- maft wiring question
- MAFT Pro/SD Tuners in CHICAGO
- maftpro map sensor
- MAFT install question
- How do I adjust idle? P0507 code
- Where do I connect the "BARO" wire on an Evo IX?
- Help need a tuner in Tampa, FL
- Need Tuner in or Near CA That Can Tune For MAFT
- Newb to maft pro
- speed density vs blow through?
- maft or maft gen 2
- Problems using the MAF Translator on MAFTPRO
- MAF-T -VS- MAFTPRO.. i need help
- No MAF = No knock?
- Hear Ye, Hear Ye, new MAFT Pro update is out there.
- MAF-T nubee
- Maft gen 2 Question
- Can MAFT Pro control Meth
- Initial settings for 4.89
- MaftPro with Reflash????
- Any tuners in the NW who can tune this bad boy?
- MaftPro=GOD piggyback!!
- Idle fluctuations
- change setting to use 3.5 bar map?
- using AEM map for speed density setup
- Passing MARTA
- MAFT Pro installed, problems
- questions
- So . . . what's happening in this forum
- MAFTPro for your ECU map switching needs.
- Simplest way to eliminate off-throttle surge?
- Fuel MPG
- Can a MAFPro be used to trim fueling using an output from a meth inj flow sensor?
- Hardcore Idle Surge after installation of MAFT Pro (2G DSM)
- Timing Control anyone?
- mappro and meth for a 35r?
- How do you guys like MAFT PRO?
- What can and cant you use maft pro for?
- New V4.5 thread
- .xdf file for evo
- V4.5
- T&TP and others: Please help with MAF Translator
- general maftpro operation question
- Boost control
- Tunerpro RT irritating me today
- Scott from TTP willing to do a Weekend Travel?!
- New logging idea
- How to adjust fuel trims
- Misc questions
- MAFTPro in MD,DC or VA area?
- Throttle response help needed
- Tuned by Jester
- Can I use the MAFT to simply measure airflow?
- New UICP
- Want MAFTPro? Here is what you need!
- TunerPro RT software questions
- Airflow source question
- Car doesnt run after install... Help please
- Why cant i get to the setup parameters?
- How much TPS/MAP enrichment are you running
- Air Temp Sensor
- Aux Outputs
- hi/mid/low and ve questions
- Hey TTP
- Cold start
- We would like to see your bins
- Tunerpro RT want list...
- Screenshots?
- MAFTP with reflash
- Deleted my ADS file
- Finally a nice day outside.
- EVO MAFT (std version) available soon
- MAFT Pro Info and clarification
- ETA on timing control
- How to hookup AFR input
- MAfTPro Testing..
- Regarding timing control
- AFR Tracking questions
- Tunerpro rt software
- welcome to the maftpro forum
- MAFTpro Subforum
- Want to eliminate your MAF?
