- Low oil pressure @ idle
- Headwork
- AMS vs ARC intercoolers
- OIL comsuption!
- Modifying your MIVEC cam gear
- oil pressure drop-what is dangerous??
- Can I see any performance gain on FP Red with basic bolt-on ?
- Best Tool to Install/Remove Valve Sten Seals?
- clearances on wiseco pistons
- COP with Dynatek CDI - yah or neh?
- boost 'flutter'
- Tuned on wrong spark plugs
- Burning water. What to do?
- High boost reliability for road racing
- Exhaust housing?
- half Radiator
- TPS cel? bov?
- oil light check help
- Weak spark - any test for coils?
- Cuts out at only at WOT
- what's next?
- boost gauge?
- looking for a turbo
- A Bass Ackwards question.. Can you make an evo8 N/A?
- Cam and Springs question
- Best compression for e-85?
- coolant leak at TB side under hard acceleration.
- update on my lifter noise
- recirculation issue?
- Building my motor...need help and suggestions
- Camshaft 102130322 & 10213000
- lifter noise??
- no boost pressure?
- valve locks
- L19 Head Stud Torque
- valve guide seals
- evo 9 boost issue
- Stock Fuel System?
- busted oil cooler
- helppp
- Idle control error
- Need replacement injector clip and outter plastic clip
- Cams question
- evo9 turbo wheel
- ac delete
- 05' RS "Service Engine Soon" Light Flashing, Not Solid.
- Kelford 280's ???? should I do it....
- Help on my clutch runout #'s please
- Injector question
- bullseye turbos
- EVO 8 OEM rods vs 1G DSM Bog Rods
- MSD 75lb injectors
- Help! Boost only w/ full throttle and above 4,500
- Check Engine/ Weird boost/ Low idle
- Weird Boost Leak
- Need help head gasket
- Ring Tension
- CHRA parts swaps - putting the good parts from an 8 and 9 together
- Full Rebuild - recommendations?
- miss fire
- Car won't start
- kelford install
- Balance Belt Tensioner
- Adj Cams?
- Evo 9 Cam Centerline
- Evo 9 Cam Centerl ine
- Valve spring keepers??
- Non-AC Accessory belt size
- ATP EVO GOLD Turbo- Aussie Made
- how many times i can use the ARP headstuds
- Timing belt help
- over heat after cam install
- how to tell
- Coolant flow rate for Evo VIII/IX turbo?
- modded evo no start at times
- Can a Timing belt effect compression?
- Help vacuum problem
- injectors
- Mod Advice: MAP 38mm MVS O2 Eliminator Downpipe w/FP Red
- Cam question
- injector resistors location
- possible immobilizer issue
- oil return fittings for precisions. Where to buy asap?
- Fuel regulator
- Who runs Kelford 280's?
- kia or evo block in 4 cylinder dragster
- JDM Evo VII in Thailand- input/feedback on planned mods
- Bigger turbo on stock pistons an conrod
- GT35r vs HKS 3037s >which's better for my evo?
- O2 signal wire
- Head Gasket Issues
- Timing belt noise.
- what are the best spark plugs
- What is Evo 8 rocker cover made of?
- Show me your setup for high elevation
- TPS wire diagram for Q45 Nissan Throttle body
- 2 pP0300 codes.. HELP!!!
- Oil pressure light flickers on at idle.
- Mivec IX valve cover on VIII engine?
- Evo 9 2.3L Stroker into Evo 8- possible problems?
- Engine Combinations Boost + Static Compression - Discussion
- Over 600awhp... 2.5" or 3" FMIC piping?
- What Injectors to run?
- Gt35r Exhaust housing question
- peicing a turbo kit, where can i get these little items?
- Greddy Type S
- Egt???
- Acd
- HTA3586 vs 6262 turbo
- dumb question
- White smoke that smells like fuel?
- SAS/ALS install usdm evo 9
- Evo 8 to 9 engine swap
- best Head gasket
- fpred 80mm option
- Need help with oil leak!
- Evo 1 water pump
- Quick question i cant seem to find anywhere
- Idle Problems
- Synapse BOV...does it just NOT work for some cars?
- My Car Isnt Boosting past 4lbs...Help!
- few random questions
- Airflow fluid dynamics
- Part selection choice?
- Serious Problem EVO WONT GOOO
- Intake Manifold Hose's
- Need Help with LICP for FP Green setup on 03 Evo..
- Can I use this turbo?
- extend the clip to the ignition????
- axial clearance rods.
- What do I look for in a BOV??
