- ssl
- dc sports manifold
- Competition cables
- stroker kit
- MR ecu on non MR 8?
- Do i need a heat sheild or a turbo wrap when I install my DP
- MicroTech Information Wanted!
- what little time
- Anyone got one of these?
- Question about aftermarket intake sound
- Drop in filter to Helix intake change?
- Does anyone here use MAP ECU?
- wideband and afc II
- Hotside upgrade
- where can I learn how to tune?
- P0456 code question
- Which EMS should i use?
- Al, Mark your Dynoflash calander May 06! WWII
- CAM GEARS & 264'S
- Apex-i GT Spec exhaust with clearance?
- How often do ECU sample vehicle speed
- EVO Mods Question
- Methanol Injection Help
- Boost controller question?
- AEM UEGO Wideband vs others...
- Use a 05 ecu in a 03
- SAFC-II and stock ECU for timing...
- Clear the confusion??
- Emanage Ultimate
- Found plug gap setting which works with Meth. inj.
- How do you know if dealer reflashed u?
- Boost Problem Question
- Smokedmustang Video of Launch Control, sidepipe!
- Tuning in Philly
- Tuning shops in the Houston, Texas area
- OBD-II Simulator for Standalone users..
- help please!
- Apex SAFC > Emanage?
- Hks Evc
- CReader OBDII and HKS 280 Cams
- EcuTek Forum??
- dynoflash retune?
- SACFII and halman a reliable tuning combo?
- Best ems for my goal
- oil change...
- going stand alone
- Removing Fuel Cut from Factory ECU.....?
- Slight stumble/hesitation at idle and low rpms in neutral....?
- ask for help -----Defi-Link Control Unit II
- best form of tuning
- tuning evo 9 with mivec
- Evo IX ECU Question
- ecu flash or standalone ecu
- Run 11s with these mods?
- E Manage Tuning With Evo9
- Fuel Trim???
- Mail in Reflash Help?
- Engine managment....hmmmm
- High Exhaust Temperatures
- best ecu program for warranted car
- Tuning read...
- Topspeed In Alpharetta!!!!! Great
- Precision Dyno Sheets Comparison
- Arizona tickets booked for Precision Dyno!
- Anyone ever mess with Nitromethane injection?
- Propane Injection?
- safe egt's on stock block
- "Hiccup" in my dynoflash tune...trying to fix, help
- What exhaust should I go with
- Walbro Fuel Pump, reflash?
- stealth 12 second car?
- Cruising A/F ratio?
- Zeitronix or UEGO
- Flaming Exhaust?
- safc-II vs. Flash
- No reflash needed?
- Air intake tune question
- Turbo Timer/Security system concerns
- Jestr Flash
- Custom tune question
- Cheapest Place To Get Fuel Cut Flash
- Need help with wiring!
- Question on returning car to stock tune ....
- Next Buschur Tune Day?
- which intake should i choose
- base timing MAP
- EcuTek after dealer 0300 reflash
- Precision Dyno road trip
- ECUtek vs. Tekcom (tekrom) sp?
- MBC Help
- Reflash in So Cal?
- ecu i can tune myself.......
- removable ecu upgrade
- Forge BOV from vividracing
- S AFC II for sale w/ Plug and Play harness
- Engine Management Survey
- To ECUTEK or not to ECU TEK
- jestr tuning
- Datalog ?s'
- Best Aftermarket ECU For my Evo 5
- hks bov ver2 no tool????
- NEW Question about Wide Band 02 bung placement
- ems vs ems vs ems etc.......
- Ecu +
- HELP!! need advise
- Not running right after k&n intake
- Greddy type-rs blowoff valve
- evo injectors
- P0202 code.... causes...??
- Trick electronic mounting?
- Just starting to tune my car & have some questions.
- My Alky problem NOW SOLVED!!!!!!!!!
- Service Engine Soon light...
- Running rich?
- maintanence help
- new FP, now CEL
- Just Installed Injen Intake and Forge RS BOV NEED HELP
- DIY (Homemade) LM-1 RPM Converter
- tuning question???
- make more hp?
- AFR ratios?
- MAF sensor problem.......I think.
- Car got hiccups
- knob settings for Alkycontrol-street tune
- best ecu flash?
- Stock ECU RPM Signal, voltage or pulse?
