- How many maps does 8 have ?
- Car "Cutoff" Power in 3rd at 5k RPM
- Knock sum...need some help
- after tuning
- looking for good tunner in pa
- Can't drive past 20mph
- Thermocouples for air temp
- Innovate LC-1 can't find the right O2 sensor
- Zeitronix a/f gauge
- Sputter Sputter (video incl.)
- AEM Boost Gauge sender mismatch
- What are some must have gauges??
- LC-1 Troubles
- Evo 4 Ecu
- Coil pack getting hot and not firing!
- LC-1 w/ vista
- No difference b/w Ethanol and Methanol?
- Greddy Profec B Spec II Owners
- Utec map
- two mods = lean afr
- engine issue
- Weird situation throwing p300 code.
- Pfc Tuner
- best tuner in alabama/ georgia area
- hks knock amp wiring
- 2003 evo
- hi guys
- hp loss from high air temps?
- Zietronix ZAVT-1 Parameters?
- Flating out my boost
- DynoTuning
- engine problem help
- Dialing in Blitz Dual SBC
- Will An Evo 8 Engine Fit In An Evo 4 ?
- Are all Stock Ecu's interchangable?
- Few Questions before tune
- Need input on barometric reading at wot...
- i need some expert advise??!!!
- HKS DLI2 and GEMS ECU not working
- iddle issues
- Anyone know if Evoscan v2.0 works with LC-1?
- ignition, interesting points, needs cliffs.
- Tuning / logger cable? What the hell do i have??
- How does an A/F Wideband work?
- Why is the A/F ratio so fat?
- question about a/f
- Need Help W/ Instalation And Tuning Near Mt!!!!
- inductive/cdi discussion
- Tunning places
- I need help finding a RELIABLE AEM EMS
- Trouble code po172
- Frying Widebands
- Which flash/tune???
- Reflash best bet for one time tuning?
- camshaft timing help
- Eclipse V6, Karmen type sensor?
- gripe about horsepower numbers
- Tuning conservatively on meth
- HELP!! Looking for TACH signal, where is it?
- Need help
- WORKS flash / ECUUnlocker questions
- Boost
- What should my free air ratio be?
- Need help from all of you guys
- coils just keeps blowingup
- sensor signal conversion, any electronics gurus?
- Techgauges? Wideband suggestions?
- Interesting ALS Resources.
- Uego AFR logging to have rpm based graphs
- Several doubts about evo VI TME
- Tuning for AFR and timing
- Converting an Evo for Ethanol E85
- ECU Flash and P0121 Code
- 02 Sensor and A/F
- E-85 / Methanol
- Game over for AEM EMS?
- Need 3 wire EGT gauge recommendation
- Knock sensors and knock detection
- OBD II port simulator
- Stock Injector Resistance...
- Who owns a tune? The customer or the tuner?
- discrepencies air fuel ratios with high and low comp
- Closed Loop Fuel Trims at idle & low rpms
- Advanced Forum GuideLines - PLEASE READ
- AFRs: Shell V-Power vs. Exxon w/105 Ethanol
- Effects of E-85
