- custom tunes in alaska?
- BOV which one is good
- DynoFlash VS. UTEC
- Quick question about Flash
- Japanese EVO VII needs ECU..
- boost controller
- Whats going on, you mean I can tune it myself?
- MR578511, what ecu?
- Fuel Pump b4 Tuning?
- aftermarket ignitions
- This looks like a great option for standalone ECU
- Which one Maftpro,Utec, or ecu+?
- Air filter question
- Just got tuned on LI
- Does anyone have or tried the turbo xs dtec?
- Syms TrecsII missfiring system
- Big turbo + untuned engine, ok for track event?
- 300m COP coil part number?
- ECUflash
- bov help..
- Keep the Xede or sell it?
- Exhasut Rattle
- Datalogging
- OpenPort Tuning Forum..
- openport 1.3M
- Evo tuning revolution
- Injectors for GT35r
- More power to the rear wheels
- Tuners: Where and when do you tend to your sheep?
- Mod for mod: STI and Evo Comparison
- downpipe and full pump
- High load overboost after ECUTEK tune
- Is it safe if I cut the speed wiring???
- Lm1---vs--- Xd16
- AFR- Diffinitive answer under various loads
- ? for Most Knowledgeable Tuners!
- Weird problem with AEM Uego & Greddy Turbo Timer...
- David Buschur in Phoenix for tuning 5-6-06
- Quick Question about a test pipe
- What do I need to pick up boost?
- new parts=slower..........why?
- Open ECU
- Innovative Tuning-Log Works Can it be our best friend?
- CEL again after o2 fix? is it something else?
- changing octane
- evo tuning
- AEM vs. Autronics
- gt35r same as gt3571???
- Need HELP!!!!
- spark plug question!!!!
- After an ECUTEK Flash what is next?
- UTEC vs. ECUTEK
- Dyno Sessions (experiences, tips, Pics)
- 350 wheel hp
- Which engine management should i use for 400whp
- Got an ECUTEK flash tune today
- Hydra EMS
- Can I mix 91 octane with 100?
- how much more boost?
- Can i use 91 octane in a car flashed for 93?
- ams dyno days
- 2003 Evo - Voltage Clamp
- dsm link
- Blonde, whats wrong with you?
- Hks Fcon-is
- help?
- Should I reflash
- Camber kit
- Whats a good plug & wire set up?
- monster sport
- SD and MN tuners
- cheapest GM 3 BAR map
- Flash or not to Flash that is my Question!
- where can i get a mail in flash
- Evo 8 clutch
- Timing & O2 voltage question
- Question tuning for C16 race fuel
- Quick Question
- Tuning engine for minor bolt ons
- Go motec or not?
- what do you think about blitz spak plugs?
- i need hellppp!!!!
- EGT, AFR, and tuning...
- finally a real tuner in the bay area
- M300 or Zeitronix
- ECU Harness for Evo9!!!!?????
- idle jump
- Never AGAIN
- Best EMS for my setup, need help plz!
- MoTeC vs Autronic?
- Turbo xs charge pipe
- Boost leak or problem with BOV?
- IX intake only
- Vishnu IX Reflash Review
- parameters are altred in an ecu flash for IX?
- Stock ecu resolution
- Evo ix Engine management system
- Intake air temp sensor and methanol?
- anyone running unichip?
- feeler: full time tuner
- Apexi power FC or TurboXS UTEC
- Whats are your Greddy E-01 Settings? Please Help!!
- Help with error code 001..
- Anyone using Blitz R Fit
- Rev Limiter using engine cutoff
- Has anyone seen this?
- Whining noise
- Datalogging with palm n stein lil stuck
- "ti ti ti ti" at max boost
- if u bored.. kindly answer my question
- Vacuum/Boost vs Boost Gauge
- Misfire GONE!! CULPRIT: Magnacore WIRES!!
- DTEC piggyback
- Just bought the Evo IX, nice!
- Do I have a pump?????
- Evo 9 motor work with Evo 8 ECU?
- How do the 4 Seasons affect tuning???
- Need help with ECU pinout
- Stock Airbox
- Hks Ssqv Recirculation Kit?
- What RPM does a stock IX reach peak boost?
- Intake, Turbo-Back, and IC = Fuel Cut????
- weirdest HKS SSBOV sound
- which flash?
- 2 computers, save warranty?
- AEM EMS Opinions??
