View Full Version : Interior/Exterior/Electrical
Pages : 1 [2] 3
  1. APR EVO ix Widebody.. i need help..
  2. miles to kilometers
  3. Gauge cluster question
  4. Which Wire for TPS Signal?
  5. Mini Battery kits?
  6. ELectrical Draw---need help
  7. How to hook up defi fuel preesure gauge
  8. Evo VIII ECU in 2G GSX
  9. Service Engine soon??
  10. Alternator lead very hot?
  11. elctrical problems with the a/c
  12. need help deciding: to debadge or not to debadge?
  13. MR HID headlights swapped into RS
  14. stock evo ix mr, se, gsr, rs, etc.. seat bracket, rail, weight
  15. I Need A Roll Bar That Still Has Useable Backseat Area
  16. Electrical Problem
  17. My turn signals wont work on my evo and the daytime running lights are disconnected b
  18. Before I take it to the stealership...
  19. Front Bumper
  20. pass front window messed up???
  21. downforce/windtonnel wing tests
  22. Seat bolt info, thread etc..
  23. swap sti hids into evo?
  24. Where to buy : Rear Wing Double stick tape?
  25. Autopower Roll bar with sunroof
  26. New Bigger Seats
  27. making headlight air duct. working with foam and fiberglass.
  28. lug nuts
  29. Airbag light
  30. I need help with a four way switch
  31. Dog chewed my arm rest
  32. Misfiring
  33. No communication with tool on OBD2.
  34. flat bottom undertray
  35. ignition switched power wire at ecu harnes
  36. Need help with large build (Please)
  37. rexpeed triple gauge dash pod installation question....??
  38. AC works sometimes
  39. CF Trunk fitment?
  40. Blew a Fuse?
  41. help slim fan fitting and wiring
  42. Progressive Door Locks
  43. RMR seat bracket
  44. APEXI TT wires help
  45. Best place to get USDM IX or JDM MR tail lights?
  46. battery relocator kit...
  47. Nothing Works...Car wont Start...Help!
  48. car wont start, no dash lights
  49. Evo 9 Steering Wheel Color Question.
  50. Egay S7 AC gauge faces, anyone tried em? LQQK
  51. Tail Lights are not working!!
  52. I need a "Wingless" trunk lid in Tarmac Black
  53. Installing SE lip and JDM Rear Bumper
  54. Strange Lighting Problems
  55. HIDs not level adjusting
  56. radio relocator
  57. Is it possible to install the foglight pieces from hid healights into non hid headlig
  58. I'm looking for more supportive seats then what are in the 9 and still as comfortable
  59. HVAC controller stopped working
  60. Rear crash beam mod for JDM IX rear bumper
  61. Need help picking guages
  62. P/N for front lip
  63. Color or color code fo 05 MR GG rear wing?!
  64. Power source and ground for WB
  65. Electrical problem...please help!
  66. Engine Oil Light
  67. CD stuck
  68. Boost gauge failure
  69. Power Loss
  70. Bought some paint and it doesn't quite match...
  71. bumper grill
  72. where to buy harness connectors
  73. need help
  74. Did some LED footwell lighting yesterday.. (Pics inside)
  75. need new oem sideskirts
  76. Need help picking LEDs for inside my autometer gauges.
  77. Direct gauge replacement for MRs?
  78. OEM MR Oil Pressure Gauge
  79. How can I have high and low hids and yellow hid foglights?
  80. What is the easiest way to get hids and yellow hid foglights to work with non hid evo
  81. Does anybody know who can do the best job at modifying my rear crash bar to work with
  82. I ordered a evo 9 se lip and a evo9 jdm rear bumber. What rivet device would I need?
  83. What is the best stuff to strip factory evo wheels of black spray paint?
  84. Electrical Hell..
  85. Some picks of my EVO IX
  86. Evo IX MR Shift Console Cover
  87. Those 2 little plastic inserts on the Evo IX front bumper, i lost 1
  88. Fuel Level Sender Tech Question
  89. Information regarding type of material used...
  90. Ground for new radio?
  91. idle issues after dash replacement?
  92. tried "Elect. Grem. from Rain" sticky...didn't solve issues...
  93. Are GlowShift guages any good?
  94. WTB-2003 evo 8 used headlights housing
  95. Lights flicker going over bumps, ideas?
  96. Switch bulb replacements??
  97. Converting HID car to non HID
  98. Interior Dash
  99. Small Battery
  100. Help - Double din ac converion
  101. carbon wing
  102. Shift Knob Size
  103. Shift Knob Size
  104. DC to DC converter Help
  105. Small Project - One Big Issue
  106. CF vortex generator
  107. HID Conversion Non SSS IX
  108. new exhaust,problem.
