options...
  76. In Stock--> Flow Gauges for Water/Meth Injection kits
  77. Labonte MotorSports Recognized by Snow Performance
  78. Snow Performance NOW with Lifetime Warranty!!!
  79. HFS-1 or HFS-5
  80. Snow Performance Boost Solenoid Problem..
  81. When did you start using meth...
  82. Raising Boost With Meth
  83. alcohol/meth injection and rev limiter
  84. How long did your pump last on 100% meth?
  85. Meth Prices
  86. Aquamist Questions from a current SMC user
  87. air fuel ratios and meth
  88. Holy cheap Methanol Source
  89. Where did you mout your N2O Purge?
  90. The Do and Do not in a alky injection system
  91. checkvalve to solenoid valve on a progressive pump speed kit
  92. Alky kit w/o solenoid valve...not good!
  93. AEM Water/Alcohol Injection Kit
  94. 5 or 6 qt tank came with HFS group buy?
  95. Meth doesn't smell right? Need help quickly!
  96. from Aquamist...
  97. Trigger HFS-1 w/Prosport MAP sensor?
  98. Shurflo Methanol pump
  99. Richard L and Aquamist are.....
  100. ATTN: Richard L and other Aquamist users
  101. At what point does the HFS setup start spraying?
  102. Alky kit manufacturer, show us your facility
  103. labonte and snow kit, whats the difference???
  104. anyone has a smc or snow kit laying around?
  105. What are your ideal failsafes?
  106. Who here has blown a motor from running meth...
  107. Snow Performance Featured On Forza Motorsport Showdown
  108. Cheap source for methanol tanks
  109. What do you...the customer want to see as far as comparison's go for meth kits???
  110. Snow Performance Incentive Program: 12/15/-01/15
  111. anyone using a hand pump to fill methanol tank?
  112. Nitrous Newbie
  113. Crazy idea or not?
  114. 15 Pages of Nitrous Info.
  115. 15 Pages of Nitrous Info.
  116. Aquamist meth users - please read...
  117. Our Controller/Failsafe..2D grid mapping
  118. Failsafe with forge mbc and stock ecu
  119. blowing Meth during startup???????
  120. quick shots of my aquamist kit...
  121. Number of nozzles and restrictor size in hfs-5 system
  122. Seeking advice from CoolingMist users
  123. who makes the best Water/Alcohol injection kits?
  124. which meth kit to get
  125. Im Ready To Buys NoS!
  126. What is the difference between the HFS-1 and the HKS-5?
  127. water-methanol injection befor the turbo
  128. 500 + HP EVO Vid
  129. Aquamist HFS-5 questions
  130. New coolingmist failsafe/controller
  131. Coolingmist questions and Answers...ask them!
  132. Shurflo pump vs race pump
  133. My HSF-5 install pic, plus a easier way to filler up!
  134. Aquamist help needed (pump won't turn on)
  135. Perrin's solution to weak dollar..
  136. Methanol Shelf Life
  137. Power Mist Methanol
  138. Single injector Drivers?
  139. Injection Fail Safe by Labonte MotorSports now available
  140. The new VCS3G Alcohol Injection Controller by Labonte MotorSports
  141. What is the biggest shot anyone has run?
  142. Another Alchy Article in Turbo Mag
  143. question about nozzle size, % of meth/water usage??
  144. noticing a failure trend for SMC pumps.
  145. Labonte MotorSports-Get to Know Us Sale
  146. Tuning by turbine wheel color
  147. Methanol/Nitromethane
  148. Safe place to mount HSV?
  149. Water Injection only, before IC inlet
  150. My Failsafe Reaction Time
  151. Meth on track days?
  152. Meth
  153. Water/Alcohol on a Daily Driver?
  154. My meth set up idea
  155. Abner, got a message for you...
  156. Refreshed Aquamist 2d x2 nozzels (pics)
  157. 2step and Meth
  158. Nitrous Questions
  159. Aquamist Thanks
  160. DDS3 mounting
  161. Zzombae's evo - Aquamist HFS-5 and a extraordinary handling car!
  162. Vroomevo's - Aquamist HFS-5, JDM style
  163. Methanol + water = milky
  164. AEM Water/Meth Kit
  165. aquamist preassembled kits, pictures!
