- spark plug gapping
- Oil Catch Can Fitting Size?
- has anyone ran testing on different exhaust
- only boosting 10PSI ? ? stock solenoid??
- Problems, 2003 Evo VIII recently purchased
- Car only boosts 1 bar, 4th+5th gear turbo doesnt spool til late.
- *****important Notice For The Forge Diverter Valve*****
- what is this?
- ARP Rod Studs
- my evo overheating :/
- ARC Parts?
- cylinder head specs and repair...got questions
- Hallman Boost Controller Q&A...
- safe without a tune for 1 month?
- Boost Level question...
- need help on greddy profect b spec 2
- how much boost
- cam gear timing ??
- my car cuts out
- fuel filter
- no spark :(
- Anyone considered/attempted ITB's
- First Oil Change
- oil light
- Pre-throttle body pressure for manual boost controller
- Anybody use the new FORGE piston-type WGA??
- low oil pressure
- Compression problem
- buddyclub soundclip?
- 50 trim Turbo only
- Denso Iridium Spark Plugs...help?
- blown engine on e-85 600 miles......
- Data Acquisition Discussion (I want to log everything...)
- Crank case evacuation pump
- Free 8hp Mod?
- FPEVOGreen/Buschur 20g-9LT turbo + 18lbs actuator on only pump = Boost hump
- Lifters or belt tensioner
- T3 divided exhaust manifold, anybody?
- HKS ssqv recirc.
- Who does the best turbo porting, and manifold porting?
- Best anti surge housing for gt35r?
- Machine Work Vs. No Machine Work On 9k Evo 9 Motor...
- ebay turbos:
- Why mount the diverter valve on uicp?
- Shearer Evo Street Brawler Turbo Kit?
- oxygen senser test ??
- Fuel Cell Expansion/Replacement for Evo 9 SE
- Cams to use with 2.3 stroker?
- What are the effects of 9.8cm puck failing?
- Will I get compressor surge runnning 30psi on a perted atp gt35r?
- What is the best anti surge hosing for atp gt35r?
- need help, and pics of the stock evo8 turbo/housing.
- Looking for PIN out of 04' 8rs and 06' 9MR
- I am thinking about drilling my compressor shroud on my atp gt35r turbo to prevent.
- 10.5 hot side
- How much material can safely be removed from a gt35r with porting and a maford manifo
- What if I square the atp hotside flange and do the same to a maxford manifold?
- Can i port atp hotside to match dc sports manifold flange
- wiring diagram: boost solenoid
- Wierd BOOST ISSUES HELP!!!
- stock to t3 adapter
- Atp gt35r .63ar max whp with 93, meth and supporting mods.
- Atp kit, will it work with a gt40r.
- Which blow off valve?
- Agency Power kit
- Plug Selection with Nitrous
- Measurements of removed internals
- What's limiting power on stock internals?
- Not firing
- injector tips
- Limit of Efficiency for Stock Evo IX Turbo in PSI
- ARP Head studs
- Valve Question
- Overbore Limit.
- Nanocomposites in future engines?
- need block ID help fast!!
- Throttle Body Coolant recirculation
- Quick ? about timing and balance belts...
- How to make atp gt35r turbo kit twin scroll.
- Quick question about bolts connecting mani to turbo.
- Just bought a Atp gt35r 63 ar turbo kit for my evo 9.
- Looking to buy a gt37r turbo kit.
- hks stand alone
- valve spring install
- Oil starvation during hard cornering
- Greddy Problems: Profec B Spec II Not Holding Boost
- "Hairdryer effect" and aftermarket FMIC
- head question
- spring height
- If space were not an Issue How would you build a Header?
- Engine Bearing Tolerances
- Rev limit on the 4g64 crank
- Stock WGA-Travel distance?
- Size Does Matter
- Help Water level low / cuts / Temp crazy
- Mivec
- HELP!! high vacuum reading
- Need a way activate a relay via boost?
- Path for my ATP GT3076 turbo?
- Fujitsobu catback mated to buschur downpipe/testpipe
- idle fluctuations after cam install?
- weird rain issue anyone have this happen?
- Another Alcohol backfire!
- BLE Solid Timing Belt Tensioner
- what should i get
- Drive Belt Replacement
- Low whp ?
- Max boost Apexi RX6 turbo kit
- Opinions/suggestions needed(Low WHP problem)
- replacing cams on a 9
- Gear dependant signal?
- Electronic boost controller
- greddy profec b spec 2 ?'s
- Flooded the Evo....Please help.
- Coated Intercooler Question(s)
- IX BOV Mod for Higher Boost
- Crower Cam Question
- Precision PT-67 spool time?
- Evo 9 cam timing only in the lower revs? is this true?
- Disassembling an Evo 9 turbo?Expert Help needed!
- fabrication ?'s
- help me
- VNT,VG Like Turbo setup
- Need help finding vaccum leak.
- trouble with Apexi WS2 Cat Back and Espelir Down pipe
- Installed MBC and Downpipe/Cat-Delete and now problem
- big turbo vrs little turbo
- Direct Electronic Boost Control
- Will the 05-06 TBE fit the 03???
- back to stock intake?
- Mivec on non mivec engines
- Dynojet Setup
- Piston design quench zone
- Megan Racing Exhaust ??????
- MAF 03-06 all the same
- EVO longblock weakness???
- ANYone with a T88?
- 4g63 block differences
- XS Engineering DP and Nesei LICP on IX
- Camshaft sensor broke - Is the EVO 8 same as EVO 6? HELP!!
- DIY "Gus Mod" Switch Questions
- Ported stock intake manifold vs Magnus SMIM.
- whats the most reliable manifold that can last a nice 4 hours of racing hard?
- Intake manifold explosion! Alcohol possible cause?
- Raise the fuel pressure
- GT35 ... Antisurge Housing? Questions
- Adjustable Wastegate
- Cam position sensor on evo9 intake cam?
- 4 bolt vs 5 bolt (ford style) discharge housing
- bad Idle Speed Controller (ISC)?
- oil viscosity, weights etc-long/neat race car
- The Intake Manifold Thread
- What determins engine response besides rotating assembly weight?
- Spark plugs
- The Fuel System Thread: Stock to 1000+whp
- About backpressure : intake pressure...
- Diverter valve tech.
- Boost creep w/External Wastegate [dsm]... suggestions?
- Piston Coatings Etc
- Head Specs
- Coil on plug diagram - should help some out
- flow charts, flow numbers et al
- Boost creep with stock turbo....
- Boost taper
- torque plates and honing
- PCV system theory and Oil catch cans.
- piston engineering
- Controlling the IAC Motor
- aftermarket piston specs
- WHP to BHP
- Mitsubishi OEM turbo specifications (including flow rates)
- Advanced Forum GuideLines - PLEASE READ
- First test intake manifold (lots a pics)
- Engine Air Flow Dynamics
