- Look at these logs please...
- Airbox Evo 6
- ECU + or AEM ??
- jestr flash?
- Beginners tuning guide?
- Stock EVO 9 ecu $$$??
- any ideas for the engine dying??/
- datalog lab
- ECU reflash recommendations?
- Tuning Options
- is this a deal?
- Who offers the best custom TUNE?
- Turbotrix or XEDE
- To the 50 trim guys, what EM do you use?
- "closed loop" and test pipe
- First Logs, Evoscan stored DTC's
- help with service engin soon light
- o2 sensor
- Ecu
- Xede vs AEM vs Flash. A dilema for a "simpleton"
- reflash or stock
- Oil/Air Change Question
- Fine
- tuning: reflash Vs everything else...
- Tuning question!
- Can I use Zeitronix without O2 sensor?
- ECU harness pins
- Tuning Software
- Turbotrix visit
- 11.9 @ 118 Mph @ 22.5Psi EVO 9
- Just installed some upgrades on my IX MR
- Help - MAF Honey Comb Finished... What now?
- Access Port or Laptop..
- Zeitronix and map sensor??
- C16 on a car not tuned for it?
- beginner tips pls
- do i need a reflash?!
- noob question
- can crank shaft sensor make ur car run poorly????
- Resetting ECU
- Evo 9 ECU ????? Where i Can get one
- Noob questions, go easy on me
- help with evo 6 problem
- best data logging tool
- waste gate spring
- evoscan help....
- 2.0 Build Up Resources
- Are the oem spark plugs okay for 23-24psi?
- What is the max safe EGT(centigrade) for EVO IX MR
- What is the max/norm EGT temp(Centigrade) at WOT/23 psi for EVO IX MR
- Please discuss my Log
- Launch Control
- Several doubts about evo VI TME
- Got a new EVO IX MR w/ plans for a bigger turbo in year. What beginner mods?
- Evoscan questions.
- MAF Hz vs. HP
- Switchable maps for different octane?
- oil leak.. please help
- Resetting the HKS Super AFR
- Motec M800 Oem
- Gems ECU Not powering fuel pump
- Let me know if I got this right.
- How does the stock cat affect wideband AFR readings?
- Datalog Lab shows 294whp from a flash.
- Hmmmm Help!
- Need engine management for APS turboback/cat/intake/bov
- Anyone been pulled over with the Greddy Ti in Cali w/ no silencer?
- Does anybody know if an exhaust silencer reduces power?
- Tuning options for Evo IX?
- my power went from 390whp to 443whp w/ AEM ems
- TurboXS UTEC and afew things for sale on EBay
- VIshnu Stage 3 Just dynoed; 422 WHP
- Which ECU tune gets the most whp increase
- AEM TRU-BOOST Gauge-Type Controller??
- Problem with car starting
- Boost Controller....ALONE
- Confused about solenoids...
- Intereting Logs on IX
- anthing I need before re flash?
- Why isnt it a good idea to run a electronic boost controller
- NGK Wideband?
- Need Feedback, Please!
- muffler: before and after dyno
- question on which boost lines to use
- help: EVO 8 ECU DIAGRAM
- Reasons for pulled timing after 5k RPM's?
- dynoflash?
- Tuning near Boston
- New exhaust = Higher knock count ???
- quick tuning ? about 255 pump
- Only 9 Psi
- Re-flash, Piggyback, or Stand-alone?
- What do you think ?
- engine management for the evo IX
- help on ecu tunning please~
- help on ecu please~
- Close loop vs Open Loop condition
- AM I in Limp Mode?
- EVO IX 406fwhp 575Nm. torque
- boost issue
- pump/alky maps on flash?
- newbie here!
- Any ignition gurus out there???
- idle problem
- Typical a/f ratios and timing
- tuning with afc or flash
- remote tuning with VNC
- '05 Evo Viii Mr Ecu Pinout...
- ecu (which one)
- How to disable the boost control valve
- Management - Logging in Win XP on a carpc?
- Devo Tuning or AMS? Pros and Cons?
- O2 sensor volatge questions?
- How to tell if an injector is bad
- Newbie Wideband Questions
- Pocket Logger OBD-II
- Innovative LM-1 W/ Auxbox question...
- Used fuel injectors
- Running too rich
- Pardon my n00bness... Which flash is the best cost/gain?
- timing advanced why???
- At what point is "Lean", TOO LEAN? With meth. also.
- How many actually blew up WHILE RUNNING METH INJ?
- Can some one help me with evoscan??
- good 1st mods...
- Car problem....
- DetCan / Knock sensor audio clips?
