View Full Version : Interior/Exterior/Electrical
Pages : [1] 2 3
  1. Nothing Turns on When i turn they key
  2. Splicing headlight harness
  3. painted ac lines
  4. Help with car alram please!!!!
  5. Front Fender/Hood/Headlight Adjustment
  6. I need a sunroof motor. Anyone know where I can get one?
  7. LED lights
  8. Wiring up DRL
  9. Roof Spoiler ;D
  10. Need Help ASAP
  11. AfterMarket Rear crash bar 4 Jdm rear bumper
  12. Bleached seats?
  13. Evo 7 bumper
  14. IX front badge
  15. Short in pass. tail/parking light
  16. anyone have problems with STRI DSD-SLM electrical gauge?
  17. ACD switch bulb?
  18. Anybody running seibon fenders with 18x9.0 wheels if so let me know in the thread wit
  19. What widebody fenders are available,that are around 20mm+ that fit with stock evo 9 b
  20. breake lights out
  21. EVO 8 & 4g64 eclipse galant ECU pinout
  22. gauge cluster issue and sun roof issue
  23. How do you fill holes in plastic
  24. Autometer guage cluster
  25. HID headlights adjustment issue - moving up and down
  26. 2g 4g63 crank sensor signal same as evo CPS???
  27. Any body here using the 35 mm ait front fenders on their evo, does it fit like stock?
  28. license plate light fuse???
  29. head linner removal?? help
  30. HID Lights
  31. Weird Electrical Issue
  32. Color match for interior a pilliars?
  33. Battery Problem
  34. dash bulbs
  35. Fender Rolling Tempe/Phoenix Area
  36. Evo 9 AC Relocation
  37. VIII suede clean
  38. Any Good shop in NYC...Need 6pt. Cage done in ma Evo 9
  39. A Little RS Help
  40. HELP! Edge Insight or gauges?
  41. Electrical/Charging/Short issue tell me what you think
  42. Ebay jdm rear
  43. tachometer help
  44. Help with tail lights
  45. lens paint removale
  46. Brake light doesn't come on, dash?
  47. Paintless Dent Repair above windows?
  48. Wheel help: I think its goes here
  49. Hks evc5 ebc
  50. Anybody eliminated the EVAP system?
  51. Those that have carbon fiber lips....
  52. Jdm Evo batteries
  53. Help me please
  54. evo 8 spoiler
  55. need help
  56. Keyless entry not working on a 03 evo, Please help!!!
  57. Driver side door lock help!!
  58. what do i need
  59. Please Help!!! Electrical issue?
  60. EVO III wiring diagram wanted.
  61. wanted: evo 6 (tme) LHD electrical wiring/circuit diagrams
  62. SRS light and horn issue
  63. Window switch question
  64. turbo timer is turning on and off
  65. do they?
  66. automatic windows for RS??
  67. Can someone help me weld a crack in my front fender that i got from rolling them aggr
  68. weird interior light problems.
  69. Fast Blinker!!
  70. Really depressed, need electrical help for LED mod!
  71. HID's I need'em
  72. clock, radio, remote, odometer
  73. Mounting new seats
  74. Lower seat rails?
  75. So I ripped the rear o2 housing house... what wires go to what wires?
  76. STRI Gauge Problems, Any Advice?
  77. water issue getting into the intake filter
  78. why is my car running lean
  79. Wiring experts, chime in here...
  80. Front Bumper Clips???
  81. Defi Warning Siren Issue
  82. AEM uego reading lean???
  83. !!!!Help!!!! AC Condenser fan
  84. evo 8/9 spoiler fit on evo 7?
  85. Factory temp gauge problem
  86. what would cause...
  87. Evo x recaro on ix help
  88. Jdm rear bumper question
  89. Sunroof wont move?? Not the bolts, already checked!
  90. HVAC Decal Part Numbers?
  91. Twin Walbro install(Question)
  92. im thinkin electrical problems maybe?
  93. IC switch, dimmer switch, headlight leveler bulbs?
  94. help speed gauge dont work
  95. Drivers side door only locks manually?
  96. Evo 9 front bumper
  97. Will Sparco Evo 3 seats fit an Evo?
  98. APR EVO IX Fiberglass Front Bumper w/ Lip fitment with AMS Race FMIC
  99. Where is the rear wiper RELAY?
  100. Defi brightness?
  101. Are my taillights stock??
  102. front plate bracket hardware
  103. defi egt problem
  104. Bad electrical problem! Help!
  105. help with radiator support.
  106. headlight
  107. Bad battery or alternator?
  108. Having a problem with the headlight's!!!!
  109. Where is door relay in my Evo?
  110. Help with door Locks and Dome Light..
  111. DIY gauge cluster mod
  112. rig turbo timer up to also shut off headlights
  113. probably get flamed
  114. bulbs that illuminate the gauge cluster
  115. Switch bulbs
  116. 35w vs 55w
  117. What do you think fellow evo techs
  118. Top dash removal
  119. hid balist
  120. HELP! PLZ Zeitronix
  121. Frozen UEGO
  122. Evo VIII/IX Interior Swap into 5G Mirage
  123. blinkers and hazzards not working suddenly??
