View Full Version : Interior/Exterior/Electrical
Pages : 1 2 [3]
  1. lower cubby
  2. CF exhaust shield
  3. Intercooler Spray
  4. gauges
  5. Foglight bulbs
  6. HELP.. wing on CF trunk..
  7. To patch drilled hole on chasis front panel....
  8. Request Pic of Ralliart Matt Silver 6 Speed Gear Knob
  9. If I have MR guage panel do I even need to buy relocation kit??
  10. EVO Bumper Cover
  11. Radiator Fan Issues on an IX
  12. Voltex Diffuser question.
  13. best seats for evo8 aftermarket
  14. OEM Gauge Replacement
  15. Stock evo9 / MR Recaro vs Bride Xax2 / Ergo2 / Brix2
  16. Galant HVAC controls in EVO
  17. Coil on ignition problem
  18. Please HELP! JDM EVO headlights FOG wiring HARNESS
  19. How do you..
  20. electrical problem
  21. AEM c2di
  22. IX SE Fogs on a IX GSR Conversion Q.
  23. Ignition Switch Wire on ECU
  24. I think I have a short
  25. fender
  26. Lighting for Autometer Sport Comp II gauges
  27. Best Deals On Interior Products?
  28. Question for you relay gurus..
  29. A-Pillar Gauge Pod
  30. Greddy TT Install? Help!!!!
  31. are evo 8 and 9 coil packs the same
  32. Paint is chipping away from my Brembos
  33. Where Are The Threads For Easy Way To Change Projector Bulbs
  34. hid ballast compatability
  35. Headlights / Foglights upgrade
  36. tires
  37. alternative window cranks for rs's
  38. Are the sensors from OEM gauages compatible with DEFI or other guages?
  39. AEM Uego and Truboost brightness issue and some EGT that fits the look
  40. New 3th brake-light
  41. Evo Steering Wheel Conversion
  42. questions about ETACS operation
  43. EvoIX headlights --> Halogen & Foglights combo......
  44. Need help wiring Aeromotive 16302 Pump controller
  45. need Meter Display Unit for evo 8 south fl.(will pay it find it or if u have)
  46. how do you bring down voltage on pioneer z1 installation
  47. Hella FF50 foglights on a IX
  48. Front Bumper Latches for Quick Release
  49. pioneer z1, psssssssssssss noise
  50. High pitched tone after DEFI gauges and Greddy EBC install
  51. IX RS into an VIII MR
  52. Better airflow through IC and radiator
  53. WTF.. is my car posessed?
  54. Volk ce28n Time Attack
  55. Key Ignition issue...
  56. Will Evo9 Climate Controller work in EVO8?
  57. guage Questions
  58. Pioneer AVIC-Z1 + Orbital Double Din
  59. Installing Pioneer Avic 9DVD
  60. HKS\Rexspeed Side Spats Functionality?
  61. All three brake lights failed. Any help?
  62. Voltage Regulator
  63. What is going on here?!
  64. Issues starting my car!
  65. Schematic and Simple Test Request
  66. air flow problem for climate control system
  67. MFI relay and other problems.
  68. windshield wiper attack!!
  69. APR Spoiler fitament?
  70. Aerodynamics - undertray and rear diffuser
  71. Drag on Evo's and various cars
  72. Sport Gauge Oil Temp Probe Signal
  73. Dashboard lights, passenger taillight not working.. HELP!
  74. I tried to be pimp like EVO Dave
  75. Power windows and door locks into an RS
  76. oil pressure gauge
  77. Please help, ELECTRICAL ISSUES...
  78. headlight help
  79. Yellow Fog Lights
  80. Electrical HELP!
  81. maf miss reading?
  82. Name this wire!!!!
  83. problem with interior lighting behind gauges
  84. AEM Wideband
  85. Aftermarket HIDs in a non-HID Evo, please help settle the debate
  86. Front bumper differences
  87. Air/Fuel Ratio on a 9?
  88. Upper Gauge panel options ?
  89. Gauge Cluster Full Sweep Effect?
  90. Carbon fiber interior
  91. Custom Boost Guage...in progress
  92. Defi Question
  93. How to get the gauge cluster out?
  94. Stock Radio question
  95. clock
  96. interior guages ugly orange
  97. roll cages
  98. bellypan questions...
  99. Carbon Fiber wing
  100. Wiring diagram for sport gauges
  101. Air fuel gauge probs help
  102. Gauge Options
  103. Lancer Evolution Seat covers?
  104. guage cluster Q
  105. Fuse setup problem; please help
  106. Red W21W Bulbs?
  107. FQ400 Vortex Generator
  108. AVC R Where i can Put it?????
  109. Evo IX felt insert in stock doorpanel
  110. Clips for hood shroud and trunk?
  111. Stereo Noise
  112. Seat Rail offset?
  113. anybody seen any hot body kits for the evo ix
  114. Problems with windows
  115. Electrical issue with Defi control unit after navi install
  116. Adding factory fogs to Evo IX GSR
  117. Roll Cage with full interior??
  118. OBDII Drive cycle
  119. Radio install 06?
  120. fog lamps in bezel
  121. Trim panel for rear seat removal?
  122. Tach Wire
  123. Interior paint
  124. Upgrading Bulbs in HIDs
  125. Small battery questions
  126. APR widebody kit fit evo IX
  127. h11 connectors
  128. EVO IX Gauge Cluster.(bolsen mod)
  129. Big Big Big Problem
  130. no spark or tach signal
  131. electrical system doesn't wanna work...
  132. anyone knows where i can get some EVO5 parts??
  133. Pics of 60mm Lower gauge pod
  134. Stock temp gauge is tweaking out
  135. Need Help With ECU Fuse....Blowing
  136. Headlights auto off switch - Turbo timer install
  137. JDM MR HeADLight install question.
  138. Electrical issue after Defi install
  139. intake mani pres.
  140. Issues Temp gauge
  141. Saga Gauge Install help...
  142. Roll Cage
  143. Need help: hid vs. nonhid IX headlights
  144. boost gauge
  145. gauge cluster wiring. where to find it.
  146. Post exact weights of weight reduction you have done!
  147. Building Ignition using DSM Ignitors/Transistors, Need pin diagrams
  148. Autopower bolt in cage doesnt fit with sunroof?
  149. Advanced Forum GuideLines - PLEASE READ
  150. Interior Fuses 12v-constant source