- Bozz Speed Ecu?!
- upper i/c pipeing question
- Need Help Quik. Power Fc w/commander or EcuTek
- boost questions
- tommi makinen and 1.4 bar ?
- Fuel pump question
- Pros / Cons to Removing the Stock Air Box Lid?
- help.. tuning issues
- Stock 05/VIII / fq340 difference??
- HKS EVTC Mivec Controller
- EVOSCAN Log files??
- evo 9 ecu
- AEM or FLASH
- Evoscan and Wideband?
- emanage initial settings
- CTS question need quicky anwser
- AEM Uego 30-4100 need help
- Apexi Gizzmo Mivec Controller Anyone used one yet?
- Plug and play flash at home for the IX?
- Are your AFR's supposed to change??
- wideband O2 meters: TUNING TOOL FOR MY GARAGE?
- Relocating the Battery?
- Problems with my eevo need some help
- '03 with 3076 tuned
- Tuners & Knock
- What IX Plugs for meth
- When does race fuel go bad?
- AMS Meth. Question. about the light. simple Q!
- CEL code reading w/ Tactrix cable ?
- Cammed EVO with stock exhaust
- Plese help me
- careful w/ launch control!
- Will there be problem's?
- 100 octane = ? boost
- Experiance with ScanGauge II?
- Need so help got bad dyno numbers
- Some detailed pics on 02 simulator install?
- Tuning Expectations?
- HELP! Trouble codes
- Which Rpm is best for the 2-step on the stock turbo?
- HELP PLS Knock threshold setup and phantom knock question
- evoscan with aem wideband? help
- Injector scaling: If ECU scaled 780cc, can I use 750cc?
- question for the powered gt35 evo
- LMA-3 / Auxbox - RPM Connection
- dyno graph for baseline and just tune on an 05 evo
- Are custom tunes always better than any mail-in flashes???
- hks f-con
- apexi power fc for the evo ix
- Help this HAWAIIAN reach 400ehp on pump gas
- whats the best wideband to go with?
- ecu flash dyno tune results
- Need tune with bolt-ons?
- Flash? SAFC? I can’t decide. Yes I’ve searched, this is a intelligent question.
- Anybody experienced with Exede and ECUFlash?
- O2 sensor feedback
- Running on MS 109 race gas, didnt feel power gain over 91...
- RPM Signal??
- Free ecu flash! No one talking about it yet?
- Terrible tunes by well-known tuners???
- Initial Mod Review
- XEDE, EcuFlash, AEM...etc???
- Issue following tune
- evo timing question
- avcr setting help
- Achieving a stable and strong idle with cams
- Running rich
- "flood clear" wideband calibration?
- MAF voltage peak-peak
- custom tune in connecticutt
- Tuning
- 14 Psi still causing knock!!!!!
- Installed hallman MBC
- Engine Management options for the EVO 9?
- What Spark Plugs?
- Evo MR 2005 Dyno numbers
- plan on buying an ecu but need your help
- Evo timing...
- optimum battery voltage at idle
- at what point are bigger injectors needed?
- Help with bad idle.
- can anybody help with dsmlink
- Need to Tune!! My Options....
- Difference??? ECUFLASH & ECUTECK
- Looking for a custom tune in the Birmingham area...
- Evo IX reflash w/stock exhaust
- EVO V Ralliart ECU, programable by user?
- I was told not to relfash...
- Need a tuner, NY/NJ/CT
- Which reflash
- Which EMS?
- At what point is tuning necessary or at least recommended.......
- what to use???
- Electronic Gizmo Stupid; Please help
- Boost fluctuating
- Hydra Vs. EMS Physical Comparo
- Coil-on-plug
- Stay with AVC-R or go with Blitz SBC-I color??
- oil low and only miles????
- I am in the bay area should that effect purchase
- Best Engine Management for Turbo Upgrade
- A/F Numbers with Al's Mail in Flash
- ATI Fluid Super Dampner
- Should i go ECU flash or SAFC controller?
- Too high AFR after tune?
- MPG and diffrent octane......
- Basic Necessary Gauges
- At my wits end.. help solve my stalling!
- Aem Ems
- Pocketlogger Help
- Suggestions about future mods, with tech question.
- IX specific thread
- TPS Volts Needed
- Best EM? What are people using
- ecu flash
- Mbc
- To Flash or not to Flash.......kinda confused on the whole thing????
- Aem or Flash for me?
- AVC-R? settings for EVOVIII MR
- palmnstein o2v(2) logging
- attn: pocketlogger users
- wat did i blown in the motor car wont go start shaking after 2000rpm
- What is the easiest way to read engine timing
