View Full Version : General Engine Management / Tuning Forum
Pages : [1] 2 3 4 5 6 7 8 9 10
  1. zietronix wideband
  2. apexi neo
  3. problems with possible spark blow out.
  4. modding a car that has been previously tuned
  5. Motec maps
  6. usb to serial adaptor for tactrix cable?
  7. Zeitronix not working since EGT install
  8. evo dosnt feel right
  9. Using higher Octane then mapped
  10. Ok to drive with tactrix cable when not datalogging?
  11. Can I flash with openport 1.3R?
  12. GSC S2's(1st/early version)....upgrade to ????
  13. data logging
  14. Evo not running well (PO300)
  15. evo viii 260 cyprus
  16. Altered Atmosphere?
  17. stock evo IX map
  18. Removing RRE dual map switch????
  19. Base injector scaling
  20. Evo1 STS
  21. Rich AFR's Idle and WOT
  22. Cant read Write ECU with evoscan???
  23. Knocking Please help me understand
  24. Alternator Upgrade
  25. whats pushing the limit for boost on 93
  26. looking for a good shop
  27. wide band readings (compare please)
  28. Partial throttle knock
  29. Evo 9, AEM ecu vs stock ecu + gm 3" MAF
  30. fq 360 reflash
  31. need help
  32. throttle body spacer... ??
  33. What would cause a lean mixture?
  34. 12 Tooth Trigger Disc
  35. can stock ecu be lock by tuner
  36. Evoscan convert PSI to Bar
  37. trying to figure out if my tune is good? please click.
  38. HELP!!! Innovate XD-16 Issue
  39. Clutch question, new clutch needed.
  40. RPM inconsistency in datalog with Evoscan
  41. Good Place To Tune
  42. All knocked up
  43. Tuning 1200cc on stock ECU???
  44. Need help wiring up Zeitronix ZAVT relay (pics)
  45. trying to figure what tune is best
  46. Obdii
  47. Injector duty cycle & eveoscan
  48. base map for a 35r 3582 or better 3586?
  49. Map ecu
  50. New guy.. looking to pick a few brains
  51. Need help on boosting.
  52. smoke coming from under the exhaust manifold?
  53. New Evo 8 Owner
  54. problem logging
  55. change trans oil.
  56. re tune for more boost?
  57. Tactrix
  58. CEL Flashing on Reset
  59. evoscan not working
  60. EvoScan Question
  61. Cant figure this out please HELP!
  62. Ignition coil
  63. Problem with AFR & Fuel trims
  64. why so hard to find a damn belt
  65. My Next Tune
  66. Would you tune on these mods or wait for more?
  67. were's the boost gone on my car
  68. Greddy Profec
  69. stock motor hp
  70. Zeitronix ZT-2 question
  71. Want to ask an opinion. Clutches....
  72. E85 Rundown?
  73. Tuning in New England Area
  74. EDGE insight product info?
  75. Tactrix Cable missing mitsubishi plug - Can I tune or log?
  76. HELP! Apexi PowerFC People!
  77. how to log IAT's on evoscan?
  78. anybody who can tune i need one northeast pa
  79. Stock Waste Gate from an EVO VI
  80. Need help with turbo controller
  81. Drivers for tactrix 1.3 cable????
  82. need a good map fr evo8 stock ecu
  83. Engine management needed?
  84. Engine build for turbo help
  85. engine management
  86. tach help!
  87. what do u think of my datalogs
  88. A/F Info
  89. P0403 EGR Solenoid error on Evo 5...
  90. TUNE REQUIRED FOR O2 housing and exhaust mani
  91. Swapping in a replacement ECU?
  92. AEM EMS need inspection sticker
  93. Evo VI Tommy Makinnen ecu upgrade??
  94. MAF Sensor Max
  95. hesitation (?) at 2k rpm
  96. BISS (base isdle set screw) and bad idle and stall
  97. Tuned, now a slightly lean idle with new mods...
  98. service engine soon
  99. Heater and engine check light on after ecu swap
  100. Testing a crank sensor?
  101. Evo 3 idle problem, please help..
  102. ECU - Flashing ABS & Yaw when OBD has something reading - EVO 9
  103. Help!
  104. Questions on Tuning 05 VIII
  105. Automatic ECU Tuning
  106. Swapping ECU's
  107. Cannot access the ECU for Diagnostics - EVO9
  108. Please Help
  109. How for can you go?
  110. how do I know if I still have my tune?
  111. Buying a GPS
  112. PCMSCAN connection issues w/ tactrix cable
  113. AEM EMS Having hiccup from RPM Signal Noise
  114. knock count
  115. Logworks Vs. Evoscan
  116. MBC vs ECU
  117. Please help. Need EVO8USDM ECU pinout
  118. no O2 reading on evoscan?
  119. Evoscan cable problems
  120. serial to usb cable trouble for Uego/evoscan
  121. Spark Plug Change\Car Bogs Down
  122. Another 4WS tune in the making
  123. What is needed to log the afrs from a aem uego
  124. Headers
  125. Anyone running haltech ps1000/2000 on EVO 6 ?
  126. dual fuel map rom
  127. new e85 setup
  128. confused..