  124. Oil Light Flickering and E-Brake Light Problems
  125. evo 8 hks 280 exhaust cam
  126. Hks evc 6 ebc
  127. Drag Coefficient and Total Frontal Area
  128. remote entry fobs dont work
  129. Nisei Stock Battery Tray Help
  130. I put my double din down low.
  131. Evo 9 IX ECU Pinouts
  132. Electrical SHORT???
  133. 02 wiring testing from ECU to ....
  134. Has anyone ever swaped out the climate control?
  135. blue foglight bulbs?
  136. DEFI GAUGES - 60mm
  137. HID level adjuster problem
  138. Defi Boost Gauge problem
  139. EVO 8 turn signals wont work
  140. Are EVO RECARO seats true RECARO?
  141. dash illumination color change
  142. cam angle sensor's rpm signal wire?
  143. front plate...
  144. Removal of top part of dash
  145. How to Splice into Wires on the ECU Harness??
  146. need electrical help BAD!
  147. Hvac help
  148. reupholstered evo viii seats
  149. oem body parts?
  150. Where ca i get a orbital 2 din kit?
  151. Ebay OEM CF Trunk
  152. right turn signals stay on?
  153. 2006 Evolution Mr. Igntion/ wipers problem?
  154. Wound back Rotor or recon alternator?
  155. no fuse in the radio fuse spot
  156. Ciggarette/ashtray lights not working
  157. Fuel pump wiring upgrade
  158. My engine control fuse keeps blowing any help out there...
  159. Need Help with Tach Install
  160. EVO 9 front Wiper Issue
  161. evo kevlar hood/bonnet
  162. double din kit ??
  163. afr gauge
  164. JDM evo hvac
  165. EVO 4 Spoiler
  166. Evo X steering wheel into an 8/9
  167. 03 evo heat not working well
  168. Defi control unit problem
  169. Can you post your Evo 8 Body kit ???
  170. Alternator/Battery Issue
  171. Blow Off Valve
  172. SRS + electrical problems
  173. parking lamp bulb
  174. LED/BOSCH Sensor Questions
  175. Sunroof Problem
  176. Sunroof Problem
  177. Need help with a SRS fault code...
  178. MR Gauge Relocation
  179. HID problem
  180. Visors!
  181. HID question
  182. jdm headlights question
  183. Seat removal peice?
  184. Screwing in a A-pillar pod
  185. Help adjusting headlights
  186. Headlight dashlight out
  187. Spoiler!
  188. Fuse Box Diagram
  189. Splash Hub Reg/Short Dimensions
  190. Is this possible?
  191. Caught front lip on a curb...............
  192. defi control box help
  193. Pics wanted....redone cloth armrests in door panels
  194. Need help!!! Evo having weird symptoms!!!!
  195. Where can I get the Blue material used in the EVO 8 Recaro Seats?
  196. Evo V (CP9A) upgraded speedometer upgrade..?
  197. Starter Issues
  198. NO HEAT! Help cold in PA
  199. Immobilizer Question
  200. evo 9 bumper fit on evo 8
  201. Megan Short Shifter
  202. HID bulb Clip?
  203. Hazard Bulb
  204. Major problem
  205. Which Filter is good for 06 Evo MR
  206. what is the best EBC???
  207. Major Problems!!!
  208. Hid Installation
  209. Red Boost, EGT Gauges..
  210. stripping down the harness..... buschar/ams/trackstar/stm help!
  211. Tail light issue
  212. Ipod adapter??
  213. Dimmer switch is not working any ideas why?
  214. Gauges Pod Question1
  215. Blitz T.Timer Major problem
  216. need parts for 05 Evo
  217. Rear wiper works when it wants to
  218. wierd problem please help!
  219. wiring diagram for evo9MR
  220. evo 2, kill switch
  221. parts for a 2002 evolution
  222. Looking for IX gas gauge wiring...
  223. wideband in ashtray installed
  224. EVO8 --> 2G ECU Swap nearly done...Need HELP!
  225. Keyless CF Trunk?
  226. Looking for UK Evo8 Rear Fog
  227. I think I have gremlins sneaky ones
  228. Does anybody no how I would about adjusting tsx retrofitted lights?
  229. Help finding Reverse Gear Wiring
  230. Charging issue
  231. Wiring up jdm evo 7 headlights to an evo 8
  232. Which regular Lancer trunk lid will fit my Evo?
  233. pillar pod
  234. Drivers seat???
  235. Scratch on the dash near the instrument cluster. Suggestions!
  236. gutted interior today!
  237. Cheapest vendor for RallyArmor mud flaps for Evo VIII?
  238. What Bride seats to choose?
  239. Stock Sound System Question
  240. Help!!!
  241. MR Voltage meter fluctuation
  242. Oem Paint Question
  243. Looking for a stock spoiler!
  244. Mitsu Connector Bodies and Pins/Sockets?
  245. APR EVO ix Widebody.. i need help..
  246. miles to kilometers
  247. Gauge cluster question
  248. Which Wire for TPS Signal?
  249. Mini Battery kits?
  250. ELectrical Draw---need help