  109. coolant fan fuse keeps popping
  110. Apexi Pen TT Eratic Problem
  111. turning on headlights= dash lights go off
  112. My LED conversion so far (exterior)
  113. Help with HID's
  114. Intercooler Spray Light
  115. center console
  116. Looking for info on AEM's NEW "Pencil Coils"
  117. boost gauge question
  118. Sparco Seats
  119. wrap dash
  120. Razo Shift Knob Question
  121. Installing JDM EVO VIII Headlights(NON-HID)
  122. Mechanical boost gauge question...
  123. What type of socket harness is used for the rear sidemarkers?
  124. Enkei Wheel Nt03 M
  125. Evo jdm interior rhd conversion
  126. need help please.!!! (electrical lighting)
  127. in dash lcd monitor
  128. Volt gauge light & left side climate light out, also indecipherable fuse pic question
  129. Swapping Rear 8 Bumper To A Jdm 9
  130. Evo VIII Seats in WRX?
  131. Electrical gremlins from rain
  132. Aftermarket seat heaters
  133. Voltex Rear over fender pic request.
  134. My electrical system sucks! Please help!
  135. wiring gauges to a switch
  136. rali art replica front lip
  137. Need Help Please!!!!!
  138. Body damage under rear bumper - Help please
  139. Ralliart Meter Display Unit
  140. OEM foglight switch with non oem hid car
  141. OEM HID Problem
  142. Why to use leds.
  143. over 30psi....
  144. Evo IX Bumper material
  145. Obd2 Port!?
  146. Power mirror noise through speakers
  147. US Evo Indicator Lights
  148. ebay gauges
  149. injector circuit rewiring...
  150. A/C button not working?
  151. Any regulated 5VDC on the EVO?
  152. Fuel Pressure Sending Unit for logging purposes!
  153. electrical short????
  154. install a volt gauge
  155. MR 6th Gear Blockout
  156. IX Oil Temp Gauge Dead
  157. Body Part Numbers
  158. Going To Harnesses but keep oem warnings
  159. Seibon lid-shaving weight-3,031lbs
  160. Xetronic HID, Parking Light Problems
  161. ?? rear window wipers dont work...
  162. Help!: Turn Signals do not work
  163. interiror and body parts
  164. Immoboilizer Problem .. I think
  165. Angle factory gauges towards driver. PICS
  166. Voltage to frequency converter
  167. DashBoard Removal
  168. rear center armrest
  169. BRIDE Stradia Low Max is here!!!
  170. oil temp gauge (F vs C)
  171. Shave those pounds ...
  172. Rear Window Defroster
  173. parking lights buzzing
  174. spots on Windshield can't get rid of it.
  175. Optima battery
  176. Odd Electrical Problem, Please Help!
  177. Where to get wing mounting hardware amd adhesive?
  178. Replacein that hood
  179. Orlando, Fl. Steering wheel.
  180. Momo Steering wheel..
  181. carbon fiber hood fitment?
  182. Need help with oil sensors??
  183. egt gauge
  184. Latest Turbo Timer?
  185. Evo 8 HID's swapped into non-HID or RS??
  186. Kansai Service Rear Diffuser
  187. e-brake wiring issue?
  188. are these aftermarket interior parts street legal? (racing seats, harnesses, rollbar)
  189. LC-1 erradict readings
  190. acd wiring diagram
  191. For all the tall/track evo drivers..
  192. Quick disconnect steering wheel adapters worth it?
  193. seat warmer fuse - WTF?
  194. double DIN conversion and spoiler removal
  195. Dome Light help
  196. New Gauges & Stereo Pod
  197. special tool to remove steering wheel?
  198. Autometer 12v Boost gauge
  199. Alternate wiring, dash and steering removal - oh my?
  200. Carbon Fiber Front Bumper
  201. pics or info on F1spec seats
  202. Gas guage problem
  203. Evo 8 Front Emblem
  204. Headlight Replacement Questions
  205. Question about Defi Blue racer
  206. Sunroof Stuck???
  207. Daytime Running Light Relay(?)
  208. Takata
  209. Little Help with what lip kit this is...
  210. Budget race seats - Corbeau vs F1Spec vs NRG
  211. looking for a replacement boost guage that reads in PSI
  212. Correct HiD bulbs?
  213. Gauge Problems
  214. Racing seat fitment (harness slot height)?
  215. Evo I - III Roof Spoiler?
  216. Left side running lights not working...
  217. nitrous window switch tach signal
  218. MR single DIN gauges
  219. UK (?) evo seats
  220. greedy boost gauge help
  221. My VIS trunk is wayyy off, anyone elses?
  222. Question about JDM rear, Please Help
  223. Brightest HID bulb for stock set up
  224. What to do without wing?
  225. help sticking defi control unit
  226. Why won't my A/C diods light up nemore?
  227. upgrading ext, int, and elec
  228. Do any other aftermarket Recaros bolt up to our OEM seat?
  229. odyssey batteries
  230. gauges
  231. HELP!! Looking for TACH signal, where is it?
  232. Front Bumper Swap.
  233. Harness bar
  234. No power inside car,but in enginebay
  235. Color choice?
  236. Pulling stock steering wheel closer?
  237. 8-9 battery sizes
  238. best seat belts
  239. HID Conversion For IX?
  240. symbols on evo 3 tachometer
  241. Switched 12V
  242. Speedometer stopped working among other things.. Can anyone help?
  243. STRI Gauges
  244. WTB: Passeger side headlight
  245. Evo IX ECU wrong, 4 O2 sensor
  246. Custom carbon fiber molding/overlay shop
  247. In Dash Nav in lower cubby
  248. For those of you with the JDM Rear Bumper
  249. ralliart Evo VIII sports combination meterset
  250. EVO IX dash inserts