  129. Greddy Profec B Spec2 Settings
  130. Apexi SAFC
  131. New to tuning...
  132. Anyone care to check out my track run?
  133. currently a mazdaspeed owner trading in for an Evo
  134. data log can someone read it for me?
  135. Retune needed for ets licp?
  136. Service engine code, but not connecting to obd reader
  137. 2thousand dollar budget what should i do?
  138. Evo JDM 03 Issues
  139. first upgrade?
  140. Throttle Hang
  141. Anyone go from Aem Ems to Oem Ecu?
  142. Running rich problem
  143. Throttle Position prob
  144. E85 and 91 octane map switching
  145. Evo3 ECU help please!
  146. couple test pipe questions
  147. Need some help from some good mechanic
  148. AVCR.... Sensor Selection
  149. evoscan
  150. f con speed density
  151. going to have my 1st tune at ivey tune on 6/17
  152. 4WS tuned....!! Finally fixed!
  153. Evo's first tune
  154. Speed density = p141 code?
  155. need help with exhaust
  156. Evo 9 - Plug & Play ECU - fast & easy
  157. E85 and twin fuel rails
  158. stock ecu and a 35r turbo?
  159. is this a good boost controller?
  160. Can't log fuel trims
  161. quickest and cheapest way to get to 400whp?
  162. i need some input
  163. How would you know?
  164. Dead Battery..Now Problems..Help!
  165. CEL on, "fuel lean" only few mods .. normal ?
  166. Good tunning shops in Nor Cal / SF Bay Area?
  167. Need Help Wiring TurboXS Tuner Pro
  168. MAP sensor for Zeitronix
  169. Need Help!! tunning issue??
  170. Thrust Bearing!!!
  171. Eboost settings and boost fluctuating. Experienced ppl please help
  172. tactrix 1.3 or 2.0 decision
  173. ECU RPM signal convert to pulse - Help please.
  174. A little more about reverse engineering
  175. Is my battery toast?
  176. i have tuning questions
  177. apexi avcr
  178. Innovate vs AEM...
  179. Tuning 950cc Injectors & GSC S2 Cams, Stock ECU
  180. How far can i push stock ecu?
  181. evo wont goooooooo
  182. Need mitsulogger
  183. How much knock is normal?
  184. New clutch??
  185. New clutch??
  186. TBE+tunning?
  187. Tuning Question sorry i'm new
  188. School me on evoscan...
  189. Tuning Issues
  190. where to get a GOOD all around tune??
  191. Free Dynoflash tune
  192. HKS 264s
  193. What Engine management is best for Evo 1
  194. Bought used evo/found it has a flash...?'s
  195. Dip in AFR Around 3500
  196. Evo 7 ECU tuning
  197. JDM evo 8 MR ecu pin layout
  198. Knock at 3k rpm under cruise?
  199. O2 Volts vs. AFR
  200. ECU Reflash or COBB Tuning Access port?
  201. Popping sound at 4k RPM
  202. zeitronix Dashdaq VS LC-1 with dl32
  203. Overheats when defrosters and hot/cold fan is on
  204. aem hookup to evoscan
  205. What to look for in Evoscan....low idle start up problems
  206. Kelford 272's and cam gears
  207. Question on datalogging values in Evoscan
  208. Innovate wideband problem!
  209. Lean condition in Evo 5 w/ knock (Help diagnose)
  210. How to use DLL
  211. Evoscan 2.5 on Evo 5, need help.
  212. Engine rebuild and knock
  213. ECU+ Anyone ?!?!
  214. aem uego question...
  215. EFI tuning (Evo Tuning) Literature
  216. Hydra ems
  217. Ecu Map graphics
  218. Can I use a Zeitronix 3.5 Bar MAP sensor in place of stock?
  219. mail-in flash
  220. Reading CEL
  221. CEL P0141, P0136 replaced rear O2 and cleared. and than...
  222. Leanin Out After 15-20 min Drive
  223. Programmable ECU????
  224. FMIC and Tuning question.
  225. chokes when shifting at WOT
  226. mail in flashes
  227. Dynoflash mail in tune ftw.
  228. while driving my car shutdown and now will not start!!!
  229. Mounting solutions for netbook for tuning/logging purposes
  230. Zeitronix help
  231. HKS DLI II..should little red light be on?
  232. RPM Surge at 4th during Boosting?
  233. injector duty cycle above 100%
  234. What are the Pros and cons to ECU base boost?
  235. Which ecu version is this?
  236. Hks EVC 6 help
  237. OpenEcu.Org versus Norton Internet Security
  238. New Intake = Tuning right?
  239. Evoscan not saving datalogs (searched like crazy)
  240. Next Best Upgrade before tunning again-
  241. ECU/GM 3-port boost question
  242. Injector Battery Comp (usec) 1200cc
  243. MAFT install question
  244. Has the ECU been effed with?
  245. Wideband vs narrow band
  246. Ems??
  247. Cam gear adjustment??
  248. What is this?
  249. where can i get the aem ems the cheapest!!!
  250. Need help tuning!!!!!!