- evo 8 turbo w/10.5 hotside which wga to use?
- 20g surge question
- Boost leak? or not?
- 2.3l strocker w/ i-beam ques.
- p0300 random misfire!!!!
- Oil on exhaust manifold stud???
- HELP! wierd noise at idle
- Tomei 2.3L stroker specs
- Question about timing belt service...
- Engine noise, please help!!!
- Turbo comparo
- Evo IX Throttle Response
- What do you see hear?
- who has made there own cop?
- blowing fuse problems
- Magnus sheet intake mani problems...
- HELP ASAP with M3 CAMs
- hta 35 dumppipe
- Having serious timming issues
- Tial wastegate flutter
- Where to put stock map sensor in Magnus intake manifold?
- turbo??
- evo9 boost problem - im at my wits end..
- Which is safer for DD?
- Oil cooler line threads/pitch
- too much boost/boost flutter in 5th gear help please!
- FP Green ..
- what the best turbo for daily & drag use for evo4 ? fp green, red or GT28, OR ???
- 2003 evo 8 turbo?
- Compression results, leak down test results, and questions...
- WTF!?! Random misfire happening around 3k RPMs at 71-74 MPH in 5th gear only.
- FP Green & GSC S1 setup !
- Can't boost past 10psi...wastegate and vacuum lines ok!!
- need help with car
- check engine
- Twin Scroll Sceptics BMW X5 M owns you....
- Upgrade FMIC Intercooler
- Quiet 3 inch performance exaust....anyone ???
- .hta gt35r but what else...
- Big jolt when I let off the gas at high RPM.
- 500 WHP Daily Driver !!!
- hey guys i was wondering how many miles should u change your timeing belt
- Porting & Polishing head BUT wut about valve size ?
- Weird noise after Buschur FMIC install!
- Cam TDC Marks
- what turbo should i get
- cam install = no boost?
- Fuel and Spark Problems
- Lifter Question's etc....
- H-bean or I-bean RODS
- EVO VII MR - Ti/alloy option
- wiseco .20 piston pin
- GFB BOV leaking from top
- holset 256
- Fp Green turbo hot side
- Making COP setup, need source for Male connector
- Whereto have a head Oring'd
- GREDDY SPEC V question
- Drive belt making alot of noise!
- Yet another head oem head gasket thread.. Share your personal abuse stories.
- Head question
- Safe Boost Limit on STOCK 2004 EVO VIII GSR Turbo?
- Are the evo 9 stock headstuds safe to 30 psi used with an fp red?
- Evo VIII Mivec swap? ( evo9 engine in evo 8)
- Sites to buy Evo 3 parts: 4g63t whatever
- hks turbo timer install
- Evo VI RS2 IC piping / review
- Fuel Heating???
- Borg Warner turbo...
- EVO 8 and 9 Electronic Boost solenoid
- CEL P0202. Pls help!
- lean idle
- ebay manifold
- coil on plug wiring
- external wg hookup
- EVO hesitation, shutter HELP!!!!
- strange noise
- Who Is a good tech starting issue Evo 8
- Help: misfiring under load
- evo VIII "under load" problem
- bearing noise
- NEED HELP: HTA 35r Oil Feed Line
- Right rebuild kit for the TD05HR?
- Air Bearing Turbos in Testing
- Battery
- 4g63 to a 4g64 block
- boost problem evo 8
- e3 spark plugs
- Max power on stock exhaust??
- NEED HELP: unstall turbo kit new one on!
- Spark plugs & Gap for Evo9 on Meth
- headstuds / cam install questions?
- Need Help....Hard to Start and Idle Issues....
- car won't idle :(
- How much?
- motor swap question
- o2 housing
- stock injector questions
- Kiggly Racing Oil Pressure Reg for Evos
- Installed my oil pressure gauge now I have questions.
- Best BOV/Recircle valve ? Sugest please.
- Troubleshoot Power - Mods listed, graphs included - I'm told this is not good power??
- 57 P trim hotside for evo?
- Cams/MIVEC
- what brand is better ?
- turbos
- Throttle Body Coolant By-Pass???
- At home engine build parts recomendations??
- What Mods You Need For A Red On A 8
- Backpressure on high boost
- Precision 3582 RLPS w/ mitsu housing
- 2.0 Build?
- HTA 35R not enough?
- evo9 turbo on evo8
- (T31 4bolt) Is there really a big difference between ported/unported Turbo housing?
- Need Help!! How to Prime Turbo!
- o2 Housing drilling...
- How Much Power Will I Have With My New Parts?
- Which Cams Combo?
