- B.O.V Question
- FP Red Flow Rate
- hks 2.0 ams gt37r
- FP Red on Evo X set up Help
- Removing head - can the turbo stay
- What InterCooler To Buy?
- color coordinated engine bearings???
- ACL Rod/Main Bearings Extra Oil Clearance?
- Stock 2.0L EVO IX with GT35R turbo kits come in..
- 1G DSM cam gears into my Evo 8 ???
- Power cut at 6000rpm
- Do I have the quickest/fastest stock ecu/mas EVO?
- EvoIII Head
- My car is stuck in warm up mode!!!
- balance shaft removal
- Turbo Flow Brainiac Needed
- FP RED setups, recommendations, and advice
- Help Head Removal
- determining b.o.v type
- evo 8 and 9 ignition
- volient idle v2.
- 10psi. . . 15psi . . . then works fine???
- Garrett GT 30 OR GT35.pls help
- very low idle and stalling
- help please
- 20g or GT28
- Need Help on MAP Sensor
- trust-greddy???
- Pin retainers... OH MY GOD!
- NOS Anyone?
- Intercooler End Tank Design/Theory
- Talon TSi Exaust manifold compatibility
- kelford cams anyone?
- Gt30
- evo parts for sale
- problem after cam install
- boost leak test causing oil leak from 02 housing?
- boring cylinders
- is this stock turbo?
- Remote ACD resivoir relocation kit
- 6765 Precision turbo???
- Edelbrock 75mm TB with Ford IAC questions
- Drop in Pistons+Rods: BS Removal?
- 2g dsm crank same as ours?
- EVO 9 turbo issue
- TD06 / T67- 25G review
- shaft vibration help
- Wiseco pistons in 2.3 stroker
- compression problems??
- is it ok to drive with a blown exhaust manifold gasket?
- rhd evo 5 white smoke(compression test +
- Wiring 2 fans up?
- Need Help HKS 272's Stock Valve Springs
- werid noise from turbo housing
- Hi Flow Cat Or Test Pipe?
- Evo 1 Oil Filter?
- EVO7 Oil temp and Pressure readings
- downpipe bolt thread
- More datalog goodness
- Anyone tried these 02 sensor replacements...
- exhaust
- hks intercoolar help
- extreme power cut falls on face!!!
- revolver 280's stock valvetrain?
- EVO 8 FP 4R Cam
- DynoTuning
- 9 turbo
- HTA 35r VS GT850R????
- If i was to upgrade my internals on my evo motor would i be able to run 30 psi on 93
- Modified Crank Trigger Plate
- Cam angle sensor Orientation
- installed forge mbc boosting question..
- Choice Of Block For High HP Build
- Vp C12
- Shimming the 4g63 hydraulic lifters
- GSC S3 and stock ECU
- weird boost broblem??
- no fuel pressure wont start
- Choice of cam gears
- Maintenance time
- No start after fuel pump and injector install
- need help! strange idle decreased boost
- fuelpump/spark plug question
- wierd boost leak i beleive any ideas please?
- Any how-to for replacing Alternator?
- EVO 8 Oil pump Gear Play, need a confirmation.
- vacuum lines/effect on boost
- Cam Timing
- Oil temperature probe location - filter housing or drain plug?
- whıch slım fan can ı use
- Stock boost on GSR 260?
- porting titek o2?
- Bad boost creep
- Advice needed on setting fuel pressure
- 2 part question
- maximum oil working temp?
- Fuel Pump Question
- boost problem. please help
- upgrading turbo question
- porting exhaust manifold
- best way to clean out Intake manifold
- Misfire at idle
- setting the timing
- CYL 1 and 3 are DEAD!!!
- P0401, P0300
- Tial wastegate control with an Apexi AVCR
- compression ratio for 600-700 hp
- HKS EVC VI set up
- exhaust and turbo manifoldx
- boost controller/guage
- New Product in Development! Interested?
- Carbon Pistons??
- What turbo would I need to run to get 500 whp and 500 wtq with mods on pump gas ?
- Gsc S1 cam Timing
- wrapped damaged cams?
- Supporting Safety mods for Cosworth Cams
- intercooler & pipping
- White smoke under decel?
- Strange Boost Leak - need some help
- How much boost should I dial before Ecu tuning? Please reply, need advice
- Specs for a 2.2ltr question
- mysterious active differential problem
- Engine Troubles?
- Why use other mods, if increasing boost can get the power you want...?