- fuel pump 255 help
- Am i Running too lean
- stand alone tuning
- When should i tune?
- Haltech Plug and Play system for EVO Lancers
- boosting around 24psi????
- ground wires
- xd-3 questions
- Looking for a good tuner
- dynoflash + boost controller
- Is it safe?
- Zeitronix accuracy
- farmers dyno sheet.. blah..
- Does anyone sell Blowthru Meters anymore???
- PO300 code problem
- p0412 code keeps poping up. what is it?
- TT or Dynoflash?
- Question bout s-afc II with wideband
- trying to figure out @ what rpm should you be @ around 11.5?
- Mustang Dyno Graph Thread
- engine surging?
- My 1st Datalogs
- Coil On Plug DIS-2 question
- evos downtuned from factory
- 4 wheel Dyno in Wisconsin?
- dynoflash- mail in versus custom
- Autronic PnP shopping
- For those with a fuel pressure guage
- Dyno day with Marco Passante of Magnus Motorsports.
- Water/Alky/Meth tuning
- home-made "racing chip"
- Reflashing in my area???
- Question for you EVO guys,...
- Which Engine Management 2 go with?
- Peak/Hold Voltage for FIC injectors
- Stock ECU Modding
- People with FIC injectors, please help......
- Building a DYI knock listener
- Rev Limiter
- Ecu Flash or TurboXs Utec
- myth?
- Downpipe? ... next step in mod? help...
- ECU Pinout information
- Motec M800
- BOV Questions
- Cams = more rich than before?
- anyone running xede stage 1 w/o cam gears
- What is the best way to read knock?
- Want car to go faster! HELP
- ECU Reset
- Vpro who tunes near cinci?
- AVC-R thread QA
- Tuning R&D for those interested . . . .
- datalogger
- EcuTek & Vishnu need advice
- any budy running the ECU+
- Dynojet Question
- Confusion HP Score on Dyno
- Stock ECU question
- stock exhaust dia
- Flash Preparation Thread
- Final Tune Results!
- DSMLINK need help!!
- HKS Vpro or AEM? So confused!
- Autronics autotune Vs. vishnu smart
- AEM EMS-Precision Dyno
- Need Advice On Tuning My New Cams And Gears.
- which turbo timer?
- dynoflash vs turbotrix reflash
- Need Help Deciding Where to Tune???
- What ECU w/ turbo upgrade???
- Running on 90 RON!! Need Help!!
- rev/boost/fuel limiter removal then S-afc tuning
- boost loss
- Profec B-spec II question
- Turboback install??
- What System???
- Dyno
- Pinout / Wiring Diagram For EURO Spec EVO 8 ECU
- Unichip
- Looking for Quality Tuner in NJ
- verticle FMIC?
- evo 7 output question
- Standalone Engine management and Emission/inspection
- wideband and a/f ratio
- HKS KANSAI OR TOMEI ECU for GTA
- tunning place in CA
- PLEASE HELP me with my profec B spec II
- what to do for engine management??
- Tuning places in AZ?????
- Owens Developments cast manifold
- Looking For The Best Cold Air Intake... Anything Good Out There...
- Dyno Plot smoothing for the mathmatically inclined.
- tap for wideband O2?
- Element Tuning/ Hydra EMS
- Evo9 Head on evo 8
- question about cams Again
- EcuTek.. new information?
- Anyone try this yet?
- air/fuel mixture 101...needed
- efi 101 class
- tuning with lm1 and s-afc2?
- Simple question about clutches
- It has been proven (better performance)
- greddy type s bov adjustment
- anyone know how to tune greddy profec b boost controller?
- Some thoughts on the newer ECUs and Vishnu active tuning
- what to do about Cold Start???
- what do you guys think about these features for a standalone?
- SAFC with flash ecu
- Pocket Logger ODBII - Which vendor has these?
- mail-in flash: dynoflash or turbotrix
- Tuner in GA
- Dealership approved mod sticker
- Ralliart ECU
- cold idle/idle problems. please help
- need ECU
- Modding in New Evo 8
- p0300 dealer flash is messing things up
- Dyno tuned w/ bov hose loose
- typical A/Fs for lean versus rich conditions??
- Tuning sites
- Changing plugs more often than my underwear!!!
- WORKS reflash question
