- ECU+ with plug in play patch harness FS
- Silver box ECU+ with extras!
- WTB: ECU+ Silver pnp box
- No misfire, 0 knock, low timing advance???
- Topspeed
- Ecu+ for sale
- Anyone get rid of their Service Engine Soon light?
- Any vendor still have a brand new silver ECU+ in stock?
- running problems
- Key program and ecu tune
- F/S ECU+ plug and play
- Baud rate and ECU+
- hp?
- what palm
- size injectors
- ECU+: almost 3X faster logging than other MUTII loggers
- Engine cut out
- WTB stock ECU VIII!!!
- WTB! stock IX ECU
- ECU+ is the best logger EVER!
- New ECU+ software firmware
- FS: ECU + $395 shipped
- SpooldYou's Part Out
- 2.10 SW, firmware beta release
- Walbro255
- remote map switch
- Wanted: Stock 03 ECU
- F/s Ecu +
- Will tuning pass smog
- going to get my first flash...need some advice
- FS ECU+ plug & play
- Software?
- silver box ecu+ for evo 8 FS
- ECU+ Featured in Modified Magazine!
- ECU+ Now On Sale!
- New user with a few questions
- ecu+ info
- injector setting vrs ecu
- FS: ECU+ "Wire-it-yourself" silver box
- some stupid question about timing
- install ecu+/lc-1/ logworks
- need more help with the mas
- help with maf
- Innovative wideband
- New ECU+ feature: EVO ROM editing and map tracing
- Hesitation at WOT, new WB and GM MAF
- Miami Ft. Lauderdale
- MAP sensor trouble
- Swapping front ECU
- Tactrix-compatible firmware update available
- Ideas on Ecu+ Knock Sensing / control
- MUT-II diagnostic and logging support done
- front oxygen voltage?
- Evo 9 ECU Pinout
- any interest in silverbox Evo 8 ecu+??
- Offline map editing now working
- New GM 3.5" MAF support
- Any 1 for Mines ECU
- ECU+ for logging only?
- EGT probe adapter
- where to buy MAP sensor?
- New ECU+ firmware and software now available
- For Sale: ECU+ + Evo 8 Plug and Play
- Ecu+
- Is this Lean?
- any drawback on ECU+
- will ecu+ ever support the aem 5 bar map sensor?
- knock voltage vs knock count
- fuse problem
- GM translator at ECU+ and flash?
- First log question about gm 3 bar
- Tom Collins Rules
- ECU+ Remote display prototype..
- ECU+ and Reflashing? Of course!!
- ECU+ PnP for JDM EVO9
- Differences between black and silver ECU+ versions?
- GT35R maf readings..
- New all-in-one graph view
- Has anyone used MoTec's Plug and Play
- Any one got Stock 3rd gear pulls?
- New views selector
- Log file trimming
- Coming Back To The ECU+ World.
- Life after UTEC, couple questions
- New features in the last week or so
- OBD-II Switch and Plug N Play harness
- ecu+ + ecuflash and other question
- Would a leaky BOV cause this?
- Cool ECU+ picture
- ECU + Help with dyno Pull
- New P0300 fix beta available
- For those running a GM Maf
- ECU + Question
- Setting ECU+ TO stock
- ECU + Questions
- Dyno calculation
- Cant connect
- ECU+ is in, how accurate is the dyno?
- cutting out problems here help
- Evo IX ECU+ Update
- MAF options..
- My experience, and where is an AFR Graph?
- where do i get the 3in maf sensor harness from?
- Screenshots
- Can i just hook the wideband 02 sensor into the secondary 02 sensor hole?
- ecu+ ?
- Quick ECU+ question...
- pics of my 3" gm mass air setup
- more issues with my gm maf setup
- Now pre-ordering: ECU+ for Evo IX!
- Ecu/camshaft Question
- Hello from UK & first ECU+ logs
- P0300 caught on a log.
- MAP sensor problem
- Fs: Ecu+ Pnp
- Messing with timing...
- need to check my wiring for gm maf
- cant get a computer to connect to my ecu+ hu
- ecu+ wire groups?
- GM 3inch MAF setup with pics
- AFR while building boost
- OBD Scanning??
- 12v source for gm maf
- Review of ECU+ from an XEDE perspective
- Please help!
- Nitrous Control
- ECU+ log with larger turbo upgrade?
- 3.5 gm maf
- Opening tunes up for discussion...
- ECU+ Question
- Need Stand Alone Or EMS???
- 1st datalogg + tune - confused
- I Need Help! A/F off the chart lean!
- Fried ECU+?
- ecu+, 50trim, 750cc inj
- aem uego and ecu+
- Boost Control
- Map Conversion
- ECU+ for RHD JDM Evos
- Boost spike- a major problem?
- In Car PC Set Up For ECU+
- Connector question...
- Dan from MachV rocks!
- trouble codes....
- calibrate your fuel trims?
- Scanmaster 3 and ECU+
- Voice ur opinion: Open source the ECU+ code
- FS: Brand New ECU+
- Launch control/2 step rev limit
- Dan @ Mack V (ECU+)
- Possible to have some of these options?
- ECU+ with aftermarket gauges
- Any XEDE Converts??????? Some questions....
- Is Anyone Here Using Pocketlogger?
- Saving and Loading maps from the Palm
- Will speed density be a future option for ECU+
- Palm pilot help.....
- Knock Setting
- Another batch in stock!
- Look at these 2 logs..
- I can't upgrade firmware with my palm pilot?
- ECU+ and Wideband connections
- Wierd knock back-off issue
- Question for Tom :)
- Questions about GM 3inch MAF.
- Do you realize?
- Timing Adjustments
- problem with injector scaling to 720cc
- What Is This Ecu +????
- Upgrades for my ECU Plus
- Wideband A/F Question
- ECU+ and Zeiotronix?
- ECU+ inaccuracy LM-1 wideband reading...
- Check Engine Light?
- ECU+ For Sale
- EGT Temps
- Ivan
- injector question
- Installed a wideband...14:1 AFR wtf?
- Idea on how to mount the ECU+ Box
- serial to usb connectors
- The ECU+ now does OBD-II!
- Help please:
- ECU+ and Evo IX
- Second time using ECU+. No P0300
- My first tune.
- at what voltage do you consider it a knock event?
- first 2nd gear pull, no tuning, threw another code.
- Threw a code =/
- actual dyno graph vs. ecu+ graph
- wiring for gm mafs
- it just came the mail!
- Tuners with ECU+ experience?
- having some software issues
- ECU+ Availability
- Flash before ECU+?
- ECU+ power Limit?
- Sharing Logs
- Tom need help yet?
- Alky support roll call
- Alky/Meth Option for ECU+
- Knock question for Tom
- Future plans for boost control?
- My dynosheet with ECU PLUS
- Replacing The EVO MAS
- Welcome to the ECU+ forum!
- Head count
- ECU PLUS 1st STEPS
- YES!!!! Thanks ADMINS!