- GM maf use and relocation possibility?
- Choice of Cam??
- new jam lifters
- Is anyone making a turbo kit w/GT-K turbo from Turbonetics
- Why are BOVs that VTA not good for MAF?
- HELP! anyone.
- AEM intake question.
- fp green
- what cr should i go with
- sensor problems
- What is the deal with Full Races Twin Scroll?
- Plugs fouling..help!!!
- Boost raises above 27 PSI and up!!! Need help! Hallman MBC
- IX crank in a VIII - question
- Mitsubishi TSB on "Coolant / Oil Revisions" to the 7-Bolt Engines ?
- Evo IX Stock piston, 2 or 3 piston rings??
- Need help deciding on next mod
- is it possible with this setup to hit 400!?
- Cam Gear Tool
- finding dumptube ??
- Twin charging (again)
- When to get a FP regulator?
- mivec head
- Intake/exhaust porting...hp increase???
- Big Issue Need All Engine Builders Input Please!
- Reducing sound and remaining the boost.
- Help with TwinScroll 35R Turbo!!!
- advice please
- To o-ring or not to o-ring that is the question
- no spark...
- Compression Help?
- Car shakes and goes crazy when hitting boost?
- Engine noise?
- Need Advice
- spittin out of the exhaust
- GT30R setup ...?
- question about oily spark plugs
- valve spring rates
- 65mm TB Port causing whistle
- Propane Injection in a gas engine?
- EGR elimination how-to available?
- Got A Major Boost Problem, Some One Has To Know What This Is!
- Turbo Boost problem
- Are DSM and EVO lifters the same part 4g63T?
- 2.3L stroker...cam and turbo spec
- turbo swap complete something is really wronge with car i need help
- What supporting mod for running 35R kit w/ maf delete
- bov problems????hepl!!
- Need Help ASAP!!!
- electronic dump valve???
- boost control question
- Crank sprocket & pulley wear?
- Monster style
- Stock Plug wires
- Smooth vs. rough surfaces
- 38mm turbosmart wastegate
- PTE vs Denso injectors
- UICP & stock inake
- mustang dyno vs. dynojet dyno
- intercooler horsepower gains
- Blitz SBC-ID III ?
- New turbo purchased...Need help on setup
- Turbo upgrade - need help pls guys
- EBC Boost solenoid question
- Which Turbo spools faster ??
- FP Green
- Air Duct Plug??
- Install ARP studs without head removal?
- Couple driveability concerns, maybe time to re-work things
- Trouble with Possibly bov please help figure out!
- Just getting ready for BR 35R
- DSM equivalent of this turbo?
- HP gain????
- Toluence
- Having boost Problems Help!
- Scram/Ram Jet engines
- Hose Dims for Stock Intercooler
- turbo upgrade
- Strange RPM issue after boosting
- Can someone explain the benefits of clipping a turbo?
- Tanabe Concept G Blue, any good?
- 2step water pump/head gasket failure
- 2.3l stroker question !!
- help for engine light
- GSC1 or 20g
- SARD blow off valve
- HELP! Car Starts then dies after CAM install
- Help! Car Wont Drive After Cam Install
- car wont start if oil is too low???
- Vacuum Reading...
- arp main stud torque specs
- DTC PO171 System to Lean...HELP.!
- GT35 or GT37
- stock internals
- new turbo help
- IS that a good deal??
- head noise need help
- Magnaflow 43000 series HFC OBD2 EPA CARB Compliant?!
- Anybody using GT3571?? how much WHP???
- Ticking On Deceleration!!!
- What do my Spark Plugs say (Pics)
- white smoke /low oil
- EWG for stock turbo?
- Shift Calculator
- building head
- Waste Gate Actuator
- Compressor Surging Explained!!! (tons of text)
- Can a stock evo 9 turbo REALLY handle 30psi?
- packages?
- My IX won't start!
- Piston to Wall Clearance for forged pistons?
- Vacuum Line Access for BOV
- Cylinder pics....
- starts but...........
- Spiking
- can't boost over 14psi, WHAT?
- Engine shudders at 18-19 psi and looses power
- Where to get o2 housing flange?
- Breaking in built motor hurts BB turbo?
- aftermarket wga w/meth?
- JDM MR Blow Off Valve
- Question on a Greddy Turbo Timer:
- FQ-320 = MR + HKS Super DraggerII, HKS intercooler pipe kit, Change in wastegate
- lancer evo 8 5 speed block/evo8 6 speed block
