- manual transmission will not shift
- my ACD hard line under the car is dented HELP!
- Help My competition Clutch Wont Disengage At around 2500 RPM's
- Clutch hydro problem, I have tried everything. Need help!!
- Clutch won't engage?
- Jerking issue
- Going back to single disc setup instead of twin what will i need?
- Question
- Something in the drivetrain grinding....
- Take a look at my slave cylinder... think its been replaced wrong
- Help, Issue With Turning! Loud Bang
- evo mr tranny
- Clutch runout numbers help
- Trying to drop the tranny
- 3rd gear issue.. trying to fix today
- transmission / clutch question
- When shifting into 2nd - seems to "lag"(not turbo) to apply power
- Cable Bushings, metal vs urethane
- 03 evo pressure plate to throw bearing wire ring busted
- Opinions on AP Racing Clutches
- 1st gear issue
- what is this grommet?
- 7 RS front LSD?
- Safe to rebuild Exedy twin HD
- ATS/Carbonetic clutch
- 4th to 5th problem
- Drivetrain Thump
- Lighter Driveshaft
- Will 06 MR Transfer Case fit my 05 GSR?
- need help asap with removing the end of the cv joint
- Making the rear diff stronger - Cryo treat?
- short shifter
- Help!!!! Exedy Twin HD ?
- Whine/vibration on fast decel shift
- another ACD issue. am i killing my car? searched.. NO solid answers. HELP!
- Spacers do they really damage the transfer case.....?
- ABS ring question. RR axle. missing teeth? can i replace?
- just got my competition clutch stage 4 installed
- Kart boy bushing
- Replacing Clutch On Evo IX
- Need Help with pressure plate clip
- Shifting at high rpm's...
- Act hdss not disengaging properly (new)
- Clutch Kit...
- Bigger clutch master cylinder
- Warranty covered????
- banging from the rear during quick shifts
- part # question
- Rear engine 4WD
- Trans help w/pics Need a used gear and slider
- Diaqueen fluid clarification
- Fidanza 3.2 noise
- 3 Transfer Cases broken - What to do?
- car locked up high rpm going into third!
- IX MR; 2nd Gear POP OUT on decel, any ideas?
- Converting tranny to run FWD (READ BEFORE YOU FLAME)
- 6 speed short shifter
- need a pic of evo 8 viscous
- busted center diff, how far can I drive it?
- Humming...need input
- Whining between 3000-3100 rpm
- clutch job with ACD
- evo 8 and 3kgt vr4 wheel bearing=same part #??
- How long has your Quartermaster or PTT lasted?
- Help! I think my transmission went bad.
- what gear oil to use?
- clutch or the tranny problem?
- Best Way to fix Rear end Clunk
- axle upgrade
- Clutch or Transmission?
- Exedy twin disk questions....
- clicking sound
- Think 1st gear is going
- Transmission filter change.
- acd t/c to non acd t/c swap
- How can i reinforce My Gear Box ?
- 6 Speed Transmission Problems
- Driveshaft vibration Need Advice
- Exedy twin disk clutch
- cannot get my clutch out
- Clutch problems
- help gear fluid leaking after clutch install!!!
- ABS Module EVO X RS
- ACD Pump Sensor?
- 5 to 6 speed conversion........
- Evo 3 1st & 5th gear oem part numbers.
- Evo 9, 6 speed
- Rear LSD axle problem
- Evo IV drivetrain problem
- Transfer Case tricks
- Transmission fluid Overflow Tube
- Having Clutch Probs Need Help PLEASE
- Need Second Opinion On Clutch
- Wierd Noise above 60mph, Any idead?
- changing axle seal on transfer case?
- 6spd tranny
- transmission
- My neutral is stiff as a rock hard to move, but my 1-5 is fine?
- ticking or popping sound when taking off from a stop with the wheel turned
- runnig problem
- Results from Evo 8/9 Transmission Failure Survey
- Cusco RS differential install help
- Car in Neutral, let clutch out, car moves
- Weird jerking
- Car wont shift into second..
- Evo 7 clutch
- knocking noise help please
- 4th gear issue
- AYC ACD problem
- Avoiding ACD issues when doing clutch?
- ACD Help!
- Clutch install question Evo 8
- Tranny?
- Car will not go into gear when its running.
- Rear diff prob...
- flywheel bolts stuck!?!?!?!
- Weight Of Evo 8 5spd Tranny?
- Clutch problem
- My Mysterious active differential problem
- Confused about drive train
- Need Help!!!!
- How much faster would a evo lap around a track compared to a evo without acd?
- Whining and sometimes a jerking
- possible clutch problem
- Which evo is faster in 1/4 mile evo 8 or evo 9 with evo 8 4th gear, and if they bo ?
- Seperating Spindle and Knuckle...
- Helppp Pls
- EVO 8 and EVO 9 axles = same!?
- ımportant
- Installed/Made Tranny Cooler for my 6 speed.
- Is this normal?
- T-case whine
- Has anyone ever tried putting the AYC in a USDM Evo IX?
- HELP! Rattle and Whine noise
- '03 Transfer Case Disassembly Threads??
- Motec ACD Controller = AWESOME
- DSM Experts - RWD Trans
- Exedy & ACT single plates
- help: loud huming noise
- vibration problem
- Clutch Pricing??
- Any One Try The OS STR Clutch
- Neo Mtf
- Just Ordered ACT HDSS
- constant wavering squealing/screaching sound
- Drivetrain Questions
- Gear Ratios for all EVO transaxles?
- Retrofit ACD into a non ACD car?
- Shorter 4th and 5th gear? where can I get them?
- tc and tranny removal what do i need
- Diagram needed!!!
- Clutch
- Shifter feel
- backlash adjustment on Evo rear diff.
- Need help with rear diff
- how to adjust clutch
- help on 5th gear scrape
- TC cooler
- this totally sucks. help guys
- Clutch disc question?? ACT
- Car sputtering when trying to make a turn?
- Drive train loss
- Twin plate experts please help!!! 4/2/07
- no lift shift??
- Drivetrain Interchangability
- Shifter Problem ............. PLEASE HELP!!
- Car Trouble: Slipping Clutch??? Not Sure, Help!
- Transfer Case issue
- Cam Profiles
- 3rd gear Synchro busted?
- loud noises from drivetrain
- 4.11 gear from galant gvr-4?
- Flush the tranny at 2000 miles?? Diff too??
- new Spec multi disc clutch
- Transmission Problem Help Needed
- MR gearing rpm/mph question
- Tranny problem I think????
- TRE Transfer Case
- What are the differences between a 5-speed or 6-speed clutch?
- How to install a front CV Boot?
- Cusco Center LSD vs. Stock VCU LSD
- 20/80
- 700 miles...Needing new Synchros
- I need your opinion...
- Which Clutch
- Ralliart ACD ECU
- Do you think Mitsubishi should place a recall on their transfer cases?
- tfer case ? what actually blows up
- what could this be?
- Diagnosing ACD problems?
- Need Help Putting The Trans Back In!!!!
- Motec Center Diff Controller
- 2005 MR 6 Speed and engine into 2003 EVOLUTION 8. drive train questions.
- Help me figure this out please!!
- Shift fork help...
- Tranny comparison DSM, EVO VIII, EVO IX and EVO MR
- Possible Rear Diff. Issue?
- TOB/Wedge collar removal
- Twin disk to triple disk clutch conversion.
- Advanced Forum GuideLines - PLEASE READ