- Problem w/evo
- Turbo back exhaust question
- Can an evo tune itself ?
- Car WONT START
- gasket problem
- Fuel cut, Boost cut?
- Stock ECU can out learn a flash?
- EGR foolery
- Road Tune
- datalogging and wideband....
- What should my boost gauge say?
- 4G63, 4G18 & 4G93 parts lists?
- Milking the stock ecu for MAX power
- AFR meter...
- My first Sony,.....I mean Tune.
- Best tune for alky...non EMS
- Where can i find Evo IX ECU diagram ?
- Boost solenoid help
- Utec Vs. SAFC II
- Wiring Alcohol kit
- Question about the MAF (MAS?)
- Question: Plug gap ???? BPRES7'S
- ix ecu plug and play
- Is it a good idea to get a wideband AF if you already have a flash?
- Question for 10.5 hotside buyers. Wich bolts??
- Flash with Revolvers???
- Motec M800 for EVO IX has been released!!!
- How did u learn
- Standalone EMS vs. ECU Re-flash
- Let's talk Hydra EMS for the IX
- Has anyone seen the new Motec plug-in ECU for Evo's?
- injectors question
- Just got dyno tuned today!
- Greddy EBC always on?????
- maf translator with a flash vs. aem ems
- 06 IX MR Mod Suggestions Needed
- Intercoolers
- 2.3 stroker kit just put in but car won't start, please help!
- Evo IX ECU tuning --> what's best?
- Performance Tuning Shop?
- Immobilizer stand alone question.
- HKS EVC V Boost controller question
- Engine Seems To Stay Rev'd During Shifts???
- Chiming In
- EGR Removal
- maf delete ???
- Differences in ecu response to knock question
- AFR off on STOCK ECU?
- SmokedMustang's Misfire -- Caught on Tape!!
- Puzzled...
- Best MPG per HP/TQ
- Staged Tuning packages for evo ix
- simple ECU
- Tuning Educational Video: Base Fuel Table
- Help! Advice for flash.
- ECU question.
- Best Next MODS
- Forced Fed Experience Anyone???
- BOV flow too fast?
- Coil Explanation Needed! Can they be half-bad?
- HKS Twin-spark AND Coil-on plugs redundant?
- First impressions with new evologger
- My Works upgrade results
- Evo ix 6-speed Exhaust system
- Blow off Valve
- Log Knock with Zeitronix ???
- just a quetion
- 264/272/280 cams
- Data Loggers and Scan tools
- turbo upgrade
- evo in mississippi needs help
- Somebody Have a decent map?
- WOT hesitation/fried coil problems solved?! Must read!
- ams mail in flash??
- Choosing a good wideband
- Wideband O2 location
- Why I chose Meth. over Race Gas. Was it worth it?
- Evo IX Standalone/Piggyback
- Hydra EMS
- stock 03/04 FMIC water sprayer activation conditions?
- Evo 8 Flash
- Questions about 05 EVO
- How many psi
- Need help on tuning///
- engine shut down
- Does this sound like a "bad" O2 sensor problem? pop when STOMP!
- question about rpm converter
- P0401 and strange AFR. 03 EVO
- Anyone using unichip?
- tuners using headphones
- Map Ecu Ordered!!!!
- DynoScan Configuration
- Is there an engine management solution out that can do the following:
- big problem. need educated help please
- Vishnu Tuning Stages
- Can dealers detect a reflash?
- 03 ecu into 05 evo????
- CAT Replacing test pipe =CEL?
- CEL Problem
- Will leaning out your air/fuel .5 gain much extra hp?
- Tuning for cams
- Question about mail in tunes
- Tuning/Flash, ecutek evo IX questions
- boost controler and AEM
- Introducing the all new PLX R-300 unit, now available
- Anti-lag Setup with MSD-DIS2
- Motec M800 for IX
- BC+ EMS= only need one??
- Has anyone ever put the Unichip Guarantee to the test?
- Just tuned
- Engine Management Challenge
- Advice - Evo 6 BIG POWER
- Question about wideband readings.(Tailpipe vs. Downpipe)
- Confused about tuning solution, need help
- PLX R-500 Wideband A/F Computer, anyone using this?
- JUN computer?.
- Anyone seen this?
- Engine tuning
- Will sampling you wideband from your dp vs a tail pipe sniffer make much difference?
- flash question
- exaust for Evo IX
- Wide band sensor location
- Logging: Dell Axim?
- ssl