  166. Painless has lauched a new PPS system...
  167. HFS-5 + 50 trim + not so good traction
  168. Best bare bones kit????
  169. Aquamist and the AEM Tru-Boost
  170. MBT and water/methanol injection
  171. how many 100% meth users have tried 50/50
  172. Question: DDS3 W/I gauge from Aquamist
  173. Dry vs wet?
  174. Nozzle mount Question
  175. Finally! FP Green + HSF-5 + Kevin D. Sorry no dyno graphs.
  176. Tons of meth - good or bad...
  177. meth/oct.
  178. Aquamist Success Story Videos
  179. Can you run nitrous with meth?
  180. HSF-5 ecu pinout issues with evo IX
  181. This is getting installed tomorrow!
  182. S-L-X Denatured Alchohol and HFS-5?
  183. question about meth
  184. Aquamist components and Methanol
  185. Converting from Snow to Aquamist
  186. How Meth Made My Car Fun Again
  187. Hooking up a test button to Aquamist HFS
  188. Snow Peformance: New Controller Reads Boost Or MAF!
  189. Aquamist what? stealth tank+pump install
  190. HFS-5 Issue - Urgent
  191. HFS-1 IDC or MPS trigger
  192. Head studs and Meth
  193. Aquamist Advantage
  194. New Coolingmist Evo Failsafe Water/methanol kit!
  195. Al - the "feel" of a alky injection kit
  196. DDS3 adjusting?
  197. 50/50 mix still flammable
  198. meth/alky???
  199. New to methonal kits
  200. Aquamist HFS 1 and HFS 5 "complete install kits" available
  201. Plugs for meth/35r
  202. Apex'i NEO and Aquamist HFS-5
  203. AquaTune system
  204. Basic info about Methanol Injection??
  205. SMC guys, Start Stop suggestions...
  206. Install price?
  207. Predicting Nozzle Size (HFS-5)
  208. HFS-5 Install - Stupid Question
  209. Milo on the dyno - Aquamist HFS-5 + 50 Trim
  210. Where to buy SMC kit?
  211. 521 WHP with Aquamist HFS- 5 on PUMP gas
  212. Need Gasket for Aquamist Level Sensor
  213. MAC Solenoid connectors
  214. Aquamist port injection?
  215. SMC M10 nozzle... need one
  216. EBC w. Safe Injection
  217. HSF-5 install question: How long of a piece of aluminum
  218. Miss fire at 25 PSI w/ meth?
  219. Help Please-HFS-5 kit Failsafe Questions...
  220. Take of two meth injection cars on the dyno 470 and 500 whp
  221. ATTN: Richard L please help asap!!!
  222. Progressive pump speed injection system - Do they work?
  223. What kind of water should I use?
  224. Aquamist kill switch?
  225. Basic Kit, Looking for upgrades
  226. upgraded lines...
  227. Aquamist HFS-1 Review
  228. Has anyone used a Cooling Mist set up??
  229. Woot Woot SafeInjections are back FINALLY....
  230. Important update on aquamist tank hole size...
  231. Anybody heard of this "SMG" and "devils own" Kits?
  232. am i ready for my hfs-1 tune?
  233. Need HELP! Oversized hole for HSF-5 nozzle holder
  234. Valve flow calculator
  235. Is someone tries to develop his own system?
  236. Anyone used the silicon hose water jet adaptor?
  237. LaBonte Motorsports failsafe controller
  238. Another Partial HSF-5 Install w/ Pics
  239. Discussion of WAI trigger point
  240. AEM meth kit questions.
  241. Pump and Tank install
  242. HFS-1 Install problem
  243. methanol + water = hot
  244. Milo's 18 quart Aquamist HFS-5 methanol/water injection system + pics of car
  245. Indepth study of WAI injection systems
  246. <<<Tuned with meth>>>
  247. Pumpless/wireless (almost) HFS-5 install
  248. Problem with HFS-1
  249. New AEM kit or Snow 2D kit?
  250. FS: Hole saw, hole saw drill bit, tap, tap drill bit
